Official OPPO UDP-203 Owner's Thread - Page 1268 - AVS Forum | Home Theater Discussions And Reviews
 279963Likes
post #38011 of 38237 Old 02-17-2020, 09:21 AM
Tsender's Avatar
Quoted: 61 Post(s)
Originally Posted by WOLVERNOLE View Post
Slightly disrelated, but may I ask how you like your Marantz SR 7011 ? I am thinking of getting the new SR 7013 (?) 2019 model, but it only has 110 wpc into 2channel.
Recommendations?
Anthem MRX 720. Great sound and power. Not a lot of bells and whistles but again they focus on sound quality. Only a little more than the SR7011. Plus you get Anthem Room Correction. Took my system to another level.
WOLVERNOLE likes this.
Tsender is online now
post #38012 of 38237 Old 02-17-2020, 12:28 PM
dianebrat's Avatar
Quoted: 395 Post(s)
Liked: 377
Recommendations?
You shouldn't judge amps by power ratings, so start with that.
I came from 3 Yamaha's in a row and found they had a ton of soundfield options I never used, the Marantz soundfields were more the kinds I used, I bought mine refurb and then had the dreaded speaker post issue that was fixed under warranty, all said it's a strong amp with good options and a sound profile I like, especially with the Auro option that I use about 3/4 of the time.
The only thing I could have asked for is more flexibility in the amp assignment options when you get to 9.1
dianebrat is offline
post #38013 of 38237 Old 02-17-2020, 02:58 PM
Carbon Ft Print's Avatar
Quoted: 373 Post(s)
Liked: 321
Just had my OPPO203 serviced by OPPO customer service. Very pleasant experience, cost effective and extremely professional people. I truly miss having new products from OPPO.
BobDyl, Keenan, robsis and 14 others like this.
Carbon Ft Print is offline
post #38014 of 38237 Old 02-18-2020, 06:04 PM
A_D_A_M's Avatar
Quoted: 37 Post(s)
Liked: 70
Is there a way to play CDs via [HDMI Main] to a receiver without turning on the projector? Right now there is no audio unless the projector is on. I tried powering up the Oppo first, and then the receiver (and vice versa) to no avail. I only run one HDMI cable to the projector because other sources are connected to the Denon X7200WA.
The only solution I can think of is to run [HDMI Main] to Input 2 on the projector, and [HDMI Audio Only] to the X7200WA...which is lame because that means ordering another Ruipro cable, possibly introducing dialogue timing issues, and having to select Input 2 on the projector whenever I want to watch a disc versus streaming/gaming.
A_D_A_M is offline
post #38015 of 38237 Old 02-18-2020, 06:44 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5893 Post(s)
Liked: 8430
The problem is the input on your projector is an HDMI Zombie. It won’t die! Even though the projector is “off”, it is keeping that input live enough that the Denon thinks it is really there to participate in the HDMI handshake. But it isn’t actually responding so the handshake fails and the Denon leaves the audio muted.
The usual culprits here are HDMI ARC (audio set to come back from the tuner in the projector to the Denon on the cable that normally feeds video into the projector), and HDMI CEC — remote control functions sent over the HDMI cables.
Try disabling HDMI ARC in the projector and also disabling HDMI CEC in *ALL* devices.
Another workaround that sometimes works is to switch the projector to a different HDMI Input before you turn it off. That might work with an input that is not even cabled.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #38016 of 38237 Old 02-19-2020, 05:14 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2071 Post(s)
Liked: 2576
^ Or install a simple HDMI input switcher (or HDFury device) between the AVR and projector so you can disconnect the projector's HDMI signal from the AVR (with the switcher) or make the HDMI handshake happy all the time (with the HDFury device).
gsr is online now
post #38017 of 38237 Old 02-19-2020, 01:32 PM
ze324's Avatar
Quoted: 25 Post(s)
Can the Oppo play a 4K 60Hz Dolbyvision dual video stream folder structure from USB? At 24 Hz this is no Problem, but at 60 Hz it is played as 1080p DV with 60 Hz.
I have a file in TS Format with 4k 60Hz DV in single video stream. This is correctly displayed on my Panasoniv tv.
But a 4k 60 Hz DV folder structure with dual video streams is displayed as 1080p 60 Hz with DV. I have tried different settings on the Oppo, but no success.
