Official OPPO UDP-203 Owner's Thread - Page 1241 - AVS Forum | Home Theater Discussions And Reviews
 279351Likes
post #37201 of 37529 Unread 10-08-2019, 11:52 AM
jbug's Avatar
Quoted: 281 Post(s)
Liked: 136
I had my 203 locked into Dolby Vision for blu rays but while trying to find out why I lost audio and video I changed something. What are the steps to get it back. I stayed up late fiddling but never could find the right steps. I was getting the DV pop-up previously but not now even though I have HDR set to DV in the menu.
jbug is offline
post #37202 of 37529 Unread 10-08-2019, 12:01 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4673 Post(s)
Liked: 4548
I forget if Source Direct has any effect on DV conversion. Are you using Output Resolution = Custom and Custom Resolution = UHD Auto?
Verify that HDR Setting -> HDR = Dolby Vision.
Set Standby Mode to Energy Efficient and power off and on again. If still no good, I'd Reset Factory Default and try the above again.
Note on forcing DV: "This works for standard Blu-ray and UHD discs with and without HDR. It does not work for interlaced sources like DVD or for media files like MKV. In my testing it did not work for 3D Blu-ray."
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #37203 of 37529 Unread 10-08-2019, 12:45 PM
jbug's Avatar
Quoted: 281 Post(s)
Liked: 136
-Bill
Thanks McClain. I tried all the settings for resolution but did not see the DV logo pop up this time around, not even for 4k disc that include DV. I'll check the other settings that you mentioned also. As for 3D, I'm pretty sure that i was able to have it applied to 3D but again, I'll go over the settings.
jbug is offline
post #37204 of 37529 Unread 10-08-2019, 12:51 PM
wmcclain's Avatar
Liked: 4548
The logo popups sometimes get lost in a long handshake when the video formats change. Does your display have anyway to indicate what it is receiving? And what does the OPPO Extended Info say for what it is sending over HDMI Output?
-Bill
galonzo likes this.
post #37205 of 37529 Unread 10-08-2019, 12:55 PM
jbug's Avatar
Quoted: 281 Post(s)
Liked: 136
-Bill
203 says SDR when I played the 3D version of Aladdin last night.
Edit: You are right, it works on BD but not 3D. I'm getting the DV pop up now. 3D is fine without it though on my E6. Thanks again.
jbug is offline
post #37206 of 37529 Unread 10-08-2019, 01:16 PM
wmcclain's Avatar
Liked: 4548
Try a standard Blu-ray and give us the details under Media Info and HDMI Output. Tell us what you have for settings under Video Setup.
-Bill
post #37207 of 37529 Unread 10-08-2019, 01:35 PM
jbug's Avatar
Quoted: 281 Post(s)
Liked: 136
-Bill
See above edit.
jbug is offline
post #37208 of 37529 Unread 10-08-2019, 04:48 PM
cbolton's Avatar
Quoted: 87 Post(s)
Liked: 31
Originally Posted by cbolton View Post
I tried a different cable no luck. I also unplugged the cables from both the AVR and Oppo for about a minute and then retried - still the same. I think it has to be a handshake issue as nothing has changed in the settings from when it was working a couple weeks ago. Attached are the Pictures of the AVR and Oppo. The AVR shows zero audio when checking out the input info - shows 4K for video and the audio page is completely blank. Any other suggestions on things to try?
I picked up an entirely new HDMI cable and still seeing zero audio from the Oppo to my AVR. I have powered off the AVR and Oppo to try and force the handshake but it didn't work.
I feel like this is an HDMI handshake issue as another poster mentioned but I'm not sure how to try and force them to reconnect. Any ideas?
cbolton is offline
post #37209 of 37529 Unread 10-08-2019, 05:06 PM
Quoted: 117 Post(s)
Liked: 27
Try changing Oppo Input to HDMI IN and back to Blu-ray player.
Try disabling HDMI CEC.
Enviado de meu SM-G975U1 usando o Tapatalk
Sent while surfing
Cricket-RJ is online now
post #37210 of 37529 Unread 10-08-2019, 05:54 PM
Matt2026's Avatar
Quoted: 915 Post(s)
Liked: 26434
Is it Premium Certified?
Name:	premium certified.jpg
galonzo, ti-triodes and naustin like this.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #37211 of 37529 Unread 10-09-2019, 03:19 AM
Quoted: 30 Post(s)
Originally Posted by Bob Pariseau View Post
^ Set the Dolby Vision output to TV Led instead of Auto.
—Bob
Hi I have an LG B6 and that DV issue never seemed to effect me on the latest firmware using setting Auto
If I change the setting to player Led I get a screwed up picture in DV, Auto and TV led are fine.
