Official OPPO UDP-203 Owner's Thread - Page 960 - AVS Forum | Home Theater Discussions And Reviews
 278829Likes
post #28771 of 36757 Old 04-29-2018, 10:33 AM
SeeMoreDigital's Avatar
Quoted: 967 Post(s)
Liked: 717
Originally Posted by dmh2000 View Post
As proof of concept, I set up a quick Twonky server on my Thecus and it is streaming DSD - 5.6MHz (DSD128) to the Denon receiver. So it is the Oppo UDP-203 that is having the issue 'verifying' that DSD128 can be played on the Denon.
I guess you could have done much the same by transferring some DSD128 files onto a USB flash-drive and inserting it into your Denon's USB port
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is online now
post #28772 of 36757 Old 04-29-2018, 10:53 AM
Liked: 1
I did that originally, and the Denon played DSD128. I have to verify what rdgrimes said, "..DSD64 can be bitstreamed over HDMI, DSD128 and DSD256 cannot. This is a limitation of HDMI, not of the player or processor." Still can't find any documentation to back that up.
♥ Sony XBR75X940E 75-Inch 4K ♥ Denon AVR-X4300H 7.2.4 (ATMOS DTS:X) ♥ NAD 275BEE Amp ♥ OPPO UDP-203 ♥ GoldenEar Triton One ♥ PCH-C200 ♥ Thecus N5550 8TB (Raid5) ♥
dmh2000 is offline
post #28773 of 36757 Old 04-29-2018, 11:02 AM
rdgrimes's Avatar
Quoted: 3775 Post(s)
Liked: 2975
You were playing the files directly, not bitstreaming over HDMI. You're chasing wild geese here, its not possible for the Oppo to bitstream DSD128+ over HDMI. (Nor would you hear any difference if it could.)
SeeMoreDigital and bwillcox like this.
rdgrimes is offline
post #28774 of 36757 Old 04-29-2018, 11:20 AM
Quoted: 967 Post(s)
Liked: 717
@dmh2000
If you are into listening to 'multi-channel' audio, you'll probably find that your AVR is unable to do this for all audio formats when pulling them directly from your NAS or even a USB connected HDD. Have you tried?
Cheers
post #28775 of 36757 Old 04-29-2018, 11:22 AM
Liked: 1
Yes, I thought about that right after I posted, (I compared apples to oranges). Thanks.
dmh2000 is offline
post #28776 of 36757 Old 04-29-2018, 11:34 AM
cvn74n2's Avatar
Like another recently said, I gave in to AVS peer pressure and just bought a 203. I had been waiting for my current TV (2007 42" 720p Panny plasma) to die before moving towards a UHD ecosystem. However, with Oppo's decision to no longer make players, I felt I would start the process. The next step will be a newer AVR with multi-analog audio inputs (Marantz 5xxx/6xxxx?) so I can take advantage of hi rez audio files without having to keep my TV on or transfer them to a USB flash drive. Once the Panny goes, I am leaning towards the latest TCL 6-series for the price-to-value it offers. Although I have been a long time lurker, I will be viewing this thread more closely for issues/mitigations/enhancements as I learn the player's capabilities and limitations. You may see me ask a question at some point, but I will do my best to do due diligence before asking.
galonzo and Madmax67 like this.
cvn74n2 is offline
post #28777 of 36757 Old 04-29-2018, 11:55 AM
Quoted: 967 Post(s)
Liked: 717
If you prefer analogue amps, why not do what I have done and buy/use a good quality stereo integrated amplifier along with say, three (matching) stereo power amplifiers. You can turn your amps on, as and when you need them. You can even hide the power amps out of view
post #28778 of 36757 Old 04-29-2018, 09:55 PM
Holland108's Avatar
Quoted: 65 Post(s)
Liked: 29
I still face some HDMI issues, when switching discs BR > 3D or UHD HDR -> UHD DV.
The fix is usually to swith off/on the 203. But it remains anoying.
Yes, I did fully reset, after the latest firmware update.
The strangest one is while loading the DV disc. The screen Dolby Vision is presented on my LG E6, but the screen remains black.
203 is connected directly to the TV for picture, and sound via hdmi to my Denon.
Any thoughts? Or better send a mail to Oppo....
Holland108 is offline
post #28779 of 36757 Old 04-30-2018, 01:24 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5783 Post(s)
Liked: 8256
Check that the firmware is also up to date on the LG E6 and that ALL of your HDMI cables are Premium Certified. If you have anything else in the HDMI path, including switches, adapters, or wall plates, test by bypassing all of those so you have only simple, direct, single cable HDMI connections.
