Official OPPO UDP-203 Owner's Thread - Page 786 - AVS Forum | Home Theater Discussions And Reviews
 279920Likes
post #23551 of 38184 Old 01-05-2018, 12:30 AM
jong1's Avatar
Quoted: 528 Post(s)
Liked: 523
There's not much this thread can do to help with these reports. There is no general problem with Dunkirk, or any other disc. If a disc doesn't play, get it replaced. If you seem to have an abnormal number of discs that do not work, try playing one of them in another Oppo, e.g. in store, and if, after all that, you think your player may be faulty, raise the problem with Oppo Support.
galonzo, FQs19 and Maddog56 like this.
jong1 is offline
post #23552 of 38184 Old 01-05-2018, 04:05 AM
riddle's Avatar
Quoted: 184 Post(s)
Liked: 92
Hi
does eny know know if this is important for bether qualit?
Power supply board module for OPPO player UDP-203
thanks
riddle is offline
post #23553 of 38184 Old 01-05-2018, 04:15 AM
jong1's Avatar
Quoted: 528 Post(s)
Liked: 523
Unless you are a big fan of snake-oil I would say no! Go for a 205 if you want a noticeable step up in audio quality.
But you might find these interesting (if mostly referring to the 103/5):
http://www.audiopraise.com/forum/read.php?8,830,830
http://www.modwright.com/blog/post.p...tes-for-103105
LG OLED65E6V, Yamaha RX-A3060 AVR, Oppo UDP-203 UHD Blu-ray player, Apple TV 4K, Sky Q 2TB, Chromecast Ultra
Home-built Ivy Bridge i5-3570K HTPC, 8GB RAM and Nvidia GTX1050 GPU with Plex and Jriver Media Centre,
Ruipro 15M Fiber HDMI cable, B&W FPM speakers, Logitech Harmony Ultimate intelligent remote.
jong1 is offline
post #23554 of 38184 Old 01-05-2018, 05:13 AM
Quoted: 286 Post(s)
Liked: 198
Originally Posted by brentsg View Post
My Dunkirk locks up at 23:18 and resumes like 20-30 seconds later, clean disk... updated firmware.
And again at 1:23:03.
Watched my 4K disc several times now with no problem. Maybe you have a bad one?
Spoiler!
RetiredandLovingIt is offline
post #23555 of 38184 Old 01-05-2018, 05:21 AM
geebo's Avatar
Quoted: 74 Post(s)
Liked: 38
Dunkirk played flawlessly for me. Looked awesome in DV, too.
galonzo likes this.
geebo is offline
post #23556 of 38184 Old 01-05-2018, 05:22 AM
.NET Solution Architect
SoulOfUniverse's Avatar
Quoted: 664 Post(s)
Liked: 593
There was a good review by Vincent in regards to Oppo udp203 comparison with ub900, I have both and I prefer oppo due to its features, quality wise they are pretty much the same
Video: Synology 416Play NAS 24TB -> OPPO UDP-203 / Zidoo X9S / Nvidia Shield 4K -> Lumagen Radiance Pro 4444 -> SONY VPL-VW760ES -> Elite Screen 135'' 16:9 1.1 Max White;
Audio: DENON X3500H -> Dali Zensor 7.1 Dolby Atmos (7, 1, E12F, Vokal, Dolby Alteco C1)
SoulOfUniverse is offline
post #23557 of 38184 Old 01-05-2018, 06:02 AM
Liked: 0
Newbie Question: Oppo as a ATV4K processor
I did a search on this thread, so excuse me if this has been answered....
I am installing a new ATV4K and Oppo 203 to feed into a JVCRS520 projector...
Would I get better video processing utilizing ATV4K-> Oppo 203 HDMI Input -> Oppo 203 HDMI Output ->projector
or allow the ATV4K to feed projector directly?
flavorguydfr is offline
post #23558 of 38184 Old 01-05-2018, 06:43 AM
brentsg's Avatar
Quoted: 233 Post(s)
Liked: 320
Thanks for the feedback, will try another copy. It actually locks up the player in 2 spots..
hdfonz and RetiredandLovingIt like this.
Pioneer ELITE PRO-720HD | Pioneer PDP-5010FD | Sony XBR-55X850B | LG OLED55E6P
OPPO BDP-103 | OPPO UDP-203
PlayStation 4 Pro | Xbox One X
brentsg is offline
post #23559 of 38184 Old 01-05-2018, 07:03 AM
Greg TB's Avatar
Quoted: 47 Post(s)
Liked: 53
Originally Posted by JaremyP View Post
It's not a sync issue, it's no audio at all. It's not my files either. It's an issue posted about here for some time.
