Official OPPO UDP-203 Owner's Thread - Page 387 - AVS Forum | Home Theater Discussions And Reviews
 278836Likes
post #11581 of 36769 Old 02-25-2017, 11:08 AM
ConnecTEDDD's Avatar
Quoted: 2921 Post(s)
Liked: 3569
Originally Posted by Bob Pariseau View Post
ConnecTEDDD,
It would also be helpful to re-check RBG Video Level using 12-bit output to see if the errors are math rounding due to the 8-bit limit.
--Bob
Hi Bob,
I will check it out next time
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #11582 of 36769 Old 02-25-2017, 11:15 AM
Liked: 3569
Originally Posted by KMFDMvsEnya View Post
Thanks for checking this out. If you get the opportunity to test RGB PC Level 8bit that would be helpful as well.
In my case it bypasses the internal conversion of the VT60 and will simply passthrough RGB PC Levels. I may try out YCbCr 4:4:4.
Hi, I found no reason for that test, since content in Blu-ray will be always be Video/TV Legal Levels (RGB-Video / YCbCr), if I select to output RGB-PC, it will not reproduce the correct levels. It will be Ok only if you want to view pictures from USB (which are PC/Data levels.)
YCbCr is always Video Levels only.
post #11583 of 36769 Old 02-25-2017, 11:41 AM
Cal68's Avatar
Quoted: 346 Post(s)
Liked: 341
Originally Posted by chi_guy50 View Post
User experiences vary depending on a number of factors, not the least being type of PJ/display and setup configuration to include cabling. I have been using my UDP-203 for one month now and have had no significant issues. Like you, I was motivated to start watching UHD Blu-rays despite only having a 2K display by my desire for the immersive sound track sometimes reserved for the UHD Blu-ray release.
My new 4K/UHD display will be here shortly, but in the interim I appreciate having had the option to watch whichever version of a given title best suits my A/V needs.
I would encourage you to take the plunge with the reassurance of Oppo's 30-day (and sometimes thrice that if you run into operational problems) return policy.
Originally Posted by pbz06 View Post
Agreed. I was on the fence too, especially after reading this thread. But I made the plunge and everything has been smooth and working great. All my gear is current and running everything on Auto. I’ve had one hard freeze and two instances of very quick stuttering (x-men apoc.), but every other movie (about 20 so far, both UHD and standard Blu-ray) has been flawless. I would recommend it, since you can always return it. I ended up selling my other player (Panasonic) since I was happy.
Originally Posted by gwsat View Post
My advice would be to avoid the 203 until you are ready to upgrade to a UHD HDR TV. There are many films on 1080p BDs that have Atmos soundtracks, although I admit, that many others offer it only on their UHD HDR disks. I should add that in recent weeks my 203 has been trouble free but all I use it for is to play UHD HDR disks, 1080p BDs, and DVDs. As you have no doubt already seen here, though, a lot of 203 owners are still experiencing problems.
Originally Posted by Carbo View Post
This is also the reason I am doing this, for Atmos/DTSX soundtracks. I have been holding off for the next gen of JVC 4k projectors. I will probably hold off till next years models. None of these projectors is ready for prime time yet, they all have some kind of deficiency. As far as the 203. I have watched about four movies so far on it. All down converted UHD with Atmos and didn't have any problems playing them(freezes or audio drop outs), but while the colors look good the Contrast/brightness levels are off and need some kind of adjustment compared to the Blu rays.
Thanks for the feedback guys, I appreciate your advice. Looks like the score is 3 to 1 in favor of my going ahead and getting the Oppo 203 now. I'm actually in the same boat as Carbo in that I too am waiting for the next gen of JVC 4K projectors to come out at a reasonable price. I think that I will probably wait for a few more months before taking the leap and purchasing the Oppo.
By the way, can I continue to use my current HDMI 1.4 cable to connect the Oppo 203 to my 1080 JVC projector? The cable runs through walls to my PJ, so if I need to change it out, then I'll need to factor that cost into the equation as well.
Cal68
Cal68
Cal68 is offline
post #11584 of 36769 Old 02-25-2017, 11:42 AM
Gooddoc's Avatar
Quoted: 3687 Post(s)
Liked: 3283
Originally Posted by Jeff Barthel View Post
Watched Hacksaw Ridge 4K last night. Played fine up until the layer change (~1h50m ~1h53m) where it paused momentarily. Then at around 1h56m or so, it stuttered and finally locked to where a power recycle was required.
