Official OPPO UDP-205 UHD Blu-ray Player Owner's Thread - Page 178 - AVS Forum | Home Theater Discussions And Reviews
 4143Likes
post #5311 of 6958 Old 08-25-2018, 09:12 AM
Sevenfeet's Avatar
Quoted: 365 Post(s)
Liked: 382
Originally Posted by tngiloy View Post
I'm kind of afraid to ask these questions here. My questions will show my computer/streamer ignorance, so please be kind.
I'm thinking about switching from JRiver to Roon.
The 205 is listed as a 'roon ready' device.
How do I hook up roon to the 205? Do I need a roon ready streamer box hooked up to the 205 ??
Or can I hook up Roon directly to the 205?? If so how??
Tom
Configuration of the Oppo 205 as a Roon endpoint is dead simple. In fact, setup of most Roon endpoints is pretty easy. Once you setup your Roon Core on whatever machine you choose, you can configure all your endpoints from any client on the network....PC, Mac, iOS, Android...it doesn't matter. Just make sure they are powered on so the Roon Core can find them. The clients don't search for the endpoints themselves...they rely on the Core machine to know where they are and whether they are available. So when you choose which endpoint(s) you want to play through, you'll only see the ones the Core sees at that time.
So to configure, select "Settings" from the menu in the upper left corner of the screen. From there, select "Audio". Roon will then present every available endpoint on the network. My screen shot has my two Oppo devices, a 205 and a 203 as well as a number of Airplay devices including Apple TVs, a Airport Express and a Denon receiver. Click the "enable" button next to your 205 and then give it a name to your liking. If you want to tweak some of the preferences for that device, click the "gears" icon next to the name and select "Device Setup". But defaults should serve you fine in most cases since the 205 is known endpoint type to Roon. There is also a selection here for "DSP Settings" which can get into some of the finer configuration of a given endpoint and is probably not needed in most cases but feel free to check it out.
The Roon Core remembers whatever preferences you selected for the endpoint in question so if you turn the endpoint off, Roon stops broadcasting its availability to the clients. If you turn it back on, then you'll see it again with all of your changes intact.
Keep in mind that using an Oppo 203/205 as an Roon network endpoint has three key drawbacks:
1. All DSD music is converted by the Roon Core to PCM since the endpoint software on the 203/205 can't handle it.
2. All multichannel music gets converted to 2 channel (there is some control in the preferences on how this is handled)
3. While MQA music can be played through the optical disc transport, USB thumb drives, network shares (SMB/DLNA) and through the USB DAC input on the rear, I don't think that it can handle it through the Roon enabled networked endpoint. Bob Pariseau can confirm that. Roon Core can do the 1st stage unfold of MQA files before the endpoint sees it. But if you want real unfettered MQA support, use another device like a PC, Mac or separate dedicated Roon endpoint to feed the Oppo 205's USB DAC port directly.
Finally, I've found the Roon Core to be extremely flexible in how it handles music regardless of the source and delivers content regardless of the endpoint. If you have a 24bit/352khz music file and you try to play it through an Airplay device only capable of 16/44.1, it handles it seamlessly. Roon will also tell you what's happening in the conversion process by clicking on the "star" icon next to the music selection in question. This is much like how JRiver tells the user about the conversion and transport process.
Name:	Screen Shot 2018-08-25 at 9.54.10 AM.png
ID:	2446332   Click image for larger version
Name:	Screen Shot 2018-08-25 at 9.55.40 AM.png
ID:	2446334   Click image for larger version
Name:	Screen Shot 2018-08-25 at 9.56.15 AM.png
tngiloy, Cla55clown and Madmax67 like this.
Sevenfeet is offline
post #5312 of 6958 Old 08-25-2018, 09:50 AM
silveramp's Avatar
Quoted: 12 Post(s)
Originally Posted by Bill Mac View Post
Not sure about getting AM-FM but it looks like you have a speaker on top of the 205. If it's blocking the vents on the top cover of the 205 that's not a good idea. The 205 needs to have those vents unblocked with a good amount of clearance for cooling. You'll easily shorten the life of your 205 with those vents blocked.
