OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 25408Likes
post #541 of 9888 Old 03-08-2017, 07:51 AM
AMartin56's Avatar
Quoted: 2166 Post(s)
Liked: 1150
Originally Posted by ecossecableman View Post
For us non HDR projector owners has anyone carried out a comparison of how the white crushing Oppo experimental strip metadata compares pic wise to the Sonys 'unique' HDR to SDR non BT2020 conversion (I'm told an HDFury in the chain doesn't help- unlike for the Panny900 where it works superbly well)
I'm curious. Where did you hear this? The HD Fury folks can't seem to confirm one way or the other. I suppose the Sony automatically engages it's conversion when told that HDR isn't compatible?
Sent from my Pixel using Tapatalk
AMartin56 is offline
post #542 of 9888 Old 03-08-2017, 07:51 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6063
If you are happy, I would save the $$$.
XBR65A9G / XBR65A8F / 55R615
ATV4K / Uverse / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is online now
post #543 of 9888 Old 03-08-2017, 07:55 AM
ecossecableman's Avatar
Quoted: 54 Post(s)
Liked: 25
an owner on this thread unfortunately confirmed it. Apparently the Sony conversion only gives SDR 709.
HDFury have not to my knowledge found a solution to get u SDR BT 2020 unless you have later info. Do you?
ecossecableman is offline
post #544 of 9888 Old 03-08-2017, 08:14 AM
curlyjive's Avatar
Quoted: 697 Post(s)
Liked: 315
From my comparison of the Oppo, Panasonic, and Sony, I believe Sony is remapping HDR Bt2020 to SDR BT709 but exaggerating colors. It gives the impression of a wider color space.
curlyjive is offline
post #545 of 9888 Old 03-08-2017, 08:31 AM
cdnscg's Avatar
Quoted: 607 Post(s)
Liked: 123
In your opinion, is the Sony remapping image solid, or looks artificial?
cdnscg is offline
post #546 of 9888 Old 03-08-2017, 08:34 AM
curlyjive's Avatar
Quoted: 697 Post(s)
Liked: 315
It's more exaggerated than the 709 color space on the blu ray equivalent. Some may like the look, others may find it artificial. Depends if you are used to a more accurate image or are used to colors that are a bit oversaturated. I also might be fine for some titles and not others.
post #547 of 9888 Old 03-08-2017, 08:39 AM
cdnscg's Avatar
Quoted: 607 Post(s)
Liked: 123
I'm curious to know if you like it?
cdnscg is offline
post #548 of 9888 Old 03-08-2017, 09:01 AM
Quoted: 54 Post(s)
Liked: 25
so which looks better to ur eyes, the crushing whites oppoor the
so which looks better to ur eyes, the crushing whites Oppo or the exaggerated WCG Sony
Also, any idea why the Fury works with Panny but not Sony? Thx
post #549 of 9888 Old 03-08-2017, 09:50 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6063
SDR 2020 mapping is not an exact science, and neither is SDR 709 from HDR 2020. All of them are likely to vary a bit. Only time I used it was HDR strip on the Oppo (which was OK but needed work) and the Panny 900 + Fury. The Panny + Fury for SDR 2020 was quite good to my eyes.
post #550 of 9888 Old 03-08-2017, 09:53 AM - Thread Starter
apw2607's Avatar
Quoted: 357 Post(s)
Liked: 359
Originally Posted by Therberg View Post
Where are you reading about the strange behavior with some 2016 Sony TVs? I have a 75 X940D that I am having some intermittent issues with.
Hopefully this link works. Issue on a 850D with the x800. Seems like it got resolved with new cable !
Therberg likes this.
apw2607 is offline
post #551 of 9888 Old 03-08-2017, 10:34 AM
ggw2000's Avatar
Quoted: 892 Post(s)
Liked: 452
Originally Posted by ffo4kooch View Post
Thanks. I have 18 Gbps cables, but not seeing 'certified' anywhere. I'll place a Monoprice order and see if different cabling helps.
Good move. What length cables are you using?
Gerry
Sony XBR 75X940E - Sony STR-DH790 ATMOS - Sony UBP-X700 UHD BD Player - ATV 4K - 2019 Shield TV Pro
ggw2000 is online now
post #552 of 9888 Old 03-08-2017, 10:39 AM
Nima's Avatar
Quoted: 237 Post(s)
Liked: 136
Why does the Fury Linker not work with the Sony?
Nima is offline
post #553 of 9888 Old 03-08-2017, 10:58 AM
ffo4kooch's Avatar
Quoted: 17 Post(s)
Gerry
Cables are 12'. I think I can reduce to 6' and make it, but I'll probably grab a couple of 10'ers also.
yanks1 likes this.
ffo4kooch is offline
post #554 of 9888 Old 03-08-2017, 11:25 AM
Quoted: 27 Post(s)
Liked: 5
can anyone write correct audio settings for this player ?
