Official OPPO UDP-203 Owner's Thread - Page 829 - AVS Forum | Home Theater Discussions And Reviews
 280417Likes
post #24841 of 38834 Old 02-02-2018, 06:33 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5925 Post(s)
Liked: 8488
Originally Posted by rlb View Post
Good point; however you ignored my question in your haste to be clever. I wasn't throwing stones at OPPO. I was asking if anyone knew why Apple could implement "low latency" a couple weeks after Sony received the update; but OPPO (and yes Sony) would require several months.
Seriously? Anybody who really knows can't talk. So you are just stirring the pot.
And I'll have you know I never hasten to be clever. Nor am I slow. I am clever precisely as fast as I mean to be.
--Bob
dianebrat, muzz, Taxcheat and 13 others like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #24842 of 38834 Old 02-02-2018, 06:47 AM
tbass2k's Avatar
Quoted: 348 Post(s)
Liked: 406
Originally Posted by veger69 View Post
By file browser you mean the Network short cut at the bottom of the oppos screen?
Yes
Sent from my SM-N950U using Tapatalk
cTwining likes this.
tbass2k is offline
post #24843 of 38834 Old 02-02-2018, 07:04 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2165 Post(s)
Liked: 2729
Yes.
gsr is online now
post #24844 of 38834 Old 02-02-2018, 07:08 AM
muzz's Avatar
Quoted: 933 Post(s)
Liked: 647
--Bob
"Call me Forest Gump"...
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #24845 of 38834 Old 02-02-2018, 07:22 AM
tkusterb's Avatar
Quoted: 97 Post(s)
Liked: 98
Shouldn't that be "Forrest...Forrest Gump"?
muzz and galonzo like this.
tkusterb is offline
post #24846 of 38834 Old 02-02-2018, 07:31 AM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 231
It doesn't sound like anyone has found any bugs in the latest beta, right? I'm planning to load it tonight, but wanted to check in with the bleeding edgers here, first
Preamp/Amps: Anthem AVM60, Emotiva XPA-2, XPA-5, A-300
Speakers: (7.1.2): Klipsch Reference Premiere / Power Sound Audio S3000i sub
Video: LG OLED65B7A, Oppo UDP-203, Roku Premiere+, Nvidia Shield TV
Room: GIK Acoustics treatments
MackGuyver is offline
post #24847 of 38834 Old 02-02-2018, 07:44 AM
rdgrimes's Avatar
Quoted: 4096 Post(s)
Liked: 3408
Originally Posted by tswire View Post
Multisystem-electronics.com was the vendor on Amazon.
Thanks for your help. If it doesn't help then I will return and by local (found a place with unmodded version)
No offense intended, but you got taken for a ride on that deal. The player has no warranty from Oppo for starters, but mainly they seriously gouged you and did nothing but install hacked firmware.
These guys are trusted, and also sell a simple hardware mod kit that you can easily install yourself. The Oppo warranty is not effected by the presence of a hardware mod.
https://www.ebay.com/itm/OPPO-DIGITA...sAAOSwE0JY-0-B
rdgrimes is offline
post #24848 of 38834 Old 02-02-2018, 07:49 AM
galonzo's Avatar
Quoted: 1552 Post(s)
Liked: 2165
Originally Posted by cmdrdredd View Post
Thanks, though I have read in the previous pages about certain issues popping up but no real mention of what they are, unless I missed it. People asking to roll back etc. I'm getting my unit on saturday so I was just curious as to what firmware to update to when it arrives. If you are pretty confident in the beta I may give it a go.
Welcome to the party! I only use this player for UHD disk playback and streaming HDR via the HDMI input (Roku Premier Plus, so that all HDR is on one input on my display), so I can't comment on any issues with network playback that has some wanting to know about rolling back their firmware to the last official (which used to be possible, but not any more). I will say, the notes for the beta claims to have a fix for the BR2049 UHD disk, but on the last official (54-1127, which is what your player will prompt you to update to via network once you have it connected), I was able to play through from beginning to end without issue. Also, I've been keeping a running list of UHD disks that I haven't had any issues with since I got my player in Dec. 2016, FYI.
