OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 320 - AVS Forum | Home Theater Discussions And Reviews
 25382Likes
post #9571 of 9757 Old 04-27-2019, 11:04 AM
JonfromCB's Avatar
Quoted: 208 Post(s)
Liked: 147
Can someone tell me what firmware updates are available and how to accomplish them? Thanks
JonfromCB is offline
post #9572 of 9757 Old 04-27-2019, 11:18 AM
LNEWoLF's Avatar
Quoted: 466 Post(s)
Liked: 282
https://www.sony.com/electronics/sup...x800#downloads
Twin Pioneer AVR Locomotives-Elite SC 97, SC 1222 7.2.4, DOLBY Atmos and DTS X, (Front Pre Out,) JBL Pro Synthesis LS Series Speakers, F L R-LS80, Cen-LS, S L R-LS60, SB L R-LS60, 4 Dolby Atmos Enabled Klipsch R41SA, Twin Klipsch R120SW. Mitz 73740 DLP, Sony UBP-X800, ATV G4, Yamaha ATS 1060 Sound Bar, True Depth Firestorm 2.0 3D Glasses, Harmony Hub with Utlimate 1 Remote, Broadlink RM Pro2, EYE Pad Air, Winegard FL6550A
LNEWoLF is offline
post #9573 of 9757 Old 04-28-2019, 08:12 AM
JonfromCB's Avatar
Quoted: 208 Post(s)
Liked: 147
Originally Posted by LNEWoLF View Post
Thanks, I asked the question here before I went through the process looking for any helpful information/glitches, warnings, lessons learned, etc before I updated. Updating was about as simple and straight forward as any recent piece of equipment I've purchased....more simple than most and there has only been one update. I checked the Sony site for the "plain language"
explanation of the update, and after the update I quickly realized there is no longer Grace Note support/function. This really pizzes me off, as I use the 800 for music more than I use it for video and a big part of why I selected it was it's audiophile level processing along with it's ability to put all the album art, track information and words to the songs on the screen during playback....all that is now gone.
KramerTC likes this.
post #9574 of 9757 Old 04-28-2019, 11:14 AM
gentlejax's Avatar
Quoted: 44 Post(s)
Liked: 24
what should the player be set to in the Audio settings section for pcm 48/96/192 ?
gentlejax is offline
post #9575 of 9757 Old 04-28-2019, 11:30 AM
LNEWoLF's Avatar
Quoted: 466 Post(s)
Liked: 282
Within the original link I provided. The removal of Gracenote is listed on the product firmware page under “product alerts.”
https://www.sony.com/electronics/sup...icles/00203410
LNEWoLF is offline
post #9576 of 9757 Old 04-28-2019, 05:47 PM
Quoted: 21 Post(s)
Liked: 2
Send a message via Skype™ to bernievink
The best your reciever amp can process without causing trouble.
also remember the HDMI cable may cause trouble at higher bit rates if it is not a high quality cable.
Samsung UA60KU6000WXXY TV, Sony STR#dh770 Receiver with wall, ceiling, and floor mounted 7.1 Sony Speaker system, Sony UBP-X800 Ultra HD Blu-ray™/DVD Player
bernievink is offline
post #9577 of 9757 Old 04-29-2019, 01:06 PM
ezda's Avatar
Liked: 0
Originally Posted by bommai View Post
Which firmware version. I thought I had the latest and I don’t have any hisses converting from dsd to pcm.
Sent from my iPhone using Tapatalk Pro
It's the latest US version, M36.R.0338 which apparently only removes Gracenote.
I tried a 16- and 24-bit 176.4KHz PCM file from a flash drive (over two different AudioQuest HDMI cords swapped to test) and no hissing or alias noise. I also tried 88.2, 96, and 192 .wav and flac files, no issues. I only get high-frequency hiss (aliasing noise) when playing SACD that is internally converted to PCM. I'm 95% sure it didn't have this issue before as I would have noticed something as annoying as that, but could be wrong. I tried the CD layer - no issue with noise. I tried both HDMI outputs. I also confirmed that playing an SACD over the COAX has no issues (and yes, this is a rare player that plays SACD over COAX at a downsampled 16-bit 44.1, and NO it's not secretly playing the CD layer on a hybrid disc.)
What's interesting is that if I use the sample rate conversion function in my DAC to convert the 176.4 to 88.2, the aliasing noise is gone and it sounds much better, but still has some weirdness to it. I have not tried a .dsf or whatever DSD file from a USB stick yet, but will follow up. It's as if the 50k high pass cutoff filter isn't in place.
It's weird that Sony decided to use 176.4KHz instead of 88.2 like dozens of other players, and in the case of DSD>PCM conversion, the higher sample rate ISN'T better.
Here's an example on an Oppo:
"Why not 176.4KHz when converting SACD to PCM?
The hardware is capable of doing 176.4 and the licensing is not different. OPPO believes that 88.2KHz actually produces a better quality result for SACD DSD to PCM conversion. OPPO feels that even to offer 176.4 as an option would mislead people into thinking the higher rate must be better when that's simply not the case.