I cant get atmos . With OPPO player no problem .
dario888 is offline
post #555 of 9888 Old 03-08-2017, 11:29 AM
Quoted: 54 Post(s)
Liked: 25
you need to ask HDFury. I was referring to the Integral btw
post #556 of 9888 Old 03-08-2017, 11:30 AM
Quoted: 27 Post(s)
Liked: 5
ok so there is something wrong here.
I'm watching my second 4k HDR movie and still getting screen info that movie is SDR and not HDR. What I'm doing wrong?
dario888 is offline
post #557 of 9888 Old 03-08-2017, 11:39 AM
b0rnarian's Avatar
Quoted: 2079 Post(s)
Liked: 1253
Very basic question to get out of the way - are you sure you are using the UHD Disc and not the BD by accident? It would help to know your equipment chain.
Samsung 65 KS9800 + Denon X4500H (11.2) + OPPO 203 + PS4 + Roku
Disc Lot For SALE : HERE!
b0rnarian is offline
post #558 of 9888 Old 03-08-2017, 11:46 AM
Quoted: 27 Post(s)
Liked: 5
I'm using UNDERWORLD and Resident Evil. Both should be HDR. There are lot of options under screen menu.
What should I select under "Output Video Resolution" ? "Auto" ?
Cant get atmos and HDR no matter what I do. very frustrating
I have sony Sony XBR75 X940D.
dario888 is offline
post #559 of 9888 Old 03-08-2017, 11:48 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6063
Does the 940D have the HDMI type setting where you have to turn it on for the panel to report itself capable and get HDR?
post #560 of 9888 Old 03-08-2017, 11:49 AM
UHD Addict
aaronwt's Avatar
Quoted: 9436 Post(s)
Liked: 6116
Yes. Some UHD BD titles put the UHD disc behind the UV insert for some reason. I've know I've accidentally put the 2K disc in a couple of times. Now I just put the UHD BD on the right side of the case whenever I run into a title like this. And put the 2K BD on the left where it should be.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #561 of 9888 Old 03-08-2017, 11:51 AM
Quoted: 150 Post(s)
Liked: 85
You need set "BD mix" to off in the audio settings.
Therberg is offline
post #562 of 9888 Old 03-08-2017, 11:52 AM
b0rnarian's Avatar
Liked: 1253
Slow down and before putting the disc into the player, check and see if it says Ultra-HD on the disc itself and not just Blu-Ray.
apw2607 likes this.
post #563 of 9888 Old 03-08-2017, 11:56 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6063
If that one worked, are you sure you are playing the UHD disc?
post #564 of 9888 Old 03-08-2017, 11:56 AM
b0rnarian's Avatar
Liked: 1253
yes and everything is on.
But I'm getting SDR from PLAYER info. TV shouldn't matter , correct?
If player shows its playing disc in SDR then TV settings don't matter.
update ok something very strange here.
I just put my new MAD MAX 4k disc and it shows HDR !!
Underworld and Resident Evil still shows SDR. Anyone here who has this 2 discs can confirm same ?
TV does matter, for example, if your tv doesn't support HDR then the player will downscale to only SDR, just as an example. Sounds like you are using the wrong discs cuz Mad Max is working fine.
post #565 of 9888 Old 03-08-2017, 11:56 AM
Quoted: 27 Post(s)
Liked: 5
Thank you .
Resolved my issue
yanks1 likes this.
dario888 is offline
post #566 of 9888 Old 03-08-2017, 11:57 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6063
Yeah, some are in plain view, others have the blu-ray there and the UHD disc under the digi copy (stupid, stupid, stupid).
post #567 of 9888 Old 03-08-2017, 11:57 AM
b0rnarian's Avatar
Liked: 1253
Thank you .
Resolved my issue
Another happy customer LOL
apw2607 likes this.
post #568 of 9888 Old 03-08-2017, 11:59 AM
Kris Deering's Avatar
Quoted: 4055 Post(s)
Liked: 7091
Question. I don't see it listed on the main page but does this player support Sony's exclusive streaming service for their 4K streaming titles? I know their TVs do, but wondering if this does as well.
My Home Theater UPDATED DEC 2017
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #569 of 9888 Old 03-08-2017, 12:00 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6063
Not as of right now.
Vudu (not UHD)
Youtube
Amazon (no HDR)
Netflix
post #570 of 9888 Old 03-08-2017, 12:02 PM
b0rnarian's Avatar
Liked: 1253
Vudu (not UHD)
Youtube
Amazon (no HDR)
Netflix
So YT is playing in 4K/HDR?
Reply Blu-ray Players
4kupscale , 5040 , dsf , Epson , problem , Sony , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
