Official OPPO UDP-203 Owner's Thread - Page 965 - AVS Forum | Home Theater Discussions And Reviews
 279046Likes
post #28921 of 37039 Old 05-06-2018, 11:38 AM
Sanjay's Avatar
Quoted: 147 Post(s)
Liked: 71
Originally Posted by neb04 View Post
Also, is there a limit to the capacity of a USB connected HDD that this player will be able read, like the 83 and 93?
I regularly use a 8tb USB hard disk with the UDP-203. Therefore I think it's safe to assume that 10 tb & 12 tb hard disks should work too
galonzo likes this.
Sanjay is offline
post #28922 of 37039 Old 05-06-2018, 11:41 AM
Sanjay's Avatar
Quoted: 147 Post(s)
Liked: 71
Originally Posted by Bob Pariseau View Post
(TrueHD (including Atmos) in an MKV file can be finicky this way. You can use an M2TS file instead as a workaround.)
This is a problem that I have faced only with Oppo. Both on the 103 and the 203. Never faced any issues with the other media players or with nay PC software players. In case there is an additional Dolby Digital track in the MKV, then merely switching to it and then back to the TrueHD /Atmos track, resolves the issue too
PS: The problem with using M2TS as a workaround is that M2TS does not support chapters.
galonzo and SuperFist like this.
Sanjay is offline
post #28923 of 37039 Old 05-06-2018, 11:45 AM
Keenan's Avatar
Quoted: 3891 Post(s)
Liked: 3605
Originally Posted by DLDukes View Post
Keenan, thanks for the link. Everyone, else please ignore the Harmony talk. I have installed that app a couple of times and can't figure out how to get it to work with my Harmony One. The app wants me to set up or connect to a hub which my remote does not have. The One has a charging base not a hub. What am I missing? How do I get passed the hub setup and use the app as a configuration tool for my remote?
D
Originally Posted by ppasteur View Post
I don't believe that you can. The App talks to the hub which passes the correct codes to your devices. No hub, then the App does not work.
Sometimes people just do not read carefully and fully before posting.
So, AFAIK, you cannot use the App with the harmony one. I have the same remote BTW.
Sorry, I thought the One was similar to the Elite or 950 but I see the One uses the older version 7.x desktop software. It's been awhile since I've used that but I did setup my 103D with the ability to change inputs when starting up, this was with Harmony 880. I'll check it when I get a chance and let you know.
The first image below is using the front input on a 103D and the other the rear input on the 103D. The rear input command I used twice and I think I had to do that because of a timing issue or something, it may not be necessary. This was with the 7.x desktop software. If you try using the 103D command set from Harmony it might accomplish what you need.
Name:	2018-05-06 12_22_06-Logitech Harmony Remote Software (7.7.0).jpg
ID:	2399596   Click image for larger version
Name:	2018-05-06 12_23_10-Logitech Harmony Remote Software (7.7.0).jpg
Keenan is online now
post #28924 of 37039 Old 05-06-2018, 12:04 PM
Quoted: 69 Post(s)
Liked: 107
I have a UDP 203 that I bought shortly after they became available. I had previously used an Oppo 80 since I bought it new after they came out. When the 205 came out I was considering buying one as I wanted the headphone and USB DAC capabilities. However, Oppo added MQA to the 205. That put an end to the 205 for me. I did not want anything infected with MQA in my system.
It appears that the firmware update is the same for the 203 and 205. Does the firmware update install any aspect of MQA on the 203?
KeenObserver is offline
post #28925 of 37039 Old 05-06-2018, 12:54 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5805 Post(s)
Liked: 8276
The 203 does not support MQA, as I think you know.
However, since you feel so strongly about this, it would be wise to assume that some aspect of MQA code IS installed in the 203, even if that code is never executed. And even if the 203 doesn't have the HARDWARE to execute that code if it tried. (Different DACs, for example.)
This sort of implementation detail is not something OPPO typically reveals, but you've got nothing to lose asking OPPO Tech Support to see what they say.
--Bob
galonzo likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #28926 of 37039 Old 05-06-2018, 01:05 PM
Quoted: 69 Post(s)
Liked: 107
--Bob
Equipment manufacturers that work in conjunction with MQA to provide MQA support generally sign non disclosure agreements. This seems especially so with MQA.
My concern is that Firmware that enhances MQA might degrade non MQA music performance.
post #28927 of 37039 Old 05-06-2018, 01:11 PM
Read the FAQ!
Liked: 8276
I've seen no indication that non-MQA audio quality was impaired in the 203 or 205 starting with the firmware that added MQA support to the 205.