My Equipment: Oppo UDP 203, Pioneer SC-LX89, Panasonic 65" GZW2004, Front: Quadral Rodan 9, Back: Quadral Sedan 9, Center: Quadral Base 9
ze324 is offline
post #38018 of 38237 Old 02-19-2020, 10:04 PM
Neil S. Bulk's Avatar
Quoted: 68 Post(s)
Liked: 50
I discovered tonight the Media Control app for the 203 and 205 is no longer on the Google Play Store. I don't know why, as apps for older models are still available there. The Amazon App Store has the app though. I just had to jump through all the hoops to install that store on my devices before getting the Oppo app.
Neil S. Bulk is online now
post #38019 of 38237 Old 02-20-2020, 07:42 AM
chi_guy50's Avatar
Quoted: 2341 Post(s)
Liked: 2452
It is also still showing at the Apple App Store.
Neil S. Bulk likes this.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #38020 of 38237 Old 02-20-2020, 08:02 AM
rdgrimes's Avatar
Quoted: 4021 Post(s)
Liked: 3320
You can also download the APK file directly from Oppo.
rdgrimes is offline
post #38021 of 38237 Old 02-20-2020, 09:44 AM
A_D_A_M's Avatar
Quoted: 37 Post(s)
Liked: 70
—Bob
Thanks so much Bob! I will also try using the Optical output on the Oppo (in addition to HDMI Main), and then switch the input on the Denon to Optical before playing a CD. Perhaps that will be enough to avoid the missed HDMI handshake of a dormant projector.
A_D_A_M is offline
post #38022 of 38237 Old 02-20-2020, 10:47 AM
Philnick's Avatar
Quoted: 700 Post(s)
Liked: 348
Back in the day when I had an Oppo BDP-93 in my theater, connected multichannel analog to a pre-HDMI AVR, with its HDMI cable run direct to a Panasonic PT-AE2000 projector, I found that turning the projector either on or off triggered an HDMI handshake, during which all outputs from the Oppo - even analog audio - were muted during the handshake. At least the 93 allowed the sound to come back after a moment when I turned the projector off!
I ultimately rigged up a small automobile seatback composite video monitor designed for entertaining the kiddies on a trip. The 93 had a composite video output that was fully-functional at 480i level, which allowed me to browse my DLNA music collection while leaving the projector off.
So what you're proposing - to use the SP/DIF optical link for the audio - might not avoid the problem.
Phil
True 4K/HDR10/3D JVC DLA-RS1000 (NX5) projector, 7.2.4 Paradigm/Boston Acoustics/Onkyo speakers, fed by Yamaha RX-A3070 w/ Denon 2307CI to power 4 overheads. Sources: Oppo UDP-203, 4K Roku Ultra, Dell Win 10 PC via HDMI for Amazon Music HD and sampled grand piano.
My water-themed landscape photography website - only 24 pix up so far.
Philnick is online now
post #38023 of 38237 Old 02-20-2020, 12:23 PM
cpix's Avatar
TV turns automaticlly off while watching movies.
I have the Oppo 203 uhd player. While watching movies the TV has a tendency to just turn off, i have no power saving on on the tv or anything that would make it turn it self off. It differs from medium, with DVD it turns off every 3-5 min or so, with bluray a little less, and with uhd, more or less only one time. This does not happen when i use the "source direct" resolution on the player, but does happen while the resolution is 4k 60hz (on the oppo). The Oppo is connected to a Denon x6500h AVR, and then connect to Phillips OLED 65OLED873/12.
anyone has any clue as to why this would happen? my denon is at least set to keep the signal alive.
cpix is offline
post #38024 of 38237 Old 02-20-2020, 02:34 PM
pappaduke's Avatar
Quoted: 487 Post(s)
Liked: 484
Sounds like a CEC/ARC problem. Just a thought.
galonzo likes this.
Man cave-Marantz 8012, Oppo 203, 4K ATV, FireCube 2, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM. B&W PX for travel
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
post #38025 of 38237 Old 02-21-2020, 12:55 AM
cpix's Avatar
Think you're right, problem seems to been corrected by disabling CEC =)
pappaduke likes this.
cpix is offline
post #38026 of 38237 Old 02-21-2020, 11:06 PM
pappaduke's Avatar
Quoted: 487 Post(s)
Liked: 484
I had the same problem several months ago. CEC is a great idea that has been poorly implemented.
post #38027 of 38237 Old 02-23-2020, 05:43 AM
SimpleTheater's Avatar
Quoted: 264 Post(s)
Liked: 111
Originally Posted by Carbo View Post
I have this problem also.
I will add that it has nothing to do with GoT or the 203. It is a Yamaha & Atmos issue. I have the same issue on my Yamaha 5100 and it happens if I use the Oppo 203 or the Panny 9000.
It has also happened on more discs than just GoT.
