Official OPPO UDP-203 Owner's Thread - Page 1288 - AVS Forum | Home Theater Discussions And Reviews
 280452Likes
post #38611 of 38866 Old 05-30-2020, 01:43 PM
Serenity's Avatar
Quoted: 41 Post(s)
Liked: 72
Originally Posted by fookoo_2010 View Post
By disc I was referring to either a 4K disc or BR disc and both of those occurences have happened to me. The 203 failed to read a 4K disc of Christopher Nolan's The Prestige as well as a 4K disc of Crouching Tiger, Hidden Dragon, but both were readable and playable via the Panasonic 4K player 820. The BR failure occurred with Netflix disc rentals which were then playable on a Panasonic BT500 player. I supose that you have just been fortunate.
I have both of those, but didn't have issues with them. I assume that you reached out to OPPO support. They are still doing support, so if there is a chance that you do have a HW issue, you would still have the opportunity to have them fix/replace something. FWIW
Tom C and galonzo like this.
Serenity is offline
post #38612 of 38866 Old 05-30-2020, 03:31 PM
fookoo_2010's Avatar
Quoted: 332 Post(s)
Liked: 149
That is probably expecting too much as there hasn't been anything recent in terms of oppo updates. And I don't expect any.
fookoo_2010 is online now
post #38613 of 38866 Old 05-30-2020, 04:50 PM
Liked: 0
Hi all owners OPPO UDP 203 :-)
I have this problem: when I upload some WAV files in 24 bit / 192 kHz format to a USB Flash drive, I have dropouts during playback. When I burn the same files to DVD -R, they play well even in the highest resolution ...
I use the rear USB3 ports and the corresponding USB3 flash drive. That should be sufficient for these transmissions.
Do You have the same problems?
Thanks for the feedback :-)
The best Regards from Prague, Petr
hifik is offline
post #38614 of 38866 Old 05-30-2020, 07:16 PM
rdgrimes's Avatar
Quoted: 4099 Post(s)
Liked: 3414
Thumb drives are notoriously slow, often too slow for high res music. Try converting those same files to FLAC and see if they play better, or get a faster thumb drive.
rdgrimes is offline
post #38615 of 38866 Old 05-30-2020, 07:28 PM
Sound & Vision's Avatar
Quoted: 483 Post(s)
Liked: 289
Tonight I watched the new Midway Movie in 4K Ultra on my 78KS9800.. I had issues throughout.... The Top letterbox bar was flashing off and on and brief sound pauses as well.. I searched on the net and found reports of Midaway 4k Ultra being the 1st 4k Ultra movie to use some sort of new BD-J copy protection.. It drove my 78KS9800 crazy with the top letterbox bar randomly flashing on and off.. This new BD-J copy protection is either tripping up my Oppo 203 Player or my TV or Both.. I was thinking my Oppo 203 does not support this new copy protection and perceives the movie as a copy?? There seems to be no way to stop it.. This is only on the Midway 4K Ultra disc as its the 1st and only disc with this new BD-J copy protection.. If more movies come out like this i'm going to just play the blu ray version.. Which defeats the purpose of enjoying a 4k movie. 😞
https://www.makemkv.com/forum/viewtopic.php?t=21505
RagtopFE likes this.
Sound & Vision is offline
post #38616 of 38866 Old 05-30-2020, 10:43 PM
lujan's Avatar
Quoted: 5216 Post(s)
Liked: 3230
https://2mkv.com/forum/viewtopic.php...708386516b9158
This is what I got when I followed the link you provided:
lujan
697 Ultra HD
740 HD
4 SD
lujan is online now
post #38617 of 38866 Old 05-30-2020, 11:00 PM
Quoted: 483 Post(s)
Liked: 289
post #38618 of 38866 Old 05-30-2020, 11:18 PM
lujan's Avatar
Liked: 3230
Great, that one works, thanks! I remember playing this title back when it was first released on the Oppo 203 and didn't have the issues you describe.
galonzo likes this.
lujan
697 Ultra HD
740 HD
4 SD
lujan is online now
post #38619 of 38866 Old 05-31-2020, 02:52 AM
glangford's Avatar
Quoted: 874 Post(s)
Liked: 777
USB 3.0 should be plenty fast enough, even usb 2.0 should be. I've used usb 2.0 on 96/24 files and that worked fine. (I normally buy hi rez music at 96/24). I currently have a few albums of 192/24 in FLAC on a usb 3.0 thumb drive that works fine on the front port which is usb 2.0 and they work just fine. (In my furniture style cabinet the rear port is too much of a pain to get to.) I use FLAC format. If you have a MAC you can convert your files to FLAC with a free program called XLD.