--Bob
post #28928 of 37039 Old 05-06-2018, 01:29 PM
rdgrimes's Avatar
Quoted: 3822 Post(s)
Liked: 3039
Originally Posted by Sanjay View Post
Actually, with the UDP-203, there is no need for naming the folder 'AVCHD'. All UHD full backup folder structures work just fine with whatever name you give them.
You are half right. AVCHD is required for network shares, not for attached storage.
giomania and Sanjay like this.
rdgrimes is online now
post #28929 of 37039 Old 05-06-2018, 03:00 PM
Patrick Jow's Avatar
Originally Posted by wmcclain View Post
Noise is normal during the intro material but it should be quiet while playing the main feature.
UHD does spin faster than other discs so extra noise is possible. Do you notice a pattern to the noise? Louder at the beginning, quieter as you chapter skip into the title, maybe becoming louder again past the half-way point?
-Bill
Bill:
Yes, the player does quiet down a lot, and remains very quiet, when it plays into the main content of the disc.
Thank you for pointing this out.
Patrick Jow is offline
post #28930 of 37039 Old 05-06-2018, 03:14 PM
Read the FAQ!
Liked: 8276
Originally Posted by Patrick Jow View Post
Bill:
The variable speed optical drive runs at its highest speed when it is bulk loading content from the disc. For example, high speed is used while loading the disc’s BD-Java program, and while loading the on-disc menus.
—Bob
post #28931 of 37039 Old 05-06-2018, 03:32 PM
DLDukes's Avatar
Quoted: 38 Post(s)
Liked: 54
I'm good, I was able to get both activities working as needed, Thanks all for the suggestions
D
Klipsch RB-51II (Mains) Klipsch RC-52II (Center) Klipsch RS-42II (Surrounds)
SVS SB12-NSD / Klipsch KSW-10 (Subs)
Pioneer Kuro PDP-5080
Denon AVR-2310CI - Oppo UDP-203 - Roku 3
DLDukes is offline
post #28932 of 37039 Old 05-06-2018, 03:39 PM
David Aiken's Avatar
Quoted: 816 Post(s)
Liked: 1467
--Bob
MQA material carries a flag to identify it and MQA processing should only be applied to MQA material. Non MQA material is supposed to be processed without the application of any MQA processing so non MQA content performance should not be degraded by MQA processing. Unfortunately I have seen test reports in Stereophile indicating that at least 1 DAC incorrectly applies some MQA processing to non-MQA material so it is possible for non MQA performance to be impaired by an MQA DAC. This happens because the DAC manufacturer is implementing the MQA software incorrectly so it's a device manufacturer issue rather than an MQA issue. I have seen no indication that this problem is occurring with the 203 or 205.
What surprises me about this is that MQA are supposedly maintaining tight control over manufacturers who are adopting MQA, just like Dolby does over manufacturers in respect of Dolby Vision. It would seem that MQAs certification processes or whatever it is they do pays close attention to MQA performance but they don't seem to care if their processing is incorrectly applied to non MQA content.
In the absence of any reports indicating that the 203 and 205 are getting it wrong I'm inclined to side with Bob and believe this isn't a problem with the 203 and 205 but I guess it is possible that a future firmware update could introduce the problem noted with some other DACs. Correctly implemented, MQA processing should not be applied to non MQA material and therefore should not affect music performance.
AVfile and KC-Technerd like this.
David Aiken is offline
post #28933 of 37039 Old 05-06-2018, 05:04 PM
hatlesschimp's Avatar
Quoted: 505 Post(s)
Liked: 541
Hooked up Hugh Dean's SAKSA 85 diy amplifier to my 203 via the RCA FL FR outs and played some flac music and sounds pretty darn good. The amp is a winner. Thinking I might sell my Rotel 1585 5ch 200wpc and build 11 channels with this board.
Sent from my SM-G965F using Tapatalk
hatlesschimp is offline
post #28934 of 37039 Old 05-06-2018, 08:19 PM
Liked: 3
For What it's worth, Oppo had 23 model 203's left when I started ordering my second unit about half an hour ago...by the time I finished ordering, they had 18 left.
WOLVERNOLE, AVfile and Matt2026 like this.
presient is offline
post #28935 of 37039 Old 05-06-2018, 08:55 PM
WOLVERNOLE's Avatar
Quoted: 338 Post(s)
Liked: 156
Question
Did you order directly from Oppo ?
WOLVERNOLE is offline
post #28936 of 37039 Old 05-06-2018, 09:55 PM
Matt2026's Avatar
Quoted: 892 Post(s)
Liked: 25285
13 right now, guessing all will be gone by early tomorrow, unless they're getting another shipment...
[Edit] 10 left...
