Official OPPO UDP-203 Owner's Thread - Page 1240 - AVS Forum | Home Theater Discussions And Reviews
 279444Likes
post #37171 of 37615 Old 10-05-2019, 10:36 AM
Quoted: 196 Post(s)
Liked: 299
Originally Posted by michel34 View Post
Thx I will do that.
There's some discussion here https://forums.stevehoffman.tv/threa...phasis.777476/ about previous Oppo models, with users opining that the Oppo de-emphasised any emphasised material before passing it out via SPDIF.
RichB and LRS3 like this.
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is offline
post #37172 of 37615 Old 10-05-2019, 01:55 PM
cbolton's Avatar
Quoted: 87 Post(s)
Liked: 31
Unhappy HDMI Audio Issues
Hello,
Earlier this year I posted an issue where HDMI connection for video and audio direct to my Yamaha 3070 AVR stopped working suddenly. I could get audio working when I did video to my lg oled directly and audio to my AVR. I used that for a week or two then went back to the single hdmi cable for both and it started working as before without changing any settings. The issue is back and now splitting the audio and video out via different cables isn’t working either.
I reset the Oppo to factory defaults, upgraded AVR firmware and I can’t find the issue. I will attach screen shots of my avr and Oppo displays when I get home to see if that helps anyone identify my issue. This was working fine two weeks ago!
Any suggestions greatly appreciated!
cbolton is offline
post #37173 of 37615 Old 10-05-2019, 02:32 PM
rdgrimes's Avatar
Quoted: 3921 Post(s)
Liked: 3195
Originally Posted by cbolton View Post
Hello,
Best guess is that you're dealing with HDCP handshake failures. The only way to clear one of those is a cold boot of all connected devices. That means no "network standby" settings or the like, and worse case is to pull the plug. Forcing a new handshake doesn't work. Oppo has to be set to "Energy Efficient" standby and Yamaha must have pass-through and network standby disabled.
As to what's causing this handshake to fail, a dodgy cable is the place to start. But "no audio" is usually a failed handshake at the AVR, although anything is possible with HDCP.
galonzo likes this.
rdgrimes is offline
post #37174 of 37615 Old 10-05-2019, 06:05 PM
groberg's Avatar
Angry b
Originally Posted by Sofdec7 View Post
(If this message was regarding the DolbyVision issue)
The most recent firmware for the Oppo UDP-203 (and 205?) as of now: UDP20X-65-0131
There's a glitch that will only display a solid black screen when playing back Dolby Vision content if you have any modified Picture Adjustments on the oppo (ie: Sharpness, Saturation, Contrast, Brightness, etc...)
This glitch was not present in any previous versions of the firmware, only the 65-0131 version. HDR10 content is unaffected.
The fix is to go into the Picture Adjustments setting (under Setup -> Video -> Picture Adjustments) and set these to default (0,0,0,0,0,0).
Since the player allows 3 different custom picture settings, make your preferred adjustments to one and leave one of them at default. You'll need to set the player to this default (0,0,0,0,0,0) before launching the DolbyVision title. If watching HDR10/SDR content, you can use your customer picture adjustments.
This may be isolated to the LG OLED panels.. but it sounds like it corrupts the video output of DolbyVision so there's a good chance it affects all TV models. There is currently no firmware fix for this problem.
My OPPO Is set to all 0’s. Spider-Man Far from a Home is all red, not black on my LG
Same April firmware version
groberg is offline
post #37175 of 37615 Old 10-05-2019, 08:36 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5839 Post(s)
Liked: 8335
^ Set the Dolby Vision output to TV Led instead of Auto.
—Bob
galonzo and stanhere like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #37176 of 37615 Old 10-05-2019, 08:42 PM
cbolton's Avatar
Quoted: 87 Post(s)
Liked: 31
I tried a different cable no luck. I also unplugged the cables from both the AVR and Oppo for about a minute and then retried - still the same. I think it has to be a handshake issue as nothing has changed in the settings from when it was working a couple weeks ago. Attached are the Pictures of the AVR and Oppo. The AVR shows zero audio when checking out the input info - shows 4K for video and the audio page is completely blank. Any other suggestions on things to try?