After 2 months, I fall in to the category of owners whose experience has been far from glitch free. I don't think there has been an evening where I've used the player and haven't had some issue - lockup, freezing, audio stutters.
To be told the majority of issues are due to either a cable issue or a dirty disc seems to be the order of the day.
My expectation of playing a disc from start to finish problem free is not unreasonable as this is the intended use of the hardware. So far, my experience has been a disappointing/frustrating one. It reminds me of the release early, patch later mentality of the software industry.
On a positive note, I have to commend Oppo on the speed of the player. What loads almost instantly on the 203 takes 20-30 seconds on a Playstation 4 Pro drive. This was with the Band of Brothers blu-rays and Stalingrad 3D blu-ray, which now seems to play properly on the Oppo with the Feb 17 beta firmware.
Yeah, I'm patient, and have been a long time Oppo customer, but I've never had problems like this with any Oppo player. Very disappointing. With the frequency of problems, it's hard to believe these issues weren't ID'd prior to release.
Gooddoc is offline
post #11585 of 36769 Old 02-25-2017, 12:00 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 159
Had the same free on hacksaw as well. Movie was amazing though
Holiday121 is offline
post #11586 of 36769 Old 02-25-2017, 12:04 PM
Phil Tomaskovic's Avatar
Quoted: 212 Post(s)
Liked: 45
I thought the old iOS app should work with the 203? It says it can't find my player. Even when player is running ( as opposed to in standby ). I know there is a new media control app coming.
Phil Tomaskovic
Phil Tomaskovic is offline
post #11587 of 36769 Old 02-25-2017, 12:06 PM
Quoted: 212 Post(s)
Liked: 45
Has anyone traded in their old 103 to Amazon for a gift card? A couple days ago it was around $390 but down to $242 now. Was wondering if people were getting the full value offered or getting a lower offer due to wear or some other reason.
Phil Tomaskovic
post #11588 of 36769 Old 02-25-2017, 12:09 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4542 Post(s)
Liked: 4376
It sort of works if you enter the player's IP address manually. I tested this with the Android version but I think IOS is the same.
-Bill
gwsat likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #11589 of 36769 Old 02-25-2017, 12:17 PM
wl1
wl1's Avatar
Quoted: 415 Post(s)
Liked: 372
It does work, you just need to set the IP address manually. A case of making it static would make future connections easier too.
gwsat likes this.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #11590 of 36769 Old 02-25-2017, 12:31 PM
David Aiken's Avatar
Quoted: 815 Post(s)
Liked: 1466
Originally Posted by LDBaha View Post
So are you saying HDR is bad on your OLED? Is this because HDR allows for super bright colors and the OLEDs aren't as bright as other LCDs?
Sent from my Pixel using Tapatalk
No, I'm saying nothing like that at all. HDR is extremely good on my OLED and I'm very happy with the results I get. What I was saying was that the things that many people talk about when they talk about how great HDR is are not the things I appreciate about HDR. The things about HDR which make the difference for me are subtler and a lot less flashy than the highlights "eye candy" which seem to impress a lot of people.
richlife and captainbrent like this.
David Aiken is offline
post #11591 of 36769 Old 02-25-2017, 12:35 PM
Quoted: 212 Post(s)
Liked: 45
I tried manually using the IP address shown in Network Setup. It complains that the firmware is out of date which it isn't, and when I say don't ask me again it till doesn't connect.
Phil Tomaskovic
post #11592 of 36769 Old 02-25-2017, 12:46 PM
Ronman79's Avatar
Quoted: 300 Post(s)
Liked: 192
Originally Posted by Kewler View Post
I have owned the UDP-203 for three weeks now, but I watched my first UHD Blu-ray yesterday: I rented a copy...
Just curious as to where you rented the UHD disc.
Equipment List: Theater - JVC DLA-X770R / Denon X4300H / Panasonic 820 4K BD Player / Polk Audio RTiA9 Towers / Polk CSiA6 Center / Polk 65RT (6), FXi5 (2) Atmos and Surrounds / (4) Polk PSW505 12" Subs / Black Flame Painted Screen Wall / Nvidia Shield TV / Dish Hopper 3 - 4K/ XBOX One S / Harmony Elite / Echo Dot / Tripp Lite UPS Backup / Furman Conditioner / App and Tap controlled Philips Hue Lighting / Monoprice Cabling
Ronman79 is offline
post #11593 of 36769 Old 02-25-2017, 01:00 PM
wmcclain's Avatar
Liked: 4376
The 203 Media Control Apps should be out soon.