If this does not lead to a simple solution, get in touch with OPPO Digital Tech Support for more help diagnosing this.
—Bob
tonyve and galonzo like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #28780 of 36757 Old 04-30-2018, 01:27 AM
Holland108's Avatar
Quoted: 65 Post(s)
Liked: 29
—Bob
Will get in touch with Oppo, I have 1 direct cable, and everything is up-to-date.
post #28781 of 36757 Old 04-30-2018, 02:47 AM
Read the FAQ!
Liked: 8256
^ Just so you know, I'm also using an LG E6 with my 205 (dual HDMI cabling), and I'm not experiencing these issues.
While waiting to hear back from OPPO, here's another thing you can try: HDMI is just friction fit, and it only takes a small shift of plug in socket to screw things up.
So double check that all of your HDMI plugs are fully inserted straight into the socket, with nothing, e.g., cable weight or kinks in the cable, tugging on the plug in any direction. To do this, unplug and replug each plug, and check by grasping the cable an inch or so back of the plug and giving it a little wiggle to check the plug is fully inserted and that there's no stress on the plug from the cable. Do this with the HDMI path to your Denon as well.
Also, if you have an additional HDMI connection into another input of the TV from the output of the Denon, try physically disconnecting that temporarily to see if that cures the problem. If so, there may be workarounds related to trying to keep that unused HDMI path actually shut down when it is not in use.
--Bob
tonyve, galonzo, Madmax67 and 1 others like this.
post #28782 of 36757 Old 04-30-2018, 04:32 AM
jong1's Avatar
Quoted: 505 Post(s)
Liked: 485
^^ ditto, another E6 user with no issues, in my case with a single HDMI cable via a Yamaha 3060.
galonzo likes this.
LG OLED65E6V, Yamaha RX-A3060 AVR, Oppo UDP-203 UHD Blu-ray player, Apple TV 4K, Sky Q 2TB, Chromecast Ultra
Home-built Ivy Bridge i5-3570K HTPC, 8GB RAM and Nvidia GTX1050 GPU with Plex and Jriver Media Centre,
Ruipro 15M Fiber HDMI cable, B&W FPM speakers, Logitech Harmony Ultimate intelligent remote.
jong1 is offline
post #28783 of 36757 Old 04-30-2018, 05:46 AM
hlindstr's Avatar
Quoted: 58 Post(s)
Liked: 92
The Oppo has never supported BDXL discs. Is there some reason why you thought it would now?
Yes, it was reported that it would so I tested.
Originally Posted by zizux View Post
Hi.
The structure that you used have more than 66GB???
Regards.
The structure was back-upped from 66GB disc but I recorded it on 100GB BD-RE media. Precise structure size was 58,3 GB.
galonzo and zizux like this.
Oppo UDP-203 and Oppo BDP-83 both hw region modded, Apple TV 4K 32GB, LG OLED55E6V 55", Asustor 2-Bay NAS currently 8TB
hlindstr is offline
post #28784 of 36757 Old 04-30-2018, 06:59 AM
psuKinger's Avatar
Quoted: 1503 Post(s)
Liked: 610
Just a quick personal testimonial and lamentation that oppo is getting out of the Blu Ray player game.
I bought the OPPO 203 primarily for it's HDMI input and dual outputs. At the time of purchase I didn't properly value/understand just what "a great blu ray player" could be; I see now just what "value-added" is with the price increase that comes with an OPPO purchase, but at the time I was justifying the price upgrade as being more affordable than a cheaper blu ray player PLUS an HDMI splitter (to get Lossless Blu Ray audio and 4K HDR Video from my NVidia Shield to my TV and AVR in parallel, as I couldn't pass from either device to the other in series).
The last firmware update really caused me some grief in terms of A/V sync. I don't know why. But I reached out to OPPO support and asked for their help on March 2. We went back and forth with e-mails for a few days, and I didn't get any resolution to the problem. But 3 or 4 weeks later, OPPO e-mails me unsolicited, following up on my feedback, with a "test firmware" to try. For reasons I won't expound upon, I wasn't able to get around to installing it until today, but this test firmware they sent me works. My A/V sync problem seems to be resolved. So I had to take to the internet and share this. A "big company" like this keeping a "ticket" open for several weeks and then following up, unsolicited, with a test firmware that fixed my problem? Incredible, IMO.