If you play an MKV with TrueHD/Atmos audio then try to play another file with another format, there's no audio. You have basically power cycle the player to reset the bug.
I've reported it to Oppo directly, which they acknowledged as a known issue.
I'm experiencing it more regularly now that I'm watching content again instead of just managing it. It's extra trouble for me given my setup and requires walking across my house and downstairs to manually reboot the player.
I've experienced this exact issue. A fix would be most welcome!
Greg
Greg TB is offline
post #23560 of 38184 Old 01-05-2018, 07:12 AM
Greg TB's Avatar
Quoted: 47 Post(s)
Liked: 53
I had a 4k Dunkirk that ALWAYS stopped at 2:40, then after several seconds would jump to 2:46 and continue playing. Cleaned it several times but no change. Amazon exchanged it with another disk, problem solved! The new disk runs perfectly.
hdfonz likes this.
Greg TB is offline
post #23561 of 38184 Old 01-05-2018, 07:49 AM
Quoted: 65 Post(s)
Liked: 179
The answer is “yes”. This is a highly subjective area to begin with, and “video processing” is an overly broad category. I’d be surprised if you got any answers other than “try it both ways and see what you like best”.
LG OLED 65C7P <- Oppo UDP-203 -> Denon AVR-X4300H; Dish Hopper; Apple TV 4K; Paradigm speakers
GordonBlu is offline
post #23562 of 38184 Old 01-05-2018, 08:06 AM
rolldog's Avatar
Quoted: 602 Post(s)
Liked: 204
Starting to use my Oppo more for network streaming of mkvs including uhd content now that I’ve done a lot of media prep work on my server. The mkv audio no sound issues are quite a hassle.
To top it off I use a Control4 system. So the Oppo is IP controlled. Have to have it in network standby power mode to turn on. Which doesn’t clear the no audio issue. And there’s no restart option through the settings. Argh.
Need new firmware and a fix for this ASAP.
I'm running a Control4 system as well, but all my inputs on my matrix are being used so my Oppo is setup locally in my media room. I know Chowmain makes a Control4 driver for the Oppo 203, which increases the functionality when running it through the Control4 system. I was considering removing my Roku from the matrix, plug it into the input of the Oppo, and then I could add it to the matrix, but yesterday I found out my matrix isn't handling audio correctly, so right now I'm waiting on a replacement for my Control4 matrix. Once I get this replaced, I might add the Oppo to my matrix since every TV in my house runs 4K HDR. I would love to be able to watch some of the new 4K Blu-rays I recently bought on all my TVs hooked up to the matrix so I can compare the video quality of each TV. After having my Control4 system installed, I don't think I could ever go back to not having one.
rolldog is offline
post #23563 of 38184 Old 01-05-2018, 08:52 AM
Alfredo_Vic's Avatar
Quoted: 33 Post(s)
Liked: 2
How good is the Oppo as a media player? Does is differ much from other alternatives qualitywise(for example nvidia shield)?
And how much better is Oppo vs PS4 as a bluray player? Is it night and day?
Alfredo_Vic is offline
post #23564 of 38184 Old 01-05-2018, 09:03 AM
groove93's Avatar
Quoted: 1231 Post(s)
Liked: 725
If content I want to view doesn't play properly on my Shield, you can bet the Oppo 203 will play it without sneezing.
The interface on the Oppo 203 is basic, but who cares, this thing is a beast!!
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is online now
post #23565 of 38184 Old 01-05-2018, 09:41 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4761 Post(s)
Liked: 4676
No. "Night and day" differences vanished years ago.
-Bill
Mike_WI likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #23566 of 38184 Old 01-05-2018, 09:54 AM
Quoted: 33 Post(s)
Liked: 2
Would you say there is any difference in PQ between these two?
-Bill
So you’ll say theres just minor difference in PQ?
post #23567 of 38184 Old 01-05-2018, 09:59 AM
groove93's Avatar
Liked: 725
My response was more about performance. I haven't noticed a "night and day" difference in Picture quality. My Shield is connected to the HDMI Input of the 203 so there are some picture adjustments between the 203 and my Sony X900e Display.
Sony XBR55X900E
XBox One X
post #23568 of 38184 Old 01-05-2018, 10:06 AM
wmcclain's Avatar
Liked: 4676
For Blu-ray: well, major and minor depend on how closely you look, but our advice for years has been not to swap out player hardware trying to improve picture quality. Calibration of your display is of vastly more importance.
