Official OPPO UDP-203 Owner's Thread - Page 889 - AVS Forum | Home Theater Discussions And Reviews
 279158Likes
post #26641 of 37235 Old 03-08-2018, 05:52 PM
sikclown's Avatar
Quoted: 1681 Post(s)
Liked: 832
Originally Posted by ntxoa View Post
When I go to Oppo203 properties, Spatial Sound tab, I can select Dolby Atmos for home theater.
But when I click on Apply, I get an error message saying “Spatial sound isn’t working. Something went wrong while trying to turn on spatial sound.” And Spatial Sound stays off.
In Configure, I can select from Stereo, 5.1, and 7.1. But after that, I still can’t select/enable Atmos.
Are you using PC Atmos for games and/or upscaling?
Does Oppo Info show MLP/DD+ audio input and bitstream output when Atmos is active on your PC?
Mine stays on LPCM input and output, with no Atmos.
Hmmmm I wonder what is going on there. I don't check the Oppo info but my Denon switches to Dolby Atmos. What is your Oppo connected to for sound? I will check Oppo info when I get a chance to see what it says. I am not using this PC for gaming at all, must ISO playback, Kodi, and a few other things.
LG OLED 65C7P, Denon AVR-X7200WA, Apple 4K, Oppo UDP-203, PS4, Xbox One X
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
LG OLED 55C8PUA, Denon x4400h, Apple TV 4K, Panasonic DP-UB820,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #26642 of 37235 Old 03-08-2018, 06:00 PM
tassop's Avatar
Quoted: 102 Post(s)
Liked: 105
Originally Posted by boeingdriver View Post
Which FW version have you tried it with? Is it the lastest main version 56-0224?
https://www.avsforum.com/forum/attach...372484&thumb=1
boeingdriver likes this.
tassop is offline
post #26643 of 37235 Old 03-08-2018, 06:21 PM
tassop's Avatar
Quoted: 102 Post(s)
Liked: 105
Originally Posted by riddle View Post
Hi, yes it is uhd content (mkv uhd remux) like i was posted here this media_info picture, i think somethink here is broken. "Strip Metadata" show all data correctly compare to fault conversion at HDR OFF BT.2020.
thanks
I have found that remux and other scaled down versions of UHD discs behave somewhat poorly when it comes to HDR. Either the metadata is being interfered with or it doesn't align with the underlying video content ( or both). I was able to get a good picture by adjusting the projector settings to Rec.709 colorspace in one case but it isn't always consistent, so experimentation with display settings is useful.
On the other hand UHD.iso's are amazing when played natively through the Oppo.
tassop is offline
post #26644 of 37235 Old 03-08-2018, 06:47 PM
Meetloaf13's Avatar
Quoted: 54 Post(s)
I have a problem, just updated to -0224. Ejected tray, Put a disk in tray, press eject button, tray closes, then tray opens back up.
Have tried this without a disk, tray won't stay closed.
I have tried using the remote.
I have power cycled.
I have put the disk in, let tray close, killed power with tray closed and then restored power and tray opens automatically.
Any ideas?
Sent from my Pixel XL using Tapatalk
Samsung JU7100 75" 4K | Denon x2300 | Oppo UDP-203 | Pioneer Andrew Jones 5.0.2 | Klipsch Sub-12HG
Meetloaf13 is offline
post #26645 of 37235 Old 03-08-2018, 06:57 PM
asharma's Avatar
Quoted: 1841 Post(s)
Liked: 579
I have a HiMedia Q10 Pro android streamer hooked up to the Oppo’s HDMI in...Q10 accesses NAS, Remux’s play flawlessly...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is offline
post #26646 of 37235 Old 03-08-2018, 07:05 PM
Quoted: 128 Post(s)
Liked: 84
Thanks for looking in to this.
Oppo connects to a Samsung HW-K950.
I use the PC for MKV playback with Kodi and MPC-HC. Atmos bitstream works fine with those, and doesn’t rely on the Dolby Access app.
If I try to play Atmos enabled games or do Atmos upmix through the Dolby Access app, I don’t get Atmos when going through the Oppo. Same stuff works fine when going direct to the Samsung, though.
Somehow the Oppo is telling the Dolby app to send LPCM instead of unprocessed bitstream.
Nvidia Shield - Zidoo X9S - HTPC/MPC-HC
Oppo 203 - Samsung HW-N950 - 7.2.4
LG 86UH9500
ntxoa is offline
post #26647 of 37235 Old 03-08-2018, 07:55 PM
marine92104's Avatar
Quoted: 306 Post(s)
Liked: 144
Dang. I wish I had known that. Is there anyway to downgrade from the official to the beta?
Can anyone else play a 4k .iso on the current official software?
