Official OPPO UDP-205 UHD Blu-ray Player Owner's Thread - Page 191 - AVS Forum | Home Theater Discussions And Reviews
 4159Likes
post #5701 of 7048 Old 09-27-2018, 11:47 AM
jamoke's Avatar
Quoted: 26 Post(s)
Liked: 29
Originally Posted by CygnusX2112 View Post
5024 is the last 4 digits on mine. It was mailed out on Sept 12. It's still in its sealed box so I don't have the build date unless someone can decode the rest of the number....I assume 5024 is correct because on my old 205, 2970 matches what's on the carton and on the back of the player...
Ser# Date Shipped or Rcvd
4260 8/27
4614 9/22
5024 9/12
Current Spread = 764
jamoke is offline
post #5702 of 7048 Old 09-27-2018, 12:40 PM
PGriff1051's Avatar
Quoted: 25 Post(s)
Liked: 30
Originally Posted by Swatdude1 View Post
Good news for you Patrick. Page 23 and 24 of the owner's manual are your friend. Use any of the analog inputs from the analog out on the Oppo. The subwoofer crossover is independent of the ARC software. When setting up the "Oppo Analog" input in the Anthem, turn off the ARC and set "process analog audio input" to NO. Digital conversion and signal processing are bypassed. The level settings for your amp out and sub will remain, as will the crossover.
Thank you. Just trying to clarify. So my Anthem will use A to D converters along with the crossover info in the Speaker Config (set up a new one for the Oppo) to get the LFE info necessary? Basically take the full signal from the Analog In from the Opp and send LFE info to the sub?
PGriff1051 is offline
post #5703 of 7048 Old 09-27-2018, 02:54 PM
Wafflebird's Avatar
Quoted: 46 Post(s)
Liked: 39
4260 8/27
4614 9/22
5024 9/12
So guessing I know but I think we can rest assured they didn't manufacture say 800 so I would feel confident the number will turn out to be at least 1000 or more most likely, again guessing here. With the limited data we have gotten already we are getting an image, might be "Blurry" but an image is appearing regardless. Regardless of the outcome it may be interesting to see what we can compile here for nothing other than to know how may, with the data available, were lucky enough to land one of these units.
mickboy likes this.
If it sounds and looks good, it sounds and looks good!!
Wafflebird is offline
post #5704 of 7048 Old 09-27-2018, 03:23 PM
n'joymusic's Avatar
Quoted: 24 Post(s)
Replied to invitation on april 9th.
Received my 205 on about aug 30th. last 4 of serial # 8755
Btw for what its worth mfg date of may 2018
Hope this helps calculations.
n'joymusic is offline
post #5705 of 7048 Old 09-27-2018, 04:41 PM
jamoke's Avatar
Quoted: 26 Post(s)
Liked: 29
That certainly muddies the water as there seems to have been two different production runs, one in May and another in July.
Getting interesting!
jamoke is offline
post #5706 of 7048 Old 09-27-2018, 05:53 PM
Wafflebird's Avatar
Quoted: 46 Post(s)
Liked: 39
What have I started.............................
In all seriousness if the standard manufacturing process was followed (Guessing) it looks like at least over 4500 units now? That is a LOT of new UDP-205 owners if that is the case. Now it is possible the numbers mean something else but..............................
Once I get mine out of the box I will add my information as well.
post #5707 of 7048 Old 09-27-2018, 06:36 PM
BLMN's Avatar
Quoted: 56 Post(s)
Doubtful they had 4500 units, I would say anywhere from 1000 to 1500. I say that based on previous inquiries from other members, including people who signed up around mid may stating they were thousands deep into the waiting list and had pretty much no chance of getting one. I even question if Oppo was ever able to fulfill past April's requests.
Living Room: Mitsubishi WD82738 1080p 3D, Onkyo HT-9400 THX 7.1, Oppo DV-980H, Sony BDP-S6500 (Multi Region), Roku 2 XS
Bedroom: Sony XBR-65-850E 4K, PS4 launch edition, Sony UBP-X800
Basement: Sony XBR-75-Z9D 4K 3D, Marantz SR-8012 11.2, B&W 7.1 set, KEF Q50AB, Marantz TT-15S1, CA CXUHD, PS4 Pro, PSVR Bundle, PS3 60GB 1st gen.
BLMN is offline
post #5708 of 7048 Old 09-27-2018, 06:40 PM
n'joymusic's Avatar
Quoted: 24 Post(s)
I tend to think that there are inconsistencies in the order of when units are received by OPPO USA and when they are shipped out.
To wit my first 2 defective units
The 1st one I got was mfg may 2017 # 9735
The 2nd one was mfg in april 2017 cant find serial# at the moment
Question why would unit 1 be mfg may 2017 and unit 2 april 2017?