You might also try another usb port, I believe the 203 has two USB 3.0 ports in the rear of the player.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #38620 of 38866 Old 05-31-2020, 03:05 AM
KC-Technerd's Avatar
Quoted: 525 Post(s)
Liked: 469
Tonight I watched the new Midway Movie in 4K Ultra on my 78KS9800.. I had issues throughout.... The Top letterbox bar was flashing off and on and brief sound pauses as well.. It drove my 78KS9800 crazy with the top letterbox bar randomly flashing on and off.. This new BD-J copy protection is either tripping up my Oppo 203 Player or my TV or Both..
No similar issues with Midway (2019 Lionsgate) 4k UHD Disk played on my UDP-203 and LG OLED65C9. I've played both a RedBox rental copy (which if I remember correctly was HDR10 only) and a purchased copy (Dolby Vision).
galonzo likes this.
Oppo UDP-203 (UDP20X-65-0131), Apple TV 4K 32GB tvOS 13.4.6 (17L570)
Pioneer SC-77 (1–149–020–516–120), M&K Sound S150II/S150T/X12
LG OLED65C9AUA (04.80.03), CalMAN Home for LG 2020, i1Display EODIS3–XR Rev. B–02
KC-Technerd is offline
post #38621 of 38866 Old 05-31-2020, 04:26 AM
rdgrimes's Avatar
Liked: 3414
The Screenpass protection you are referring to only impacts ripped discs and illegal copies. Its also nothing new, but is not typical on UHD titles. It has no impact when playing the original disc.
Neil S. Bulk and galonzo like this.
rdgrimes is offline
post #38622 of 38866 Old 05-31-2020, 05:25 AM
madrac's Avatar
Quoted: 251 Post(s)
Liked: 174
No issues with Midway 4K on my Oppo 203 either.
galonzo likes this.
LG OLED65E6P, Anthem MRX720, Rogue Atlas Magnum II, UPA7, Ascend Acoustics Sierra Towers with RAAL, Luna Duo center, Sierra 2 surrounds, and HTM200SE front & rear heights, Rythmik E15HP (1, but plan on adding a 2nd), VPI Classic 1+ (VTA Tower, 3D arm), VAS NOVA and Soundsmith Paua cartridges, Manley Chinook, Oppo 103D, Oppo 203. Audio Sensibility and Blue Jeans cabling, Symposium & Isoacoustics isolation products
madrac is offline
post #38623 of 38866 Old 05-31-2020, 07:41 AM
Semi-Advanced Member
ht guy's Avatar
Quoted: 292 Post(s)
Liked: 304
Midway played fine on our 205.
galonzo likes this.
ht guy is offline
post #38624 of 38866 Old 06-01-2020, 05:04 AM
oniiz's Avatar
Quoted: 181 Post(s)
Liked: 56
Originally Posted by oniiz View Post
Is it true that the HDR OFF (BT2020), HDR OFF (BT709) & Strip Metadata settings resolve less than the REC709 color gamut regarding Red & Green saturation points, did it at one point before the 4 HDR-SDR Tone Mapping conversion modes at least resolve the full REC709 color gamut with Red & Green fully saturated with the Strip Metadata only function in early firmware?
It's strange OPPO's engineers were pretty oblivious to implement worse than the Rec. 709 color gamut in the end, is it more towards SD's Rec. 601 color gamut?
Do owners use this feature anymore & is it as terrible as it's made out to be regarding severe color saturation less than REC709 colors? Wandering if @Bob Pariseau or @gsr could offer any insight?
I read that the HDR-SDR conversion to SDR BT2020 is severely under saturated with the Red & Green color points being under the Rec. 709 color gamut, is it more towards SD Rec. 601 for Red & Green?
oniiz is offline
post #38625 of 38866 Old 06-01-2020, 07:32 PM
SimpleTheater's Avatar
Quoted: 324 Post(s)
Liked: 164
My setup is Oppo 203 to Yamaha RX-A3060 to JVC RS400
I own the Midway Ultra 4K release and have watched it twice without any issues. Before blaming a piece of equipment you may want to exchange the disc first.
DAB, galonzo and pappaduke like this.
Why is there NO perfect equipment, only compromises?
SimpleTheater is online now
post #38626 of 38866 Old 06-03-2020, 05:06 PM
MagnoliaMOE's Avatar
Quoted: 30 Post(s)
Question for fellow Oppo 203 owners. Does the 203 have HDR tone mapping? If so is there anything I need to turn on? Thank you.
MagMo
Sony 65 A1E OLED, LG 55 B6 OLED, Oppo UDP-205, Marantz AV-8802A, Marantz MM8077, Marantz MM7055, PS3 (Fatty SACD), MartinLogan Theos, MartinLogan Motif-X, MartinLogan Montage, MartinLogan Descent-i, MartinLogan ElectroMotion FX2, MartinLogan Motion 2, MartinLogan Helos 12 (4 for Atmos).