-Bill
AVGeek99 likes this.
post #11594 of 36769 Old 02-25-2017, 01:04 PM
Quoted: 20 Post(s)
http://www.superclub.videotron.com
Although only a 10-minute walk from my home, I emailed them just to be sure they had UHD BDs. There's was one UHD copy per title, all available.
Ronman79 likes this.
Kewler is offline
post #11595 of 36769 Old 02-25-2017, 01:08 PM
seainc's Avatar
Quoted: 12 Post(s)
Liked: 5
You can rent them here also, http://www.store-3d-blurayrental.com
seainc is offline
post #11596 of 36769 Old 02-25-2017, 01:16 PM
Quoted: 212 Post(s)
Liked: 45
Originally Posted by wmcclain View Post
The 203 apps should be out soon.
-Bill
Ok thanks. I shot Oppo support an email too in case something may be wrong with my unit.
Phil Tomaskovic
post #11597 of 36769 Old 02-25-2017, 01:18 PM
wl1
wl1's Avatar
Quoted: 415 Post(s)
Liked: 372
Delete
wl1 is offline
post #11598 of 36769 Old 02-25-2017, 01:19 PM
AVGeek99's Avatar
Quoted: 202 Post(s)
Liked: 142
-Bill
The Android version will connect via direct IP input as Bill suggests. You can browse your DLNA music, but when you go to play, it won't. That was my experience. I should note, that was on the 1229 FW. I haven't tried again on the new beta.
Sent from my HTC 10 using Tapatalk
Sony XBR-75X940D -- Marantz AV8802A -- Paradigm 30th Anniversary Tribute Towers -- Paradigm Studio v5 CC590 --
Paradigm Studio v5 ADP590 (4) surrounds -- Cambridge Audio Azure 840W for Front R&L -- Onkyo TX-NR906 for Center and all Surrounds :( but it works --
Oppo UDP-203 -- Roku Ultra -- DirecTv HR54 DVR
AVGeek99 is offline
post #11599 of 36769 Old 02-25-2017, 01:21 PM
wl1
wl1's Avatar
Quoted: 415 Post(s)
Liked: 372
Try post 5841.
https://www.avsforum.com/forum/149-bl...l#post49537177
And check IP Control is ON
wl1 is offline
post #11600 of 36769 Old 02-25-2017, 01:29 PM
AVGeek99's Avatar
Quoted: 202 Post(s)
Liked: 142
Jealous! My local rental shop closed first of the year. There's another one about 6 miles a way, but they are hit and miss with BRD. I'm sure they won't be doing UHD.
AVGeek99 is offline
post #11601 of 36769 Old 02-25-2017, 01:59 PM
gwsat's Avatar
Quoted: 4438 Post(s)
Liked: 5767
I tried my iOS app for the 103 with my 203 again a little while ago and it worked. The biggest glitch, which Bill McClain mentioned in an earlier post, is that you have to hit the "+" icon and bring up your IP address in order to connect. Because my 203 has a static IP address, this works satisfactorily. For those with dynamic IP's, though, I gather not so much.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB and Terra Server 24 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is offline
post #11602 of 36769 Old 02-25-2017, 02:09 PM
woofer's Avatar
Quoted: 1366 Post(s)
Liked: 2061
After having the Oppo 203 since its release in December, and also having the UB900 ...my preference is the UB900......BUT! i am still "trying" to make something of the Oppo.
Spent yesterday comparing images... the one thing that predominately stands out is the "excess" image "noise" with the Oppo pic. Using 4K UHD HDR Star trek Into Darkness. In the opening scene on Ch5 there is excessive background image noise . I have tried all manner of setting configs and it is still excessive.
Various other 4K UHD films have the same result.
The image "noise" is NOT present with the UB900.
When playing a STD Bluray , the Oppo does NOT have this noise issue, it is vary comparable to the UB900...the Oppo having slightly more saturated ,more colour depth......
STD Bluray with the Oppo i havant a problem with, the issue is when when playing 4K UHD,s ..
