OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 250 - AVS Forum | Home Theater Discussions And Reviews
 25469Likes
post #7471 of 10107 Old 03-08-2018, 03:21 AM
jnnt29's Avatar
Quoted: 164 Post(s)
Liked: 157
Originally Posted by AMDman18 View Post
Did they send you a new one or a refurb? When I had my 930D replaced with my 930E, they initially sent out a refurbished 930E. When that one ALSO had a problem, the replacement for the replacement was a new one. Even though the support people told me my first 930E would be "brand new." Basically, I don't trust Sony support lol.
I received a brand new unit not a refurbished one.
My set up: Samsung UN82nu8000 LED TV, Marantz SR7012, Emotiva XPA3, Sony UBP-X800
Roku 4k Premier, Panamax MR4000, 2 Marantz MA-500U, Klipsch KLF10 (L/R),
RC62II (center), R-1650-W (surrounds), RB81II (Rear Surrounds),
Monoprice 6.5" in ceiling speaker (top front/rear), Two Klipsch R-10SW subwoofer
https://www.avsforum.com/forum/show....php?t=1227096
jnnt29 is offline
post #7472 of 10107 Old 03-08-2018, 07:21 AM
robnix's Avatar
Quoted: 1021 Post(s)
Liked: 767
Originally Posted by mbergh22 View Post
I have. Never had an issue for the whole year Ive owned it.
Sent from my SM-T810 using Tapatalk
No issues for me either.
Looky here!
robnix is offline
post #7473 of 10107 Old 03-08-2018, 08:22 AM
UHD Addict
aaronwt's Avatar
Quoted: 9996 Post(s)
Liked: 6657
Originally Posted by jnnt29 View Post
It seems like the earlier models were freeze prone. Mine was one of the early ones. The replacement is a new build based on the serial number and working properly. I would call Sony and have them exchange it.
Mine is an early model since I got it within a couple of weeks of launch. But it's been working great. And I use the quick on mode.
Oldways7 likes this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #7474 of 10107 Old 03-08-2018, 10:53 AM
Woochifer's Avatar
Quoted: 36 Post(s)
Liked: 65
My x800 works fine.
The only hiccup occurred with Amazon video. It froze during a reverse scan, although I was doing a lot of things in quick succession while testing the app. I haven't encountered any other freezes since then.
Also, the receiver no longer recognizes the DSD stream if I try playing SACDs after going back to the home screen or doing anything else in between playbacks. I have to either toggle the power switch or switch to PCM output. Also, the doesn't recognize the SACD layer on one of my hybrid discs, and reverts to playing the CD layer.
I don't have a 4k HDTV, but I have been buying 4k Ultra BDs. I've played both Dunkirk and Hidden Figures all the way through without any issue.
Woochifer is offline
post #7475 of 10107 Old 03-08-2018, 11:08 AM
Woochifer's Avatar
Quoted: 36 Post(s)
Liked: 65
Originally Posted by locob View Post
I am the owner of a Samsung JS8500 4K TV and a Sony X800 UHD Blu-ray player. I am looking to find out what video scalers are used in each and if there is any consensus of opinion as to which does a better job. I know ultimately the answer is subjective to the viewer, but perhaps there is factual evidence regarding the abilities of what is used on the 2015 UHD TV verses the 2017 Blu-ray player. I'll post this in both forum threads for replies. Thanks.
I know that the x800 uses a Mediatek SoC to handle the video processing. Don't know which exact model. Anyone can check, if they're willing to remove the cover and then remove the heatsink from the processor.
But, generally that's not recommended because there's also a layer of thermal paste between the heatsink and the chip. You might not be able to read the markings on the chip anyway because of the paste residue. And when putting the unit back together, you need to make sure that you correctly reapply the thermal paste. Apply too much on there, and it might bleed into the wiring. Apply too little, and the player might become unreliable because of overheating.
I've removed the cover from my x800 before, and this is the interior. No analog circuitry, so the board is pretty simple. The SoC is underneath the heatsink. There's also a separate Sony ARM processor that presumably handles the apps, and the other big visible chip is flash memory.
aaronwt, Dartman and jkeldo like this.
post #7476 of 10107 Old 03-08-2018, 04:17 PM
BlackLightning3's Avatar
Quoted: 37 Post(s)
Liked: 29
Originally Posted by sage11x View Post
So I returned my first X800 due to ‘no signal’ on my projector. After trying the Samsung and LG and after being talked into the possibility that it was my hdmi cable I went and bought another X800. After replacing several cables I finally slapped a shelf next to the wall and ran a short 6 footer ‘certified premium’ to my projector. Worked for the last two weeks.
I just watched a movie last night: worked fine.
Today I’m trying to power things up and I’m again getting no signal. Without touching any of the hdmi cables I simply unplug the X800 and plug it back in. Within seconds I have an image.
I’m out of my return policy.
I really dislike this player. I now understand why so many people break the bank on the Oppo.
Turn off Deep Color output in the video settings.
