Official OPPO UDP-203 Owner's Thread - Page 1236 - AVS Forum | Home Theater Discussions And Reviews
 279180Likes
post #37051 of 37256 Old 09-17-2019, 03:33 PM
Quoted: 22 Post(s)
Originally Posted by Bob Pariseau View Post
Check to be sure you have HDMI CEC (remote control over the HDMI cable) disabled in the OPPO. The shutoff command may be coming from some other portion of your system -- for example the TV, which might react that way after receiving 15 minutes of black video.
If you are using a programmable Remote, check to see if the shutoff is related to doing some other sort of operation with the Remote. There may be an error in your setup of that Remote such that it thinks you no longer need the OPPO powered when you do that other operation.
Thanks Bob. HDMI CEC if OFF on the 203. When it happens, I'm not using the remote.
Kewler is online now
post #37052 of 37256 Old 09-17-2019, 03:49 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 645 Post(s)
Liked: 401
Originally Posted by wmcclain View Post
Is this via DLNA? The server may be confused and needs a reboot or a rebuild of its database.
-Bill
I am pretty sure it is. I have rebooted the NAS in an attempt to fix this. I just assumed the issue was with the OPPO, but I will do some research to see if is a QNAP issue.
Thanks Bill.
Mark
Sent from my iPhone using Tapatalk Pro
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #37053 of 37256 Old 09-18-2019, 08:29 AM
Quoted: 22 Post(s)
Originally Posted by Kewler View Post
This happened twice in the last few days: while the 203 is playing back FLAC files from an ExFAT hard drive, with Pure Audio engaged (to prevent burn in on my OLED TV), the 203 simply shuts off at some point.
I have sorta of a doubt about Oppo's MediaControl app on my iPhone. Reliability is average when in use: maybe it's sending data when not in use?
post #37054 of 37256 Old 09-18-2019, 03:47 PM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
Originally Posted by manutd123 View Post
So as mentioned yesterday, I was initially getting a message telling me I should connect the Oppo to a 4K tv with HDR. See Pic 1. It was then playing the disc in 1080p.
I have tinkered with the settings tonight in Video Setup and it is now playing in 4k.
Please see pics 2 and 3.
I noticed on Pic 4 that it says HDR format as SDR, so I went back into Video SetUp and changed the HDR Setting from Auto > Forced.
This started playing the movie in HDR10 but the colour was all wrong. See Pic 5.
So I changed it back to Auto and it is back to HDR Format : SDR and Pic 6 shows better colour.
Is there a way to watch in HDR or HDR10 without the dodgy colour output?
Pic 7 show the current Video Setup.
I'm late to the party, and this is just another user that has a very similar issue, not a solution, sorry, but I use a similar workaround. I don't have 4K discs come out in 1080p, but because my display also apparently indicates that it can't do HDR when playing a disc in the Oppo (and it can, as it's an LG EF559500), I also use forced HDR, and when I do, I get the exact same red-saturated pictures when the 4K disc is DolbyVision rather than HDR-10. The display I have is NOT DV capable. What I do for those DV discs is change the color space to 2020 SDR, and then I get reasonable colors, but still in 4K.
I've tried many times to find out why the Oppo thinks the LG is not HDR capable (my Roku Ultra thinks the same thing, but for my ATV 4K, I just force HDR, and it works), but I've never figured out the reason. The Denon 8500 should be able to pass the 4K HDR indicator from the TV to the source device, the LG TV is set to receive the HDR signals, and I'm using all premium certified HDMI cables, and yet, for some reason, my LG is apparently advertising itself as NOT 4K HDR capable. Your display may be doing the same. I've actually considered getting an HDFury Vertex to solve the issue. I just haven't been annoyed enough to pay an additional $300 to solve the problem. I was hoping the Oppo HDR force function could make this work OK, as it is supposed to change DV to HDR-10 in "forced" mode, but it doesn't do that correctly if it detects the display as non-HDR.