Originally Posted by biliam1982 View Post
I first checked the Roku settings. It was reset to Auto detect for the screen resolution. So I tried UHD HDR but it said it was not supported. But, I could force the Roku to output that so I did. Went through a bunch of shows/movies that were supposed to be in HDR on Netflix and Amazon. None worked. Both showed input and output to be:
Resolution: 3840x2160
Frame Rate: 60p
HDR Format: SDR
Color Space: BT709 YCbCr 4:2:2 12bit
So it appears it isn't working. I'm thinking now I should report this to Oppo directly unless anyone else has more suggestions?
You should reomve power from the Roku and change the 203 to System>>Input>>UHD HDR, then power the Roku up and try HDR again
Also, if this issue ever does get fixed, doe the HDR Off/BT2020 tone mapping work for the HDMI Input, or is it just for UHD Discs?
It is already fixed (it works fine here), and like @stevenjw already mentioned, the HDR Off/BT2020 tone mapping does also work for the HDMI input.
So what is the point of it? Try to use the native refresh rate of the content being played? Do it actually give you 24Hz native content when playing something on Netflix, Amazon, etc, once you get through all the constant changes and actually start watching something?
This setting is not quite 100% yet, but yes, when it does work, you can get the native refresh rate of the show/movie (as mentioned, navigating Netflix with it set to ON isn't the easiest, but with a little patience, it can be done); so I leave it set to OFF and have a pretty stable experience with the Roku going into the HDMI input of the 203.
biliam1982 likes this.
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield Pro | PS4 Pro | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K | Roku P+ (4630)
FS - Dr. Strangelove (1964) and other UHD Digital codes (and some HD codes)
galonzo is online now
post #24849 of 38834 Old 02-02-2018, 07:51 AM
Quoted: 303 Post(s)
Liked: 74
Non taken!!!! I will be working with Amazon to return. Local guy has them and is an official OPPO Digital dealer (straight from their website). Also $300 cheaper.
tswire is offline
post #24850 of 38834 Old 02-02-2018, 07:51 AM
rlb
rlb's Avatar
Quoted: 2290 Post(s)
Liked: 1936
--Bob
gsr did provide a thoughtful answer; for which I expressed my appreciation. Finally, you were not clever; you were merely rude.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770, Harmony Elite
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, FireTV Stick 4K, and Nvidia Shield TV Pro
rlb is offline
post #24851 of 38834 Old 02-02-2018, 08:01 AM
gwsat's Avatar
Quoted: 4558 Post(s)
Liked: 6073
You are criticizing the wrong guy in this thread. @Bob Pariseau has been the most generous poster to this thread by far and perhaps its most knowledgeable. You on the other hand . . . Think about it.
gsr, dcbii, A.Bell and 20 others like this.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB and Terra Server 24 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+; Apple TV 4K
gwsat is offline
post #24852 of 38834 Old 02-02-2018, 08:16 AM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 197
Originally Posted by sddawson View Post
If I just pass BT2020 SDR to the likes of an X500 then (with a BT2020 colour space loaded and selected), does the DI function?
Yes
Purple X is offline
post #24853 of 38834 Old 02-02-2018, 08:17 AM
lujan's Avatar
Quoted: 5206 Post(s)
Liked: 3219
Originally Posted by vantage78 View Post
Yup. I had already contacted Oppo support about this bug. Do you see the behavior in Mode 4? I'm curious, as I don't....
If we want to leave it as it was before the latest beta firmware, do we leave it at Mode 1 which seems to be the default?
lujan
695 Ultra HD
737 HD
4 SD
lujan is online now
post #24854 of 38834 Old 02-02-2018, 08:19 AM
cmdrdredd's Avatar
Quoted: 4262 Post(s)
Liked: 4574
Awesome, thanks a bunch for that. I use an Nvidia shield for all my network playback. I have about 30TB of UHD and 1080p disc rips on my NAS drives. Is there any benefit to connecting the shield to the oppo HDMI in Vs just going directly to the AVR? Is there any advanced playback information available when connecting through the oppo and will it retail full functionality like lossless audio and hdr?
Additionally is there any benefit to using the oppo for network playback over the shield itself?
galonzo likes this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #24855 of 38834 Old 02-02-2018, 08:40 AM
Read the FAQ!
Liked: 8488
I believe Mode 1 is closest -- possibly Mode 2 -- but I don't think any of the settings actually duplicate the prior HDR to SDR algorithm.