WOLVERNOLE likes this.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Aircom T-8, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #28937 of 37039 Old 05-06-2018, 10:33 PM
Liked: 3
Yes, I ordered from oppo "dot" com
presient is offline
post #28938 of 37039 Old 05-07-2018, 04:43 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4605 Post(s)
Liked: 4440
My understanding is that units were still in the pipeline until June, but that probably depends on shipping schedules and other unforseeables.
I don't know if OPPO will announce "last batch is here" or just ring a bell and say "DONE!"
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #28939 of 37039 Old 05-07-2018, 05:09 AM
RWetmore's Avatar
Quoted: 631 Post(s)
Liked: 389
Originally Posted by bob brennan View Post
As of this morning "OUT OF STOCK" - will there be another shipment - I believe they stated that the would be available until June?
Wow. Glad I decided to buy mine yesterday.
RWetmore is offline
post #28940 of 37039 Old 05-07-2018, 08:37 AM
enigmascv's Avatar
Quoted: 26 Post(s)
Liked: 24
Got mine from Crutchfield last Week. It was the last batch to come In. Love this machine and glad I made the investment!
enigmascv is offline
post #28941 of 37039 Old 05-07-2018, 08:41 AM
SnellKrell's Avatar
Quoted: 204 Post(s)
Liked: 69
Crutchfield no longer lists the 203 or the 205.
Not even a mention of Out of Stock.
The only entry is for the players' rack mounts.
SnellKrell is online now
post #28942 of 37039 Old 05-07-2018, 09:00 AM
Read the FAQ!
Liked: 8276
^ OPPO’s web store has the 203 back In Stock again.
—Bob
Mike_WI likes this.
post #28943 of 37039 Old 05-07-2018, 09:15 AM
stikle's Avatar
Quoted: 950 Post(s)
Liked: 1120
Also, the root folder on a BD-R needs to be "AVCHD" as well or the Oppo won't recognize it as a movie disc. I found this out recently with the Reference 2 Bluray Demo Disc created by AVS members.
galonzo likes this.
stikle is offline
post #28944 of 37039 Old 05-07-2018, 09:25 AM
WOLVERNOLE's Avatar
Quoted: 338 Post(s)
Liked: 156
Red face Just joined the Oppo family ! 203...
Yep, also bought mine late last night. Curious what the "Manufacturing Date" will be ?? Wondering if they are actually BUILDING any 203's into May ?
post #28945 of 37039 Old 05-07-2018, 09:30 AM
WOLVERNOLE's Avatar
Quoted: 338 Post(s)
Liked: 156
Question How do you fellas know the exact "count" of remaining 203 units "available??"
[Edit] 10 left...
JUST CURIOUS...please guys...tell me how in the heck you know the count that precisely ? I ordered from Oppo last night...they said merely "AVAILABLE" and I hit ORDER. How does it show units available? Are there different Oppo order sites?
post #28946 of 37039 Old 05-07-2018, 09:34 AM
JohnAV's Avatar
Quoted: 518 Post(s)
Liked: 701
Put in a larger number, be sure to cancel unless you want a very large CC bill. There is a 1000 showing now.
Oppo Beta Group
JohnAV is offline
post #28947 of 37039 Old 05-07-2018, 09:35 AM
Matt2026's Avatar
Quoted: 892 Post(s)
Liked: 25285
On the order page enter some large quantity and hit the Update Totals. I just put in 1000 and they have at least that many...
post #28948 of 37039 Old 05-07-2018, 09:42 AM
JohnAV's Avatar
Quoted: 518 Post(s)
Liked: 701
Did we really need all those Amp/theater images. Just wondering? How about using spoiler?
stevenjw and AVfile like this.
Oppo Beta Group
JohnAV is offline
post #28949 of 37039 Old 05-07-2018, 09:49 AM
WOLVERNOLE's Avatar
Quoted: 338 Post(s)
Liked: 156
Question Excited about my 1st Oppo ! Please offer me best "settings" for the 203;no 4K TV yet
Really excited to have just purchased an Oppo 203 on line last evening ! My first Oppo after about three Panasonic blu-rays that have been very good- between 5-9 years old. I am asking you folks if you would kindly offer me a list of "best settings" for initial setting up the 203. I should note that I have yet to purchase a 4K television (likely an LG OLED C8 this summer)...but for now, I have a plasma (Panasonic ST 50 ), which of course is a 1080p max. So HDR is irrelevant to me at this particular time. I have no receiver on it either, so it would be straight UHD blu-ray player directly into the TV's HDMI.
Thanks for your experience with this unit's settings. Looking forward to sharing about my newfound Oppo excellence !
post #28950 of 37039 Old 05-07-2018, 09:57 AM
claudiuangelo's Avatar
Liked: 7
I just got Apple 4K tv. I see a lot of peaople who put Apple tv trought Oppo 203 in hdmi in, What îs the purpose and how works? Tx
claudiuangelo is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
