OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 333 - AVS Forum | Home Theater Discussions And Reviews
 25431Likes
post #9961 of 9971 Old 01-25-2020, 07:29 PM
Thyrane's Avatar
Originally Posted by Thyrane View Post
Hey guys, it has been many many years since I've used a forum. Sorry if this has been answered, but I did a lot of research and came up empty. Is there a way to play dvds and or interlaced blurays at 4k60? It always defaults to 30p at 4k and the frames look very bad. They have "judder" and look uneven. There is only an option for 4k that simply says "4K", no option for screen refresh rate. I have an up to date hdmi cable and set the hdmi to "enhanced" on the tv. Any help would be appreciated.
A bit of an update. The player can upscale interlaced content at 1080p60. I would really like the player to scale to 4k60 because it looks a bit better than the tv. Can anyone confirm this player can upscale interlaced content to 4k at 59/60hz? I would feel better knowing either it doesn't or if there is an option I've been overlooking. I've tried literally every upscale and screen resolution combination.
Thyrane is offline
post #9962 of 9971 Old 01-27-2020, 07:26 AM
Thyrane's Avatar
Another update, it seems sending a 30p signal to the tv is tied to the video being 29.97 fps, not being interlaced. I played a non interlaced video at 29.97 fps and it still sent a 30p signal. Does anyone know if there is an option to disable 30p within the player? Anything at 29.97 fps is unwatchable on this player. It sends the correct signal at 23.976 fps. Any advice would be appreciated.
Thyrane is offline
post #9963 of 9971 Old 01-27-2020, 03:37 PM
tre74's Avatar
Quoted: 25 Post(s)
Liked: 46
If you set 4K upscaling to AUTO2, it should change from 1080/60 to 4K/60. Everything else should be set to AUTO as well.
tre74 is offline
post #9964 of 9971 Old 01-27-2020, 05:45 PM
Thyrane's Avatar
Thanks for the reply. I tried Auto with everything as well as manually selecting 4K, auto1 and auto2. It upscales 24p content correctly. Is there any way someone can check a dvd or 29.97fps file and see if it displays as 2160p60? Then I will set it to 1080p60 when watching 30p content or just stick with madvr+mpc for dvds. I only got this to have a simple all-in-one type player, but this one issue is really annoying. I would have never thought a current player would have such an issue playing dvds. Not that big a deal, but that takes away from the "simple" aspect of things because I need to change the resolution every time I watch dvds/interlaced/30p content. Thanks again for the reply.
Thyrane is offline
post #9965 of 9971 Old 01-29-2020, 03:01 AM
Liked: 0
Good morning all
I am still in 55vt30 plasma and JVC HD1 video projector, so both are Full HD and not 4K
I plan to take the sony 800m2 ou panasonic 420/820 to replace the panasonic bd500 (capricious platinum with beug)
UDH already render well in 1080p?
a significant gain against the 500 on full hd?
a special setting for downsampling from 4k to full hd?
the same video settings?
HDR conversion on 1080p with a 4K blu ray
thank you so much
ludovic62310 is offline
post #9966 of 9971 Old 02-03-2020, 06:16 AM
Liked: 4
Originally Posted by Icedearth_Dave View Post
That is really helpful to know thank you!
Hopefully it's a batch thing then and my copy on order will work fine.
So I received my third copy of Predator 4k and it worked flawlessly. Huge relief it is not a player issue as I had started to worry. Big learning point for me to persevere with problematic discs before stressing about hardware.
Icedearth_Dave is offline
post #9967 of 9971 Old 02-03-2020, 12:38 PM
UHD Addict
aaronwt's Avatar
Quoted: 9754 Post(s)
Liked: 6422
I must be lucky. I've easily played over 400 UHD BDs in my x800 and they have all played fine.
Sent from my Galaxy S10
slimm, CaptinCrunch, PJL99 and 2 others like this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #9968 of 9971 Old 02-11-2020, 10:39 AM
HeisenbergABQ's Avatar
Quoted: 48 Post(s)
Liked: 9
How long does it take for your players disc tray to eject after pushing the eject button? On mine it takes about 3 seconds from pushing the button for the tray to open. Is this normal or is there something going on with my player? I've had it for about 3 months and it's been this way the whole time, I was just thinking yesterday though that it seems a bit slow compared to players I've had in the past.
75" Sony Z9F
Receiver: Onkyo 686, Center channel: Klipsch RP-404C, front speakers: Klipsch RP-8000F's, Surrounds: Klipsch RP-500M's, Subwoofer: SVS PB-2000
Roku ultra, Xbox one X, PS4 PRO, Sony UBP-X800
HeisenbergABQ is offline
post #9969 of 9971 Old 02-14-2020, 07:34 AM
CCsoftball7's Avatar
Quoted: 1703 Post(s)
Liked: 1303
It takes mine about that long as well.
HeisenbergABQ likes this.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #9970 of 9971 Old 02-14-2020, 02:06 PM
Quoted: 450 Post(s)
Liked: 51
Mine takes about that long also. I also have a Magnavox DVD recorder that does open faster initially compared to the Sony, but it is noisier and the tray moves slower. So each brand has their quirks I suppose.
jkeldo is offline
post #9971 of 9971 Old 02-14-2020, 02:17 PM
Quoted: 48 Post(s)
Liked: 9
Good to hear it's not just mine. It doesn't bother me, but I just wanted to make sure it wasn't an issue.
jkeldo likes this.
75" Sony Z9F
Reply Blu-ray Players
4kupscale , 5040 , dsf , Epson , problem , Sony , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