SACD players do not convert at a higher rate -- as measured at the Analog output. The process of producing Analog from DSD for SACD requires a 50KHz filter (just as exists in the OPPO's DACs when DSD-Direct-to-Analog conversion is in effect), which is the equivalent of a 100KHz sampling rate limit (see Nyquist Limit). 88.2 is the highest multiple of 44.1 that does not exceed 100."
To me, it sounds like the UBP-X800 with the latest firmware is not using that 50k filter cutoff. I have no way to confirm since I can't downgrade and don't have another player... I'll probably just keep this unit for Blu-Ray only and get a different SACD transport..
ezda is offline
post #9578 of 9757 Old 04-29-2019, 05:58 PM
deano86's Avatar
Quoted: 622 Post(s)
Liked: 308
Sure seems to me that you have some very solid data to back up your theory about your sound issue being tied to the latest firmware update... why not call Sony and report your findings... not to mention they may pass you up to someone who can possibly provide you with an older version of firmware to test? Worth a shot, I would think....
deano86 is offline
post #9579 of 9757 Old 04-30-2019, 01:48 PM
bradman's Avatar
Quoted: 190 Post(s)
Liked: 144
That setting is for the digital out, not HDMI.
PSN BradCompany
bradman is offline
post #9580 of 9757 Old 05-03-2019, 12:05 AM
Quoted: 21 Post(s)
Liked: 2
Oops
post #9581 of 9757 Old 05-03-2019, 01:16 PM
toshu's Avatar
Quoted: 23 Post(s)
Does anyone know how to "side load" an app on the 800?? I would like to add Tidal and Plex
toshu is offline
post #9582 of 9757 Old 05-04-2019, 09:10 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
Originally Posted by winker12 View Post
I've got a Sacd which I purchased that will work. The only other Sacd's are ones that I downloaded from-at the time-Demonoid-or other online bit torrent sites. None of those work-I have maybe 10 or so. I have a lot of Dvda's that work through the anolog 5.1inputs using my Pioneer Dvd player. I can deal with using 2 different players but I originally bought the Sony thinking everything would work through the Sony. I guess maybe I'm over my head on the dsf/dff!
That is a Sony copyright thing, they invented Sacd and don't allow copy Sacd on disc.
But buy a big memory card/usb stick or a Mobile harddrive, I can confirm that this will play off the DSD files.
IIDexII is offline
post #9583 of 9757 Old 05-04-2019, 09:11 AM
IIDexII's Avatar
Quoted: 159 Post(s)
Liked: 201
This won't work I believe.
You're stuck with Spotify.
I prefer Spotify.
What about a cheap android TV Streamer?
ez1dog likes this.
IIDexII is offline
post #9584 of 9757 Old 05-04-2019, 03:03 PM
Quoted: 236 Post(s)
So i am upgrading from a BenQ HT2050 to a BenQ LK970 projector. Should i change my 4k bluray player from my Sony UBP-X800 to a Panasonic DP-UB820 before i get my projector calibrated? Or should i stick with my Sony?
sound2017 is offline
post #9585 of 9757 Old 05-04-2019, 04:36 PM
Sharp1080's Avatar
Quoted: 1050 Post(s)
Liked: 746
I'm confused? Why the question? Do you want a new player even though you don't have it connected to see the differences if any?
Sharp1080 is offline
post #9586 of 9757 Old 05-04-2019, 05:34 PM
Quoted: 236 Post(s)
Sorry i should have said that i want Dolby Vision through the Panasonic. Is Dolby Vision worth it or should i keep my Sony? Do i just download the Dolby Vision with the Panasonic hooked up to the internet.
post #9587 of 9757 Old 05-05-2019, 08:28 AM
Mr.G's Avatar
Quoted: 1265 Post(s)
Liked: 1357
Your new BenQ LK970 does not support Dolby Vision. No projector does that I know of.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #9588 of 9757 Old 05-05-2019, 02:09 PM
JMCecil's Avatar
Quoted: 318 Post(s)
Liked: 331
But the higher end BR players can tone map prior to sending the image. I think the Panny UB9000 has two projector modes that it will tone map prior to sending the image. One scaled from I think 500 nits and one scaled from 250 nits. Those may not be the correct numbers, but it's something like that. Not sure about the model of Panny he mentioned.
JMCecil is offline
post #9589 of 9757 Old 05-06-2019, 06:12 AM
I-SIBI's Avatar
Quoted: 83 Post(s)
Liked: 119
Send a message via Skype™ to I-SIBI
Correct... but keep in mind that the UB9000 "HDR Optimizer" introduces banding in some situations (is not a bandwidth issue, I got fiber cabling on all the chain).
For that reason I often prefer the LX500 or the X800 when projecting, even if the overall image looks a little bit darker... but there is no banding at all...
On the other side, the UB9000 can send an SDR BT2020 signal directly to the PJ... with no HDR issues...
So, even the Panny players got issues with PJs... and the HDR Optimizer is good or bad based on personal tastes... for sure is "different"...