In addition, I think you should expect to revisit your choice of Target Luminance setting. In my testing, I had to raise Target Luminance to match what I was getting before. (Was 150 nits. Now my preference is Mode 2 and 250 nits. This is testing into an LG E6 OLED panel, which of course doesn't actually need HDR to SDR conversion in the player.)
--Bob
post #24856 of 38834 Old 02-02-2018, 08:46 AM
captainrac's Avatar
Quoted: 39 Post(s)
Liked: 47
Nvidia->AVR would seem like the way to go, assuming you have ample HDMI connections on the AVR. Less risk of any pass-through issues since there are less boxes in the chain. Also you would still have the HDMI-in port available on the Oppo, should you need it.
Just my 2 pesos, amigo.
galonzo and SinGA like this.
captainrac is offline
post #24857 of 38834 Old 02-02-2018, 08:51 AM
pkeegan's Avatar
Quoted: 163 Post(s)
Liked: 216
So not a happy camper this morning. I tried all the things many of you posted to get the Public Beta onto my Region Free OPPO. I used a different USB, burned a disk image (iso) to DVD, tried all the USB inputs and nothing. So then I ventured down the setting the region to A path (instructions were included by the vendor) which told me to simply push 1 on the remote at the home screen after it boots up. I did that. Nothing.
I am fairly confident it's an NA based unit since when I did the official over network update, I have the NA version of firmware that updated.
So I can only assume that the vendor software hack for region free is preventing this and am not happy. Going to return and buy somewhere else. Still trying to work with vendor to see if there is a solution but so far not so good.
I believe the region free mod does prevent you from upgrading via usb as it utilizes a usb port and Oppo doesn't like having more than the one usb with the beta active during upgrade or any disc in the tray. I too have a region free mod. When Oppo releases the non beta your unit will update fine over ethernet (My did on the last go round).
Sony XBR55A1E
pkeegan is offline
post #24858 of 38834 Old 02-02-2018, 09:06 AM
galonzo's Avatar
Liked: 2165
I agree with @captainrac , however, yes, there is advanced media info and playback information on the HDMI input with the latest beta; you get limited info with the latest official firmware.
post #24859 of 38834 Old 02-02-2018, 09:28 AM
nathan_h's Avatar
Quoted: 3038 Post(s)
Liked: 2129
He didn't buy a USB or other hardware region free mod.
He bought a player with a software "mod".
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is offline
post #24860 of 38834 Old 02-02-2018, 09:28 AM
bodosom's Avatar
Quoted: 2498 Post(s)
Liked: 1977
There's a class of things that senior participants don't like to discuss and they can get snarky about it. If you'd like to speculate about why the ATV4K is the only device you can buy today that is sending DV to Sony/DV use the ATV thread.
Of course I can be just as 'witty' as Bob Pariseau so it's not risk free.
nathan_h likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X4700H/LG C8
bodosom is offline
post #24861 of 38834 Old 02-02-2018, 09:31 AM
bodosom's Avatar
Liked: 1977
Originally Posted by stevenjw View Post
I think the Vertex isn't reporting audio correctly on the OSD.
This is correct.
bodosom is offline
post #24862 of 38834 Old 02-02-2018, 09:43 AM
moe80's Avatar
Quoted: 88 Post(s)
Liked: 34
--Bob
Hey Bob/Everyone, yet to install the new beta firmware. Hopefully tonight.
So are we forced to select one of the new 4 options, or can we not select anything and leave it as it was prior to the firmware ?
Also, my JVC RS540 currently auto detects when I'm playing a 4K HDR disc and switches to HDR mode.
For the JVC users, what will the projector auto detect now if one uses 1 of the 4 new tone mapping options?
Thanks everyone,
CineMoe 3.0 Atmos 9.2.4
JVC RS540 | EluneVision Reference 4K Audioweave 150" 2.35:1 | Anthem MRX-1120 | Emo BasX A-150 | OPPO UDP-203 | Definitive Tech BP8060ST, CS8060HD, 4x SR8040BP, 2x SR9080BP, 4x Atmos DI 6.5R | Dual HSU VTF-3 MK5 subs | Ultralink HDC-150RM power conditioner | Harmony Elite | 8x Sonos Connect Amps| Monoprice 12AWG speakerwire, certified HDR HDMI |
moe80 is offline
post #24863 of 38834 Old 02-02-2018, 09:48 AM
Read the FAQ!