I just finished two hours of testing. What appears to have fixed it was setting the OPPO to output audio via bitstream, it was previously set to ‘Auto’. While I’m still going to keep an eye on it, because I was so consistently having issues with my Game of Thrones discs and Ford v Ferrari, and I couldn’t create a problem for over an hour, I’m confident in the fix.
I’m curious if both your Panny and OPPO are set to auto, or maybe there is a deeper issue.
I’ll report back if I run into the issue going forward, as my system was quite warmed up and I don’t know if that alone is what fixed the problem.
Neil S. Bulk and galonzo like this.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
post #38028 of 38237 Old 02-23-2020, 10:21 AM
RickD_99's Avatar
Quoted: 312 Post(s)
Liked: 230
203/205 Remotes Still Available
Just an Oppo PSA here: I recently encountered a problem with the down arrow key on my original 203 remote. I decided to order a replacement remote directly from the Oppo Digital site:
https://oppodigital.com/products.asp?cat=38
I ordered the remote on Tuesday night ($18+$5 shipping) and had the remote in my mail box on the following Friday. Nice to see that great Oppo service we have been accustomed to all these years is still apparently in effect.
Those of you intending on keeping your 203/205 for the duration might want to consider ordering a backup remote while they are still available. Be sure to use the link above rather than paying the inflated prices on flea bay.
galonzo, Matt2026 and John^Galt like this.
LG 55C6P OLED Display/Apple TV 4K/2019 Roku Ultra
Oppo UDP-203 UHD Blu-ray Player (65-0131 firmware)
ELAC unifi B5 Speakers
NAD C316BEE Stereo Amplifier
Nakamichi Shockwafe 9.2 Sound Bar (3.2 firmware)/Xbox One X 4K Gaming Console
RickD_99 is offline
post #38029 of 38237 Old 02-23-2020, 10:30 AM
Carbo's Avatar
Quoted: 485 Post(s)
Liked: 309
Interesting, I will give it a try and see if it works.
Also out of curiosity. What Jitter level are you using? I wonder if that could be the problem.
1) JVC RS540, Monolith HTP-1, Outlaw Audio 7700 & 7140, Wharfedale Jade 7's series speakers, RSL C34e(Atmos)
2) LG OLED65B6, Integra DRC-R1.1, Emotiva XPA9, Klipsch RP8000F, Klipsch RP404C, Klipsch RP500SA, Klipsch RP140D
3) Sony XBR55F900, Yamaha CXA5100 & MX5000, GoldenEar SuperSat 3 System
Carbo is offline
post #38030 of 38237 Old 02-23-2020, 04:03 PM
Quoted: 264 Post(s)
Liked: 111
I don’t see a jitter option in settings. Where is this controlled?
My “filter characteristics “ under Audio Processing is set to “Short-Delay Sharp”
post #38031 of 38237 Old 02-23-2020, 04:27 PM
Quickster2's Avatar
Quoted: 22 Post(s)
Liked: 25
I ordered the remote on Wednesday night ($18+$5 shipping) and had the remote in my mail box on the following Friday. Nice to see that great Oppo service we have been accustomed to all these years is still apparently in effect.
Thx for the tip. Ordered 1 myself. You never know.
galonzo likes this.
Quickster2 is offline
post #38032 of 38237 Old 02-23-2020, 05:20 PM
Quoted: 264 Post(s)
Liked: 111
Spoke too soon. Went to watch Game of Thrones, set audio to Atmos and got no sound. Opened the disc drawer, shut it set it back to Atmos and got sound. Didn’t risk pausing or skipping.
post #38033 of 38237 Old 02-25-2020, 04:30 AM
Quoted: 264 Post(s)
Liked: 111
Just spoke to Yamaha on the phone. They said they haven't heard of the popping issue. They said they would look into it.
Not sure if anyone else has had this problem, but if so, call them and report it so they can look into it. Tehy stated the more people that call the better chance of it getting fixed.
Yamaha = 714-522-9105
Not sure if Yamaha knows what's going on. I wrote this to them:
When playing Dolby Atmos discs via my OPPO 203 player, either the sound mutes or a loud popping sound comes through my speakers. I borrowed a neighbor’s Panasonic DP-UB900 and the same issue occurs.
I just got this reply from them:
Thanks for your email, and sorry you're having trouble with your receiver. There are no settings, connections, or updates, that would cause or prevent popping in your speakers. That is caused by a capacitor suddenly discharging, usually do to some form or hardware failure.