Really impressive. Sad to see they are getting out of the business.
gsr, stevenjw, AVfile and 23 others like this.
psuKinger is offline
post #28785 of 36757 Old 04-30-2018, 07:05 AM
kinglm's Avatar
Quoted: 334 Post(s)
Liked: 295
Last day of April and no DV update for Sony yet
But the day is not over...
StanGeek and galonzo like this.
kinglm is offline
post #28786 of 36757 Old 04-30-2018, 07:33 AM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
haha. very optimistic. I still think it may not come until June, but I really want to be wrong about this prediction.
galonzo likes this.
Video - UHD TV: Sony 940E, UHD BD:Panasonic UB900, Samsung K8500, Oppo 203 Apple TV 4K
Audio - Yamaha CX-A5100 PrePro, Outlaw Audio Amps x 3, Polk Rti-A7s x 2, Rti-A5s x 4, 70RTs x 4, SVS PB16 Ultra x2
StanGeek is offline
post #28787 of 36757 Old 04-30-2018, 08:46 AM
Read the FAQ!
Liked: 8256
I have every reason to believe OPPO is still working hard with Dolby on this.
Evidently it’s not quite baked yet.
—Bob
post #28788 of 36757 Old 04-30-2018, 09:28 AM
Quoted: 89 Post(s)
Liked: 33
Originally Posted by Neil S. Bulk View Post
Yes, this works. Thanks!
Still the user interface when having a drive connected directly to the Oppo leaves much to be desired. That would have been ideal.
You may also want to check out Roon Audio setup, as the Oppo players are Roon endpoints and the user interface experience is much better (if you have something like a tablet around). Roon also supports importing directly from iTunes (I've not tried this personally).
Rob
PT-AE8000U | LG 55C7P | Oppo UDP-203 | Onkyo TX-NR636 | JBL 5.1
robl2 is offline
post #28789 of 36757 Old 04-30-2018, 09:43 AM
Wesley Hester's Avatar
Quoted: 186 Post(s)
Liked: 142
All of this ^^^^^^^^^^^^^^ may have been 1 of many reasons on a whiteboard list in some conference room somewhere for Oppo to get out of the Blu-ray player business.
Display: Optoma UHD51A Projector > Elite Screens R135WH1 ezFrame | 7.2.4 Audio: Onkyo TX-RZ920 9.2ch Network A/V Receiver, M-5010 2ch Amplifier; Definitive Technology ProCenter 2000, ProMonitor 1000(x10), SuperCube I & 4000 | Sources: PC, DirecTV, Apple 4K, Fire Stick 4K, Oppo UDP-203, Chromecast & Roku Ultras, Xbox One X, PlayStation 4 Pro & Nintendo Switch | Remote: Harmony Elite | HDMI: 40' Monoprice DynamicView+4x1 Switch
Wesley Hester is offline
post #28790 of 36757 Old 04-30-2018, 10:46 AM
Neil S. Bulk's Avatar
Quoted: 40 Post(s)
Liked: 27
I'm intrigued and I see there is a trial period with it. It's pricey after that, but might be what I'm looking for.
Neil S. Bulk is online now
post #28791 of 36757 Old 04-30-2018, 11:29 AM
rondongon's Avatar
Quoted: 166 Post(s)
Liked: 57
...Or, you could set up a DLNA server that's able to access your content -- perhaps directly out of the iTunes library. Then use the User Interface of that DLNA server -- either on the server itself or via a separate control app running on another device -- to select the content to play. The OPPO can be used as a Digital Media Renderer (DMR) for DLNA, meaning the server can "push" files to the OPPO for playback.
--Bob
I gave up on the UDP-203 as a DMR, I have a Mac Mini with Audirvana software (Media Server), that pushes nicely to my Muso, and my old Denon-3808CI and my OLED65E7P. But it only works one out of two times with the UDP-203.
I’ve tried all combinations of restarting my Mac, or the 203, but it only works after I reboot my router one time only. Then I am back to square one, a very bizarre situation and given my Media Server and router works with other home equipment, I believe the 203 DMR implementation is flaky. (I have network standby on as well DHCP reservation )
I was hoping to use the Oppo as a DMR to my Anthem MRX-720, but maybe time for a DAC.
rondongon is offline
post #28792 of 36757 Old 04-30-2018, 12:27 PM
fuhkinay's Avatar
Quoted: 34 Post(s)
Liked: 25
Got my 203 last week & hooked it up this weekend. So far, I'm underwhelmed. Not that the sound or picture is bad, it just doesn't knock my socks off. I think I read too much about Oppo and my expectations were too high. I just expected it to be so much more of a "wow factor". I watched parts of a couple of Bluray Discs as well as some plain DVDs. Honestly, I think my old Panasonic DMP-BD60 outputting 1080p to my Sony XBRX900E had a better picture. Sound is comparable with CDs, maybe a bit better on Bluray on the Oppo.
