Official OPPO UDP-203 Owner's Thread - Page 803 - AVS Forum | Home Theater Discussions And Reviews
 279630Likes
post #24061 of 37887 Old 01-21-2018, 03:10 AM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
Originally Posted by Sevastos View Post
Sevastos likes this.
jong1 is offline
post #24062 of 37887 Old 01-21-2018, 04:18 AM
glangford's Avatar
Quoted: 764 Post(s)
Liked: 681
Originally Posted by Schubeedoobee View Post
Thank you... while that is true, I noticed on all my discs the anomaly occurs at chapter 7 at about 59 minutes. This morning I had some success in cleaning the disc thoroughly and getting to play normally thru this section of the movie.
However, when I watch the bit rate on the fly it continues to drop drastically at chapter 7 interface from a normal 68-75mbs to 45-48mbs... still better than 0mbs
Blade Runner is the first disc where I've ever had a playback problem. About 1:10 and 1:13 and another spot a bit later and I didn't note the time. It froze momentarily for about 10 secs then powered on through. Weird. We continued to watch the movie. I cleaned the disc when I put it up and will try again later today to see if it plays normally.
Edit: Running it under hot water for a minute, drying then wiping with a lens cloth seemed to do the trick.
Supercharged Song Towers, Oppo BDP-203, Anthem MRX-520, LG B6 OLED
Headphone Rig: Oppo BDP-95, Burson Audio Soloist MKII Headphone amp/ Sennheiser HD800S, Sennheiser HD650
glangford is offline
post #24063 of 37887 Old 01-21-2018, 05:30 AM
tbuick6's Avatar
Quoted: 50 Post(s)
Originally Posted by ayrton View Post
My favorite features: It's an OPPO, plays everything I throw at it perfectly (including Blade Runner 2049 UHD), Will convert my concerts @ 60 fps to 30..
Great picture quality and the ability to strip metadata from HDR.
Add to that the exceptional 3D performance. Just watched Blade Runner 2049 3D Blu ray and it looks exceptional with absolutely no ghosting or other issues. Saw it in the Theatre (non 3D), on AppleTV in 4K HDR and now in 3D on Oppo. Can honestly say the 3D is my preferred presentation. Amazing depth that provides a fully immersive experience. Definitely one of the best 3D discs out there, and the Oppo plays it perfectly.
ayrton, galonzo, TomcatTLC and 1 others like this.
"To Live Outside The Law You Must Be Honest"
tbuick6 is offline
post #24064 of 37887 Old 01-21-2018, 09:53 AM
Postmoderndesign's Avatar
Quoted: 536 Post(s)
Liked: 316
Windows 10, smb the UDP-203 not working as network attached storage
My old windows 7 media center died and now I have a Kaby Lake computer on Windows 10. Sharing files from my computer to the UDP-203 used to be simple but I am completed flummoxed trying to share my new computer's media hard drive with UDP-203. So, what is the solution?
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Display: LG OLED 65e6p, Player: OPPO UDP-203, AVR:Yamaha TSR 7810, Streaming: Comcast 60Mbps RG6 to Cat6a, Speakers: Mains Vandersteen IIC, Center, Surrounds, Rears Klipsch
Postmoderndesign is online now
post #24065 of 37887 Old 01-21-2018, 09:57 AM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
Plex Media Server works well.
vfrbest, galonzo, azz7686 and 1 others like this.
jong1 is offline
post #24066 of 37887 Old 01-21-2018, 10:04 AM
robert9674's Avatar
Quoted: 1257 Post(s)
Liked: 792
I ordered the UK UHD DV version of blade runner 2049. I’m looking forward to seeing it. I have never watched this movie so it should be a treat. Does U.K. UHD digital codes be redeemed in the USA?
