Official OPPO UDP-203 Owner's Thread - Page 753 - AVS Forum | Home Theater Discussions And Reviews
 279963Likes
post #22561 of 38237 Old 12-03-2017, 08:47 AM
AVfile's Avatar
Quoted: 359 Post(s)
Liked: 179
Jazzrock,
I won't pretend to know what algorithms Oppo uses to do the SDR conversion. The Target Luminance value is intended to match the max Luminance capability of your display, but with the use of HDR varying so wildly, it is better to set by eye. Squeezing the full dynamic range into the standard range requires a compromise. The setting allows you to shift the balance in favour of highlights (high number, less white crush, darker image) or lowlights (low number, more white crush, brighter image).
You are correct that the YCbCr setting that works best with your projector is what matters. This can be determined by using a 1080p chroma burst test pattern as found on the Spears & Munsil or other calibration discs.
I have 10-bit color selected but I don't think the Oppo uses Deep Color when converting from HDR so there is probably nothing to gain here. You can start with 8-bit and experiment.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #22562 of 38237 Old 12-03-2017, 08:50 AM
Superman23's Avatar
Quoted: 940 Post(s)
Liked: 380
Ok guys the lip sync issue of my Oppo’s 203 HDMI IN is worse after the latest firmware update. I have my Directv Genie 2 plugged into the oppo’s 203 hdmi in port. Then I have my oppo 203 going directly into my LG B6. Both cables are high speed 18gb certified hdmi cables too. I tried playing with the oppo’s AV/Sync options and I’ve tried every setting from -100 to +200 and nothing changes. So thinking about plugging my Genie 2 directly into the tv so I can get my lip sound back in sync. If I take my PS4 Pro out from the B6’s hdmi 3 port and plug that into the oppo hdmi in will create a response lag? Don’t care about lip sync cuz I won’t be watching movies on the PS4 Pro.....,just playing video games. Just don’t want any video game response lag. And the whole reason I’m using the oppo’s hdmi in is because the B6 only has 4 hdmi ports and I need a 5th one. Let me know what you guys think?
LG OLED 65B6P
Panasonic VIERA TC-P65VT30
OPPO UDP-203 4K Ultra HD Blu-Ray Player
Sony PlayStation 4 Pro
Nintendo Switch
Sony PlayStation 3
Superman23 is offline
post #22563 of 38237 Old 12-03-2017, 09:12 AM
RobDec's Avatar
Quoted: 181 Post(s)
Hi
Thank you Avfile and Spacedave! Can anyone explain what "HDMI In Specs" is and what it should be set to?
Thanks again
Rob
RobDec is offline
post #22564 of 38237 Old 12-03-2017, 09:29 AM
Quoted: 18 Post(s)
Liked: 3
Originally Posted by SeeMoreDigital View Post
What's the make and model number of your TV?
Is your Oppo directly connected to your TV or is it connected through a surround sound receiver?
If your Oppo is connected through a surround sound receiver, have you disabled the surround sound receivers post-processing features?
Sony kdl 40ex503. I have a dune hd max media player and ps4 that both play 1080p with perfect motion. Everything is plugged into a Denon avr2400 and the receiver goes to the tv. I have any upscaling feature switched off on the receiver. I might try connecting the player directly to the tv but I don't want to have to that because the tv is on the wall so the fewer cables going to it the better
Owenjohnston is offline
post #22565 of 38237 Old 12-03-2017, 10:20 AM
Quoted: 197 Post(s)
Liked: 301
Originally Posted by Owenjohnston View Post
I'm starting to get frustrated by the blurring motion issues with my 203.
This probably isn't a great deal of help to you, but I get absolutely no blurring or motion issues with my 203 via an Onkyo 555 AVR and into a Panasonic OLED.
Have you checked that you don't have any kind of noise reduction engaged in the Video Output Menu / Picture Adjustment sub-menu? It's right at the bottom of that section.
I wouldn't recommend using 60Hz output for 24P discs - just leave it in Auto.
I think you should definitely just try a direct connection to the TV, see if it makes any difference.
galonzo likes this.
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is offline
post #22566 of 38237 Old 12-03-2017, 11:13 AM
Quoted: 18 Post(s)
Liked: 3
Plugged the player directly into the tv and it was perfect, checked the amp settings and the pass through was set to auto, so I set it to bypass and hey presto it works! Feel stupid now though that it was such a small thing. Also there was no noise reduction or anything set on the oppo
Bob Pariseau and galonzo like this.
post #22567 of 38237 Old 12-03-2017, 11:17 AM
Quoted: 197 Post(s)
Liked: 301
Hoorah! All's well in the end, that's the important thing.
galonzo likes this.
post #22568 of 38237 Old 12-03-2017, 12:10 PM
chrisfsk's Avatar
Quoted: 107 Post(s)
Liked: 53
Who does the 4k upscale for the best result ? Oppo, AVR or TV ? I am watching about 80% of Blu-Ray and 20% of UHD disc.
