OFFICIAL Sony UBP-X800 Owners Thread (No Price Talk) - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 25470Likes
post #10081 of 10108 Old 06-23-2020, 09:09 AM
Liked: 0
Got a chance to buy the X80 (Best Buy version) for ~$80 used. I have a 4K non-hdr TV, and a non 4K receiver. This player is about my only choice in getting high quality audio to my receiver and 4K to my tv without having to upgrade the receiver. Usually use my Xbox for Netflix, 4K blu ray, and Spotify. Unfortunately with my receiver I’m limited to stereo or compressed surround through Toslink. Currently I have a 4ch setup, and plan to add channels as time comes. I don’t have any SACD, or DVD-A but if I had this player I would test it. btw my receiver can pass dsd. I do like the fact it can play about any disc format. Anyone tried the DSEE HX when playing regular CDs? Does Netflix play well?
Currently my only other option is the AVR Key from HDFury, and that doesn’t seem as reliable, or future proof but I don’t know. Sort of bypassing my Xbox altogether but is this a good buy? I have an older Sony blu ray player but it’s slow and can only to 1080p...and some apps have lost support.
Crashcarson is offline
post #10082 of 10108 Old 06-23-2020, 10:26 AM
btimms's Avatar
I've been using the AVR key for a couple of years now with a non 4k avr and it's been rock solid. I tried a number of different cheaper devices at the time but none came close to the key.
Sent from my SM-T290 using Tapatalk
btimms is offline
post #10083 of 10108 Old 06-23-2020, 10:49 AM
Liked: 0
I’m considering the key, but also this player. Not sure which route I want to go.
post #10084 of 10108 Old 06-23-2020, 11:19 AM
btimms's Avatar
I got the x800 because it had a separate sound output for my non 4k avr but it did not work. Hence I got the avr key and use it with an hdmi switch with my 4k devices
(atv4k, firetv4k, kodi, x800). I think the HDMI version for an avr has to be 1.4 or later which mine isn't.
btimms is offline
post #10085 of 10108 Old 06-23-2020, 12:48 PM
Liked: 0
Is there a way to test that? Because mine is version 1.3....
very interesting news. And was that for everything or specifically uhd blu rays, Netflix, or a regular blu ray? I would think a regular blu ray wouldn’t be an issue. Or maybe an hdcp codec?
post #10086 of 10108 Old 06-23-2020, 06:16 PM
btimms's Avatar
I think I had to figure it by year of introduction for hdmi versions. My avrs (2009) manual doesn't mention it.
btimms is offline
post #10087 of 10108 Old 07-02-2020, 06:18 PM
Quoted: 51 Post(s)
Neither my Sony nor my Harmony remote will connect to the x800. It connected fine last weekend and today, nothing. The movie comes up and I can't control the menu to play the movie or anything in the menu. I tried changing the batteries and Blu-ray/4k movies and that didn't fix it. Restarted the player and still the same issue. What could be the problem?
MrZoolittle is offline
post #10088 of 10108 Old 07-03-2020, 06:09 AM
deano86's Avatar
Quoted: 724 Post(s)
Liked: 390
Have you unplugged the player for a few minutes and tried again? It is not a connection problem in that the X800 uses the typical IR line of sight commands and not a Bluetooth wireless connection. So, make sure there is still a clear line of sight to the IR receiver on the front face of the player. If still not working, maybe try resetting the player back to factory defaults? Pretty rare that just the IR receiver circuit in the player would go bad....
MrZoolittle likes this.
deano86 is online now
post #10089 of 10108 Old 07-03-2020, 04:47 PM
Quoted: 51 Post(s)
Thanks. It worked an hour later and again today. Electronics can be finicky.
post #10090 of 10108 Old 07-03-2020, 06:50 PM
Quoted: 130 Post(s)
Liked: 65
What’s the main difference between the 800 and the 700 Sony?
SD1290 is online now
post #10091 of 10108 Old 07-04-2020, 01:43 PM
bguzman's Avatar
Quoted: 192 Post(s)
Liked: 1316
The X800 is a universal disc player.
