OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 203 - AVS Forum | Home Theater Discussions And Reviews
 25444Likes
post #6061 of 9990 Old 11-26-2017, 10:03 AM
Max Rockatansky's Avatar
Quoted: 137 Post(s)
Liked: 45
Originally Posted by Sharp1080 View Post
I have no issue with viewing HDR YouTube videos thru my X800 fed into a Sony XBR 940D. I had to change the HDMI input to "enhanced" and the videos play properly. You are aware that many of them labeled as HDR on YouTube are not actually HDR. The King and the Chessboard video is my quick go to test for HDR on YouTube. If you see "VP9 2" on the nerd stats icon along with 3840X2160 then it's an HDR video.
Searched and could not find. Link?
~ MAX
Sony XBR-65Z9D 4K TV | Sony STR-DN1080 AVR | Sony UBP-X800 Blu-ray | NVIDIA Shield TV | PlayStation 4 Pro | Harmony Ultimate
Pioneer Andrew Jones Design: SP-C22 Center Channel/4x SP-BS22A-LR Dolby Atmos Bookshelf/SW-8MK2 Subwoofer
Max Rockatansky is offline
post #6062 of 9990 Old 11-26-2017, 11:15 AM
DLCPhoto's Avatar
Quoted: 1802 Post(s)
Liked: 879
Thanks for the reply. I guess I had assumed that anything from the HDR Channel would actually be in HDR, but perhaps not. I'll check out a few others.
Where is the 'nerd stats icon' to be found?
Also, to clarify: you say the "videos play properly." Do you see the HDR badge when you go to the picture adjustments menu? I mean, they look awesome on my 900E, apparently even without HDR being engaged.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #6063 of 9990 Old 11-26-2017, 11:36 AM
70383roadrunner's Avatar
Quoted: 98 Post(s)
Liked: 46
Originally Posted by bobknavs View Post
From Page 25 in the downloadable manual, there are 3 settings: auto, HDMI1, and HDMI2. Auto is supposed to work in your case, but you can try manually setting the audio out to HDMI2.
Good luck.
Thanks. Got it working.
70383roadrunner is offline
post #6064 of 9990 Old 11-26-2017, 11:43 AM
Ximori's Avatar
Quoted: 282 Post(s)
Liked: 181
While on streaming, click on pause and go to the options menu then click on the icon on the far right - that'll be the nerds stats which will show all the source info.
Ximori is offline
post #6065 of 9990 Old 11-26-2017, 01:33 PM
Quoted: 109 Post(s)
Liked: 61
HDR Channel has HDR videos.
When playing youtube video with hdr you should get:
- HDR badge in youtube player (just beside 4K badge)
- HDR badge in your picture settings (SONY tvs)
nerd stats icon is available during playback as one of the options in the second menu.
Possible problems with your setup:
- cable, it needs to be 18Gbps, Blurays play fine when you have 4K/24p/HDR but youtube requires the bandwidth of 4K/60/HDR to be available
- wrong HDMI input port, not sure about 900E but A1 only has two 18Gbps capable ports
- your HDMI inputs on your TV are not set to enhanced (it sets 18Gbps manually, it is set to off for compatibility reasons by default)
- your youtube player is not updated (but I fail to see how it can be a possibility with X800 that requires you to be always up to date)
Since you have turned on the enhanced option my bet is on cable.
SONY KD-65A1
SONY UBP-X800
SONY HT-ST5000
lukv is offline
post #6066 of 9990 Old 11-26-2017, 01:48 PM
DLCPhoto's Avatar
Liked: 879
Thanks for that. I hadn't seen that before - quite useful!
That's a very good summary of the potential pitfalls in getting HDR.
In my case, all of that was in order, as I was getting HDR with UHD BD's with my X800. Turns out that @Sharp1080 was correct - the "HDR" Youtube videos I happened to pick were not in fact in HDR, even though they were labeled as such. I found some others that were, and the HDR badge showed up when going to picture settings, as expected.
Some quite spectacular demos are available, which really show off what this set can do!
Sharp1080 and fhschellenberg like this.
post #6067 of 9990 Old 11-26-2017, 01:58 PM
Liked: 0
Hi, does anybody know how to play a BDR-XL Disk with 100GB with the X800 ?
If i burn on the same CD Blank a file with less than 66gb ( only 2 layers ) it works. On the same type of blank disk i burn a file bigger than 66 gb ( 3 Layer ) the player didnt read it.
can anybody confirm this?