ID:	2624164   Click image for larger version
cbolton is offline
post #37177 of 37615 Old 10-05-2019, 09:33 PM
nc88keyz's Avatar
Quoted: 429 Post(s)
Liked: 267
Thank you , I wasn't aware of this bug and it certainly explains the behavior between the 203 and M9702 as one is on an earlier firmware I believe and I didnt notice the DV bug before. So as long as the Oppo video processing is on a flat preset, it will playback. The issue I was having was black screen, with the lossless audio track playing through the amp. ie. atmos, dtsx etc. Now it makes sense. I have an LG G6 oled, I am not sure if the behavior is present on player led but I will check at some point as I have a z9d as well available to test with. I want to say forcing resolution was a work around but I don't remember right off. Have to look at the settings again.
nc88keyz is offline
post #37178 of 37615 Old 10-06-2019, 08:26 AM
claw's Avatar
Quoted: 2446 Post(s)
Liked: 2298
I don't believe the LG 6 series can support Player Led. Newer models do. Oppo should be set to TV Led since the Auto setting has issues introduced in the most recent firmware update.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #37179 of 37615 Old 10-06-2019, 09:27 AM
brownriggd's Avatar
Was watching the UHD disc 'Green Book' and experienced numerous video dropouts. Disc was clean, no scratches, dirt. Both the TV (LG OLED65E6P) and player (OPPO UHD203) are up to date with FW updates. Player and TV are connected via a high speed HDMI cable. Also shut down the system and turned it back on to no avail...
brownriggd is offline
post #37180 of 37615 Old 10-06-2019, 09:32 AM
Crazytrekker's Avatar
Quoted: 118 Post(s)
Liked: 58
I've started noticing weird lip sync problems when playing blu-rays, especially 4K discs with Dolby Vision and HDR10.
My set up was initially:
1. HDMI video direct to LG OLED C7 (HDMI1 input)
2. HDMI audio to Denon 4200 receiver
3. Denon 4200 receiver to LG OLED C7 (HDMI2 input with ARC)
4. Technicolor Expert mode on TV
5. All TV processing off except for Real Cinema which is forced on by the TV for 24p material.
After researching I got the impression ghat Real Cinema was the culprit because it quadruples processing time so the picture falls behind. But, as I said, you can't disable it for certain inputs.
So I tried sending both audio and video to the receiver via a single HDMI cable. This has the benefit of having the TV (apparently) send delay information back to the receiver via the HDMI2 ARC connection.
That seemed to fix the lip sync while watching movies, but when watching special features the lip sync issue returns - most recently tested with Shout Factory's John Carpenter's Vampires and Lionsgate's Apocalypse Now Final Cut (the intro of which is Dolby Vision).
The only thing that seems to work is scrapping the TV's cinema modes altogether and using Game mode (replicating the settings from Technicolor Expert mode as much as possible).
Oppo/Denon/LG is quite a common combination but my issues "appear" to be unique. Can anyone shed any light? Is there something I can tweak at the Oppo end? (Most of my Oppo setting are "auto").
Sent from my SM-G975F using Tapatalk
Crazytrekker is offline
post #37181 of 37615 Old 10-06-2019, 09:52 AM
rdgrimes's Avatar
Liked: 3195
Whether it looks clean or not, cleaning it is the first step. Make sure the Oppo is set to "Energy Efficient" standby, or rebooting it won't do much.
If cleaning doesn't fix the disc, you need to replace it. If this happens on other discs then there are other issues at play.
galonzo likes this.
rdgrimes is offline
post #37182 of 37615 Old 10-06-2019, 09:57 AM
nc88keyz's Avatar
Quoted: 429 Post(s)
Liked: 267
As mentioned: I use tv led for a g6 oled and would use player led for a z9d. Sorry if that wasn't more clear.
nc88keyz is offline
post #37183 of 37615 Old 10-06-2019, 10:01 AM
brownriggd's Avatar
Thanks, will try those suggestions.
post #37184 of 37615 Old 10-06-2019, 10:59 AM
brownriggd's Avatar
Unhappy
Unfortunately it looks like an issue with the player. Tried another recent HDR release, Captain Marvel, and same thing is happening. I have a service call into Oppo. Thanks for the assistance.
post #37185 of 37615 Old 10-06-2019, 11:45 AM
Ccondo1's Avatar
Quoted: 181 Post(s)
For reasons I can’t explain, my Oppo is now down sampling all my UHD Blu-ray’s to 1080p. Menus are 4K as are streaming files. What gives? Anybody have any ideas what would cause this?