Sony A1E
Triton one
robert9674 is offline
post #24067 of 37887 Old 01-21-2018, 10:04 AM
Sammie2980's Avatar
Quoted: 242 Post(s)
Liked: 197
Thanks for all the feedback and suggestions guys. I cleaned the disc, firmware on E6 and MRX1120 is and initially was latest. Still same issue. I just find it odd that the movie is playing, audio is fine, my 5 other DV disc work without issue, and the picture can be seen if the movie is fast forwarded or rewound. Even all the warning etc play fine it is just when movie itself starts.
LivingRoom: LG OLED77C8P /Oppo UDP-203/Denon X8500H/SVS SB16 ULTRA/M5300-PM/Paradigm 85F, 45c, Mythos Gem XL x4, SVS Prime Elevation x4 /PS4 Pro/X1X/Switch/AppleTV 4K
Bedroom: LG OLED65E6P / Oppo BDP103D / AppleTV // Office: Sony 55A9F / X1X
ISF Level III Certified, CalMan VideoPro, ChromaPure, i1D3 Pro, i1Pro, C6 HDR 2000, VideoForge Pro, Murideo Six-G, Lightspace
Sammie2980 is offline
post #24068 of 37887 Old 01-21-2018, 10:13 AM
seoman27's Avatar
Quoted: 64 Post(s)
Liked: 8
why not go from the PC to the Oppo with HDMI ?
if you have a HDMI receiver go directly to that one.
I prefer the interface of windows above all TV-based/phone based media players.
And since you want to share the disks of that PC it needs to be ON anyways
seoman27 is offline
post #24069 of 37887 Old 01-21-2018, 10:37 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5849 Post(s)
Liked: 8354
Originally Posted by stevenjw View Post
Not sure if anyone from Oppo reads this thread or not. I guess I could send them an email too. A lot of folks have the Oppo 203 and a JVC projector and anyone who has a JVC knows, they're biggest con is the long sync times of around 15 seconds. These happen whenever switching between the Oppo main menu and an UHD. It would be helpful if the Oppo provided a persistent, selectable 4K24 4:2:0 BT.2020 option and screens in addition to the 4K60 BT.709 ones. Or make the Video Setup Menu options actually Force sending out signals at the selected values for the home screen; ex: HDR: On, Output Resolution: Custom - UHD 24Hz, Color Space: Auto. Either way would help eliminate a lot of delays on the JVC when using the Oppo.
Your best bet is to email your suggestion to OPPO Tech Support. Use the Email Us link on the Support page for the player. They’ll make sure it gets to the right people.
Keep in mind that some content can not be put out at /24, and that the player does not currently convert any BT.709 content to BT.2020.
—Bob
galonzo likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #24070 of 37887 Old 01-21-2018, 10:41 AM
captainrac's Avatar
Quoted: 39 Post(s)
Liked: 47
Originally Posted by rlb View Post
Dolby, not Sony, developed the "low latency" DV profile for Sony. Dolby, not Sony, failed to provide a concurrent capability for "streamers" and players. I seriously doubt that Sony has any requirement or is in any hurry for the Oppo update. Their own DV HDR player was demonstrated at CES (with a Sony Android) and will be released in a few months. Do you think it will support the "low latency" profile?
It certainly will. But we all love Oppo and don't want to be held hostage by Sony. And no one knows how well the streamer/player updates will perform.
captainrac is offline
post #24071 of 37887 Old 01-21-2018, 10:43 AM
Quoted: 197 Post(s)
Liked: 301
You may want to rethink that.
https://www.highdefdigest.com/news/s...-release/40527
dianebrat likes this.
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is offline
post #24072 of 37887 Old 01-21-2018, 10:53 AM
Quoted: 536 Post(s)
Liked: 316
Thanks for your response. I have run a premium hdmi cable from my computer graphics card to my LG Oled E6P HDMI #3 port and that does work with my trial version of DVDFab Player 5.
I had liked being able to use the UDP-203 network feature and found it adequate for full HD and convenient.