Bill
It is a monitor for usb playback,,,lots of room for air
Thankyou
silveramp is offline
post #5313 of 6958 Old 08-25-2018, 10:16 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5836 Post(s)
Liked: 8325
Originally Posted by silveramp View Post
Hi
I am using the 205 in a 2 channel audio only system
How can i receive am/fm using the 205
Will need some kind of a tuner with digital out into the 205,,,is this possible
Thankyou
You can probably get a new tuner with Optical and/or Coax Digital audio output, or you could use any existing tuner and a simple converter that takes Stereo Analog audio input and produces Optical and/or Coax Digital audio output (Stereo LPCM). For example, this one from Monoprice:
https://www.monoprice.com/product?p_id=8127
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #5314 of 6958 Old 08-25-2018, 10:45 AM
silveramp's Avatar
Quoted: 12 Post(s)
--Bob
Thankyou
Would this work
Sangean HDT-20
Enjoy your day
post #5315 of 6958 Old 08-25-2018, 01:10 PM
Swatdude1's Avatar
Quoted: 66 Post(s)
Liked: 27
Originally Posted by Sevenfeet View Post
Unlikely. If anything, MQA support made it an attractive feature. The real problem are the changing dynamics of the audiophile/videophile market, especially with Oppo's legacy business based on optical disc players which we all know are on the way out at some point. They dabbled in headphones, standalone DACs and wireless speakers. But at the end of the day, Oppo's management probably didn't know what to do with them since a major change was likely to invoke a major investment. And Oppo in the US is a rounding error on the books versus the phone business in China and elsewhere.
So they shut it down. And it's a damn shame.
Millenials! Doh! I know bits and bytes are less susceptible to wear than a plastic disc , but I hate that the market is moving to compressed formats for video. Do you see streaming services offering full-res 35gb movie files? At least we have high-res music now so maybe the market will move there for movies as well. I still use Redbox, which is probably too late but desperately moving to streaming. The Redbox disc dispensing units will go the way of Blockbuster.
Swatdude1 is offline
post #5316 of 6958 Old 08-25-2018, 01:40 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4670 Post(s)
Liked: 4545
Thankyou
Would this work
Sangean HDT-20
Enjoy your day
That has Optical SPDIF output and the 205 accepts that as input, so we presume it would work.
Note: some of the amazon reviews for the product are from people who thought they were buying a radio and keep shaking it trying to get sound out. I am reminded of bitter reviews for a computer case by those who felt cheated that there was no computer inside.
-Bill
oldsteve likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #5317 of 6958 Old 08-27-2018, 06:00 PM
Bill Mac's Avatar
Quoted: 2240 Post(s)
Liked: 3492
Oppo is sending emails out to those that registered with links to buy the 205 . Word to the wise don't wait till 8/30 to order .
Bill
mickboy likes this.
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Marantz SA-10, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #5318 of 6958 Old 08-27-2018, 06:06 PM
vp4lifehva's Avatar
Quoted: 16 Post(s)
Bill
I hesitated for a few seconds and then ordered one anyways. I already have the 203 and a Marantz AV8802A. NO REGERTS haha.
vp4lifehva is offline
post #5319 of 6958 Old 08-27-2018, 07:16 PM
joerod's Avatar
Quoted: 1177 Post(s)
Liked: 1285
I got my “forever” player ordered! Why not leave off with a 205?
mickboy and dnoonie like this.
NVIDIA Shield TV Pro | 4K/60 HDR10 ATMOS-best streaming device for image and sound available today!
joerod is offline
post #5320 of 6958 Old 08-27-2018, 07:23 PM
fmalczewski's Avatar
Quoted: 231 Post(s)
Liked: 77
It will be interesting to see if I get one of those emails... (Nothing so far.)
fmalczewski is offline
post #5321 of 6958 Old 08-27-2018, 09:23 PM
Sevenfeet's Avatar
Quoted: 365 Post(s)
Liked: 382
Still waiting....
post #5322 of 6958 Old 08-27-2018, 09:53 PM
laserjock II's Avatar
Quoted: 1301 Post(s)
Liked: 737
Got mine ordered..
mickboy likes this.
laserjock II is offline
post #5323 of 6958 Old 08-27-2018, 10:29 PM
Liked: 737
Bill
I clicked the “special link” and accidentally closed it, when I went back to it, it wouldn’t let me use it to order.
I hurriedly sent them an email and then tried to use it again and it worked.
mickboy likes this.
post #5324 of 6958 Old 08-27-2018, 10:36 PM
Jlowery1959's Avatar
Liked: 1
Laserjock. ll, do u mind saying when u signed up? Trying to gauge what my chances are.
Jlowery1959 is offline
post #5325 of 6958 Old 08-27-2018, 11:10 PM
Liked: 737
05/09/18 I was sent an email to verify my email address so it must have been right around that date.
Can’t wait to get it hooked up and hear some great music. I’m a Tidal subscriber and have a pretty decent collection of DVD-A and SACD discs.
post #5326 of 6958 Old 08-28-2018, 12:10 AM
sta363's Avatar
Quoted: 20 Post(s)
I also received the notification of being eligible for an offer back on May 9, but I have not received any offer by email in the current sale.
Anyone know when Oppo will be finished making offers to listed customers for the current (late August) batch?
sta363 is offline
post #5327 of 6958 Old 08-28-2018, 06:17 AM
Quoted: 13 Post(s)
Liked: 7
My order was canceled because I placed an order without the special invitation link. Refreshing to see a company review orders and maintain their release process. Bravo OPPO
F1nesse is offline
post #5328 of 6958 Old 08-28-2018, 07:20 AM
Bill Mac's Avatar
Liked: 3492
How were you able to place an order without the invitation link? There is no "Buy" option that I could find on the 205 product page on the Oppo Digital site.
