Official Oppo UDP-205 UHD Blu-ray player Anticipation Thread - Page 39 - AVS Forum | Home Theater Discussions And Reviews
 541Likes
post #1141 of 1146 Old 02-01-2020, 08:30 PM
Liked: 3
Originally Posted by Bob Pariseau View Post
The Volume in the OPPO will affect both the multi-channel and dedicated stereo Analog outputs. So set that to 100 (or "Fixed") when using the dedicated stereo outputs.
This is a bit risky, if you forget to lower the Volume again when you go back to using the multi-channel outputs!
--Bob
Bob:
Could you check my questions to you in post #1138 .
Thank you.
lexiconaudio is offline
post #1142 of 1146 Old 02-02-2020, 11:16 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5869 Post(s)
Liked: 8403
Originally Posted by lexiconaudio View Post
Bob:
In an older thread you wrote:
"The first thing you would look for is whether the inputs of the power amp have high impedance. Just compare the typical input impedance of quality pre-amps and a range of power amps and you'll see what I mean."
Does that mean to look for a power amp with a high input impedance? My Odyssey Audio mono extreme has an input impedance of 22k ohm. Is that high or low?
You also wrote:
"It's also important that the gain of the power amp not be so high that you have to use low values of the Volume control in the 205 to get a comfortable listening level."
I saw amps with gains of 23dB and 29dB. Is the first one low and the second high? What is the range of low or high?
I don’t have the typical impedance figures in my head at this point. Perhaps someone else could chime in. But my first reaction is 22K should be fine.
The range of gain which will work well when cabled this way depends on the efficiency of your speakers. Best would be to audition the amp you are interested in (with your speakers) so you can see what Volume setting works in the OPPO.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #1143 of 1146 Old 02-04-2020, 05:09 PM
Liked: 0
Anybody can give me any advice about what filter I should use in DAC section, because the system is connected is almost impossible to switch through them to compare? Thanks
Jorgitok is offline
post #1144 of 1146 Old 02-04-2020, 05:11 PM
Cla55clown's Avatar
Quoted: 408 Post(s)
Liked: 128
Hi, quick question. Can I have the player do a HDR to SDR conversion for video but retain the Atmos soundtrack that is on the UHD disc? I only have a 1080p projector but have a Atmos audio speaker layout. Thanks!
Sent from my Pixel 3a XL using Tapatalk
Cla55clown is offline
post #1145 of 1146 Old 02-09-2020, 05:04 AM
Quoted: 47 Post(s)
I've set filter characteristics to Apodizing Fast. Playing Apple Music at high volume with this filter I sense no smearing, greater clarity, and more detail on tail end notes than other modes. In fact, since AAC sounds indistinguishable from AIFF, I no longer purchase hi-res downloads.
csludwig2 is offline
post #1146 of 1146 Old 02-09-2020, 06:07 AM
Liked: 0
Thanks so much!
Jorgitok is offline
Reply Blu-ray Players