I tried from a USB drive connected to the front of the player.
marine92104 is offline
post #26648 of 37235 Old 03-08-2018, 08:16 PM
tassop's Avatar
Quoted: 102 Post(s)
Liked: 105
Thanks Ash - I have tried with Dune 4k Solo via HDMI-in and couldn't get anywhere, but did get a good picture by playing through Oppo USB and tweaking PJ settings. On one occasion the PJ HDR colourspace setting was triggered when the signal was in fact Rec.709.
have you tried playing UHD MKV files into Oppo via USB?
tassop is offline
post #26649 of 37235 Old 03-08-2018, 08:32 PM
Sanjay's Avatar
Quoted: 147 Post(s)
Liked: 71
How does one play a 4K ISO with the Oppo?
Epson EH-TW8300 (5040UB); Elite Screen Saker 16x9 135" | Samsung 64F8500 Plasma TV
Oppo UDP-203 UHD Blu-ray (All) | Egreat A10 Media Player | Sony PS4 (A) | Sony PS3 (A)
Marantz AV8802A (Pre-Pro) | Emotiva XPA-7 (Power) | Denon AVR5800 (Power 4xHeight )
Paradigm Reference Studio 100 v2 | Paradigm Reference Prestige 55C | Tannoy Mercury M5 | SVS Ultra Bookshelf (Rear) | Community Pro CS8 (4xHeight) | Paradigm Reference Servo15
Sanjay is offline
post #26650 of 37235 Old 03-08-2018, 09:01 PM
Quoted: 306 Post(s)
Liked: 144
I tried a 4k .iso file thru a 2TB portable drive using the front USB in on the front panel of the Oppo 203 & it doesn’t see the 4k .iso file. It does see 4k MKV files but they don’t work very well as far as navigation goes.
How are you able to play a 4k .iso file? The only difference is I’m on the official firmware & it looks like you’re on the beta firmware.
post #26651 of 37235 Old 03-08-2018, 10:04 PM
bytor's Avatar
Quoted: 185 Post(s)
Liked: 78
Hi everyone, I have a question about the analog outs with this player. Does the DAC decode all of the codecs available on 4k blu rays or just certain ones? I thought I read somewhere it won't decode Dolby Atmos, so then would it just decode a core Dolby Digital signal or something higher bitrate than that?
My current receiver is a Harman Kardon AVR 430 which is pretty old and only handles Dolby Digital and DTS core, but I like it's sound with my Klipsch RF-35 surround setup. Would getting the Oppo 203 be a noticeable upgrade using it's analog outs or would I be better off saving some money and getting the Sony UBP-X700?
jong1 likes this.
bytor is offline
post #26652 of 37235 Old 03-09-2018, 01:13 AM
SeeMoreDigital's Avatar
Quoted: 1006 Post(s)
Liked: 770
As you guys may or may not know... The Oppo's do not (and never have) officially supported the playback of .ISO (image) files, using official software releases.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #26653 of 37235 Old 03-09-2018, 02:13 AM
tassop's Avatar
Quoted: 102 Post(s)
Liked: 105
It must be the Beta Firmware. I don't know if this will work with every Beta release but I just tried it while fiddling around. I wont be updating firmware anytime soon
tassop is offline
post #26654 of 37235 Old 03-09-2018, 03:26 AM
asharma's Avatar
Liked: 579
No I have not tried USB, as over the network has worked fine for me
asharma is offline
post #26655 of 37235 Old 03-09-2018, 03:38 AM
Deckard71's Avatar
Quoted: 376 Post(s)
Liked: 113
ISOs through Oppo? How?
Displays: LG 65C7V - Optoma HD20 - Panasonic 50PZ80 - Samsung 32C650 - LG M2380D
Speakers: Focal Aria 948- Focal Aria 906 - Focal CC900 - BK XLS200 MK2 - B&W CCM362
Electronics: Roksan K3 - Yamaha RX-A2070 - Oppo 203 - PS4 Pro
Deckard71 is offline
post #26656 of 37235 Old 03-09-2018, 04:54 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4642 Post(s)
Liked: 4492
Maybe you have to move to Australia.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #26657 of 37235 Old 03-09-2018, 05:27 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1936 Post(s)
Liked: 2321
But wouldn't that make the movies play backwards?
stevenjw, muzz, oldsteve and 3 others like this.
gsr is offline
post #26658 of 37235 Old 03-09-2018, 05:31 AM
Craig Mecak's Avatar
Quoted: 332 Post(s)
Liked: 258
Red face
Yes, but at least then the movie 'The Curious Case of Benjamin Button' would make sense.
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is online now
post #26659 of 37235 Old 03-09-2018, 05:32 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5833 Post(s)
Liked: 8309
Any ideas?