MagnoliaMOE is offline
post #38627 of 38866 Old 06-04-2020, 02:16 AM
Quoted: 169 Post(s)
Liked: 59
@KC-Technerd
Hi
I was asking you about video settings not long ago, I tried Custom and noticed very slight jaggies in lettering vs source direct which smoothed things out. I currently use source direct because of this, but not watched enough 1080p content to decide if that is the only main difference.
I know you did some testing, and just wondered if you come to a conclusion on what you prefer out of source direct or custom so the player upscales 720p/1080p instead?
gunner842 is offline
post #38628 of 38866 Old 06-04-2020, 08:07 AM
Quoted: 525 Post(s)
Liked: 469
From looking at other posts you've made, I'm assuming you're talking about with an LG GX. I have an LG C9 which may be somewhat similar, but some to all of what I'm saying here may differ from the GX. No easy answer to this. You have to decide which you think produces the best results.
All the upscaling to 4k is happening in the UDP-203 using Auto or Custom UHD Auto. I do get the slight jaggies on 720/1080 lettering (and lines in test patterns that are between vertical and horizontal). However I've only noticed this on computer and video generated lettering. I'm not seeing it if the lettering is from a film source. Oppo appears to be using something other than simple nearest neighbor to perform the upscaling (bicubic perhaps?). I can tell this because when presenting a 1080p alternating pixel pattern, I'm not getting 2x2 pixel blocks of black alternating with 2x2 pixel blocks of white. Instead I get a bright white pixel, two gray pixels, a black pixel, two gray, bright white, etc. Theoretically at least, bicubic (or whatever the Oppo is doing) should be superior. The Oppo also seems to pass full bandwidth chroma when upscaling.
With Source Direct my C9 is doing the upscaling. With the C9's Sharpness set to 0, it's obvious that the C9 is performing simple nearest neighbor upscaling. That means each individual 1080 pixel becomes a square 2x2 block of 4k pixels, and each individual 720 pixel becomes a square 3x3 block of 4k pixels. (This is really the "truest" form of upscaling in my opinion.) This too will produce the slight jaggies on 720/1080 lettering. However, as the C9's Sharpness is increased to 10, anti-aliasing is introduced that hides the jaggies. High frequency chroma seems to be muted when the C9 is doing the upscaling (tested on an earlier C9 software than what's current).
For now I'm going with the Oppo doing the upscaling, and living with the occasional jaggy edge to get the full chroma bandwidth. I'm not really sure if that is better or worse than having the C9 do the scaling. I do like the anti-aliasing that the C9 does, but it comes with tradeoffs.
The Spears & Munsil HD Benchmark, 2nd Edition is the best tool I know of for evaluating the differences. However some of the Mehanik HDR10 calibration and test patterns were more useful for evaluating the anti-aliasing on the C9. I didn't mention 480 because it doesn't integer scale (not directly divisible by, not to mention not having square pixels) to 4k, so it gets a lot more complicated. I hope this helps.
Spidacat and gunner842 like this.
post #38629 of 38866 Old 06-04-2020, 08:25 AM
mskreis's Avatar
Quoted: 163 Post(s)
Liked: 50
Service question. I’ve had my 203 since it was released and have experienced frequent glitches with certain 4K discs. In the past several months it has frozen on Knives Out, Rambo Last Blood, Hunter Killer, Transformers The Last Knight. I always wash the discs thoroughly before playing them. If I sent my player in for service, would they be able to assess and potentially fix this issue?
JVC RS640; RUIPRO 10m HDMI cable; Marantz AV7704; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni, KEF Inceiling Ci 160QR x 4; Dual RSS460HO-4 18" SWs
mskreis is offline
post #38630 of 38866 Old 06-04-2020, 08:39 AM
rdgrimes's Avatar
Liked: 3414
At the very least they will clean and service it. Contact them via the website and ask.
mskreis likes this.
rdgrimes is offline
post #38631 of 38866 Old 06-04-2020, 09:16 AM
galonzo's Avatar
Quoted: 1558 Post(s)
Liked: 2171
@mskreis , I always play disks as they come, and very rarely need to give them a "wash." As a data point, my 203 played Knives Out from beginning to end flawlessly, and while I do own the other titles you mentioned, I haven't gotten around to watching them yet. HTH
mskreis and kokishin like this.