Being that you've duplicated the problem with 2 players, it's safe to assume the issue is with the receiver itself, or perhaps some other peripheral device. If you are running any of your speakers on external amplifiers, try powering them with the internal amp, and see if the problem goes away. Also, try unplugging your other peripherals (subwoofer, CD player, cable box, etc) and see if that fixes it.
If none of that helps, the next step will be to have the receiver checked out by a repair technician. You can find the closest authorized service company at the following link:
https://www.yamaha.com/paragon/servicerlocator/
If the unit is within it's 3-year warranty, be sure to show a copy of your sales receipt when dropping off the receiver. That way the service company can bill Yamaha for the repair costs.
Best Regards,
Keith @ The Yamaha Customer Support Team
Sadly the concept that this is ONLY and issue with ATMOS doesn't seem to be sinking in with the Yamaha Support team.
I have a 48Gbps Ultra 8K HDMI Cable coming today. It will be my 4th HDMI cable switch, to try and completely eliminate the cable as the issue.
galonzo likes this.
post #38034 of 38237 Old 02-25-2020, 05:21 AM
immikeulate's Avatar
Just switching from LCDs to projectors and the consensus seems to be dropping the Oppo for a Panny 8200 or 9000 for better HDR. IDK if i could do it. I love this thing. Anyone make the switch and not look back?
-PSN ID: M-Easy
-XBOX360 GT: m easy021
-"LIKE THE GREAT WARRIOR POET ICE CUBE ONCE SAID: IF THE DAY DOES NOT REQUIRE AN AK, IT IS A GOOD ONE!" -Corporal Josh Ray Person, Generation Kill.
immikeulate is offline
post #38035 of 38237 Old 02-25-2020, 05:46 AM
Philnick's Avatar
Quoted: 700 Post(s)
Liked: 348
Depends on the projector. I was looking at the 9000 but holding back because I couldn't get confirmation that it could play surround music as surround over DLNA - or be made region-free for DVDs and Blu-rays - like the Oppos.
I bought a JVC DLA-RS1000 (same as the N5/NX5) and JVC introduced dynamic tone mapping in the most recent free downloadable firmware update for all of their true 4K LCD projectors (RS1000/N5/NX5, RS2000/N7/NX7, RS3000/N9/NX9), making the Panny tone mapping irrelevant to me. (As I use the dynamic tone mapping's frame-by-frame mode, it's even encroaching on DolbyVision's main claim to fame - without denying users the ability to manually tweak the image to taste the way DV does.)
I've stayed with my 203 and I'm very happy.
Phil
post #38036 of 38237 Old 02-25-2020, 05:48 AM
lizrussspike's Avatar
Quoted: 1447 Post(s)
Liked: 2165
@immikeulatem I have the 820 and the 203, and like them both.
lizrussspike is offline
post #38037 of 38237 Old 02-25-2020, 06:38 AM
SeeMoreDigital's Avatar
Quoted: 1105 Post(s)
Liked: 936
Just-so-you-know... At the time of writing there are no officially approved "so-called 8K" (Ultra High Speed) HDMI Certified leads (ie: with a security hologram and QR code) available for sale.
Until the officially approved 'Ultra High Speed HDMI® Certified' leads become available for sale, you're better off purchasing the currently approved 'Premium Certified' HDMI leads...
Cheers
galonzo and chi_guy50 like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #38038 of 38237 Old 02-25-2020, 07:47 AM
Clark Burk's Avatar
Quoted: 757 Post(s)
Liked: 693
Cheers
Good to know. I found this on the hdmi.org site.
https://www.hdmi.org/spec21Sub/UltraHighSpeedCable
chi_guy50 likes this.
Clark
Clark Burk is offline
post #38039 of 38237 Old 02-25-2020, 08:57 AM
Liked: 936
Did you refer to the: "When will I be able to purchase an Ultra High Speed HDMI Cable?" Q&A?
Sufficed to say... The officially approved 'Ultra High Speed HDMI® Certified' leads are not available yet!
Which means, any vendor selling an "8K" HDMI lead is most likely selling snake oil...
galonzo likes this.
post #38040 of 38237 Old 02-25-2020, 01:18 PM
Carbo's Avatar
Quoted: 485 Post(s)
Liked: 309
Best Regards,
I am moving on from the Yamaha 5100. I have tried enough to problem solve and I do not believe that a repair shop will find a problem. If this is a hardware issue it might start popping up for more users. I'll just wait to see if Yamaha figures it out, in the meantime I will be moving it to another room where I don't watch discs.
Mine is past the 3 year mark and I don't want to pay them to repair what should not have broke to begin with.
I might try a Yamaha 5200.
SimpleTheater likes this.
Carbo is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