-Bill
Ted99, groove93, Mike_WI and 1 others like this.
post #23569 of 38184 Old 01-05-2018, 11:23 AM
galonzo's Avatar
Quoted: 1470 Post(s)
Liked: 2012
Also worth mentioning, if you're looking to play 4K UHD disks, the PS4 cannot (neither can the PS4 PRO).
Main: UN78HU9000/SEK-3500 | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630)
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Heat (1995) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #23570 of 38184 Old 01-05-2018, 12:18 PM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
Where can you get a copy of Dunkirk with DV? I only see HDR10 listed for that title in the US release. Thanks.
StanGeek is offline
post #23571 of 38184 Old 01-05-2018, 12:18 PM
Quoted: 33 Post(s)
Liked: 2
@groove93
thanks for your input.
@wmcclain
Yeah I can understand that. I actually have calibrated my TV so maybe this player won’t do that much difference for PQ(for blurays). If I connect it through my reciever (Marantz Nr1607) I may don’t want any extra settings from the Oppo (”auto” on Oppo, let my reciever take care of upscaling for example), correct?
@galonzo
Yeah, thanks man, I’m aware.
BTW, I have all this questions to sort out if it’s worth buying the Oppo for me. It’s quite the price tag, when you obviously could by the Shield instead as a media player, and be happy with bluray on my PS4. But of course, UHD disc support would be very nice.
galonzo likes this.
post #23572 of 38184 Old 01-05-2018, 12:53 PM
lujan's Avatar
Quoted: 5035 Post(s)
Liked: 3049
You can only get Dunkirk in DV by buying the digital copy on Vudu or iTunes.
StanGeek likes this.
lujan
640 Ultra HD
730 HD
4 SD
lujan is online now
post #23573 of 38184 Old 01-05-2018, 01:06 PM
wmcclain's Avatar
Liked: 4676
You should try it yourself to see if you can detect a difference.
-Bill
post #23574 of 38184 Old 01-05-2018, 01:13 PM
bennutt's Avatar
Quoted: 255 Post(s)
Liked: 191
Hooked one of these up last night in the quest for Dolby Vision.
Worth it! - Now if only it would pass DV through that input for an app streamer like Apple 4K or Chromecast.
bennutt is offline
post #23575 of 38184 Old 01-05-2018, 01:25 PM
geebo's Avatar
Quoted: 74 Post(s)
Liked: 38
Sorry, I must have confused it with another DV release. At any rate it has incredibly good HDR video.
geebo is offline
post #23576 of 38184 Old 01-05-2018, 03:59 PM
ayrton's Avatar
Quoted: 72 Post(s)
Liked: 72
Reading specs and PS4 Pro does support 4K UHD HDR. https://www.playstation.com/en-us/explore/ps4-pro/
Nice Stuff!
ayrton is offline
post #23577 of 38184 Old 01-05-2018, 04:07 PM
chunon's Avatar
Quoted: 3927 Post(s)
Liked: 3944
That’s all related to gaming/streaming it does not play 4k Blu-ray Discs .
galonzo likes this.
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is offline
post #23578 of 38184 Old 01-05-2018, 04:09 PM
bbbobbb's Avatar
Quoted: 34 Post(s)
Liked: 36
Except for that pesky foonote # 4:
"4 Compatible 4K display required as well as subscription to 4K-compatible content streaming service. PS4 Pro does not support 4K Blu-ray Discs. PS4 Pro provides auto-upscaling for standard Blu-ray Discs."
galonzo and chunon like this.
bbbobbb is offline
post #23579 of 38184 Old 01-05-2018, 04:46 PM
zpeedster_m's Avatar
Quoted: 43 Post(s)
Liked: 38
Yeah Sony dropped the ball on their potential 4K Blu-ray player but many have said the X-box has it's own problems playing the discs, that's why I got my 1st Oppo.
galonzo likes this.
LG OLED65C6P - OPPO UDP-203 - Pioneer SC-1522K - Emotiva XPA-3 - Polk RTI12 & CSiA6 - SVS PB12-NSD - TiVo ota Roamio
zpeedster_m is offline
post #23580 of 38184 Old 01-05-2018, 08:22 PM
Moderator
rboster's Avatar
Quoted: 1720 Post(s)
Liked: 2510
My copy freezes at 31:50 mark...it's repeatable. Cleaned the disc and still have the freeze up. I have to stop the disc and restart on the next chapter...reverse the disc to the 32:00+ mark and restart.
rboster is online now
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
