OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 25446Likes
post #301 of 9997 Old 03-03-2017, 10:47 AM - Thread Starter
apw2607's Avatar
Quoted: 361 Post(s)
Liked: 360
OK ... I'm going to back pedal. I only personally tried True HD in a MKV with DLNA. Another forum poster tried it with USB.
I just tried several TrueHD MKV test files (H265, H264) with USB ... and ran into the same issue with audio not supported on the TrueHD track .... but was able to play the DD 5.1 Core .... Sooo, not sure about this now !!
TrueHD works in m2ts containers for both USB and DLNA.
apw2607 is offline
post #302 of 9997 Old 03-03-2017, 11:19 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6140
Originally Posted by aaronwt View Post
Netflix seems to have started using this info menu again. I have at least three devices where the Netflix info display came back this week. The only difference I noticed was that the bitrate is now in Mbps instead of Kbps.
Good!
XBR65A9G / XBR65A8F / 55R615
Panasonic UB820 / ATV4K
AVRX6500H / RP-8000F / RP-504C / RP-502S / RP-500SA / FV15HP (5.1.2)
gadgtfreek is offline
post #303 of 9997 Old 03-03-2017, 12:19 PM
johnson636's Avatar
Quoted: 1559 Post(s)
Liked: 1045
Originally Posted by dan webster View Post
Has anyone used the hdr to sdr setting with a projector? I have a jvc rs500 and am thinking about getting this player. My samsung 8500 is nice but it does not do that .conversions I currently use an hd fury integral to do this .
Ditto. I also would like to know if this is possible.
johnson636 is offline
post #304 of 9997 Old 03-03-2017, 12:38 PM
Nima's Avatar
Quoted: 262 Post(s)
Liked: 142
Code:
Complete name                            : Dolby_Conductor_Lossless_ATMOS-thedigitaltheater.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 38.4 MiB
Duration                                 : 40s 134ms
Audio
Format                                   : TrueHD
Codec ID                                 : A_TRUEHD
Bit rate mode                            : Variable
Maximum bit rate                         : 8 817 Kbps
Channel(s)                               : 8 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate                            : 48.0 KHz
Compression mode                         : Lossless
Default                                  : Yes
Forced                                   : No
Perhaps someone else can try this?
I would also like to know the final verdict on this True-HD mkv from USB subject.
Nima is online now
post #305 of 9997 Old 03-03-2017, 01:36 PM
robert ham's Avatar
Quoted: 217 Post(s)
Liked: 166
2D to 3D conversion???
Does the UBP-X800 have a feature that allows you to take a standard BluRay 2D, and convert it to do a 3D format like my present Sony player allows???
robert ham is offline
post #306 of 9997 Old 03-03-2017, 01:39 PM
Jon S's Avatar
Quoted: 1141 Post(s)
Liked: 417
It does not appear that this player supports 3D.... More so since Sony dropped 3D on their TVs...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #307 of 9997 Old 03-03-2017, 01:41 PM - Thread Starter
apw2607's Avatar
Quoted: 361 Post(s)
Liked: 360
Ok. Final verdict. I got it to work !
The only thing. You can't use MKV containers. You have to use M2TS containers instead. Then TrueHD will playback fine either from USB or DLNA.
ID:	2004337   Click image for larger version
Nima and CaptinCrunch like this.
apw2607 is offline
post #308 of 9997 Old 03-03-2017, 01:59 PM
robert ham's Avatar
Quoted: 217 Post(s)
Liked: 166
It Does
Yes, this player will play 3D BluRays that is clear, not sure about the 2D to 3D conversion..
aaronwt likes this.
post #309 of 9997 Old 03-03-2017, 02:01 PM
robert ham's Avatar
Quoted: 217 Post(s)
Liked: 166
Demo
Where did you get the DEMO from???
post #310 of 9997 Old 03-03-2017, 02:09 PM
CaptinCrunch's Avatar
Quoted: 354 Post(s)
Liked: 314
X800 plays 3D movies but does not convert 2D to 3D.
aaronwt and Bob539 like this.
Sony 75X900F / MediaLight Quad 6500K
Sony X800
Denon X4400H / Outlaw 5000 (5.2.4 Atmos) AIRCOM T9
Klipsch RF-82 II, Klipsch RC-62 II, Klipsch RS-52 II, Klipsch RP-500SA
SVS PB-3000 x2
CaptinCrunch is offline
post #311 of 9997 Old 03-03-2017, 02:14 PM
Quoted: 354 Post(s)
Liked: 314
Here is the link to the Sony X800 support page. You can download the manual and check for firmware updates.
https://esupport.sony.com/US/p/model...ls#/manualsTab
aaronwt and apw2607 like this.