HT TCL 55P605, BenQ W7000, Pioneer UDP LX500, Panasonic LX1000, Firestick 4K, ATV4K, Pioneer SC-LX701, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Music Sansui SR-4050, SR-3030, Dual 1219, Pioneer BDP-85FD, Emotiva PT-100, Sherwood Newcastle R-972, Polk Monitor 10 & 5, SVS SB1000
bguzman is offline
post #10092 of 10108 Old 07-04-2020, 02:05 PM
Cheddarhead's Avatar
Quoted: 824 Post(s)
Liked: 948
Build quality, the 800 is much better and the 800 has the ability to play almost any type of optical disk you throw at it, very handy if you are into music and SACD or DVD-A.
Current system:
Sony 75X900e/Sony STR-DN-1080, CS-3/CS-8/CS5
Sony X800 4K blu-ray player/Dish Hopper3
Roku 4 Premier/Sony PS-4
Cheddarhead is online now
post #10093 of 10108 Old 07-04-2020, 07:53 PM
UHD Addict
aaronwt's Avatar
Quoted: 10013 Post(s)
Liked: 6672
The X700 does Dolby Vision, HDR10, and HLG. While the X800 does HDR10 and HLG.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #10094 of 10108 Old 07-04-2020, 08:37 PM
flyinion's Avatar
Quoted: 625 Post(s)
Liked: 434
I need to replace my x800 at some point. Didn’t understand about the 4K formats at the time and getting a 4K tv finally and need a player with Dolby Vision. I bought the x800 two years ago to replace a 9 year old BR player. Started buying 4K discs as well since they tend to have Atmos and DTS:X more often and that gets left off BR a lot. Downscaling has been fine mostly. Oh well
LG 65" CX OLED | Denon AVR-X4500H | Sony UBP-X800 | Chane A2.4 L/C/R | Chane A1.4 SR | SVS Elevation Atmos/height | SVS PB-2000 | Logitech Harmony 950 | Arris MX011ANM (Xfinity X1) | Apple TV 4K
flyinion is online now
post #10095 of 10108 Old 07-05-2020, 05:30 AM
Quoted: 272 Post(s)
Liked: 163
I went from the 800 to the 800.M2. The M2 is a very nice unit and if you want to stay with this level Sony a worthwhile step up.
bguzman and ToonMasterTim like this.
Johnson-from-Arizona is offline
post #10096 of 10108 Old 07-05-2020, 07:11 PM
Liked: 0
Got this player the other day. No issues. I have hdmi 1.3. Hardest part was trying to figure out how to turn the hdmi out OFF. Might not be that simple for anyone else, but had 2 receivers and both worked fine, both non 4k. using a composite for monitor out on the receiver would work too to trip the receiver to pass audio even though it detects not passing through the tv.
post #10097 of 10108 Old 07-07-2020, 02:04 AM
flyinion's Avatar
Quoted: 625 Post(s)
Liked: 434
So I finally upgraded to a 4K OLED today, been using my X800 with a plasma for a couple of years (needed a new BR player and figured might as well). I'm unsure if I have the color sampling set correctly? I just left it on auto with deep color enabled. My Denon reported it was getting a 4K/24p YcBcCr 4:4:4 signal. Just wondering if I should be setting it manually to say 4:2:2?
post #10098 of 10108 Old 07-08-2020, 03:45 PM
tre74's Avatar
Quoted: 68 Post(s)
Liked: 91
That sounds right. You will see the numbers change depending on the disc used for playback.
tre74 is offline
post #10099 of 10108 Old 07-08-2020, 04:03 PM
flyinion's Avatar
Quoted: 625 Post(s)
Liked: 434
Are you sure? I thought discs were mastered at 4:2:0 or something like that? I was playing the 5th Element UHD and it was reporting 4:4:4 instead in the Denon signal in/out display so it seemed like the player was upconverting to 4:4:4 because it probably detected the Denon and LG OLED could handle it. I tried setting it manually to 4:2:2 and couldn't see any difference visually on a handful of scenes so kinda not sure what to do with it at this point. I don't want to sacrifice any PQ etc. but I don't think I need to be converting to a format that uses a ton more bandwidth just because the connection chain can handle it if there's no actual benefit.
post #10100 of 10108 Old 07-08-2020, 08:02 PM
UHD Addict
aaronwt's Avatar
Liked: 6672
That depends. If set to 422 it can stay at 422 since the HDMi spec requires 422 to always be in 12 bit. And it can be used at 2160P60 or 2160P24.