And I have never tried the plex media server though I did use media browser previously and found it time consuming to set up and then suddenly media browser could not play .iso files and I had to convert all my .iso files to mkv. So, I became wary of these front end consolidators with too little concern for their legacy users.
So, I guess I just going to have to pay the Windows 10 penalty and experiment with ways to get things done that I find best.
post #24073 of 37887 Old 01-21-2018, 11:02 AM
captainrac's Avatar
Quoted: 39 Post(s)
Liked: 47
General question here. For the best viewing experience with streaming apps its seems the way to go (maybe the only way to go) is to use the TV's native apps. All I'm interested in is Netflix, Hulu (Handmaid's Tale only, lol), and maybe Vudu (when they lower the UHD rental prices a bit).
With RokuUltra->Oppo:
No Atmos
No Dolby Vision
With ATV4K->Oppo:
No Atmos
Buggy Dolby Vision (graybars, forced HDR mode, no date on fix)
With Native Apps + ARC
Atmos
Dolby Vision
Miller Time
I bailed on Sony. C7 arriving next week. Can anyone share their experiences with Native Apps + ARC? I've heard some chatter about audio sync issues. Sorry if this is slightly off topic. Thanks in Advance.
post #24074 of 37887 Old 01-21-2018, 11:07 AM
robert9674's Avatar
Liked: 792
Originally Posted by steverobertsbbc View Post
Wow ok thanks you just saved me 40$ .
Sony A1E
Triton one
post #24075 of 37887 Old 01-21-2018, 11:13 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
I'm wondering how much Sonys lack of DV support has to do with them removing it, cuz it's listed on Dolbys site as having it..
Nahhh, that couldn't be it ..Oppo can play it...on an LG...
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #24076 of 37887 Old 01-21-2018, 12:06 PM
rdgrimes's Avatar
Quoted: 3970 Post(s)
Liked: 3240
Discussed multiple times in this thread, do a search for specifics. But the gist of it is that Windoz10 disables SMB 1.0 (or whatever it is) by default, so you have to turn it back on. Microsoft is protecting you from your "insecure" HT connections.
rdgrimes is offline
post #24077 of 37887 Old 01-21-2018, 12:09 PM
bguzman's Avatar
Quoted: 162 Post(s)
Liked: 1034
No Atmos
No Dolby Vision
With ATV4K->Oppo:
No Atmos
Atmos
Dolby Vision
Miller Time
TCL 55P605 w/Roku TV Native Apps + ARC
Dolby Vision
Atmos
HT TCL 55P605, BenQ W7000, Pioneer UDP LX500, Panasonic LX1000, Firestick 4K, ATV4K, Pioneer SC-LX 701, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Pioneer UDP LX500, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is offline
post #24078 of 37887 Old 01-21-2018, 12:32 PM
tomhorsley's Avatar
Quoted: 259 Post(s)
Liked: 218
Or you could install a DLNA server on your PC and bypass all the smb stuff. There is a pointer to an oppo recommended DLNA server for windows on the oppo website. I use minidlna on my linux server and it works great.
galonzo likes this.
tomhorsley is offline
post #24079 of 37887 Old 01-21-2018, 12:38 PM
Quoted: 536 Post(s)
Liked: 316
Yes, that is what I am looking for-directions on how to turn on SMB (possibly v3) in Windows 10. And do I have to do a registry edit? And does the Oppo UDB-203 work with SMBv3?
post #24080 of 37887 Old 01-21-2018, 12:48 PM
JazzGuyy's Avatar
Quoted: 435 Post(s)
Liked: 444
SMB1 (which the Oppo uses) was disabled by default in Windows 10. Do a search of this thread for Windows 10 and you will find several posts on how to re-enable it.