Sony X800
SVS PB-3000 x2
post #312 of 9997 Old 03-03-2017, 02:16 PM - Thread Starter
apw2607's Avatar
Quoted: 361 Post(s)
Liked: 360
You can download the demo here
apw2607 is offline
post #313 of 9997 Old 03-03-2017, 02:45 PM
b0rnarian's Avatar
Quoted: 2210 Post(s)
Liked: 1391
How do you convert it to m2ts, I have a hard time converting some via TSmuxer, it wouldn't even read the files.
b0rnarian is offline
post #314 of 9997 Old 03-03-2017, 04:28 PM
Quoted: 44 Post(s)
Liked: 31
Originally Posted by gadgtfreek View Post
Looks good in the proper scenes. In certain scenes like the library I saw some softness and odd blacks, but if you read the High Def Digest review and the Blu-ray dot com review, that was in the source, so my first experience seems accurate to what the viewer saw. The player is fast and moves around menu's well.
I am starting to think Blu-rays look a little flat after watching 3 HDR movies in a row though. Dr Strange, with their spells, and the end part where he goes to another place and there are inky blacks and wild colors, HDR would have been sweet.
Thanks for the reply. I had read the blu-ray dot com review and I normally find their reviews to be accurate, but I just wanted another opinion. I finally got my HDR player so I hope to start building my HDR library. I do get the same impression on some blu-rays (any content really) after watching HDR content and then switching to an SDR source.
djpalacios91 is offline
post #315 of 9997 Old 03-03-2017, 05:12 PM - Thread Starter
apw2607's Avatar
Quoted: 361 Post(s)
Liked: 360
I'll send you a PM. Bit of topic for this thread I reckon.
apw2607 is offline
post #316 of 9997 Old 03-03-2017, 05:13 PM
Liked: 0
I just had Chad B calibrate my jvc RS500 and received the sony x800 the next day (poor timing), I have three settings on my projector now normal 709 for regular blu ray, and HDR 2020, and SDR 2020, so far I have watched a few movies on regular blu ray and UHD HDR disc as well and everything seems to work great, I notice a big difference when I switch the projector from 709 to HDR 2020 when watching a UHD disc, hope that helps a little. haven't used the SDR setting.
cjv8350 is offline
post #317 of 9997 Old 03-03-2017, 06:13 PM
SLYDoggie's Avatar
Quoted: 251 Post(s)
Liked: 168
In my case, the projector is the one which does the 2D to 3D conversion. I didn't even know that this was something that was ever done in the BluRay player itself. Are there BluRay players that actually do the 2D to 3D conversion?
Not sure why I'm asking though as I haven't really seen a good use for this capability. I'm an avid 3D Blu-Ray viewer though. Just too many "quirks" with the 2D to 3D conversions that I have seen with my projector.
Regards, Steve
Projector/Receiver - Sony VPL-VW1100ES 4K PJ & Sony STR-ZA5000ES 4K Atmos AVR
Media Devices - Panasonic DP-UB820 4K BR, Sony UBP-X800 4K BR, ATV 4K, and Roku 4K
Screen - 145" Dragonfly, 1.2 Gain, 16:9, Matte White Fixed Screen
Theater Remote/Cables - Universal MX-990 RF Remote, Monoprice Certified 18Gb HDMI Cables
SLYDoggie is offline
post #318 of 9997 Old 03-03-2017, 06:29 PM
Quoted: 44 Post(s)
Liked: 31
So here's a quick question, i'm not sure if someone can help or point me in the right direction. Before anything, I am going to post my Home Theater setup so that all information is available.
Sony X930D
Sony X800
Marseille mCable
So here is my observation and ensuing question:
Today I got the X800 setup and connected it to the TV via the mCable. Then I put in my Lucy 4K disc into the player and hit play. I then noticed that the TV did not automatically switch to HDR mode. I hit "display" on the X800 and it displayed that it was playing a 4K disc and it also had HDR on the upper left hand side of the display menu.
I subsequently had to manually switch my TV into HDR mode and for all intents and purposes it seemed to me like the HDR content was being displayed correctly. Now, my question lies in that, normally, the TV will automatically switch itself into HDR mode when there is HDR content being displayed (such as from Netflix, Amazon etc). Is this a result of the mCable and its interaction between the Source and the TV, is it a bug? Was I viewing the movie in HDR or SDR?
I'm a little confused, I hope someone is able to help.
post #319 of 9997 Old 03-03-2017, 06:45 PM
jakline's Avatar
Quoted: 12 Post(s)
X800 failed - Need BestBuy return advice
When I rook the update a couple of days ago, the UI froze on the player and I got a "running internal tests—contact support" message. A power reset brought the player back.
Today I turned on the player and I had no video. If I insert a disc, I can play it; but that is the only wY I get a video signal.