PSN - Escobar
Yamaha RX-A870 Fronts: Bowers and Wilkins 704 S2 Rosenut Center: Martin Logan Motion 8i Rears: Martin Logan Motion 4 Front Heights: Martin Logan Motion 2 Subwoofers: 2 x Definitive Technology Supercube 2000
Sony 55" A8F, Panasonic UB820
BlackLightning3 is offline
post #7477 of 10107 Old 03-08-2018, 04:38 PM
jnnt29's Avatar
Quoted: 164 Post(s)
Liked: 157
There are thousands of these units out in the wild and only a small percentage have problems. Those problem ones are usually the units that are brought up here by people looking for advice. Keep talking about the the models that are working well to show that not all units are problems.. Thanks for providing info on your Sony..
jnnt29 is offline
post #7478 of 10107 Old 03-09-2018, 01:25 PM
Liked: 0
I didn't see this but if anyone already posted I apologize. Just curious if anyone ever gets what I would call a pink tint to there apps when backing out of a movie and if so what it may be caused from. Thanks for the help.
stimperley20 is offline
post #7479 of 10107 Old 03-09-2018, 06:23 PM
Davird_Jr's Avatar
Quoted: 54 Post(s)
Liked: 34
Originally Posted by Todd Scott View Post
I spent a lot of time, literally hours, adjusting my set (a 55X900E) to find the magic combination to bring shadows from the darkness. Using Bladerunner 2049 on the X800 player and some high contrast scenes, I ended up discovering that AUTO for color space is not a good choice at all. Set my TV to use DCI instead and the shadow detail and color was much better. Almost but not quite there. Then I discovered bumping gamma to +2 did it. I have no idea if this is set up correctly now but I am really, really happy with the HDR picture now. The farm house/kitchen scene at the beginning of the movie is particularly challenging due to the high contrast of bright overcast natural light from the small windows. Previously this scene was just way too dark I could barely discern there was an unlit florescent fixture above the stove. I went back to watch my problematic scenes in Altered Carbon. A huge improvement!
I really need to get my hands on a HDR test disc to verify levels. But
I heard that some Sony discs have a hidden test pattern menu if you enter 7669 on the remote. But the X800 has no keypad and even though the X900 allows numeric entry through HDMI control, I was unable to envoke these test patterns.
If it's not too much trouble, would you mind posting details of your TV and player settings, I would be interested in trying them here. TIA.
49Merc likes this.
Dave
Davird_Jr is online now
post #7480 of 10107 Old 03-10-2018, 12:27 PM
MisterXDTV's Avatar
Quoted: 49 Post(s)
Liked: 26
DCI is just plain wrong for color space: UHD Blu-rays are mastered in a BT.2020 container, even if the content inside is DCI.... If you force the TV to output DCI color space you are not decoding colors correctly....
aaronwt likes this.
MisterXDTV is offline
post #7481 of 10107 Old 03-10-2018, 12:40 PM
Todd Scott's Avatar
Quoted: 125 Post(s)
Liked: 64
If I use BT.2020 it looks like somebody turned the light offs. Everything is dark. I don't know the differences between any of these colour settings. All I know is DCI gives me a better picture. I'm willing to research it but it's probably over my head.
Sent from my SM-N900W8 using Tapatalk
Todd Scott is offline
post #7482 of 10107 Old 03-10-2018, 01:47 PM
UHD Addict
aaronwt's Avatar
Liked: 6657
Something must be setupo wrong if it looks that way.
Sent from my Galaxy S8 using Tapatalk
nathan_h likes this.
post #7483 of 10107 Old 03-10-2018, 02:41 PM
Liked: 0
Anybody else's YouTube not working??
Isalechips is offline
post #7484 of 10107 Old 03-10-2018, 03:21 PM
MisterXDTV's Avatar
Quoted: 49 Post(s)
Liked: 26
I have the same TV you have (Sony XE90) and I don't have this problem: you should check your TV settings, make sure you have Local Dimming set to MEDIUM/HIGH and X-Tended Dynamic Range set to HIGH for HDR content...
It's plenty bright for me, I even turned down brightness (AKA Backlight) from 50 to 32, and I still get a very bright image...
But you shouldn't touch Color Space and HDR mode.
post #7485 of 10107 Old 03-10-2018, 03:44 PM
Quoted: 1985 Post(s)
Liked: 1276
My 900E brightness is 16 and I almost need sunglasses.
Sent from my Pixel using Tapatalk
wavytoo likes this.
Hetfieldjames is offline
post #7486 of 10107 Old 03-10-2018, 04:49 PM
MisterXDTV's Avatar
Quoted: 49 Post(s)
Liked: 26
Are you talking about SDR or HDR mode?