Dave Barnhart
Oppo UDP-203, Oppo BDP-83, Denon X4200W, Denon X8500H, LG 55EF9500, NVidia Shield TV, Apple TV 4K, Roku Ultra, RSL speakers, all Monoprice Premium Certified HDMI cables
dcbii is offline
post #37055 of 37256 Old 09-18-2019, 03:57 PM
Quoted: 112 Post(s)
Some TV has only few full 2.0 HDMI specs. My TV has only two of four HDMI rated 2.0, for instance. If you are not using a full bandwidth one it will be limited. May be your case? Did you try changing TV input?
Enviado de meu SM-G975U1 usando o Tapatalk
Sent while surfing
Cricket-RJ is offline
post #37056 of 37256 Old 09-18-2019, 05:40 PM
claw's Avatar
Quoted: 2324 Post(s)
Liked: 2175
Will have to do this when I get back home a little later.....
You can't send HDR10 to a TV that does not support HDR10 and expect to get proper color. Not possible unless you can create a custom PQ gamma curve in your TV.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is online now
post #37057 of 37256 Old 09-19-2019, 03:29 AM
Liked: 1
There's so many pages in this thread, that it's hard to find any fixes or if it's just a common issue for the 203, but I have a mix of .m2ts and .mkv files full of demo trailers that have a range of SDR, HDR10, Vision, Atmos, TrueHD, DTS-X, DTS-HD MA. I have video out to the LG OLED TV and audio out to my Integra pre-amp.
In terms of audio, sometimes watching the files has no issues and I can watch a whole heap in a row. Everything is detected by the pre-amp as the correct audio, but suddenly the ATMOS files will have no sound altogether, and then after that, all the files will have no audio. I can see the pre-amp display not changing, which I guess it's not handshaking the sound through the HDMI as I test each video out. Have tried different cables. Sometimes watching a basic stereo file will help, then other times I can't get any sound out of anything unless I power cycle the 203 player.
The files with Dolby Vision only come up as HDR10 through the TV with HDR settings set to Auto. If I set it to forced Dolby Vision on the 203, suddenly the normally blue Oppo menu hue changes to green, and then watching any video files, even SDR or Dolby Vision files, the picture will be highly saturated and the colour hue is not right. Again, power cycling will help, but then it just happens again after a few videos. So I cannot leave the 203 player set to forced Vision without these picture issues, but then set to Auto doesn't detect the Dolby Vision. Vision has no issue being detected on official UHD discs.
It only seems to happen though to files on a USB 3.0 external/thumb drives. Are all these issues built in on purpose by Oppo? Or more of a HDMI/MKV issue.
corzamoon is offline
post #37058 of 37256 Old 09-19-2019, 04:18 AM
wl1
wl1's Avatar
Quoted: 441 Post(s)
Liked: 397
Welcome to the longstanding "bug" which was even present with the 103 - so no hope for a fix. There are a few options for workarounds...
Issue:
The concern is when switching between Dolby THD and DTS HD MA soundtracks.
Option 1 - reboot between playing different ones (not very convenient)
Option 2 - organise your files so they are in Folders, of Dolby and DTS tracks, and minimise your issue to "once per" demo when changing Folders.
Option 3 - Switch to a DD track, and back again to the DD THD or DTS will "fix" the lack of sound. This works well with movies - ALWAYS Rip with an extra Dolby Digital track to allow this option easily.
Oppo provide great media playback - but the manual makes it clear it is on a "best intentions" basis. Now you know how to get round it, its not that bad - except for "short demo" clips. Its perfectly acceptable for movies IMO.
giomania and galonzo like this.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #37059 of 37256 Old 09-19-2019, 06:56 AM
claw's Avatar
Liked: 2175
I believe that MKV does not support Dolby Vision. So if you force DV in the Oppo it is converting HDR10 to Dolby Vision. Also, set the Oppo to "TV Led" Dolby Vision.
galonzo likes this.