DaywalkerNL is offline
post #6068 of 9990 Old 11-26-2017, 04:11 PM
Quoted: 88 Post(s)
Liked: 51
I have also found that skipping forward to the next video then skipping back also will activate HDR videos that weren’t activating HDR on the first try.
aaronwt and DLCPhoto like this.
chrisk114 is offline
post #6069 of 9990 Old 11-26-2017, 04:57 PM
Quoted: 1159 Post(s)
Liked: 682
When I stream YouTube the picture stalls often, sometimes completely freezes. Only about 12 feet from the modem. The Youtube app in the Tv right above it has no issues streaming. Any thoughts?
Voted most desirable mate by the ladies every year! Klan leader! Mob boss! Love advice expert! Credit cards accepted.
Kenbar is offline
post #6070 of 9990 Old 11-26-2017, 05:12 PM
UHD Addict
aaronwt's Avatar
Quoted: 9817 Post(s)
Liked: 6486
I've found HDR inconsistent. Between my firetv, Roku, and x800 I can see all the HDR channels videosd in hdr.
Sent from my Galaxy S8 using Tapatalk
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #6071 of 9990 Old 11-26-2017, 06:48 PM
Quoted: 22 Post(s)
Liked: 3
The manual states it is not compatible with BDXL's.
muzza167 is offline
post #6072 of 9990 Old 11-26-2017, 06:58 PM
pmeintel's Avatar
Quoted: 156 Post(s)
Liked: 85
Why hi there everyone, question for all those in the know I'm looking to upgrade my player prior to my display and was wondering how the image quality is of a 4K disc on a 1080 display with the UBP-X800. Your thoughts and experience is greatly appreciated.
"These go to eleven." - Great words from Nigel Tufnel.
pmeintel is offline
post #6073 of 9990 Old 11-26-2017, 07:17 PM
Scott M's Avatar
Quoted: 299 Post(s)
Liked: 227
Originally Posted by teddyc23 View Post
I just purchased the X800 player. After setting it up with my Harmony 650, I noticed I have to slightly hold the buttons for the player to register commands like OK and RETURN. I do not seem to have this issue with other components. Sony remote works great, you can press the button very quickly and it will register. I did try the delay and repeat settings with no change. I am hoping someone has seen this issue before.
Teddy
I have the X-800 and Harmony 650 remote, and do not experience the issue you have described. The remote controls the player just as well as the remote that came with the X800 (and that remote is now stored away, along with all my other OEM remotes). I did not adjust any of the default settings or add any delays in the setup of the Harmony.
Scott M is offline
post #6074 of 9990 Old 11-26-2017, 10:42 PM
NPoser's Avatar
Liked: 0
Hi folks
Does anybody know if I need an adapter 220-110V for the USA player or if the player works with both voltage as well?
NPoser is offline
post #6075 of 9990 Old 11-26-2017, 11:03 PM
tondeezy99's Avatar
Quoted: 128 Post(s)
Liked: 101
I find HDR to be spotty on the youtube app. I am running Monoprice certified 4K cables, however on HDR content on Youtube I get constant flickering. Wondering if there are better cables I should try? I am running Vizio P55>Yamaha A660> Sony X800. All HDMI cables are the same.
tondeezy99 is offline
post #6076 of 9990 Old 11-27-2017, 04:28 AM
DLCPhoto's Avatar
Liked: 879
If there is flickering (not buffering or stuttering, which would indicate insufficient bandwidth on your internet connection), that is certainly suggestive of a cable issue.
Getting 18gbps cables, especially at lengths greater than 15 or so feet, can be hit or miss. Even having "premium certified" cables is not a guarantee, even though it should be.
What is your longest length?
post #6077 of 9990 Old 11-27-2017, 05:40 AM
steveknj's Avatar
Quoted: 64 Post(s)
I got this setup last week and finally had a chance to do some testing over the long weekend. The one Ultra BD that I have (The Martian) played flawlessly. But I tried both a BD and a DVD and both mysteriously stopped at one point, black screen. Hitting play started it back up from the place it left off. I sort of remember someone else upthread having this problem but I am too lazy to sort through 200+ pages. I really haven't played too much with the apps yet as this will only be a backup for my streaming, as I have both a Roku Premiere and a Fire stick. I haven't tested a music CD yet.
Any ideas why the player would just stop like that?
Steve
steveknj is offline
post #6078 of 9990 Old 11-27-2017, 05:52 AM
bguzman's Avatar
Quoted: 173 Post(s)
Liked: 1145
Originally Posted by NPoser View Post
Hi folks
Page 34 of the US manual.