I have brightness set at 8 for SDR and 32 for HDR....
post #7487 of 10107 Old 03-10-2018, 04:50 PM
Liked: 1276
16 SDR and I just let HDR do max brightness but I turn off extended dynamic range.
post #7488 of 10107 Old 03-11-2018, 09:54 AM
mgh26's Avatar
Quoted: 98 Post(s)
Liked: 108
My unit was purchased around October of last year. Not one lock up so far with lots of red box rentals and several purchased movies supporting HDR-10. Very solid player for me I am happy to report so the actual design is really good & I guess some units got out with faulty parts for reasons unknown.... Maybe..... Only Sony may have a clue but they will not disclose if alternate sub-assys were used in the build process for some of their later/ more recent builds due to lack of original parts. This does happen quite often in the electronics industry but 2nd sorced replacement parts somtimes are discovered to NOT perform as well even though they did have the required design specifications on paper from the alternate supplier. I'm not really sure if this is the case with this unit though.
mgh26 is offline
post #7489 of 10107 Old 03-12-2018, 07:33 AM
Tristan944's Avatar
Quoted: 77 Post(s)
Does anyone know what the "Projector" setting changes from the "TV" setting?
Sound: Anthem MRX-1120. Triad Silver speakers with Atmos and SVS PB-2000 subwoofers in 5.2.2. Sony UBP-X800. Roku Ultra. Amazon Fire TV. Micca Speck G2. ViewTV AT-263.
Picture: Epson 6040UB. Seymour Enlightor 4K 140 inch screen. Audioquest Forest HDMI.
Automation: Control4
Space: Dedicated theater room. Two Jerome's Challenger sofas.
Tristan944 is offline
post #7490 of 10107 Old 03-12-2018, 07:35 AM
cdnscg's Avatar
Quoted: 717 Post(s)
Liked: 178
I know when I'm watching a UHD disc on my 4k (but not HDR) pj, the projector setting is washed out. The tv setting is better.
WynsWrld98 likes this.
cdnscg is offline
post #7491 of 10107 Old 03-12-2018, 10:17 AM
Tristan944's Avatar
Quoted: 77 Post(s)
Interesting. I'll have to compare the settings and see if I can notice a difference. Thank you for your information.
post #7492 of 10107 Old 03-13-2018, 07:55 AM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
I have a choice between the x800 and the new x700. I took one look at the x700 the other night and it was no thank you. So at the end of the month I'm picking up the x800. Its replacing a Samsung 8500 4k Blu ray player that just died the other day.
aaronwt likes this.
steve1971 is offline
post #7493 of 10107 Old 03-13-2018, 08:26 AM
cmdrdredd's Avatar
Quoted: 4262 Post(s)
Liked: 4574
What did you not like about the x700?
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is online now
post #7494 of 10107 Old 03-13-2018, 08:32 AM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
What I didnt like about the x700 is it looked cheap and Sony went back to the smaller size. The x800 is what I was looking for and it fits right in with my other HT components. Cant wait to pick one up at the end of the month.
post #7495 of 10107 Old 03-13-2018, 08:40 AM
UHD Addict
aaronwt's Avatar
Liked: 6657
Unless one needs Dolby Vision, the x800 is easily the better option. Assuming they cost around the same.
post #7496 of 10107 Old 03-13-2018, 08:58 AM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
Well I have no need for DV and I can get a good price on an x800. So that's the route I'm going.
SteveC356 likes this.
post #7497 of 10107 Old 03-13-2018, 11:05 AM
Tristan944's Avatar
Quoted: 77 Post(s)
The player has some sort of audio up-scaling to high resolution.
Has anyone used this feature?
Does it improve the original audio quality?
post #7498 of 10107 Old 03-13-2018, 12:17 PM
UHD Addict
aaronwt's Avatar
Liked: 6657
I have mine set to on. It will double the sampling rate with stereo content. so 44.1 Khz content is doubled to 88.2khz. And 48khz content is doubled to 96khz. I do think it helps some with lower quality stereo content. At least when I made a comparison last year that's what I thought.
But then my Onkyo receiver also has a feature that does the same thing. So if my x800 isn't doing it, my Onkyo receiver is doubling the sampling rate with the stereo content.
post #7499 of 10107 Old 03-13-2018, 02:27 PM
ravitester's Avatar
Liked: 0
Originally Posted by apw2607 View Post
Yes you can use Plex and enable DLNA. The x800 doesn't require anything special for DLNA (unlike previous Sony BDPs), and uses the generic DLNA profile.
Again, TrueHD is *only* supported in M2TS containers. It doesn't matter what DLNA sever you use, this is a limitation of the player.
Flac multi channel is supported (as is DSD multi) over DLNA.
I must be setting things up wrong somehow. When I browse through the sony media server link to my jriver media server dlna, in any folder that has dsf files it says "no playable file in this category"
When I browse to the same folder using my Marantz SR6011 AVR it finds them and plays them showing DSD 2.8Mhz.
I have seen some people connect their TV directly to the Sony and use HDMI2 for audio. But I am stuggling to understand why the Sony refuses to even see the files.
Any ideas?
ravitester is offline
post #7500 of 10107 Old 03-14-2018, 10:54 AM
luzovich's Avatar
Quoted: 33 Post(s)
Liked: 25
3d mkv
Has anyone tried 3D MKV files on the X800? I tried to play a MVC 3D MKV and it just played in 2D. I will re-encode in SBS and try that. Just wondering if anyone has had any success and what format worked. Thanks.
luzovich is offline
Reply Blu-ray Players
4kupscale , 5040 , amazon prime video , dsf , Epson , problem , Sony , sony bdp-x800 , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