One thing i need to stress is that my viewing is done with a JVC DLAX9500 on a 143" Scope screen...... I also have a 65" OLED display for comparisons ...the problems with the image are quite apparent on the 143" Scope screen , BUT not so much on the small 65" OLED..
Does anyone have any "constructive" feedback relating to the image noise in the Oppo?
Trust me, just like everybody else i would like the Oppo to be the product every body wants it to be.
AVfile and Ronman79 like this.
woofer is online now
post #11603 of 36769 Old 02-25-2017, 02:15 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5784 Post(s)
Liked: 8258
^ Try sending 4K/24 4:2:2 12b video to the JVC, using a direct cable to it (not through an AVR or anything else).
Confirm that all Picture Adjustment settings in the OPPO are at their factory default (0) values, and that you are using HDR AUTO.
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #11604 of 36769 Old 02-25-2017, 02:17 PM
Quoted: 333 Post(s)
Liked: 136
my 203 has been pretty problem free ,until now i have the beta fw installed from like a week ago ,and the hdmi in on the oppo is messing up will not display a picture from the cable box ,only sound ,tested everything ,and it points at the oppo ,when i pull the power for like 10 sec the oppo starts working again .5 times it has happened in 1 week
Dave Scurrah is offline
post #11605 of 36769 Old 02-25-2017, 02:19 PM
gblaue's Avatar
Quoted: 14 Post(s)
Hi all, I just got my UDP-203 player and seem to be having a problem that I can't seem to figure out. I have no home screen. I put a movie in and it plays fine. I did a search and read that it may be my cables. I tried changing the the resolution. It worked one time. So I ordered new UHD 4K certified cables. No luck. No home screen. This is my set up.
Oppo UDP-203 --> 6ft Monoprice Certified Premium HDMI Cable --> Denon AVR-X4200W --> 10ft Monoprice Certified Premium HDMI cable --> through wall connector --> 50ft Monoprice Luxe Series CL3 Active High Speed cable --> though wall connector --> 6 ft Monoprive Certified Premium HDMI Cable --> Samsung SEK-3500 --> Samsung UN65HU9000
Any help would greatly be appreciated. My BDP-103 worked just fine.
HTR Samsung UN65HU9000 w/SEK-3500 Evolution upgrade Denon AVR-X4200 Oppo BDP-103 PS4 Mirage OM-5 OM-C2 OM-RM2 Omni-S12 Mirage Incognita
Living Room Samsung UN55JS8500 Bose Soundtouch 120
Bedroom Samsung LN55A950 Bose Solo
gblaue is offline
post #11606 of 36769 Old 02-25-2017, 02:22 PM
Read the FAQ!
Liked: 8258
^ Move the player close enough to the Display that you can connect it without going through the wall. If that fixes it I'd START by assuming your wall plates are the culprits.
--Bob
post #11607 of 36769 Old 02-25-2017, 02:25 PM
woofer's Avatar
Liked: 2061
^ Try sending 4K/24 4:2:2 12b video to the JVC.
Confirm that all Picture Adjustment settings in the OPPO are at their factory default (0) values.
--Bob
Hi Bob,
Yes done that .
I gather the "Sharpness" "Noise Reduction" features have NO effect when playing a 4K UHD?
Detail in the image is there, just excess "noise" for some reason?
Even on Pristine samples like The Martian, .........the scene where he is having a shave in front of the mirror before putting on the space suit before leaving Mars.....you can see the "noise" present ...it is NOT as apparent with the UB900 even if you deliberately add excess "enhancement" to the UB900,s image( which amplifies any noise) .
post #11608 of 36769 Old 02-25-2017, 02:28 PM
Read the FAQ!
Liked: 8258
Originally Posted by woofer View Post
Hi Bob,
Yes done that .
Set the OPPO to Custom > 1080p Auto. I'm betting you are seeing HDMI signal problems due to the bandwidth.
--Bob
post #11609 of 36769 Old 02-25-2017, 02:32 PM
woofer's Avatar
Liked: 2061
--Bob
I have various HDMI Cables... Audioquest Coffee , KORDZ EVS...these work "flawlessly" with the UB900 . ? Cables are 7mtr.
post #11610 of 36769 Old 02-25-2017, 02:34 PM
Read the FAQ!
Liked: 8258
^ Try the test and see if the noise goes away.
--Bob
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
