Official OPPO UDP-203 Owner's Thread - Page 305 - AVS Forum | Home Theater Discussions And Reviews
 278836Likes
post #9121 of 36767 Old 01-27-2017, 04:46 AM
Super Moderator
teachsac's Avatar
Quoted: 1241 Post(s)
Liked: 2051
Originally Posted by Kruckus View Post
I know this might not be the right thread for this but i figured someone in this thread will know the answer.I just want to understand Dolby Vision a little more and thing i don't understand is that i thought Vision was supposed to be mastered at 12bit but yet I see that certain 10bit panels are able to support Dolby Vision. Example the OLED B6 is a 10bit panel & it supports vision. So is Dolby Vision actually mastered for 12bit?
This would not be the correct thread. You can learn about HDR and DV in this area.
https://www.avsforum.com/forum/465-hi...lor-gamut-wcg/
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #9122 of 36767 Old 01-27-2017, 05:07 AM
math wizard's Avatar
Quoted: 88 Post(s)
When I go to the SETTINGS menu, the screen blinks for a split second as if it is trying to negotiate a HDMI handshake. Is this normal? It also does this when I'm returning to the HOME SCREEN for SETTINGS or if I'm changing the HDR or resolution settings. Any infor is greatly appreciated.
Emotiva MC-700, XPA-2, XPA-3, OPPO UDP-203, minidsp DDRC-88A/BM, Polk Audio RTi12, CSi5, RTiA1, Epik Knight, Sony XBR65X850C, DirecTV C61K (4K Genie Mini), APC H15, Emotiva CMX-2, Harmony Touch, Emotiva X-series Cables
math wizard is offline
post #9123 of 36767 Old 01-27-2017, 05:10 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4541 Post(s)
Liked: 4372
You'll get a new handshake when changing resolution, color space, bit depth or HDR. I haven't see it reported for just entering Setup.
-Bill
math wizard likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #9124 of 36767 Old 01-27-2017, 05:33 AM
Kage's Avatar
Quoted: 104 Post(s)
I'm using a Harmony remote and it causing HDMI handshaking issues with the Oppo and my Yamaha receiver., because it turns on my devices at the same time. Do any of you have recommended power on delay settings?
Kage is offline
post #9125 of 36767 Old 01-27-2017, 05:46 AM
Quoted: 88 Post(s)
-Bill
Is this occurance the intication of a possible problem with the player? Since I've owned the player, I've noticed that the picture is not as detailed (sharp) as my 103.
post #9126 of 36767 Old 01-27-2017, 06:01 AM
wmcclain's Avatar
Liked: 4372
I would treat the two issues separately. You are running the current 1229 firmware?
(1) Blinking: I would suspect HDMI first. Have you tried swapping cables around, making sure of a good fit in the sockets? How long are your cable runs?
(2) Not as sharp: this would be for Blu-ray? What are your video settings? When you press and hold the Info button on the remote, scroll down to the HDMI Output section, what does it say?
-Bill
post #9127 of 36767 Old 01-27-2017, 06:48 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11028 Post(s)
Liked: 6571
Yes. Click on Devices, select the Oppo device, and then Device Delay Settings. Here is the adjustment that solved my similar issue:
Name:	Device Delay.JPG
AustinJerry is online now
post #9128 of 36767 Old 01-27-2017, 06:52 AM
johng's Avatar
Quoted: 239 Post(s)
Liked: 107
Try changing the order in which the devices are turned on, and add a small delay between each. What works for me is this order:
1. Oppo
2. AV Receiver
3. Projector
Before changing to these settings, I was turning on the projector first and experiencing handshake issues.
Good Luck
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #9129 of 36767 Old 01-27-2017, 07:08 AM
badboi's Avatar
Location: East of the Sun, West of the Moon (Home Farm, Emme
Quoted: 126 Post(s)
Liked: 129
Originally Posted by timc1475 View Post
The Oppo folks are out of California but am unsure if all their parts are made there or not. Although USA manufacturing may gain anew hopefully soon as we become wiser finally.
I agree in the short term to buy now b4 increased potential tariffs across the border, but in the long run just maybe the good ole USA will return to making most electronics & TV's here again after decades of prior trade policies that put us last that in part created the worst debt ratio in history that generations beyond us must bear.
Alrighty then.
AlexH likes this.
badboi is offline
post #9130 of 36767 Old 01-27-2017, 08:04 AM
kenreau's Avatar
Quoted: 20 Post(s)
Could someone advise me on the most recent firmware release regarding the UHD HDR dark picture issues?
My system with a JVC RS400 projector suffers from the dark picture quality while viewing 4K UHD blu rays. Back a few weeks ago there were some work arounds including the strip metadata setting and increasing brightness levels which I made. With this latest firmware update, are those same prior work arounds still necessary? Does the firmware update reset all those automatically?
Many thanks
Kenreau
Latest Official Release Version
Release date: January 19, 2017.
Category: Latest Official Release
Main Version: UDP20X-33-1229
kenreau is offline
post #9131 of 36767 Old 01-27-2017, 08:22 AM
wmcclain's Avatar
Liked: 4372
I'm recalling that advice was made for this 1229 firmware, so it should be the same with the production version.