Is Auto selecting TV led anyway?
gunner842 is offline
post #37212 of 37529 Unread 10-09-2019, 05:57 AM
wmcclain's Avatar
Liked: 4548
In this case, yes. The LG x6 series accept only the TV led protocol and the player and TV are negotiating that correctly.
-Bill
nc88keyz, galonzo and gunner842 like this.
post #37213 of 37529 Unread 10-09-2019, 08:57 AM
nc88keyz's Avatar
Quoted: 423 Post(s)
Liked: 260
Thanks for the tip to set processing to flat when attempting dv playback on latest firmware. All.other settings on auto for UHD hdr Dolby vision etc. This quick check prevents black screen bug with audio still playing in background. Likely a bug that will never be addressed with the current state of Oppo. Still a solution nonetheless.
Sent from my SM-G965U using Tapatalk
SinGA likes this.
nc88keyz is online now
post #37214 of 37529 Unread 10-11-2019, 03:01 PM
cbolton's Avatar
Quoted: 87 Post(s)
Liked: 31
I moved the HDMI cable to HDMI In and then back to the HDMI out. Also tried to disabling HDMI CEC and re-enabling it. I didn't reboot/restart the player between those events - not sure it matters though?
The other poster that asked about HDMI Premium Certified. The new cable was not, it was one I had lying around so I ordered a new one from Monoprice that definitely is. Outside of swapping the cable and hoping that works not sure what else I can try?
Matt2026 likes this.
cbolton is offline
post #37215 of 37529 Unread 10-12-2019, 08:25 AM
Liked: 1
Hi I have tried searching this thread for an answer but it's HUGE.
My oppo is fine when playing my UHD discs, but quite often when playing an MKV file the audio will briefly cut out or the file will free on an chapter change.
The files are fine on my NVIDIA Shield but it doesn't come close to my oppo 203 for picture or sound.
The Oppo is connected to my denon x8500 for audio only and directly to my Samsung q9fn for picture.
I have tried connecting it directly to the Denon for both picture and sound but I still had the same issue and on top of that my Denon 8500h doesn't support HDR10+
Any help would be appreciated.
Stanleh is offline
post #37216 of 37529 Unread 10-12-2019, 09:03 AM
rdgrimes's Avatar
Quoted: 3889 Post(s)
Liked: 3137
Best guess is a network issue or bottleneck. If you're using a USB drive, perhaps you need a better one.
rdgrimes is online now
post #37217 of 37529 Unread 10-14-2019, 07:46 AM
Rew452's Avatar
Quoted: 187 Post(s)
Liked: 85
I'm using a Qnap TVS-873 server shared folder for my UHD backups.
I can connect to the UHD folder via SMB and as long as I don't leave the folder everything works, I can play any movie there. But if I change to another folder the Oppo want's me to login again even though I checked Save for the user/password. If I re-enter login information it errors and I can only get it back by rebooting the Oppo.
Not sure why it does that but I am wondering if I changed to NFS would this issue be fixed.
Does anyone have some help on this? Would really appreciate!
Rew
Rew
Vizio PX75-G1 | Vizio P75-C1 | Denon AVR-X4500H | OPPO UDP-203 | Tivo Bolt+| Nvidia Shield Android TV | Roku Ultra | Apple TV 4k | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS8 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 | Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #37218 of 37529 Unread 10-14-2019, 08:03 AM
SeeMoreDigital's Avatar
Quoted: 1031 Post(s)
Liked: 814
Originally Posted by Rew452 View Post
...But if I change to another folder the Oppo want's me to login again even though I checked Save for the user/password. If I re-enter login information it errors and I can only get it back by rebooting the Oppo.
How odd... I've don't have this issue accessing SMB shares with my Synology NAS. It's very reliable.
galonzo likes this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is online now
post #37219 of 37529 Unread 10-14-2019, 10:09 AM
rdgrimes's Avatar
Liked: 3137
Rew
This is something on the server side, but I have no idea what. I'd suspect something to do with the way the individual folders are shared on the NAS.
I've seen a similar issue on my 203 when the NAS is putting unused HDDs to sleep, the Oppo times out waiting for it to wake up. (Synology)
post #37220 of 37529 Unread 10-14-2019, 10:51 AM
Rew452's Avatar
Quoted: 187 Post(s)
Liked: 85
Thanks, I changed server side to NFS and all is good now.
Rew
Rew
Rew452 is offline
post #37221 of 37529 Unread 10-15-2019, 08:44 AM
oniiz's Avatar
Quoted: 48 Post(s)
Liked: 4
I've witnessed something bizarre that I've never come across during disc playback ever, I was playing Rosemary's Baby Region 4 Australian dvd on my OPPO 203 & get this only the first chapter of the movie is blank as in a black screen with audio & subtitles that does not make any sense whatsoever as I believe the subtitles are part of the video stream when it gets encoded on the disc, no matter what I've tried with recycling the resolutions to re-authenticate the hdmi handshake nothing brings the picture back for the first chapter of this disc, what an odd anomaly.
oniiz is offline
post #37222 of 37529 Unread 10-15-2019, 08:59 AM
wmcclain's Avatar
Liked: 4548
Have you seen chapter 1 displayed on any other device, even a computer?