Liked: 8488
Thanks everyone,
If you don't change anything your settings after the install will be HDR to SDR Conversion Mode 1 along with your prior Target Luminance setting.
But keep in mind, the 4 conversion modes only apply if you have selected to use HDR to SDR conversion. If you leave HDR at AUTO (the default setting) and your projector says it is able to accept HDR, then you get HDR, and the Conversion Mode choice and Target Luminance setting are simply ignored.
--Bob
galonzo likes this.
post #24864 of 38834 Old 02-02-2018, 09:49 AM
Read the FAQ!
Liked: 8488
^ Answered after your first post of this question just above.
--Bob
post #24865 of 38834 Old 02-02-2018, 09:51 AM
moe80's Avatar
Quoted: 88 Post(s)
Liked: 34
--Bob
Sorry Bob, a small glitch and it said the post wasn't complete. Noticed it did go through and deleted the 2nd duplicate.
moe80 is offline
post #24866 of 38834 Old 02-02-2018, 09:52 AM
Read the FAQ!
Liked: 8488
Oh heavens, we haven't reached snarky yet.
Beta Testers are under non-disclosure. Which means we can't discuss stuff in progress until OPPO starts discussing it.
--Bob
muzz likes this.
post #24867 of 38834 Old 02-02-2018, 09:54 AM
moe80's Avatar
Quoted: 88 Post(s)
Liked: 34
--Bob
Thank you sir!
moe80 is offline
post #24868 of 38834 Old 02-02-2018, 10:01 AM
Quoted: 34 Post(s)
Liked: 9
--Bob
Fantastic statement!
Drelldrell is offline
post #24869 of 38834 Old 02-02-2018, 10:02 AM
Nalleh's Avatar
Quoted: 3290 Post(s)
Liked: 5115
Received my 203 yesterday. Installed the new firmware from USB, no problems. And i believe i found my new favourite picture
Using HDR off(BT2020), target luminance 300, and mode 2 with the RS600 at BT2020 and gamma 2.4, it’s the best picture i have seen yet. The prevous custom curve just seem dark in comparison. And so easy to tweak the OPPO settings. Good times
muzz, galonzo, asharma and 1 others like this.
Dual AVR 13.1.8 SWAtmos - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI18" - 12x12" w/6xSLAPS M12 VNF - 4x12"HB+2x18"CLHB - 6x Crowsons - 4xBK-LFE - 2x12"BB - 2x "4DX" fans- 6xNU6K - Minidsp 10x10HD-Vertex2-Oppo UDP203-XB1X-ATV4K-JVC RS600-Dreamscreen V2 120"-Samsung QE82Q60.
>>>>Nalleh’s HT<<<<
Nalleh is online now
post #24870 of 38834 Old 02-02-2018, 10:15 AM
veger69's Avatar
Quoted: 302 Post(s)
Liked: 47
Originally Posted by gsr View Post
If you have the folder structure setup correctly, as soon as you select the AVCHD folder in the Oppo's file browser, the movie will start up as if you had put the disc into the disc tray.
For it to work, you need to do the following:
1) Rip the movie with software that decrypts the movie, such as AnyDVD HD or MakeMKV to a BDMV folder structure.
2) For regular Blurays, you need to run the bdmv modifier utility to make a tweak to the structure so it will play. This can be found with a Google search for "bdmv modifier 2.0". This isn't needed for UHD Bluray rips.
3) If playing over a network share (SMB or NFS shares), place the ripped folder structure inside a folder named "AVCHD". So you'll end up with a share path something like: \\ServerName\Movies\MovieName\AVCHD\BDMV. If playing via a drive connected to a USB port, this step isn't required.
4) Now go into the Oppo's file browser and navigate to the location of the movie. If you've done the previous steps correctly, the movie will start playing as soon as you navigate into the AVHD folder.
Hmm my folder structure is correct. I placed it in AVCHD folder. Once I select the AVCHD folder it just takes me to the BDVM and certificate folders. From there I usually navigate to the stream folder, but now once I select the BDVM folder it’s empty? Could it be that it’s not unencrypted?
7.2.4 Anthem AVM60
Marantz MM9000, MM7055, Odyssey Stratos Stereo Extreme amps
Revel F52's and C52 center (4)M106 surrounds (4) C763L ceiling
Zappiti One HDR 4K, OPPO UDP-203
veger69 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