Sorry to have muddied up the waters.....
post #5709 of 7048 Old 09-27-2018, 08:13 PM
Quoted: 21 Post(s)
Liked: 2
I've been playing around with MQA files on the 205, via CD (Rebecca Pidgeon) and on a USB drive downloaded from this site:
http://www.2l.no/hires/index.html
And it works like it should, info from the 205 shows MQA being played.
But when I try to rip the same CD (Rebecca Pidgeon) uncompressed to either WAV or FLAC, to a USB drive, it doesn't work... no MQA from the 205.
Anyone else had any luck ripping MQA CDs?
I used dBpoweramp's CD Ripper app. on Windows 10 Pro.
nusihb is offline
post #5710 of 7048 Old 09-27-2018, 09:55 PM
StevenC56's Avatar
Quoted: 587 Post(s)
Liked: 206
Well Bill, it might be an exercise in futility, but I don't think it's a waste of time.
You can assume that a round number was manufactured in July (500 - 1000 - 2000 etc), so it's just a matter of collecting enough samples within a range to validate an educated guess.
With just two serial numbers reported we know the spread is at least 354.
So with this VERY limited data one can make an assumption that at least 500 were manufactured.
Obviously more data is needed to validate a better guesstimate but it's a start.
Good luck trying to figure this out. Mine was shipped on 9-17, and it's several hundred Before CygnusX2112's serial number.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #5711 of 7048 Old 09-27-2018, 10:04 PM
vercingetorix's Avatar
Quoted: 32 Post(s)
Liked: 29
ser# date shipped or rcvd
4260 8/27
4614 9/22
5024 9/12
current spread = 764
1735 6/25
Manufactured May 2018
vercingetorix is online now
post #5712 of 7048 Old 09-27-2018, 10:04 PM
drewTT's Avatar
Quoted: 2204 Post(s)
Liked: 2335
I wonder where the values are going in the next couple of months. People are nuts over these things...
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL S/510 | PS Audio DirectStream | Furman IT-Reference 15i
Sony PS4 Pro | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | iFi AC iPurifier | roon
drewTT is offline
post #5713 of 7048 Old 09-27-2018, 11:01 PM
moonhawk's Avatar
Quoted: 144 Post(s)
Liked: 77
Hi all. Just got my 205 the other day and as I don't have a $K TV yet, I'm trying to get it to work as a USB DAC, and having nu success. I have downloaded the latest general firmware, and the USB DAC input firmware installer, or whatever it's called, but for some reason I can't get it to run.
I'm on a 2013 Macbook Pro, and I just" upgraded" to OS Mojave. I'm not that great with Macs, so I'm probably missing something. If anyone can help without suggesting I read the whole thread, I'd appreciate it very much.
______________________
__________
Dave
moonhawk is offline
post #5714 of 7048 Old 09-28-2018, 05:26 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1981 Post(s)
Liked: 2389
You're going to need to be more descriptive than "I can't get it to run" to give us some hints as to what you've tried - exactly how things are connected, what software you're using on the Mac, how you have your audio output settings configured on the Mac, whether you've selected the USB DAC input on the Oppo and so on. For starters, make sure you're connecting the USB cable to the USB DAC input on the Oppo (the square connector, not one of the rectangular USB inputs meant for external USB drives) and have selected the USB DAC input using the Input button on the Oppo remote. I won't be of any assistance on the Mac side as I'm a Windows user; I haven't touched a Mac since the original ones back in the mid-late eighties .
gsr is online now
post #5715 of 7048 Old 09-28-2018, 08:04 AM
moonhawk's Avatar
Quoted: 144 Post(s)
Liked: 77
Thanks for the reply. I will get back to you this evening. The Mac is only connected for the purpose of downloading the firmware. It acts as the controller for the Bryston BDP3.
More this evening when I have time. thanks again!
__________
Dave
moonhawk is offline
post #5716 of 7048 Old 09-28-2018, 09:25 AM
n'joymusic's Avatar
Quoted: 24 Post(s)
Originally Posted by vercingetorix View Post
1735 6/25
Something interesting here:
Your unit manufactured in may last 4 # 1735
My unit also manufactured in may last 4 8755 the difference here appears to be 7020....manufactured in may just by these 2 numbers.
Perhaps a ball park number of units manufactured in may 2018....There well may be lower last 4 serial # and higher last 4 serial #s
Could the OPPO manufacturing plant produce this many BDP 205 players in a 1 month production time frame? Considering all that goes into
building 1 unit.
Just a .02 cent thought for pondering on
post #5717 of 7048 Old 09-28-2018, 10:12 AM
Quoted: 13 Post(s)
Liked: 7
I saw inventory two days ago, but I just tried to see stock levels by adding to cart and it looks like stock is gone. So let see this mid-September shipment has arrived or not.
F1nesse is offline
post #5718 of 7048 Old 09-28-2018, 10:45 AM
jamoke's Avatar
Quoted: 26 Post(s)
Liked: 29
So Far...