My chain is Oppo 203 to Anthem AVM60 to HD Fury to Epson LS10000
Ccondo1 is offline
post #37186 of 37615 Old 10-06-2019, 12:28 PM
rdgrimes's Avatar
Liked: 3195
Next task is to rule out an HDMI cable issue, which can cause dropouts.
galonzo likes this.
rdgrimes is offline
post #37187 of 37615 Old 10-06-2019, 12:30 PM
rdgrimes's Avatar
Liked: 3195
That's a complex HDMI chain. But I'd start by pulling the AC plug on the Oppo and restart.
rdgrimes is offline
post #37188 of 37615 Old 10-06-2019, 01:02 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4690 Post(s)
Liked: 4563
My chain is Oppo 203 to Anthem AVM60 to to Epson LS10000
And what are your video settings?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #37189 of 37615 Old 10-06-2019, 01:10 PM
LRS3's Avatar
Quoted: 104 Post(s)
Liked: 90
I'd be curious as to whether the Oppos properly de-emphasize pre-emphasized CDs over HDMI. I've been buying CDs since they came out in the US in 1983, so I know a number of my earliest CD purchases were pre-emphasized. My first CD player (Sony ES701), which I bought in October 1983, had an indicator on the front panel that lit up when the player was de-emphasizing those early CDs. It would be great if it could be determined that the Oppos (I have both a 203 and 205) properly de-emphasized these CDs before sending the data out over HDMI. If not, I have to wonder if the DACs in my Denon 8500 receiver are properly doing the work in that department.
LRS3 is offline
post #37190 of 37615 Old 10-06-2019, 01:45 PM
Ccondo1's Avatar
Quoted: 181 Post(s)
Never mind, I found the problem... the EDID switch on the HD Fury got bumped to the wrong setting.
Ccondo1 is offline
post #37191 of 37615 Old 10-07-2019, 03:16 AM
glangford's Avatar
Quoted: 743 Post(s)
Liked: 657
Interesting discussion. I doubt the Oppo does that, but I'd like to know. A quick email to customer support and they'll respond in a day more than likely.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #37192 of 37615 Old 10-07-2019, 06:56 AM
michel34's Avatar
Interesting. If it really did deemphasize the signal would go from wav > d/a converter > analog filtering stage (correct deemphasing according to red book) > a/d converter > spdif.
Will see what oppo support says.
michel34 is offline
post #37193 of 37615 Old 10-07-2019, 07:22 AM
LRS3's Avatar
Quoted: 104 Post(s)
Liked: 90
I've sent an email to Oppo asking about it. Will report back to this thread once I hear back from them.
LRS3 is offline
post #37194 of 37615 Old 10-07-2019, 08:31 AM
slots1's Avatar
Quoted: 73 Post(s)
Liked: 25
Can the 203 be changed to read region b blu ray discs
slots1 is offline
post #37195 of 37615 Old 10-07-2019, 08:39 AM
wmcclain's Avatar
Liked: 4563
Only with a hardware attachment. See the FAQ: Region Free Modifications.
-Bill
galonzo likes this.
post #37196 of 37615 Old 10-07-2019, 10:44 AM
brownriggd's Avatar
Oppo recommended a factory reset and that solved the problem. Thanks again
evoll88 likes this.
post #37197 of 37615 Old 10-07-2019, 03:33 PM
LRS3's Avatar
Quoted: 104 Post(s)
Liked: 90
So, I asked Oppo support about this today, with regard to the 203 and 205 models. In particular, I asked about applying de-emphasis to the digital data sent over HDMI. What I received from Oppo support was:
"The player does support Pre-Emphasis, but the player requires that the Pre-Emphasis flag be in the [CD's] Table of Contents as originally designed in the Redbook CD standards. If it is on the ToC, it should be applied to all [digital and analog] outputs."
I asked a follow-up question about whether the player then strips the pre-emphasis flag from its digital outputs so that a connected receiver/processor DACs don't see it and inadvertently perform a "double de-emphasis." What I got back from Oppo (very quick response by the way) was:
"That is our assumption. Unfortunately we no longer have the resources to confirm the information."
The latter sentence was a bit disconcerting, but I suspect the assumption was correct. I would think any competent circuit designer would realize the potential issue of sending the pre-emphasis flag over a digital connection where the proper de-emphasis had already been applied.
wmcclain: you may want to consider adding this to the FAQ. But, hey, that's your baby!
michel34, glangford, vavan and 1 others like this.
LRS3 is offline
post #37198 of 37615 Old 10-07-2019, 04:46 PM
wmcclain's Avatar
Liked: 4563
Ok, done: Does the OPPO support pre-emphasis on audio CD?
But: how can it be frequently asked if I've never heard of it?
-Bill
post #37199 of 37615 Old 10-07-2019, 05:15 PM
Clark Burk's Avatar
Quoted: 726 Post(s)
Liked: 664
I agree. That worries me too. It sounds like OPPO may no longer have a connection with Mediatek. Sounds like we’re on our own now.
Clark
Clark Burk is online now
post #37200 of 37615 Old 10-07-2019, 08:20 PM
rdgrimes's Avatar
Liked: 3195
-Bill
People been talking behind your back again.
giomania and Neil S. Bulk like this.
rdgrimes is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