While 444 at 2160P60 has to drop down to 8 bit. Which you do not want for HDR content. At 2160P24 444 can be 10 bit or 12 bit.
aaronwt is offline
post #10101 of 10108 Old 07-08-2020, 08:05 PM
UHD Addict
aaronwt's Avatar
Liked: 6672
The discs are using 420. But the HDMI 2.0 spec only allows the 420 colorspace to be used at 2160P60(or 2160P50).
The HDMi 2.0 spec does not allow the 420 colorspace to be to be used for any other framerate at 2160P.
aaronwt is offline
post #10102 of 10108 Old 07-08-2020, 08:38 PM
flyinion's Avatar
Quoted: 625 Post(s)
Liked: 434
Thanks. So what’s your take on my question? Should I set manually to 4:2:2 like I have for now or leave it on auto and trust the player to output correctly as needed?
post #10103 of 10108 Old 07-08-2020, 11:00 PM
Quoted: 496 Post(s)
Liked: 179
I leave mine at auto all times and do not worry about that figure. As was mentioned, all consumer video is produced in 4:2:0 and running the HDMI link on 4:2:2 or 4:4:4 has no impact on the movie image quality.
It will switch down to 4:2:2 to maintain 10/12-bit output required by HDR formats.
The only things that would benefit from higher than 4:2:0 chroma subsampling are the UI elements. But this player's UI is visually irrelevant anyway.
ez1dog likes this.
priitv8 is offline
post #10104 of 10108 Old 07-08-2020, 11:36 PM
flyinion's Avatar
Quoted: 625 Post(s)
Liked: 434
Hmm, well I was maintaining 4:4:4 12bit on the UHD of Fifth Element, but it was running at 24p so maybe that's why. Or my Denon is reading the incoming signal incorrectly. I say that because at least according to one HDMI spec chart I found, that should only be supported by Dolby Vision and since I have the original X800 I was just in HDR10 mode
post #10105 of 10108 Old 07-09-2020, 08:34 AM
UHD Addict
aaronwt's Avatar
Liked: 6672
444 at 12 bit is supported at up to 2160P30.
I also leave mine on Auto. Since my setup has no problem with colorspace changes and my cables can handle up to the 18Gbps bandwidth requirement.
As long as the x800 switches to 422 at 12 bit for something like Gemini Man. Which is a 2160P60 title. Because if it stays at the 444 colorspace, it could only output at 8bit. And you want 10 bit or 12 bit output with HDR. And I don't recall ever seeing the 420 colorspace at 2160P60 from the X800.
aaronwt is offline
post #10106 of 10108 Old 07-09-2020, 08:51 AM
tre74's Avatar
Quoted: 68 Post(s)
Liked: 91
In auto, you should see 444 on UHD discs at 24fps and 422 on the very few UHD 60fps discs. Same here for my X800 that is set to auto. You won't lose anything if set to 422 but don't worry about it displaying 444 if left on auto.
tre74 is offline
post #10107 of 10108 Old 07-09-2020, 09:41 AM
flyinion's Avatar
Quoted: 625 Post(s)
Liked: 434
Ok thanks guys, I'll put it back to Auto and leave it then
post #10108 of 10108 Old Yesterday, 06:23 AM
HeisenbergABQ's Avatar
Quoted: 138 Post(s)
I've had mine for close to a year now, manufacturers warranty is about up. It worked fine when I first got it, I watched the entirety of breaking bad and Better call Saul without a hitch. Now however, I rarely get through a movie without the player locking up, forcing me to unplug and restart, after which it's usually okay. Is this is even worth contacting Sony for?
Issues like this are a pita, when there's something wrong but you can't bring out the issue. It freezes almost every time I use it now, but it's usually around an hour or so into a movie, and I can't imagine Sony will do anything beyond turning it on to see that it performs basic functions. Also, is the serial# listed in a menu somewhere like on Sony TV's?
77" LG CX
Receiver: Denon X3700H, Center channel: Klipsch RP-404C, front speakers: Klipsch RP-8000F's, Surrounds: Klipsch RP-500M's, Subwoofer: SVS PB-2000
Roku ultra, Xbox one X, PS4 PRO, Sony UBP-X800
HeisenbergABQ is online now
Reply Blu-ray Players
4kupscale , 5040 , amazon prime video , dsf , Epson , problem , Sony , sony bdp-x800 , sony ubp-x800 , streaming music , surround decode , ubp-ux80 , ubp-x1000es , x800