Pioneer UDP-LX500 - Oppo 203EU - Panasonic DP-UB9000 - SONY X-800 UHD BLU-RAY -Apple TV 4K - Marantz SR6013 in 5:1:2 Dolby ATMOS/DTS:X Config - KLIPSH REFERENCE (Towers + Central + 2 surrounds + 2 Atmos Enabled) - KLIPSH R-120SW SUBWOOFER- LG OLED 65C8 - LG OLED 55B7 - OPTOMA UHD60 4K/HDR Projector on 110' SCREEN- Toshiba HD-EP30 HDDVD PLAYER - NAIM ND5 XS 2 streamer - NAIM NAIT XS 2 stereo amplifier - Roon Core on the network
I-SIBI is offline
post #9590 of 9757 Old 05-06-2019, 09:31 AM
Mr.G's Avatar
Liked: 1357
Yes, I'm aware. He was specifically talking about Dolby Vision which his projector does not support. So it doesn't matter if the UB820 has Dolby Vision capability if he can't use it in that manner.
Mr.G is offline
post #9591 of 9757 Old 05-06-2019, 09:41 AM
JMCecil's Avatar
Quoted: 318 Post(s)
Liked: 331
Yes it does matter. It's like using MadVR or whatever ... the metadata gets processed before it gets sent to the projector. It will just be on a color curve that the projector can support. So although the projector itself can't process the metadata, it doesn't have to.
JMCecil is offline
post #9592 of 9757 Old 05-06-2019, 09:54 AM
Mr.G's Avatar
Liked: 1357
I own the UB820 and use it with my Epson HC4000 projector. I am perfectly aware of the UB820 capabilities.
Mr.G is offline
post #9593 of 9757 Old 05-18-2019, 01:16 PM
FuzzyReets's Avatar
Quoted: 269 Post(s)
Liked: 34
Any reason to upgrade?
HI folks. I follow this thread from time to time to catch up. Just curious if this player is "dated" enough at this point to consider upgrading it to something newer or not? Suggestions/feedback appreciated. Thanks.
Denon x2300w
PS4 Pro
Sony UBP-X800
Apple TV4k
LG OLED65B6p
FuzzyReets is offline
post #9594 of 9757 Old 05-18-2019, 01:19 PM
toshu's Avatar
Quoted: 23 Post(s)
Shutting USB HDD down
When I shut down my Sony, and still have a portable HDD plugged in, the drive continues to spin and not shut down. Does anyone know if there is anyway to change a setting to have the USB attached HDD shut down when the player is shut down????
toshu is offline
post #9595 of 9757 Old 05-18-2019, 01:22 PM
toshu's Avatar
Quoted: 23 Post(s)
How to side load an App??
I prefer Spotify.
I prefer to use Tidal due to the streaming quality and therefore want to side load Tidal on the Sony. I hate the fact that sony so quickly stops supporting their products and limit third party apps
toshu is offline
post #9596 of 9757 Old 05-18-2019, 01:23 PM
Dartman's Avatar
Quoted: 34 Post(s)
Well if your happy with it you could always buy the upgraded version the x800m2 that now supports Dolby vision when it gets released if it hasn't been already. Sounds like it's going to be the same price. If you don't need DV then your probably fine as is.
Dartman is offline
post #9597 of 9757 Old 05-18-2019, 01:49 PM
LNEWoLF's Avatar
Quoted: 466 Post(s)
Liked: 282
The Sony X800M2 has been available for a couple weeks now.
https://www.avsforum.com/forum/149-b...on-thread.html
https://www.avsforum.com/forum/149-b...rice-talk.html
LNEWoLF is offline
post #9598 of 9757 Old 05-18-2019, 06:32 PM
deano86's Avatar
Quoted: 622 Post(s)
Liked: 308
Do you have quick start mode enabled on your Sony? If so, shut it off...
deano86 is offline
post #9599 of 9757 Old 05-18-2019, 07:00 PM
Quoted: 309 Post(s)
Liked: 237
It is not a matter of dropping support none of the Sony BlueRay players including the x800 are Android devices that might support any type of side loading. The vast majority of AV products have proprietary operation systems that you cannot decide to load whatever you feel like on.
Can you name any Blue Ray player that supports side-loading or an app store? I can't.
fhschellenberg likes this.
Current system:
Sony 75X900e/Sony HT-NT5 sound bar with SR-5 rear speakers
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/'Sony PS-4
Cheddarhead is offline
post #9600 of 9757 Old 05-18-2019, 09:37 PM
Dartman's Avatar
Quoted: 34 Post(s)
I think the unit allows you to pick favorites from the available programs they carry on whatever smart setup they are using but yes you can't find non included things like side loading from the play store or other sources. The new version I guess only includes 3 popular programs right now but I'm sure Sony will add more with software and firmware updates. They have added and removed a few since the 800 was released.
Dartman is offline
Reply Blu-ray Players
4kupscale , 5040 , dsf , Epson , problem , Sony , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
