Official OPPO UDP-205 UHD Blu-ray Player Owner's Thread - Page 206 - AVS Forum | Home Theater Discussions And Reviews
 4168Likes
post #6151 of 7105 Old 12-29-2018, 05:40 AM
hal250's Avatar
Quoted: 336 Post(s)
Liked: 186
Originally Posted by Bob Pariseau View Post
For those wondering, the new HDMI IN BYPASS mode is found in the Input selector list. Press Input button and HDMI IN BYPASS will be a new line item found at the bottom of the pop up menu which appears on screen. For a programmable remote you can select it directly by sending Input button followed by the digit button corresponding to that line item.
So the Input choices now include both the HDMI IN line (which was there before) and the new HDMI IN BYPASS line.
--Bob
Hi Bob, perhaps this is explained already but can you provide a succinct description of a use case/purpose for this new HDMI IN BYPASS line? Thanks.
hal250 is offline
post #6152 of 7105 Old 12-29-2018, 05:48 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5869 Post(s)
Liked: 8403
Its primary use is to allow Dolby Vision pass through via the HDMI Input. Dolby Vision video does not survive processing, so the HDMI In Bypass mode allows it to get through the OPPO (HDMI Input to Main HDMI output) without processing.
--Bob
pjm877, swajames and hal250 like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #6153 of 7105 Old 12-29-2018, 09:25 AM
Liked: 0
Anyone here have any issues with their USB DAC on the 205? I'm running a SGC sonicTransporter i5, with an UltraRendu hooked directly to my USB DAC on the OPPO. When I first turn on the OPPO and start playing music, I get a mottled, almost underwater sound intermittently for the for the first song or two and then it stops. Audio nirvana begins.
I have the USB DAC updated to the latest firmware. I don't see any obvious settings that would make a difference with this.
Jason
stumptown0426 is offline
post #6154 of 7105 Old 12-29-2018, 10:59 AM
Read the FAQ!
Liked: 8403
Jason
Get in touch with OPPO Tech Support. I've not heard of this problem in any of the released DAC firmware versions.
You can use the Email Us link on OPPO's Support page for the player.
The only setting which alters the function of the USB DAC Input is the Upsample USB DAC setting. Try turning that off.
--Bob
post #6155 of 7105 Old 12-29-2018, 12:48 PM
Liked: 0
--Bob
Yes, I did notice that was the only setting. I do not have mine on. I'll email OPPO. Thanks.
post #6156 of 7105 Old 12-30-2018, 08:40 AM
Quoted: 47 Post(s)
Originally Posted by Joe DiVincenzo View Post
Hello fellow UDP users
Hope everyone had a holiday season, I was hoping to get some advice, I have read and re-read some of these posts but I am confused
I connected my UDP 205 via RCA cables from the 7.1 channel analog inputs to the 7.1 channel inputs to the back of the Marantz SR 5005 , When I play a SACD of LA Woman I can here music coming out of my 5 speakers but jim morrison vocals sound muffled , also the sub woofer is not putting out any bass, The only time it sounds good is when I use the oppo app and downgrade from 5.1 to 2 channels
I thought because it was a multi channel SACD disc that the music would play properly , not sure if maybe I didn't connect it correctly or maybe my AVR is too old . But the AVR is only passing the music to the speakers so that shouldnt make a difference. Maybe the RCA cables I used aren't good quality (HOSA CRA-802 RCA)
Any suggestions would be appreciated
When you have the OPPO set for DSD to analog conversion, rather than PCM, multi-channel SACD channel level/distance/bass management will be handled by your Marantz DSP. That's to say, you will need to set output level/distance/delay/crossover to bass from the Marantz. Your Marantz has not likely been properly adjusted and that's why you have a complaint. If you set the OPPO for PCM conversion the OPPO can set output level for each channel. When you use OPPO for this function however output needs to go to an amp that has been set flat. In my system I output DSD and control channel gain with my multi-channel analog preamp, which is usually set to 0db gain on all channels to get the multi-channel effect that the producers of the 5.1 SACD had in mind rather than my notion.
csludwig2 is offline
post #6157 of 7105 Old 12-30-2018, 11:04 AM
Quoted: 58 Post(s)
Multi channel hdmi out
Probably know the answer but worth a try anyway. Can the Oppo 205 take multichannel in through the usb dac and send it out (to a multitchannel reciever - emotiva xmc1) ? Will the output to the hdmi still be multichannel?
George
Acousticmoods is offline
post #6158 of 7105 Old 12-30-2018, 11:44 AM
Read the FAQ!
Liked: 8403
George
The USB DAC Input on the 205 supports only Stereo audio input from the attached computer.
(Playing media files from a hard drive attached to the normal USB sockets does support multi-channel, and the output on HDMI will be multi-channel.)
--Bob
post #6159 of 7105 Old 12-30-2018, 12:08 PM
Quoted: 58 Post(s)
--Bob
Thanks Bob. My goal is to be able to stream Ethernet multi channel using Roon.. So it appears I have three options (leaving the server in the other room).