I couldn't find an absolute answer from the forum, thank you in advance !!!
chrisfsk is offline
post #22569 of 38237 Old 12-03-2017, 12:22 PM
SeeMoreDigital's Avatar
Quoted: 1105 Post(s)
Liked: 936
E-x-c-e-l-l-e-n-t
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #22570 of 38237 Old 12-03-2017, 12:43 PM
Quoted: 108 Post(s)
Liked: 66
Originally Posted by AVfile View Post
Jazzrock,
Thanks for your reply. Very helpfull. I did experiment with the luminance and settled, for now at 500. The white crush can be a real killer.
I believe I’ll keep the bit color at automatic.
jazzrock is offline
post #22571 of 38237 Old 12-03-2017, 02:14 PM
kristoffer77's Avatar
Quoted: 84 Post(s)
Liked: 57
I can’t upgrade the fimware on my UDP 203. It says that it cannot connect to server even though I have a wifi connection that works.
kristoffer77 is offline
post #22572 of 38237 Old 12-03-2017, 02:43 PM
wxman's Avatar
Quoted: 5743 Post(s)
Liked: 4115
Originally Posted by Spidacat View Post
I was happy to see the new firmware since it finally addresses the black crush. Even though I'd have to go from memory, what's a good movie or scene to watch to look for the improvement? I'd assume a just plain dark movie (like Suicide Squad) wouldn't really show an improvement - that's what the target luminescence is for.
Star Trek Beyond opening scene is a good test.
galonzo and Spidacat like this.
wxman is online now
post #22573 of 38237 Old 12-03-2017, 02:45 PM
Jonas2's Avatar
Quoted: 3074 Post(s)
Liked: 2054
Although I have no empirical way to prove it, I believe the Oppo in my case just slightly bests my Sony X930D at upscaling, but not by much. This was with a standard DVD. 1080p Bluray, seems to be more of a tossup.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #22574 of 38237 Old 12-03-2017, 03:22 PM
genegold's Avatar
Quoted: 68 Post(s)
I'm running the 203 to a PS Audio DirectStream dac via the coax output, with HDMI Audio set to Off. I'm finding .dsf and most .dff files will play but there's no sound when SACD Output is set to DSF or Auto, only to PCM. Is that because I'm using the coax output?
genegold is offline
post #22575 of 38237 Old 12-03-2017, 04:10 PM
oldsteve's Avatar
Quoted: 293 Post(s)
Liked: 321
That's a known bug trying to upgrade from the latest beta to the official firmware. For some of us the only way to upgrade is to download the latest firmware to a USB stick. Oppo is aware of the problem.
galonzo and kristoffer77 like this.
Main 4K Setup: LG OLED55E6P, Oppo UDP-203, Denon AVR X-4500H,AudioSource 2 channel amp,(3) Hsu CCB-8 bookshelf speakers, (2) Hsu HB-1 speakers,(Monoprice Monolith 28" speaker stands, (4) Dayton Audio IO655B speakers, Hsu VTF-2 and VTF-3 subs, 10" Monolith THX sub, Roku Ultra, Amazon Fire TV4K, Monoprice premium certified HDMI cables
oldsteve is offline
post #22576 of 38237 Old 12-03-2017, 04:40 PM
robert9674's Avatar
Quoted: 1258 Post(s)
Liked: 792
Hi. Does the oppo 203 hdmi in input support HDR now? I know before it didn’t. Want to run my Apple 4K box through the oppo 203 and still get HDR
Sony A1E
Triton one
robert9674 is offline
post #22577 of 38237 Old 12-03-2017, 04:51 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5893 Post(s)
Liked: 8430
HDR10, yes. This is the most common form of HDR at the moment.
Dolby Vision HDR, no, at the moment.
--Bob
galonzo likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #22578 of 38237 Old 12-03-2017, 04:56 PM
Read the FAQ!
Liked: 8430
Set Standby Mode ENERGY EFFICIENT and turn the player Off and back On again. This does a complete reboot of the player.
Check Setup > Network Setup > Connection Test until you get a good result (indicating networking is live again after that reboot -- this could take a minute depending on your networking hardware).
Try your firmware update again. If you don't already have a firmware-available Notification showing on screen, you can check, manually in Setup > Device Setup > Firmware Update > From Network.