CJ
claw is online now
post #37060 of 37256 Old 09-19-2019, 12:22 PM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
I appreciate the suggestion, but yes, I've tried different TV inputs, different receiver inputs, different receivers (4200 and 8500), not using the receiver at all and going directly to the device, different HDMI cables, different HDR modes on the Oppo, different source devices. At this point, I've pretty much exhausted the possibilities, and although the Oppo's HDR "force" function doesn't work for me on DV discs, given the results, I have to assume that it's my display that has the issue, even though others with the same display don't have the problem.
I really wish the 203 could completely work around the problem (as I was hoping the Oppo DV HDR force would), but at least it has ways of ameliorating it. I'm probably just going to have to spring for a new display at some point. Although with none supporting 3D any longer, I really don't want to give up that feature...even to get working DolbyVision.
Right now, I'm just happy that 2020 SDR seems to work reasonably well on the 203. Even if the colors aren't perfect, they look pretty good to me.
Cricket-RJ likes this.
Dave Barnhart
dcbii is offline
post #37061 of 37256 Old 09-19-2019, 12:51 PM
perzon57's Avatar
Quoted: 17 Post(s)
BUMP. Anyone?
Problem with my 203.Turned on Pure Audio by mistake,when I turned it off the player light came on but no video on my PJ.When I route my 105 D through the HDMI input there are video.Tried the same with a TV,and same thing happens.No video when I turn off Pure Audio.Any thoughts?
Regards.
perzon57 is online now
post #37062 of 37256 Old 09-19-2019, 01:08 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4648 Post(s)
Liked: 4496
Originally Posted by perzon57 View Post
BUMP. Anyone?
Regards.
What happens if you cycle through the Resolution options with the remote? The front panel should show the selections.
Press and hold the Resolution button and Output Resolution, HDR, Color Space, Color Depth will be reset to factory defaults. Does that do anything for you?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #37063 of 37256 Old 09-19-2019, 02:00 PM
perzon57's Avatar
Quoted: 17 Post(s)
-Bill
Been in contact with Oppo and tried all this after their suggestion,nothing helps.
post #37064 of 37256 Old 09-19-2019, 04:52 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5835 Post(s)
Liked: 8320
When you get no image on the projector, what does the Info status on the projector say it is receiving (if anything) for video from the OPPO?
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #37065 of 37256 Old 09-19-2019, 05:40 PM
ppasteur's Avatar
Quoted: 197 Post(s)
Liked: 111
Issue:
FWIW, I can restart my Denon X6400H and it fixes this problem. When I reboot the AVR, it always comes up on a different input, so I switch it to the input for the 203, and everything works on the audio side.
I have been aware of the Oppo "bug" for sometime and the above is what I have done. For some reason at one point I clicked the wrong button and turned off the AVR. I think this is marginally quicker. No need to eject a disk or browse back to the right place on a network share to resume play. Not sure why it works, but it has worked consistently for me since I discovered it. It may be resetting the HDMI handshake has something to do with it... Anyway I would be interested to hear if the same method works for others. Also would like to hear what people have to say about why it would work.
ppasteur is offline
post #37066 of 37256 Old 09-19-2019, 08:43 PM
Quoted: 112 Post(s)
Sorry if this sounds obvious, but, did you enable UHD color mode on your TV? Did you try messing around with Oppo color space and color depth setings?
By the way, I really miss watching 3D movies at home.
Sent while surfing
post #37067 of 37256 Old 09-19-2019, 09:34 PM
kokishin's Avatar
Quoted: 1306 Post(s)
Liked: 1321
WTF: Oppo 203 Media Control Android App?
I have the Oppo 203 Media Control Android app (version 1.2.0.3789) on my retired Samsung S7. I recently got an S9+ and I wanted to install the 203 Media app. It's not in the google play store anymore.
Can someone clue me in on where to find the Oppo 203 Media Control Android app (version 1.2.0)?
BTW, WTF in the Subject means "Where To Find".
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon FTV Stick 4K, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is online now
post #37068 of 37256 Old 09-19-2019, 11:56 PM
Sofdec7's Avatar
Quoted: 12 Post(s)
Running into an issue with the 203 tonight.