So now I have a bare bones UHD player and I need some advice on how to exchange the player at Best Buy. If I order one for in-store pickup, I can get a new player March 8. If I do that, can I bring my defective player in at that time and get a refund? Anyone tried that? Any other suggestions?
Thanks in advance.
Cheers,
John
jakline is offline
post #320 of 9997 Old 03-03-2017, 06:47 PM
Quoted: 44 Post(s)
Liked: 31
Thanks in advance.
Cheers,
John
As long as you take in your receipt for the defective one, they should have no problems accepting your device for an exchange/return.
post #321 of 9997 Old 03-03-2017, 06:55 PM - Thread Starter
apw2607's Avatar
Quoted: 361 Post(s)
Liked: 360
Thanks in advance.
Cheers,
John
Ok. One thing you could try to get back to the menu's is to reset the player to the lowest resolution output its capable of. Which is 480p !
Turn on the player. Wait say 60 seconds for everything to boot up.
Then on the remote hit
STOP
HOME
POP UP Menu
The player will reset the resolution to 480p. I would hope you would see a picture again.
Hope that helps ! Otherwise its a trip to BB.
apw2607 is offline
post #322 of 9997 Old 03-03-2017, 07:38 PM
bos617's Avatar
Quoted: 56 Post(s)
Liked: 108
STOP
HOME
POP UP Menu
Any ideas? Any disk I play I get "Unknown disc"
Updated the player, unplugged the player for a good 10 mins still no luck...
Sent from my SAMSUNG-SM-G928A using Tapatalk
bos617 is offline
post #323 of 9997 Old 03-03-2017, 07:59 PM
AMDman18's Avatar
Quoted: 286 Post(s)
Liked: 272
Sony X930D
Sony X800
Marseille mCable
You need to make sure "Enhanced format" is enabled for any HDMI devices capable of 4K60 or HDR. That means the port your player is plugged into. That way the TV will know to accept HDR from the HDMI port. This is not necessary for the TV's built in apps.
To do this, go to Settings->External Inputs->HDMI Signal Format.
From there you will be able to choose which HDMI ports are set to use the enhanced format. It is recommended to ONLY set inputs to Enhanced that will be connected to 4K60/HDR capable devices. After being set correctly, the TV will automatically kick into HDR when it gets and HDR signal from HDMI. You will not have to manually select anything.
AMDman18 is offline
post #324 of 9997 Old 03-03-2017, 08:06 PM
AMDman18's Avatar
Quoted: 286 Post(s)
Liked: 272
Thanks in advance.
Cheers,
John
If it comes to you having to return the player, just bring it back and they will order you a new one. You don't have to purchase a new one beforehand.
AMDman18 is offline
post #325 of 9997 Old 03-03-2017, 08:17 PM
Quoted: 1067 Post(s)
Liked: 874
Can't believe all these posts; sounds like Brain surgery is easier to operate than this Bluray player!! Jeez
fvbounty likes this.
Primary set-up 5.2.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; 2 Outlaw X12 Subs & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #326 of 9997 Old 03-03-2017, 09:00 PM
Bigmoviefan's Avatar
Quoted: 646 Post(s)
Liked: 468
i think all these 4K Blu-ray players need a few firmware updates to get the bugs out. It is very typical of the product!
yanks1 likes this.
Bigmoviefan is offline
post #327 of 9997 Old 03-03-2017, 09:12 PM
ffo4kooch's Avatar
Quoted: 17 Post(s)
x800 Failure....(temporarily)
Just finished watching Deadpool. Played great and looked great. During the credits I tried to reverse a bit and then hit the Home button on the remote by mistake. It began flashing the home screen on and off i.e., intermittent video output. Could not get it to reset (initially). Unplugged for 10 minutes tried again. Same result. Swapped HDMI cables, TV inputs etc. All paths lead to problem with the x800.
After completely unhooking it from my system, assuming it was bound for a BB return I decided to give it one more chance. About a half hour passed and I hooked it back up. Workied just like nothing was wrong. Hopefully I just confused it and for some reason it needed a long reset....
ffo4kooch is offline
post #328 of 9997 Old 03-03-2017, 10:43 PM
Nima's Avatar
Quoted: 262 Post(s)
Liked: 142
I would appreciate a PM as well.
Nima is online now
post #329 of 9997 Old 03-04-2017, 05:44 AM
UHD Addict
aaronwt's Avatar
Quoted: 9820 Post(s)
Liked: 6490
It's typical of any product nowadays.
aaronwt is offline
post #330 of 9997 Old 03-04-2017, 05:46 AM
Quoted: 44 Post(s)
Liked: 31
Hi,
Thank you for your response. I can confirm that my TV was set to Enhanced Format. I plugged it into HDMI 1 on my set. Yet, it still did not automatically switch to HDR mode.
Reply Blu-ray Players
4kupscale , 5040 , dsf , Epson , problem , Sony , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
