Official LG UP970 4K Blu-Ray Player Owners Thread (No Price Talk) - Page 98 - AVS Forum | Home Theater Discussions And Reviews
 3220Likes
post #2911 of 2930 Old 05-01-2020, 05:00 PM
Kusakun's Avatar
Liked: 0
Hi People im writing because i wanted to know if there is a way to upgrade the firmware of this player besides the online way -Which LG no longer is giving support-
Kusakun is offline
post #2912 of 2930 Old 05-08-2020, 03:40 AM
Quoted: 32 Post(s)
Liked: 42
I just got an update for the player, although the LG Website doesn't acknowledge there are any! Anybody else get this?
TheDude Abides is offline
post #2913 of 2930 Old 05-08-2020, 06:30 AM
Liked: 0
Yes i'm getting it too
BD39.338.91219.C
nova44 is offline
post #2914 of 2930 Old 05-08-2020, 11:07 AM
lujan's Avatar
Quoted: 5205 Post(s)
Liked: 3219
Me too, I'm surprised that after all this time we're still getting updates. I wonder what it does?
lujan
695 Ultra HD
737 HD
4 SD
lujan is online now
post #2915 of 2930 Old 05-08-2020, 01:39 PM
OT7
OT7's Avatar
Quoted: 16 Post(s)
Got the update.
OT7 is online now
post #2916 of 2930 Old 05-09-2020, 10:56 AM
Quoted: 1976 Post(s)
Liked: 1177
Updating as well. I hope it doesn't change my settings. I have it set to RGB and 16:9 Full.
It seems faster with slightly better PQ.
Sent from my LGMP450 using Tapatalk
DisplayCalNoob is offline
post #2917 of 2930 Old 05-10-2020, 01:10 AM
Quoted: 32 Post(s)
Liked: 42
I haven't been able to find any info on it. Anybody find something about what it did?
post #2918 of 2930 Old 05-10-2020, 05:51 PM
robsis's Avatar
Quoted: 91 Post(s)
Liked: 154
I've done several searches and have come up empty handed. Unit seem to function perfectly after the update with no change in anything. I have a few reference 4k discs that I am going to pull out and see if I notice anything different at all in the scenes I have watched and re-watched in the past as 100/100......
To Be Continued....(maybe).
vn800art and TheDude Abides like this.
Ptree:
Sometimes, it's only afterwards, I find that I'm not there.
robsis is offline
post #2919 of 2930 Old 05-12-2020, 01:31 PM
mbernstein's Avatar
Quoted: 96 Post(s)
Deleted
Samsung UN78HU9000GXZD / Marantz SR8012 (with AIRCOM Infinity T10) / B&W 705 S2 + HTM71 S2 Front + B&W DB4S sub + NHT SuperZeros 2.1 Back
LG OLED 65C8PSA / Marantz SR6013 / B&W CM1 S2 + CM Center S2 Front + Jamo J10 sub + NHT SuperZeros 2.1 Back
LG OLED 55EA9850 / Yamaha Soundbar YSP 2700
mbernstein is offline
post #2920 of 2930 Old 05-17-2020, 06:52 AM
DJ Lushious's Avatar
Quoted: 361 Post(s)
Liked: 125
Originally Posted by mbernstein View Post
After I did the firmware upgrade, something weird has happened: my Harmony Elite remote now only controls the player with direct view with the player. Player is inside a cabinet and has always worked with the IR extension that comes out of the Harmony HUB. After the upgrade only works through the control. I checked Harmony settings and commands are set to go through the hub. And I have an UBK 90, which I assume is pretty much the same player, right below it that still works perfectly with the Harmony...
Thanks for any advice.
Have you done a recent sync with your Harming remote to the MyHarmony program?
I lost functionality for powering on/off my AppleTV after a TvOS upgrade that was fixed with updating the remote with a sync.
DJ Lushious is online now
post #2921 of 2930 Old 05-17-2020, 10:15 AM
mbernstein's Avatar
Quoted: 96 Post(s)
Thanks. Yes, I had already done it a few times, and tried to re-program, but it didn't help either. Very weird.
post #2922 of 2930 Old 05-17-2020, 11:59 AM
mbernstein's Avatar
Quoted: 96 Post(s)
Well, I re-positioned my gear and it worked. Probably I did something stupid. Thanks for the help, I will delete my original post.
post #2923 of 2930 Old 05-23-2020, 02:22 AM
ptruman's Avatar
Blimey - the UP970 has a firmware update out of the blue...
This takes us to SW version BD39.338.91219.C
Mine installed - not sure yet what it's fixed/changed as it was very late.
YouTube is doing HDR correctly - didn't get a chance to load NetFlix.
ptruman is offline
post #2924 of 2930 Old 05-26-2020, 09:49 AM
Liked: 1177
After some testing of several disc, on this player. RGB appears to be the proper color space to use. YCbCr seems to compress dynamic range and color. Dolby Vision looks exceptionally detailed, colorful, with lots depth and highlights that pop while the player is set to RGB.
HDR10 works fine under YCbCr and is actually the right color space, DV no. Atleast on my display.
post #2925 of 2930 Old 05-28-2020, 08:36 PM
NoUDont's Avatar
Quoted: 84 Post(s)
Liked: 39
What tv do you have?
So you manually go in each time in settings and change to RGB depending if the disc has Dolby Vision?
NoUDont is offline
post #2926 of 2930 Old 05-28-2020, 10:16 PM
Liked: 1177
2016 Vizio P Series. The answer is yes, the difference in PQ is worth it and significant enough to change the setting. And most of my disc have DV encodes.
NoUDont likes this.
post #2927 of 2930 Old 05-29-2020, 07:21 AM
NoUDont's Avatar
Quoted: 84 Post(s)
Liked: 39
Great. Thanks. I have a 2017 Vizio M Series. I will give it a try.
NoUDont is offline
post #2928 of 2930 Old 06-16-2020, 08:20 AM
afrogt's Avatar
Quoted: 2502 Post(s)
Liked: 1635
Still own a UP970 and the thing is loud when playing a 4K disc. Watched Jaws 4K last night. Haven't done a firmware update in about 2 years once Dolby Vision worked. Didn't want to lose that since it had disappeared before for others. Guess I should download the latest firmware to see if it enhances anything on this unit.
Was there ever a fix for the noisiness?
Afro GT
afrogt is offline
post #2929 of 2930 Old 06-16-2020, 11:00 PM
Quoted: 32 Post(s)
Liked: 42
This is down to the mounting of the drive, as the build of this unit is quite cheap. The early units were apparently mostly bad, the later UP970's were better. Some people opened up their unit & tinkered with the drive seating. I've found that light pressure on the top of my unit makes it quieter so I have my cable service box on top.
However, even so, some disks are always a little noisy for me.
post #2930 of 2930 Old 06-17-2020, 08:22 AM
afrogt's Avatar
Liked: 1635
I put a book on top yesterday which seemed to quiet it down. I think the disc matters too. Didn't notice the noise with Top Gun 4K but definitely did with Jaws 4K.
I also did the latest firmware update which went smoothly. Jaws hung up about 75% thru the movie and I had to restart that scene to get thru the movie on Monday. Hopefully the update fixed that little glitch.
Its a solid machine and relatively cheap. I think I paid $135 at Fry's a few years ago. Current players cost way more than that now.
Afro GT
afrogt is offline
Reply Blu-ray Players