Power requirements Rating: Input 120 V AC, 60 Hz
HT TCL 55P605, BenQ W7000, Pioneer UDP LX500, Panasonic LX1000, Firestick 4K, ATV4K, Pioneer SC-LX 701, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Pioneer UDP LX500, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is online now
post #6079 of 9990 Old 11-27-2017, 06:02 AM
tondeezy99's Avatar
Quoted: 128 Post(s)
Liked: 101
All cables are 6ft monoprice certified cables. Swapping around cables results in the same issue.
post #6080 of 9990 Old 11-27-2017, 07:35 AM
DLCPhoto's Avatar
Liked: 879
Weird. Are you able to play UHD Discs in HDR without issue? If that works fine, that would suggest your cables are ok. Do you have any video, or a more precise description of the 'flickering' you're experiencing? That might help determine where the problem is.
post #6081 of 9990 Old 11-27-2017, 07:45 AM
Quoted: 394 Post(s)
Liked: 113
Hi folks
You'll need a step down transformer to "step down" the 220v to 120v. The player accepts 120v.
Theater:JVC RS440, Elite 120". 7.1.4:RTi8, CSi5, FXiA4, RTiA3, 620-RT(4) & SVS PB12-NSD. Denon X4300H, UPA-700, Crown XLS1502 & XLS1000(2). Sony UBP-X800, Panasonic DP-UB424, Shield & ATV 4K. Lounge:Vizio M70-D3, Benq HT1075, & Elite 106". 7.1.4:RTi12, CSi5, RTiA1, TSx110, MC60(4), & RBH I-12. Marantz AV7702, Crown XLS1500, XLS1000(2) & Amp 100v2(2). Samsung UBD-K8500, LG BP440, Shield & ATV
shyyour is offline
post #6082 of 9990 Old 11-27-2017, 07:57 AM
william06's Avatar
Quoted: 922 Post(s)
Liked: 511
Just for a test go into picture settings see if screen shift is on. When you get the flickering see if turning it off stops the flickering. I get it occasionally and when I do I turn screen shift off and it stops. When I switch channels I turn it back on and all is well n
Lg oled65G7P
Panasonic UB9000 . pioneer lx500 uhd blu ray players
atv4k 2nd gen cube, roku ultra 2019
Toshiba Xa2 HD-DVD
Samsung HW-Q90R ZA soundbar
william06 is online now
post #6083 of 9990 Old 11-27-2017, 08:12 AM
phantom52's Avatar
Quoted: 336 Post(s)
Liked: 301
OK just bought this player yesterday from BB. Still using a Panasonic Plasma. I've read through about 30 pages on this thread and could not find anyone that has the settings for the X800 to a 1080p display. Sorry if was stated and overlooked them. My question is what is the best video settings for my display? Any help will be appreciated. So far really love it although I've only used for a few Bd movies. Coming from an Oppo BD-83 that bit the dust after purchasing it when it came out. Thanks in advance for any help.
phantom52 is online now
post #6084 of 9990 Old 11-27-2017, 08:33 AM
petetherock's Avatar
Quoted: 1757 Post(s)
Liked: 936
Has anyone seen this post on FB?
petetherock is offline
post #6085 of 9990 Old 11-27-2017, 08:47 AM
BGLeduc's Avatar
Quoted: 2733 Post(s)
Liked: 2639
He was a very brave man. :-)
BGLeduc is online now
post #6086 of 9990 Old 11-27-2017, 09:08 AM
Liked: 0
does anybody know which UHD Player on the market is compatible with bdxl ? ( BD-R 100GB )
Thx
post #6087 of 9990 Old 11-27-2017, 11:34 AM
Quoted: 394 Post(s)
Liked: 113
maybe i should tempt fate as well and plug mine directly
NPoser likes this.
shyyour is offline
post #6088 of 9990 Old 11-27-2017, 12:06 PM
Quoted: 394 Post(s)
Liked: 113
i just plugged mine directly and there was no smoke, so i think its safe to say the Sony UBP-X800 is dual voltage (YMMV).
NPoser likes this.
shyyour is offline
post #6089 of 9990 Old 11-27-2017, 12:22 PM
Quoted: 394 Post(s)
Liked: 113
Originally Posted by Mike219 View Post
I need advice from anyone using a US player in a 220v country. How are you connecting it to power? When I moved overseas, I found that my Sony PS3, listed at 110v/60Hz, worked fine connected directly to 220v/50Hz. I'm hoping that this unit is as easy to use. And to answer the question before it's asked, all my videos are Region 1. Thanks and Happy Thanksgiving.
Hi folks
So it seems i was wrong, based on what someone posted i decided to plug mine directly and it works so its safe to say the player is dual voltage, but try at your own expense.
NPoser likes this.
shyyour is offline
post #6090 of 9990 Old 11-27-2017, 02:28 PM
Sharp1080's Avatar
Quoted: 1071 Post(s)
Liked: 772
It's there as I found it right away. Not the exact name I had posted earlier.
Max Rockatansky likes this.
Sharp1080 is offline
Reply Blu-ray Players
4kupscale , 5040 , dsf , Epson , problem , Sony , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