Maybe I don't have things set properly. Was hoping for a better out of the box experience.
fuhkinay is offline
post #28793 of 36757 Old 04-30-2018, 12:38 PM
Keenan's Avatar
Quoted: 3811 Post(s)
Liked: 3508
--Bob
Are devices like HDMI swivel/angle connectors a detriment to the efficacy of certified premium high data rate cables? Does one of these at one end or both ends throw out the capability of the cable itself?
Keenan is offline
post #28794 of 36757 Old 04-30-2018, 12:39 PM
Taxcheat's Avatar
Quoted: 457 Post(s)
Liked: 340
So, any chance you could pop in a DV disc and check whether they accidentally included the beta DV code that Dolby Labs is currently sitting on?
galonzo likes this.
XBR-75Z9D fed by Oppo 203. Decrapifying the X1 Extreme
Taxcheat is offline
post #28795 of 36757 Old 04-30-2018, 12:49 PM
Read the FAQ!
Liked: 8256
That's a definite "Maybe". ANY sort of adapter in the HDMI path can be a source of problems. And as far as I know, there's no such thing as a Premium Certified program for such adapters. So using them is a gamble.
--Bob
galonzo and azz7686 like this.
post #28796 of 36757 Old 04-30-2018, 01:03 PM
wozman's Avatar
Quoted: 33 Post(s)
UPDATE
The Oppo arrived today to my work address, "Outstanding" didn't want to take the chance the nobody was home, for the delivery........Can't wait to get home tonight and setup this bad boy with my Home Theater.
Question? should I be running the latest Firmware update (thru Wifi?) immediately after plug in? OR do you download the latest firmware and install with the use of a USB stick? (like I did recently for my Pioneer Elite SC-95) OR do I disregard the firmware for the time being.
Thanks again AVS
Media Room: 55" Panasonic ST60, Pioneer Elite SC-95, Oppo UDP-203, Panasonic DMP-UB400, HTPC, PS4, Pioneer Andrew Jones Series Speakers plus Subs (Atmos Ready 5.2.4)
Living Room: 50" Pioneer Kuro Plasma PDP-5020FD, Pioneer VSX-1326-k, Panasonic BDT-360, PS3, Bose Acoustimass 6 Series(5.1)
wozman is offline
post #28797 of 36757 Old 04-30-2018, 01:09 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4541 Post(s)
Liked: 4372
Originally Posted by wozman View Post
UPDATE
Thanks again AVS
You can do it either way. Details are at OPPO's web page and in the manual.
I would definitely update to the latest.
-Bill
galonzo and wozman like this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #28798 of 36757 Old 04-30-2018, 01:15 PM
Keenan's Avatar
Liked: 3508
--Bob
That's what I figured. My current display has the HDMI inputs such that straight attachment tends to expose the cable from the side of the display in a way that can be seen by the viewer so I used one of those adapters. I'm trying to plan ahead and get the cables I need for when I get my 4K display in the next few months and was curious about those adapters. Thanks!
Matt2026 likes this.
Keenan is offline
post #28799 of 36757 Old 04-30-2018, 02:09 PM
psuKinger's Avatar
Liked: 610
No dice, at least not on my Sony 940E...... shame on Sony for such a crappy implementation.
muzz, Taxcheat, StanGeek and 1 others like this.
post #28800 of 36757 Old 04-30-2018, 02:52 PM
DLDukes's Avatar
Quoted: 36 Post(s)
Liked: 49
I'm sure this topic has been discussed ad nauseam, but I am late to the game, and still a thread novice and skeptical of my ability to get good advice in a search.
I am set up with one HDMI out going to my avr (see signature). What do I buy if I go dual HDMI? Assuming I make a direct connection to my Kuro? The Kuro is 720P, I have my Roku 3 plugged into the 203's HDMI In. I Mostly watch Blu-ray movies, with the occasional DVD or multi-channel disc on Pure Audio.
Is the expectation "cleaner"/"better" video?
D"
Klipsch RB-51II (Mains) Klipsch RC-52II (Center) Klipsch RS-42II (Surrounds)
SVS SB12-NSD / Klipsch KSW-10 (Subs)
Pioneer Kuro PDP-5080
Denon AVR-2310CI - Oppo UDP-203 - Roku 3
DLDukes is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