1. Use an Ethernet to usb connector to feed the signal into the OPPO and play it through the OPPOs dac.
2. Use an Ethernet to usb connector as in (1) above but use hdmi(audio only) out to hdmi in on the xmc-1.
3. Use an Ethernet to hdmi adapter and feed directly into the XMC-1.
Any idea which would provide the best audio solution?
post #6160 of 7105 Old 12-30-2018, 12:37 PM
BrianJB7's Avatar
Does Oppo 205 impact LG C8 Advance Picture Settings?
Connected the Oppo HDMI Out (Main), with a compliant 4k HDMI cable, directly to a LG C8 TV. It seems the Oppo is causing the C8's White Balance feature to "gray out" & the C8's HDMI Ultra HD Deep Color cannot be set to on.
4K and Bluray discs seem to look their best, but is the Oppo 205 impacting the TV's picture settings functions (White Balance and Ultra HDMI HD Deep Color?
Tried asking this question in another way on the OLED forum without any responses.
Happy Holidays to all!
BrianJB7 is offline
post #6161 of 7105 Old 12-30-2018, 02:29 PM
chrisdack's Avatar
Quoted: 241 Post(s)
Liked: 82
Originally Posted by Mark1000 View Post
Originally Posted by dbphd View Post
Most Tidal Master files seem to be MQA, but are all?
When you play an MQA file, does the 205 display 96 kHz or 192 kHz? That is, Roon does the first unfolding to 96 kHz, but does the 205 do the second unfolding to 192 kHz?
A Tidal Master file is MQA by definition.
No, with Tidal MQA it is 88.4 or 96, so no more unfolding, according to the OPPO info screen, and also the Tidal site; see my earlier quote. It WILL do extra unfolding with discs or local MQA files to 192 or 384 kHz. I do not use Roon, but I guess if you can play a file that is encoded from a 192 or 384 original the OPPO will render it correctly, as it does for local files.
Mark
What happens with MQA that unfolds to 96Khz on first unfold but back to 44.1 with the second unfold?
chrisdack is offline
post #6162 of 7105 Old 12-30-2018, 08:35 PM
Mark1000's Avatar
Quoted: 118 Post(s)
Liked: 51
Mark
That looks like strange behavior. ‘Unfolding’ to 44.1 is not possible. It looks like the file or stream is not recognized as MQA and plays as a regular CD quality file. Are you using the latest USB firmware 1.18 or higher (not system firmware that is)?
Mark
Marantz 8802A | Rotel RB 1590 / 1555 | Bowers Wilkins 804D3 / HTM2D3 / DB3D / 703S2 / 706S2 | Oppo 205 | Bluesound NODE 2i | LG OLED65E8 | Denon AH-D7100 | Chromecast Ultra | Apple TV4K | Cable box 4K | Darbee Darblet
(Denon 4520 | LG OLED55E6 | Bowers Wilkins 704S2 / ASW700 | Oppo 203 / HA-2SE | Apple TV | Chromecast Ultra / Audio | Denon AH-D2000)
Mark1000 is offline
post #6163 of 7105 Old 12-31-2018, 09:21 AM
Read the FAQ!
Liked: 8403
It is "normal" for TVs to change which of their settings are available according to the type of content they are being fed. It's not the OPPO doing this, but rather the TV maker deciding this is the best way for their TV to work when receiving that video input format.
--Bob
post #6164 of 7105 Old 12-31-2018, 09:23 AM
Read the FAQ!
Liked: 8403
Last time I checked Roon only supported Stereo to the OPPO. So if you want to use multi-channel from Room you'll need to connect it to your XMC-1 instead.
--Bob
post #6165 of 7105 Old 12-31-2018, 12:10 PM
Quoted: 58 Post(s)
--Bob
Thankyou Bob.
Happy New Year!
post #6166 of 7105 Old 12-31-2018, 01:44 PM
Liked: 0
Jason
Update: I pulled the OPPO out of the chain and ran the USB from my UltraRendu directly to the USB input on my XMC-1 processor. All issues go away when I do this so it is an OPPO issue with the DAC.
I've emailed OPPO and am awaiting a response.
Jason
post #6167 of 7105 Old 12-31-2018, 02:00 PM
rhale64L7's Avatar
Quoted: 1146 Post(s)
Liked: 543
I don't have this problem. I use the USB Dac input on the 205 with a SOTM sms200 ultra. I am using Roon. I have the Emotiva RMC1 that the Oppo's balanced out is connected too.