Bill
Bill Mac is offline
post #5329 of 6958 Old 08-28-2018, 08:45 AM
ratscrew's Avatar
Bummer. It looks like they are still filling requests for 205s that were made well before mine. I only found out about the final run on June 6th, and hopped in then.
Sounds like I'll be SOL.
Looks like I will be one of the schmucks that overpays for one on eBay.
Is the going rate about 2K? What other sites besides eBay would these popup up on.
I hate supporting scalping, but I have been an Oppo fan since they started. Oh well, it's only (lots of) money.
ratscrew is offline
post #5330 of 6958 Old 08-28-2018, 08:56 AM
Sevenfeet's Avatar
Quoted: 365 Post(s)
Liked: 382
Yeah, I came in on June 6th as well. Haven't given up hope yet.
post #5331 of 6958 Old 08-28-2018, 09:29 AM
Quoted: 13 Post(s)
Liked: 7
Bill
There is no "visible" buy option. Do a little product code switcheroo on the Sonica product page and added the 205 to cart. When it comes to things like this, there is always an exploit but OPPO is holding the fort down.
lovebuzz#836 likes this.
F1nesse is offline
post #5332 of 6958 Old 08-28-2018, 09:29 AM
Liked: 1
Thanks Laserjock ll, OPPO confirmed my email address on May 9, as well. Haven't seen an invitation in my inbox though. Still hopefully waiting.......I've never chkd my inbox as much as I have last few months. Good luck everyone!
post #5333 of 6958 Old 08-28-2018, 09:36 AM
Liked: 737
The email came from [email protected] in case you needed to do a search or look in spam/junk folder or something.
I know they have used several different email addresses in the past correspondence I’ve had with them.
Good luck!
Standard FedEx ground with signature was $33 or so
post #5334 of 6958 Old 08-28-2018, 10:54 AM
Roger Mathus's Avatar
Quoted: 97 Post(s)
Liked: 51
Good luck!
For those who received invites in past two days, when did you sign up? I think they may still be replying to early April requests?
Roger Mathus is offline
post #5335 of 6958 Old 08-28-2018, 12:38 PM
joerod's Avatar
Liked: 1285
Mine shipped!!!
mickboy, dnoonie and F1nesse like this.
joerod is offline
post #5336 of 6958 Old 08-28-2018, 01:15 PM
jkscherk's Avatar
Quoted: 128 Post(s)
Liked: 42
I checked with them in July and they told me I was in the first 25% of the list, but I still haven't received an email. Waiting patiently.
9.2.4 || Processor: Denon AVR-X3600H || Amps: Emotiva BasX A-300
Speakers: PSA MTM-210 LCR, BA VSi 593 IW Surround-Wide, BA VSi 560 IC Tops
Subs: Seaton Submersive F2+Slave Front
Screen: 2.40:1 Seymour XD, 120" wide || Projector: JVC RS-600 + Panamorph Paladin
Sources: Nvidia Shield, Oppo 205, Roku Ultra 4K, ATT UVerse, Toshiba HD-A35 HD-DVD
jkscherk is offline
post #5337 of 6958 Old 08-28-2018, 01:37 PM
Russ Rubman's Avatar
Quoted: 116 Post(s)
Liked: 29
Oppo told my father point blank over the phone that they are winding down and closing up shop. Warranty issues after a year will probably be a challenge. Is it really worth the money given that there will be no more firmware updates and no support down the road?
Russ Rubman is offline
post #5338 of 6958 Old 08-28-2018, 01:56 PM
JohnAV's Avatar
Quoted: 518 Post(s)
Liked: 706
A interest list button has reappeared on the 205 support page, the following has been added
August 27, 2018 We have begun sending out e-mails inviting registered customers to purchase am OPPO UDP-205. As we have already begun winding down our business, we have limited fulfillment capacity. E-mails are being sent out in daily batches to throttle the amount of orders to fulfill.
Aja likes this.
Oppo Beta Group
JohnAV is offline
post #5339 of 6958 Old 08-28-2018, 02:13 PM
Bill Mac's Avatar
Liked: 3492
Oppo is winding down on the aspect of producing and selling new players. That has been known for quite some time by members here. So no ground breaking news there. Oppo will continue to offer service and firmware updates well past one year. Not sure why you think Oppo will not offer warranty service on players they're currently selling with two year warranties.
Bill
Madmax67 likes this.
Bill Mac is offline
post #5340 of 6958 Old 08-28-2018, 02:16 PM
Quoted: 116 Post(s)
Liked: 29
Meant to say "after the two years".
It is second-hand info of course, but they told him that after the two years they were gone for good. Not just the players but the whole operation.
Reply Blu-ray Players