Get in touch with OPPO Tech Support. They’ll likely walk you through re-installing the firmware as a first step.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #26660 of 37235 Old 03-09-2018, 05:57 AM
Quoted: 36 Post(s)
Liked: 30
And the movie Upside Down would look . . . well, normal
joeysta is offline
post #26661 of 37235 Old 03-09-2018, 06:24 AM
sikclown's Avatar
Liked: 832
Stupid question but what do you have the Oppo audio set to? Auto, LPCM, or Bitstream? I will say this though Microsoft does some weird things with how they send over audio so your issue is likely there. Kodi kind of bypasses your Windows audio settings so it can get a little confusing there.
sikclown is offline
post #26662 of 37235 Old 03-09-2018, 09:20 AM
Meetloaf13's Avatar
Quoted: 54 Post(s)
—Bob
Very good, I e-mailed them last night, just waiting to hear back. Thank you Bob
post #26663 of 37235 Old 03-09-2018, 10:03 AM
Buddylee123's Avatar
Quoted: 904 Post(s)
Liked: 622
This firmware update is getting expensive
Despoiler and sikclown like this.
Buddylee123 is offline
post #26664 of 37235 Old 03-09-2018, 10:13 AM
Quoted: 128 Post(s)
Liked: 84
Oppo HDMI audio is set to Bitstream. Seems strange that the Oppo still sends LPCM in that mode.
Have tried Auto, but that doesn’t help.
Also tried switching back and forth between Bitstream and Auto with PC connected and powered on because I saw that someone had fixed another sound problem by switching that way.
Also tried unplugging and replugging cables, and power cycling devices, but that hasn’t helped either.
LG 86UH9500
ntxoa is offline
post #26665 of 37235 Old 03-09-2018, 10:36 AM
groove93's Avatar
Quoted: 1025 Post(s)
Liked: 585
There is a section in Kodi where, I believe under video, where it says "sync playback with display". I may have inadvertently checked this after the firmware update last week. This caused Oppo to report LPCM from my Nvidia Shield, rather than output lossless audio formats such as Atmos or DTSMA.
In the description, it says that the player will not bitstream audio or something similar.
Now it may be a different meaning for the windows version of Kodi, but this was the case for Kodi on Android TV.
Sent from my Pixel 2 using Tapatalk
Sony XBR55X900E
Marantz SR7010/Marantz MM7025
Oppo UDP-203 - Nvidia Shield
XBox One X
Klipsch RP-260f - RP-440C - RP140sa- RP-160m - RB10 - Sony SA-WM500
groove93 is offline
post #26666 of 37235 Old 03-09-2018, 11:00 AM
lujan's Avatar
Quoted: 4603 Post(s)
Liked: 2673
I just saw "Interstellar" on the Oppo 203 on Wednesday night and I couldn't believe how much more the 4k disc added to the experience than the 4k digital copy. I think this title has more IMAX scenes than any other title out there or at least more than the other Nolan titles with IMAX.
galonzo and bob brennan like this.
lujan
561 Ultra HD
721 HD
4 SD
lujan is offline
post #26667 of 37235 Old 03-09-2018, 11:33 AM
Quoted: 128 Post(s)
Liked: 84
Yep. I always make sure to keep that turned off with Kodi/SPMC on the Shield and PC. It definately can cause problems when trying to bitstream.
So Kodi has been ok for me. Just the Dolby Access app has problems.
LG 86UH9500
ntxoa is offline
post #26668 of 37235 Old 03-09-2018, 11:33 AM
Quoted: 904 Post(s)
Liked: 622
That was the one that I picked to watch. I’m about 30 minuets in and I still cannot believe how good this update has my JVC projector looking. I almost feel like I need to send OPPO a gift basket for this
stevenjw, Bytehoven and Greg TB like this.
post #26669 of 37235 Old 03-09-2018, 01:16 PM
R8ders2K's Avatar
Quoted: 160 Post(s)
Liked: 151
Originally Posted by curlyjive View Post
If you have it check the opening sequence of Star Trek Beyond. Thats where I have seen it in real content. Big improvements have been made, but I still see it there.
I'm curious as to what you're seeing...?
Originally Posted by sonichart View Post
The John Wick boogeyman song scene has been improved with the latest official FW release. However subtle, the flickering in the black background is still present. Turning on CMD (Motion smoothing) fixes the issue as does playing the movie in HDR BT2020.
With regard to the black clipping, I will refer to atabea's post. The Oppo is performing dynamic tone-mapping and for whatever reason, doesn't resolve the black clipping patterns properly. Playback of regular content is not clipping blacks -- I demo'd quite a few scenes from IT and if the Oppo is clipping blacks I'm just not seeing it. Instead, I'm seeing a ton of shadow detail and vibrant colors.
I just watched the Boogeyman scene on the 4K disc and granted, I'm new to the 203 and my 940E, but I didn't notice anything. My 203 is running the latest firmware (0224) and after doing the reset, I've pretty much left everything on default settings.
Sony XBR-75X940E
Onkyo TX-NR777
DIRECTV HS17 + C61K
Oppo UDP-203
TV 4K
R8ders2K is offline
post #26670 of 37235 Old 03-09-2018, 01:50 PM
curlyjive's Avatar
Quoted: 683 Post(s)
Liked: 315
Look at the bodies of the alien creatures you'll see shadow areas that look like black batches due to clipping. some of the chamber walls show the same. This does not exists on the uhd played through the panny nor does it exists on the blu ray.
curlyjive is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