Month--Ser#---Date Shipped or Rcvd
MAY18 8755 8/30
MAY18 1735 6/25
JUL18 4260 8/27
JUL18 4614 9/22
JUL18 5024 9/12
jamoke is offline
post #5719 of 7048 Old 09-28-2018, 10:58 AM
n'joymusic's Avatar
Quoted: 24 Post(s)
So Far...
MAY18 8755 8/30
MAY18 1735 6/25
JUL18 4260 8/27
JUL18 4614 9/22
JUL18 5024 9/12
It could be that there are not enough data points or sets yet to from a clearer picture. It would be very helpful if all the responders to OPPO's
invitation would share their information : month year of manufacture, last 4 of serial # date shipped or rec'd
please continue to contribute...could help answer some questions.
Thanks everyone!
post #5720 of 7048 Old 09-28-2018, 11:17 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4690 Post(s)
Liked: 4563
Thanks everyone!
Perhaps you could volunteer to accept this information via PM and present us with the results after the final collation?
-Bill
jmanthey, gsr, Bill Mac and 2 others like this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #5721 of 7048 Old 09-28-2018, 12:31 PM
Bill Mac's Avatar
Quoted: 2245 Post(s)
Liked: 3505
-Bill
Excellent idea, thank you! This being the 205 "owners" thread not the "serial number" thread. It would best if the discussion was via PM or a new "serial number" thread be started by those interested. The discussion of serial numbers only bogs this thread down for new and current 205 owners seeking information.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Marantz SA-10, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #5722 of 7048 Old 09-28-2018, 01:31 PM
Quoted: 50 Post(s)
Liked: 38
Where did you see inventory for the 205?
thanks
ad5wb is offline
post #5723 of 7048 Old 09-28-2018, 01:47 PM
Quoted: 13 Post(s)
Liked: 7
thanks
When you add to cart. Add an insane quantity like 1000 and then update cart totals. Their error handling system then tell you the maximum quantity and if you would like to update to that amount
F1nesse is offline
post #5724 of 7048 Old 09-28-2018, 01:51 PM
muscles's Avatar
Quoted: 778 Post(s)
Liked: 1107
Subscribing to this thread has become tiresome for people who already own units. I want to know about features and updates on the units themselves not on the availability and logistics of acquiring one. Perhaps a new thread needs to be formed? If this is normal for these kind of threads then no big deal and I will kindly unfollow.
Greg
Subwoofers: Dual Rythmik F18SEs - Dual JTR RS1's - SB13 Ultra
Speakers: 2xJTR Noesis 212RT 1 210RM - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's - PS Audio M700 - McIntosh MT5 - GoldNotePH10 - Oppo UDP-205 - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is offline
post #5725 of 7048 Old 09-28-2018, 02:17 PM
Wafflebird's Avatar
Quoted: 46 Post(s)
Liked: 39
Hey guys apologies for clogging up the thread, as I represent a large commercial manufacturer in my “Day job” I was just making mention of how someone may be able to glean an estimated amount of units. It was certainly not my intention to create additional (uninteresting to some) posts related to serial numbers/quantities.
Aside from that hoping to get some “Install” time this weekend and give this unit some love.
muscles and CygnusX2112 like this.
post #5726 of 7048 Old 09-28-2018, 03:39 PM
jmanthey's Avatar
Quoted: 42 Post(s)
Liked: 27
“Some” should be replaced by “most”.
sphinx99, deckarep and Sound Shark like this.
Joe
jmanthey is online now
post #5727 of 7048 Old 09-28-2018, 04:28 PM
n'joymusic's Avatar
Quoted: 24 Post(s)
-Bill
Thank you for the suggestion....would be interesting ...just not for me just now...
thank you for sharing..
post #5728 of 7048 Old 09-28-2018, 04:44 PM
Bill Mac's Avatar
Liked: 3505
Greg
I agree. A new thread should be started for that discussion. If a new thread is not started the discussion of estimated units available, produced and serial numbers is more pertinent to the "Oppo to stop production? This is not a joke." thread IMO.
https://www.avsforum.com/forum/149-b...-not-joke.html
Bill
Bill Mac is offline
post #5729 of 7048 Old 09-28-2018, 05:21 PM
mickboy's Avatar
Quoted: 61 Post(s)
Liked: 77
I TOLD everyone here and at the SH forums that I thought it was in the HUNDREDS, not thousands. My last four, and I got one of the June '1st allotment ' is 1729
Mickboy
"We Never Really Got It On Until Detroit"
M.Jagger 1969
mickboy is offline
post #5730 of 7048 Old 09-28-2018, 05:25 PM
mickboy's Avatar
Quoted: 61 Post(s)
Liked: 77
My birthday was also may 2018 and my last are 1729.
So now this gets intriguing, let's make like the Senate and flog this thing till we get to the truth!!!!!!
Beave
M.Jagger 1969
mickboy is offline
Reply Blu-ray Players