JazzGuyy is offline
post #24081 of 37887 Old 01-21-2018, 12:57 PM
Quoted: 536 Post(s)
Liked: 316
Thanks for the DLNA advice. Is this what you are suggesting? http://www.oppodigital.com/KnowledgeBase.aspx?KBID=4
post #24082 of 37887 Old 01-21-2018, 12:59 PM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
Why not try Plex Server? It's free, quick to install, really very easy to set up and then a better way of browsing media than SMB.
jong1 is offline
post #24083 of 37887 Old 01-21-2018, 01:05 PM
seoman27's Avatar
Quoted: 64 Post(s)
Liked: 8
Then the question rises
what is DLNA capable of feeding your oppo.
Tried to find an answer but could not find it.
But with SMB you're 100% sure it is not transcoded.
So your multichannel flac file is played as is.
You just give the oppo the means to acces the data.
I find DLNA sluggish.
My music is stored by a logical structure so i don't need a database to find an artist.
for me there is no reason to use DLNA and because i don't know how it works i prefer not to use it.
seoman27 is offline
post #24084 of 37887 Old 01-21-2018, 01:21 PM
SeeMoreDigital's Avatar
Quoted: 1073 Post(s)
Liked: 878
I find DLNA sluggish. My music is stored by a logical structure so i don't need a database to find an artist. for me there is no reason to use DLNA and because i don't know how it works i prefer not to use it.
Most, if not all 'smart' TV's and 'smart' Blu-ray players from common branded manufacturers only support DLNA/UPnP...
Both DLNA/UPnP and SMB have their advantages and disadvantages. I use both...
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is online now
post #24085 of 37887 Old 01-21-2018, 01:54 PM
seoman27's Avatar
Quoted: 64 Post(s)
Liked: 8
That is the scary part!
What most manufacturers do is based on what most of the people seem to be wanting
And nobody seems to care about quality, just abundance.
So why should DLNA support 6channel pcm? Nobody uses it.
again i don't know what dlna is capable of and what not.
This thread is about a machine which is handling both.
What should we choose based on performance?
seoman27 is offline
post #24086 of 37887 Old 01-21-2018, 02:00 PM
stevenjw's Avatar
Quoted: 665 Post(s)
Liked: 899
—Bob
Thanks! I went ahead and did that right after previously posting. Hopefully, I'll hear something positive back. Not sure how hard it would be, but seems like they could include two sets of setup menu pages with the current set as default and an option to select the JVC friendly BT.2020 4K24 set for anyone wanting to use those instead. If they did, then I think anyone using an Oppo 203 with this new setting and a JVC projector for UHD playback could chose the correct userX option in the JVC (or let the Vertex do it) and eliminate some sync delays with the Oppo menus.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is online now
post #24087 of 37887 Old 01-21-2018, 02:08 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4720 Post(s)
Liked: 4596
As near as I can recall, container and codec support for SMB is the same as for local storage and uses the same interface, so it seems the most natural to me.
If you can get it to work. No trouble using Samba on linux here. All I know about Windows is how to swear at it.
With DLNA you are dependent on implementations that sometimes try to be too helpful, doing unneeded transcoding, or decidedly unhelpful by not allowing certain containers and codecs.
But there are minimalistic DLNA servers that work about the same as SMB: oShare for Windows is well-liked. I test with miniDLNA on linux.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #24088 of 37887 Old 01-21-2018, 02:19 PM
bodosom's Avatar
Quoted: 2315 Post(s)
Liked: 1832
Slow handshake with Denon+LG
Is a 6-7 sec. handshake expected for UHD with colorspace options on AUTO? My other UHD devices are faster.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500H/LG C8
bodosom is offline
post #24089 of 37887 Old 01-21-2018, 02:42 PM
wmcclain's Avatar
Liked: 4596
That does seem long. What are your other video settings, particularly Output Resolution? What if you use specific values rather than AUTO?
-Bill
post #24090 of 37887 Old 01-21-2018, 02:52 PM
Quoted: 35 Post(s)
Liked: 6
-Bill
Sounds all interesting. What about a possibility for a MAC? At the moment I use my old time capsule with SMB runs fine, but no connection to my Mac via Network. Are there any experiences?
Regards
Erwin2017 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