Player is connected directly to the tv (LG OLED C6P) with the included cable. Watched a DV title the other night with no problems. Put one in tonight and the screen goes black as soon as the DV title displays on the TV.
Tried multiple cables and inputs. Tv and opportunity are both on the latest input. Reset the player to factory settings and DV worked.. but it was 1080p. See output to 4k and it broke again.
Reset tv to default and no change.
4K HDR10 is fine but Dolby vision is doing this every time. Hard reset tv and player multiple times with no luck. Any ideas?
Sofdec7 is offline
post #37069 of 37256 Old 09-20-2019, 12:45 AM
perzon57's Avatar
Quoted: 17 Post(s)
--Bob
Thank for the tip,I will try tonight and see what it shows.
Regards
post #37070 of 37256 Old 09-20-2019, 06:03 AM
Patsfan123's Avatar
Quoted: 501 Post(s)
Liked: 325
What was the movie? Sometimes cables do go bad.. however unlikely it seems.
Assuming you are on latest firmware for the player and the TV?
LG 65C6P FW: 05.30.70 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #37071 of 37256 Old 09-20-2019, 06:21 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
Yes, I've enabled UHD mode on the inputs. I've tried disabling and re-enabling to see if it made a difference. No joy. It's a bit of a pain on the LG to do that, since the TV reboots when you change the UHD color mode on one of the inputs.
In any case, yes, both my wife and I enjoy 3D a lot, which the 203 makes very easy, so I'm not planning to upgrade my display for a while. It's a bummer that Oppo is getting out of the business, because I think they could have fixed the HDR force mode so that DV colors work right even on my display. It would be easy to say get another player, and one day I might have to, but having one as good as the 203 that I also made region-free for a lot of my content makes it worth putting up with the firmware glitches that will no longer get fixed. And of course, since it's my display with the issue, it's not really their problem, and another player might not handle it well either. They have worked with me in the past though to fix bugs with content, so they might have been able to help with this one too if they had stayed in business. Oh well, that's this hobby.
Thanks for taking the time to try to help.
Dave Barnhart
dcbii is offline
post #37072 of 37256 Old 09-20-2019, 09:38 AM
Crazytrekker's Avatar
Quoted: 115 Post(s)
Liked: 58
Originally Posted by steverobertsbbc View Post
Just to pick up on this point, if running an ethernet cable between the router and player is difficult, have you considered using a pair of powerline ethernet adaptors to make the connection over your mains wiring? This is how I connect my router upstairs to my AV gear downstairs and it works very well.
Great minds! I discovered powerline (accidentally) a few days ago and have wired everything up. It works almost flawlessly!
I just have one remaining niggle. For some reason there is still an occasional mismatch between the audio playing and the display info. Last night on the Oppo an album fell out of step by 5 seconds. Just now my receiver fell out of step by 2 minutes, i.e. the display/track/time was 2 minutes behind the audio.
Is this a FLAC problem, i.e. caused by the time/effort needed to decode the file? It's clearly not player specific. Just wondering. Do any of you clever chaps know?
Crazytrekker is offline
post #37073 of 37256 Old 09-20-2019, 09:42 AM
Sofdec7's Avatar
Quoted: 12 Post(s)
Tried Venom when I first noticed it. The 2nd one was IT which worked fine 2-3 days ago
Tried 3 different cables and 3 different inputs. Tried multiple configs on the 203 with restarting the player in energy efficient mode each time to make sure it changed
Converting to hdr10 worked fine.. but I'd prefer Dolby vision
Sofdec7 is offline
post #37074 of 37256 Old 09-20-2019, 11:57 AM
perzon57's Avatar
Quoted: 17 Post(s)
--Bob
The info on the PJ shows:Input signal RGB-Video,Resolution 1920 x 1080,Scan Mode Interlace,Refresh Rate 49,95 Hz.
Regards
post #37075 of 37256 Old 09-20-2019, 01:05 PM
Read the FAQ!