If this doesn't fix the problem for you, you can download the firmware for install from a USB stick. If you have a North America version of the OPPO 203, the download file and instructions are here:
http://www.oppodigital.com/blu-ray-u...e-54-1127.aspx
Or call OPPO Tech Support and they'll sort this out for you.
--Bob
kristoffer77 likes this.
post #22579 of 38237 Old 12-03-2017, 04:57 PM
Read the FAQ!
Liked: 8430
Yes.
--Bob
post #22580 of 38237 Old 12-03-2017, 05:03 PM
Read the FAQ!
Liked: 8430
Originally Posted by RobDec View Post
Hi
Thanks again
Rob
The HDMI Input of the 203 is capable of receiving signals that older HDMI hardware can not generate for output. During the HDMI handshake, the source device asks the OPPO what is OK to send. Some older devices froth at the mouth, gibber a bit, and fall over backwards when the full list of possibilities, in all its glory, is returned by the OPPO.
The HDMI In Specs prevents such drama by setting the OPPO to restrict what it says the HDMI Input can accept -- thus avoiding Future Shock in the source device.
Set HDMI In Specs to match the best type of output your source device is able to produce.
Keep in mind that SOME older source devices are well made, and will work perfectly well even though the OPPO says it can accept a whole host of formats the source device can not produce. So if you leave HDMI In Specs at the factory default (UHD HDR), you may have no problem at all.
But if you DO have a problem, reducing the HDMI In Specs to a lesser setting may keep your source device happier.
--Bob
gsr, Brandon B, dcbii and 2 others like this.
post #22581 of 38237 Old 12-03-2017, 05:14 PM
Spidacat's Avatar
Quoted: 317 Post(s)
Liked: 434
Thanks for the recommendation. I'll put in next chance I get.
Spidacat is offline
post #22582 of 38237 Old 12-03-2017, 05:54 PM
Sebring5's Avatar
Quoted: 342 Post(s)
Liked: 249
Almost a year now and no firmware updates to fix these issues as per Oppo's commitment to me:
No 1080i input.
Picture stutter if you hook up a U verse receiver set to Dolby 5.1 instead of stereo.
If you need 2 channel stereo output, you can only use analog outputs. No down mix for optical or coaxial output. Either that or use an external device to down mix to stereo.
Maybe someone at CES will have something better. Doubtful, but always a possibility.
Meridian Audio G65 Sound Processor/UHD 722 HDMI Audio Processor/M6 Active Speakers, Sony A1E 65" OLED 4k UHD, Apple TV, Sony UBP-X1100ES
Sebring5 is offline
post #22583 of 38237 Old 12-03-2017, 07:27 PM
Superman23's Avatar
Quoted: 940 Post(s)
Liked: 380
Anyone?
LG OLED 65B6P
Nintendo Switch
Sony PlayStation 3
post #22584 of 38237 Old 12-03-2017, 07:38 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4763 Post(s)
Liked: 4680
Anyone?
Have you tried the different Device Setup -> HDMI IN Specs values?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #22585 of 38237 Old 12-03-2017, 07:58 PM
Superman23's Avatar
Quoted: 940 Post(s)
Liked: 380
-Bill
Thanks Bill. I’m in there right now and HDMI IN Specs option are 1080p, UHD 24hz, UHD and UHD hdr. Doesn’t have anything in there for audio video lip sync?
LG OLED 65B6P
Nintendo Switch
Sony PlayStation 3
post #22586 of 38237 Old 12-03-2017, 09:38 PM
Quoted: 84 Post(s)
Liked: 57
Ok, but I am only on the official firmware, not the beta.
post #22587 of 38237 Old 12-04-2017, 03:57 AM
Quoted: 84 Post(s)
Liked: 57
On a side note, I have messed around with output settings and for me 4:2:2 works the best. 4:4:4 seemed too unstable with my LG B6.
post #22588 of 38237 Old 12-04-2017, 04:54 AM
wmcclain's Avatar
Liked: 4680
I would try the variations to see if they make a difference. If not: sorry.
-Bill
wmcclain is offline
post #22589 of 38237 Old 12-04-2017, 07:36 AM
Superman23's Avatar
Quoted: 940 Post(s)
Liked: 380
-Bill
Ok I’ll give it a shot tonight. Never know right? Thank you Bill!
LG OLED 65B6P
Nintendo Switch
Sony PlayStation 3
post #22590 of 38237 Old 12-04-2017, 08:09 AM
claudiuangelo's Avatar
Liked: 7
Hello, guys its possible to play bluray folder or iso?
claudiuangelo is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