The update does not reset settings, but the instructions say to do it manually. This is easy these days because of the Settings Management feature. Save your settings to USB stick before, restore them after.
-Bill
kenreau likes this.
post #9132 of 36767 Old 01-27-2017, 08:23 AM
Quoted: 88 Post(s)
-Bill
Thanks for the reply
Yes, I'm running 1229 firmware.
The HDMI fit firm in their sockets. Currently, I'm using the OPPO supplied cable, but have swapped it with other certified cables with the same result. My cable run is 6 ft.
The not sharp is for UHD. My settings are: HDR: Auto, Output Resolution: custom, Custom Resolution: UHD Auto, Color Space and Depth: both Auto.
When I press INFO, the HDMI output section says HDR BT2020, 4.2.2 12 bit
post #9133 of 36767 Old 01-27-2017, 08:33 AM
wmcclain's Avatar
Liked: 4372
For all UHD titles? Are you comparing it to another player, or to Blu-ray versions of the same title?
-Bill
post #9134 of 36767 Old 01-27-2017, 08:51 AM
Quoted: 88 Post(s)
-Bill
This is compared to blu-ray version of the same title
jude924 likes this.
post #9135 of 36767 Old 01-27-2017, 08:55 AM
wmcclain's Avatar
Liked: 4372
That's not good advertising for UHD! What titles?
What display do you have? It will require different calibration for its HDR modes.
Does Source Direct look better than Custom/UHD Auto?
What if you turn HDR off in player? Does the image seem better?
-Bill
post #9136 of 36767 Old 01-27-2017, 09:21 AM
Quoted: 88 Post(s)
-Bill
This is for all titles. HDR mode looks dark. HDR off looks a lot better (almost like the blu-ray version). Source Direct does look better than Custom/UHD auto in both HDR and non-HDR modes. I have a Sony XBR65X850C monitor.
For the record, 4K from Direct TV, Netflix, Youtube, VUDU, etc.., looks better than 4K from the player. It is sharper with more detail. This is for both HDR and nonHDR sources.
My settings for all 4K inputs are the same.
post #9137 of 36767 Old 01-27-2017, 09:44 AM
jjwinterberg's Avatar
Quoted: 101 Post(s)
Liked: 63
Originally Posted by amnesia0287 View Post
Let's be fair here, more than likely there is a cable issue, just not the one people are thinking of.
There is absolutely a problem with "18Gbps" cables not being able to handle their claimed bandwidth, but at least from what I can discern, the OPPO is also more sensitive than many players/devices to this failure. It's totally possible there is some sort of configuration/hardware problem, perhaps something like the HDMI port is running the wrong voltage or something. However, given that we already know the player has error recovery problems, to me, the likely cause is that the errors are occurring on all devices, but the OPPO unlike the others is failing to recover from the errors cleanly.
My opinion as well.
It would be interesting to know what HDMI transmitter/receiver chips are used by the players in question. I looked over the TI transceiver data sheets last night and there is flexibility in how the chips can be configured. There could be a hardware or configuration root cause.
jjwinterberg is offline
post #9138 of 36767 Old 01-27-2017, 10:00 AM
curlyjive's Avatar
Quoted: 650 Post(s)
Liked: 314
Per the sharpness, what titles have you tried. My general impression has been that UHD titles with a true or near 4K DI look noticeably sharper than ones that were unconverted. The unconverted titles look softer and less detailed than the blu ray counterpart. I attribute that to DNR or other processing being used on the unconverted titles.
As for the darker image, HDR titles are graded darker to begin with. Even when HDR is off, the base grading still looks darker. Now The oppo still is crushing some detail in my case wen converting HDR to SDR. I hope that will be addressed soon. Remapping luminance from HDR to SDR seems to need work.
stevenjw likes this.
curlyjive is offline
post #9139 of 36767 Old 01-27-2017, 10:04 AM
JohnAV's Avatar
Quoted: 516 Post(s)
Liked: 697
John Archer (Forbes) wrote a early review of the UDP-203 also.
Oppo UDP-203 Ultra HD Blu-ray Player Review: The Return Of The King - 1/27/17
Multiple comparisons to Samsung and Panasonic UHD players. Some issues with player operation mentioned noted with 203.
Oppo Beta Group
JohnAV is offline
post #9140 of 36767 Old 01-27-2017, 10:34 AM
Quoted: 88 Post(s)
Some of the titles are "Magnificent Seven", Jason Bourne, Now You see Me 2, Life of Pets, Star Trek (newest movie), Batman vs Superman
post #9141 of 36767 Old 01-27-2017, 10:38 AM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 812
FREE 3D MOVIE!!
For my fellow AVS buds located within the USA.
If anyone has the 203 or 103 region adapter & a 3D capable TV feel free to PM me.
As you can see in the below pics I bought a triple 3D pack of movies from E-Bay. I just received this triple pack today btw.
3D Prometheus & iRobot play fine on my 203 so I am def keeping these 2 but the 3D Vampire Hunter is region B or C only, this is what the 203 player said in that it would not play.