Liked: 8320
Regards
That looks OK, given that you are in Europe and use 50Hz video. So the video output in the player is actually functioning.
It looks to me like the player's Copy Protection check isn't happy with what it is getting back from the projector, so it is muting the video output to black.
I suggest you turn off BOTH the projector and the player. Then unplug both of them from wall power. Then, while still unplugged, press and hold the front panel Power button on the player for a few seconds (to discharge any residual power). This combo forces a complete reboot of the player (and hopefully also of the projector).
Then plug both back in. Now turn on JUST the projector. Wait until it is fully booted up. Then turn on the player and see if you get video. If NOT, press the Resolution button on the OPPO remote to cycle through the choices of Custom, Auto, and Source Direct (as shown in the player's front panel display) to see if any of those give you video. Wait about 10 seconds on each of those choices, as it may take the player and projector a bit of time to implement the change.
--Bob
galonzo likes this.
post #37076 of 37256 Old 09-20-2019, 02:18 PM
perzon57's Avatar
Quoted: 17 Post(s)
--Bob
Tried this,no video whatever I try.
post #37077 of 37256 Old 09-20-2019, 03:51 PM
Read the FAQ!
Liked: 8320
^ I want to confirm: You DO get video to the projector if you select to play video coming into the OPPO on its HDMI Input, correct?
If true, I think this may be beyond your ability to fix.
Do you have another TV you can try to see if this problem is specific to your projector?
The player may need service, so at this point I’m mainly trying to collect information.
—Bob
post #37078 of 37256 Old 09-21-2019, 01:32 AM
perzon57's Avatar
Quoted: 17 Post(s)
—Bob
It all started when the 203 would'nt let me play a 3D movie,saying my PJ was'nt compatible with the format,which it is.
I then would try my 105D through the HDMI Input,but I hit the Pure Audio by mistake.When I turned off Pure Audio the video did'nt come back,and have'nt since.The 105D plays fine trough the HDMI In Bypass input on the 203 so I got to see the movie in 3D.
I have a little TV I use for menus from my 105D.Connected the 203 to that and got video.Hit the Pure Audio button and video went black and when I turned it off video did not come back on the TV either.I'm on the latest EU firmware.Cables and PJ is the same I've used with the 203 all the time.
I've contacted the place where I bought it and they was to contact their supplier for further instructions.I have not much
hope for getting the player serviced in Norway.
Regards
post #37079 of 37256 Old 09-21-2019, 04:09 PM
Sofdec7's Avatar
Quoted: 12 Post(s)
I think there might be a glitch in the Oppo UDP-203 and Dolby Vision titles.. is someone able to test/confirm this?
Player: UDP-203 - Most recent firmware
TV: LG OLED C6P - Most recent firmware
Create a new picture setting on the Oppo (I believe under Setup - Video - Picture Adjustment) as:
Contrast +3
Saturation +2
Sharpness +2
You'll need to fully shut down the player (make sure Energy Efficient is turned on, so it fully shuts down) and then start it up again.
Play a DolbyVision title after that.. Does the DolbyVision display normally? Or do you get a black video signal?
I've confirmed on my own player that setting these back to 0 on every setting does fix the issue.. And DolbyVision is supposed to ignore these picture settings entirely (only applying them to HDR10) but it seems to create an error with the picture. Once I set them back to 0 and re-start the player, it works fine.
BillyJoeFish likes this.
Sofdec7 is offline
post #37080 of 37256 Old 09-22-2019, 05:29 AM
Ganymed4's Avatar
Quoted: 301 Post(s)
Liked: 154
Regards
I would recommend making a factory reset on the Oppo and try different power on sequences. First player, then PJ and vice versa. I sent my Oppo player to Oppo directly, when the drive was broken. That was no problem and took nearly the same time as in Country service.
However, I don't know if after cease of their business Oppo still offers this service.
Good luck and greetings to Norway.
perzon57 likes this.
Ganymed4 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