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield Pro | PS4 Pro | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K | Roku P+ (4630)
FS - Dr. Strangelove (1964) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #38632 of 38866 Old 06-04-2020, 11:31 AM
abilyeu's Avatar
Quoted: 50 Post(s)
Liked: 47
My 203 plays most discs flawlessly, but every once in a while it will stutter and/or freeze at some random spot, even on a disc that had no problem before. If I can manage to reverse a few seconds or minutes and replay the problem section, it will often repeat in the same spot. In most cases, simply ejecting the disc and playing it again fixes the problem. If that doesn't work, then cleaning the disc will usually clear it up. Lately I have started erasing the persistent storage after every few discs. So far it hasn't frozen on me since I started doing that, but it's too early to say for sure that it fixes the problem.
mskreis, Tom C and galonzo like this.
abilyeu is offline
post #38633 of 38866 Old 06-04-2020, 01:12 PM
Quoted: 332 Post(s)
Liked: 149
Service question. I’ve had my 203 since it was released and have experienced frequent glitches with certain 4K discs. In the past several months it has frozen on Knives Out, Rambo Last Blood, Hunter Killer, Transformers The Last Knight. I always wash the discs thoroughly before playing them. If I sent my player in for service, would they be able to assess and potentially fix this issue? Sent from my iPad using Tapatalk
Not likely unless it behaved like that on every 4K that you tried to play. It is not usual to have a 4K disc not play on the 203, but be playable on a different brand 4K disc player.
post #38634 of 38866 Old 06-04-2020, 03:11 PM
rdeyoung's Avatar
Quoted: 118 Post(s)
Liked: 137
Hey guys,
Ive been having issues with my Oppo 203 lately. Several blurays have been sending audio to only the front right channel speaker (only upon first playing) for several minutes before it finally fixes itself and sends audio signal normally. Its happened with the Nickelodeon's Avatar: The Last Airbender Bluray set and the Dynasties BBC Bluray. Ive ruled out that it's the bluray discs fault because it will happen again if I pause the playback and then hit play.
Has anyone else experienced this?
CG Lighting Artist for Walt Disney Animation Studios
Pioneer Elite VSX-92TXH AVR || Klipsch RF-7ii, RC-64ii, RS-62ii || SVS SB13U || Samsung UN55C8000 3DTV || XBone || X360e || N Wii U || N Switch || ATV 4k || Oppo 203
rdeyoung is offline
post #38635 of 38866 Old 06-04-2020, 03:32 PM
Quoted: 324 Post(s)
Liked: 164
Originally Posted by rdeyoung View Post
Hey guys,
I've experience NO sound. The two things I would try is a different HDMI cable, and changing the output to Bitstream (or if set to Bitstream to PCM). Also, does your AVR tell you what it is receiving? For example my Yamaha, if receiving stereo will only light up the left and right channel, the other 11 channels will be blank. So if you're only getting audio to the right speaker, is the left lit up?
I'm betting on a bad connection in HDMI and hopefully its the cable. Also, try a different HDMI input on your AVR to make sure its not your AVR's HDMI input that is causing the issue.
Good luck.
post #38636 of 38866 Old 06-04-2020, 03:32 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2172 Post(s)
Liked: 2743
Hey guys,
I don't recall any other reports of that. Which audio output are you using on the player? If HDMI, I would suspect your AVR rather than the Oppo.
galonzo likes this.
gsr is online now
post #38637 of 38866 Old 06-04-2020, 05:43 PM
dianebrat's Avatar
Quoted: 411 Post(s)
Liked: 418
If the AVR is a 2016/2017 Marantz or Denon they have been known to have speaker binding post issues.
dianebrat is offline
post #38638 of 38866 Old 06-05-2020, 01:05 AM
Quoted: 169 Post(s)
Liked: 59
Thanks very much for the detailed information, when you say about computer/video generated lettering exhibiting jaggies, is that things like subtitles, would this include movie credits or are they part of the movie content?
As for you mentioning getting the full chroma bandwidth, I'm a little lost here, is that to do with the 4:2:2/4:4:4 chroma stuff, if so from what I understand it gives better colour if 203 is set to custom/auto so that its doing the upscaling.
I would need to check again but I think I did notice slightly muted/flat colour when set to source direct, I think I will change back to custom and let the 203 do the upscaling.
Thanks again
post #38639 of 38866 Old 06-05-2020, 07:57 AM
mskreis's Avatar
Quoted: 163 Post(s)
Liked: 50
Done, thanks for the link. Currently troubleshooting with them now via email.
galonzo and RagtopFE like this.
mskreis is offline
post #38640 of 38866 Old 06-05-2020, 05:51 PM
rdeyoung's Avatar
Quoted: 118 Post(s)
Liked: 137
Good luck.
Hey guys!
I checked the audio output settings and the hdmi audio was set to Auto - so I switched it to Bitstream. I thought for sure I already had it on Bitstream but maybe one of the Oppo updates switched it back? After switching to Bitstream I still had the issue... The AVR does report what its receiving, in this case DTS Stereo (L&R) for the Avatar bluray set. My AVR is very old, 2008 I think? Im also using newer Mediabridge Flex Series HDMI Cables, ill try to swap it out to see if thats the cause as well. Anyone have a recommendation for really good hdmi cables thats 2.1 ready in case I have to buy new ones?
rdeyoung is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