With the Oppo, what if you chapter skip backwards and forwards? Does this happen elsewhere, and does chapter 1 appear when you skip back to it?
What are your video settings on the player? What does the Extended Info popup say for both the Media Information and HDMI (Main) Output Information when you are playing chapter 1?
Are you sending video through a receiver? Do you get the same results when the player is connected directly to the display?
-Bill
wl1 likes this.
post #37223 of 37529 Unread 10-15-2019, 09:27 AM
oniiz's Avatar
Quoted: 48 Post(s)
Liked: 4
-Bill
Yes, chapter 1 plays back perfectly in another player as well as a PC drive, what is odd is the picture does not reappear when chapter 2 comes along unless I chapter skip forwards but if I skip back to chapter 1 the picture remains blank with audio present.
It's connected directly to a Sony 2015 flagship 75X9400C Australian variant of the US 75X940C, the Extended Info popup screen Media Info 576x720 50i HDMI Main Output 3840x2160p 50p, Custom Resolution setting UHD Auto.
I've never factory reset the player nor have I ever cleared persistent storage but I believe that is only applicable to 4K & 1080p Bluray discs.
oniiz is offline
post #37224 of 37529 Unread 10-15-2019, 09:37 AM
wmcclain's Avatar
Liked: 4548
That is indeed very strange. Just for completeness I would do the Clear Persistent Storage and Reset Factory Defaults. You can save your current settings on a usb stick and restore them after a reset.
Your output settings look correct, but as an experiment I would try other output resolutions to see if there is a difference. Source Direct is always available; that will send 576i50 to the display in this case.
-Bill
galonzo likes this.
post #37225 of 37529 Unread 10-15-2019, 03:02 PM
ScottAvery's Avatar
Quoted: 720 Post(s)
Liked: 209
Originally Posted by Clark Burk View Post
The latest firmware is 2/08/2019. It did not address the lack of color saturation in the HDR off BT2020 if that was the issue you were questioning.
Originally Posted by inonefly View Post
Yep that’s what I was referring to. Thanks for confirming, think I’ll stay with my 54 firmware.
Was tone mapping working in 54? Was it not broken all along?
Assuming it was, if I can't use DV anyway (Projector), would I benefit from rolling back to 54 for tone mapping?
ScottAvery is offline
post #37226 of 37529 Unread 10-15-2019, 07:34 PM
Plasmoidial's Avatar
Quoted: 128 Post(s)
Liked: 41
Sorry if this is a stupid question, but how do you get the yellow/gold subtitle text to disappear from the screen? Any time I select from the sub menu, it will show which option I selected in yellow text on the bottom left side of the screen, and I can't find any way to remove it other than turning the subs off, stopping the content and then restarting. Similarly, just selecting "off" doesn't work either, because I will then have "Off" stuck on the bottom left side.
The only time this issue seems to resolve itself on its own is if I let the content time out while paused until the screen saver comes on. That removes the yellow text, but this should not be the standard behavior, because it's intrusive.
Plasmoidial is offline
post #37227 of 37529 Unread 10-15-2019, 07:40 PM
wmcclain's Avatar
Liked: 4548
Is this on media files? I've seen it there from time to time, but not on optical discs.
I toggle the subtitles off and back on. That clears it for me.
-Bill
post #37228 of 37529 Unread 10-15-2019, 11:52 PM
Quoted: 97 Post(s)
Liked: 51
Is the WD My Passport Ultra (4TB) external HDD capable of working well with the Oppo?
yobbo is offline
post #37229 of 37529 Unread 10-16-2019, 01:17 AM
Quoted: 128 Post(s)
Liked: 41
-Bill
Yes, I guess I could have been more specific. Turning them off and on does not work for me. Nothing works other than turning them off, then stopping the media and resuming. It's not usually a problem because I don't normally bother with subs, but sometimes there are either foreign speaking parts, or simply unintelligible parts that require them.
post #37230 of 37529 Unread 10-16-2019, 01:17 AM
hlindstr's Avatar
Quoted: 69 Post(s)
Liked: 96
BT.2020 SDR tone mapping has always been broken. You cannot roll back firmware! Player prohibits it.
galonzo likes this.
Oppo UDP-203 and Oppo BDP-83 both hw region modded, M9702 v3 "Chinoppo" (65-0131), Apple TV 4K 32GB, LG OLED55E6V 55", Asustor 2-Bay NAS currently 8TB
hlindstr is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