So...
The 1st person who PM's me with the aforementioned criteria with their address they want me to ship it to, I will ship this new Vampire Hunter 3D disc at N/C just so it will not go to waste, as I do not plan on buying the adapter region converter.
This is my way of giving back to the community that has helped me over the years.
Couch Potato out.
gsr, stikle and StumpyBloke like this.
timc1475 is offline
post #9142 of 36767 Old 01-27-2017, 10:51 AM
JaytheDreamer's Avatar
Quoted: 237 Post(s)
Liked: 241
Stuck on network but recovered
Last night I thought I would just run the FW update to the official (though I already have the same Beta installed). I have the unit set to alert on updates but never got any alert. Went to Setup menu, clicked check for update online. It circled Searching.. with the wheel turning for 8-10 minutes doing nothing. No command from remote would work either (my home network and internet were fine all the time and other devices were functioning properly).
Then I power cycled the unit, it came back up immediately showed the new FW alert, grabbed it and installed (everything under couple of minutes). No problems after that.
______________
Thanks, Jay
Spoiler!
JaytheDreamer is offline
post #9143 of 36767 Old 01-27-2017, 11:04 AM
Liked: 1
Originally Posted by mel_in_az View Post
The dropped frames are accompanied by severely out of sync audio. Regular Blu-rays seem OK, but 3D discs have pretty horrendous audio sync issues...
- Mel
Hi Mel,
Did the 1212b firmware also fix the issue with the out of sync audio? I have the exactly same problem, 3D discs with judders and out of sync audio
It also seems that there is a new firmware version UDP20X-33-1229, did you update your player with it yet and if yes, is everything fine?
T-800 is offline
post #9144 of 36767 Old 01-27-2017, 11:05 AM
wxman's Avatar
Quoted: 5361 Post(s)
Liked: 3770
Do you have a HDR bright room setting or something similar to that? I use that on my E6, as HDR Standard is too dim and dull. I then adjust my OLED light and contrast down, so it is not blinding, and IMO looks better. Still not all that impressed by HDR10. Hope OPPO get the Strip metadata function working properly, because SDR2020 looks impressive and is not dark like HDR.
dlynch34 likes this.
LG 65E6P OLED - LG 65EF9500 OLED - OPPO 203 - OPPO 103D
wxman is offline
post #9145 of 36767 Old 01-27-2017, 11:08 AM
curlyjive's Avatar
Quoted: 650 Post(s)
Liked: 314
Of those I have star trek beyond and magnificent 7. Magnificent 7 is a bit dark and I don't like the color grading. I didn't find it soft. Star Trek beyond looks a bit soft as well. I believe both are unconverted from a 2k DI. So thats a possibility on those.
post #9146 of 36767 Old 01-27-2017, 11:12 AM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
I have an Amazon Fire TV plugged into the rear input.
When I switch to the input, let it settle then wake the Fire TV, i get the menu screen.
Then I select a show on Netflix, press play, and I get a blank screen.
Seems its not playing well with the Fire TV. odd thing is, it worked yesterday.
Just checked - it will play 1080 from Netflix , but wont play anything in 4k.
I have to unplug the Fire TV to get it going again. Changing inputs on my processor and restarting wont fix it.
Is this because the rear input wont pass HDR?
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Panasonic UDP 700 & Vertex| Apple TV4k | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Sub Master/Slave |
AidenL is offline
post #9147 of 36767 Old 01-27-2017, 11:14 AM
dpippel's Avatar
Quoted: 325 Post(s)
Liked: 450
The HDMI input on the 203 currently has some issues (including audio sync) that are supposedly being worked on. Can't recall if it doesn't support 4K at all right now or if it's just HDR on the input that it doesn't like, but your best bet would be to avoid using it until Oppo releases a fix.
______________
LG OLED65E6P | Yamaha RX-A2080 | Oppo UDP-203 | Panasonic DP-UB820
My Media Collection
dpippel is offline
post #9148 of 36767 Old 01-27-2017, 11:16 AM
mel_in_az's Avatar
Quoted: 76 Post(s)
Liked: 82
Originally Posted by T-800 View Post
Hi Mel,
Oppo just sent me 36-0112b. Since I've installed it audio sync is fine and I haven't seen any dropped/frozen frames on 3D. Watched a few movies straight through without issue. Hopefully they will distribute this beta widely. They told me it includes all the fixes in 1229. So good news on the 3D front.
Mel
mel_in_az is offline
post #9149 of 36767 Old 01-27-2017, 11:19 AM
Mikedit's Avatar
Quoted: 128 Post(s)
Liked: 92
The HDMI input does not support HDR.
Mikedit is offline
post #9150 of 36767 Old 01-27-2017, 11:20 AM
AidenL's Avatar
Quoted: 674 Post(s)
Liked: 310
Yes, I'm thinking that - but I'm not even sure if thats the issue - the HDR flag isn't showing on the shows, but the 4k flag is.
So Im uncertain if thats the issue. I don't think all 4k Netflix shows are in HDR?
AidenL is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