Ron
65" LG B8 Oled,Emotiva RMC1L Processor, Digital Amp Co. 5 Cherry King amplifier, Dish Net Hopper, Panasonic UB 820, Sotm SMS 200 ultra Neo and SPS 500 power supply, Rythmik E15HP SE sub, Aerial 6t mains, Aerial 5T surrounds, Aerial 7cc center, ISO Acoustics under all the Aerials 4 Goldenear HTR 7000 ceiling speakers for Atmos All in a dedicated theater with bass traps in all corners and soffits. Front wall and first reflections treated
rhale64L7 is online now
post #6168 of 7105 Old 12-31-2018, 02:04 PM
SeeMoreDigital's Avatar
Quoted: 1083 Post(s)
Liked: 911
EU/UK Public beta release of UDP20XEU-64-1221B
Hi all,
The EU/UK public beta release version of UDP20XEU-64-1221B has just been released. Here's a link: http://www.oppodigital.co.uk/beta-fi...U-players.html
Cheers all
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #6169 of 7105 Old 12-31-2018, 04:39 PM
markmanner's Avatar
Quoted: 346 Post(s)
Liked: 295
New Public Beta firmware is out for the 203 and 205. If you have a North America player, you can download it for USB install from the OPPO Support page for the player.
It adds HDR10+ support and a new HDMI Bypass mode in support of Dolby Vision pass through via the player's HDMI Input.
--Bob
Hi Bob, I have downloaded the Dec. 28 beta update bin file, but, unlike in the past when doing beta updates, I now get a 'file corrupted' message when the player tries to read the update file. I have tried downloading several more times, and same result each time( used 2 different usb sticks too). Anyone else seen this behavior or have an idea?
Mark
System
Spoiler!
markmanner is offline
post #6170 of 7105 Old 12-31-2018, 04:44 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4742 Post(s)
Liked: 4619
Mark
What is the exact size and name of the file?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6171 of 7105 Old 12-31-2018, 04:47 PM
markmanner's Avatar
Quoted: 346 Post(s)
Liked: 295
-Bill
Hi, it is:
UDP20X.bin
size 131MB (138,086,400 bytes)
on disk 131MB (138,088,488 bytes)
Thanks for your help,
Mark
System
Spoiler!
post #6172 of 7105 Old 12-31-2018, 04:53 PM
wmcclain's Avatar
Liked: 4619
Hi, it is:
UDP20X.bin
Mark
I have 138086400 bytes which matches your first number. What do the two different values mean?
And what firmware do you have installed now?
-Bill
post #6173 of 7105 Old 12-31-2018, 04:57 PM
markmanner's Avatar
Quoted: 346 Post(s)
Liked: 295
-Bill
the size on disk number is always slight different, I just included it to be complete. Looks like my file is ok based on your experience. Not sure what is going on.
[Edit, I have UDP20X-60-0625 now]
System
Spoiler!
post #6174 of 7105 Old 12-31-2018, 05:19 PM
wmcclain's Avatar
Liked: 4619
That's odd. Have you ejected any disc in the tray? Shut down the player and started again?
Do you get the same results when you initiate the installation from the Setup as when you plug in the stick and and let the player discover the new firmware?
-Bill
post #6175 of 7105 Old 12-31-2018, 06:12 PM
BrianJB7's Avatar
--Bob
Thank you sir.
You are a value added resource. For over 13 years I've used your informed responses to get the most out of my audio and video equipment.
Thanks again.
Happy New Year!
pjm877, swajames and Cla55clown like this.
BrianJB7 is offline
post #6176 of 7105 Old 12-31-2018, 06:47 PM
chrisdack's Avatar
Quoted: 241 Post(s)
Liked: 82
Mark
Mark
Will see if I can find the tracks that do it and get a photo. Saved into my favourites somewhere.
Peeved because it's gotten my qnap>205 working with MQA Tidal but I couldn't sit on that, and then lost the ability to remote control in the upgrade to v18. Broke link between ir and Kodi.
Happy new year by the way!
post #6177 of 7105 Old 12-31-2018, 10:44 PM
markmanner's Avatar
Quoted: 346 Post(s)
Liked: 295
-Bill
Hi Bill, I have tried both ways, same result. I may do a factory reset next, and then try the firmware update (I always do one afterwards of course).
I will report tomorrow.
Happy New Year!
System
Spoiler!
post #6178 of 7105 Old 01-01-2019, 07:03 AM
Liked: 911
Hi @markmanner
What capacity USB pen-drive are you using. And which 'File System' has it been formatted to?
Cheers
post #6179 of 7105 Old 01-01-2019, 08:04 AM
markmanner's Avatar
Quoted: 346 Post(s)
Liked: 295
Originally Posted by SeeMoreDigital View Post
Hi @markmanner
Cheers
Hi, I tried two different usbs, one formatted to fat 32 (a 32GB usb), the other to exFat (a 128GB usb). FWIW, both of those USBs were recognized by the OPPO, and I used each of them to copy the .cfg file I planned on using to restore settings after the update. I think one of them was probably one I used before to do a beta upgrade but I'm not certain.
System
Spoiler!
post #6180 of 7105 Old 01-01-2019, 08:36 AM
Liked: 911
Wow...
Given their huge capacities they almost certainly contain a hidden partition of some kind that's interfering with their detection. When it comes to device firmware updates, the smaller the USB pen-drive the better. Personally I use a 2GB model formatted to FAT32 or a 4GB model formatted to NTFS.
Cheers
Reply Blu-ray Players
