Official OPPO UDP-205 UHD Blu-ray Player Owner's Thread - Page 223 - AVS Forum | Home Theater Discussions And Reviews
 4119Likes
post #6661 of 6799 Old 05-24-2019, 12:31 AM
Liked: 0
Hello, I have a question regarding my oppo 205 DRC control, I have been into setup menu and switched it on in order to reduce the loud sections on bluray & DVD and am not sure if this
is going to make any changes to CD playback, which I would like to remain the same. My audio out goes from coaxial into a seperate DAC if this info helps.
66deg is offline
post #6662 of 6799 Old 05-24-2019, 04:49 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4574 Post(s)
Liked: 4416
Originally Posted by couchfungus View Post
Has anyone here looked at the analog outputs of a UDP-205 with a scope?
There is a three part test series starting here:
http://archimago.blogspot.com/2018/0...-1-output.html
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6663 of 6799 Old 05-24-2019, 04:52 AM
BillP's Avatar
Quoted: 501 Post(s)
Liked: 434
couchfungus, I undersand your concern. But if it's out of the range of human hearing, and the 205 sounds great (the most important test), then who cares? Name another option (player or DAC) for serious music listening at the original 205 price point that sounds better (I have seen posts claiming that DAC X sounds better, but always at much higher price).
Bill Mac likes this.
BillP is offline
post #6664 of 6799 Old 05-24-2019, 06:02 AM
meli's Avatar
Quoted: 324 Post(s)
Liked: 94
Has anyone here looked at the analog outputs of a UDP-205 with a scope?...
I know there's some measurements here:
https://www.audiosciencereview.com/f...d-player.3660/
meli is offline
post #6665 of 6799 Old 05-24-2019, 10:06 PM
couchfungus's Avatar
Quoted: 34 Post(s)
Liked: 33
Yes, I've seen the scope and analyzer traces in the online reviews of the UDP-205. But note that those results are bandwidth limited and/or made at high signal levels. The scope traces in my post are showing oscillation at high frequencies and low amplitudes.
Do artifacts like this affect the sound quality? I don't know. My Oppo is mostly used as a DAC for music listening, and my speakers are very revealing. The system sounds great, but perhaps it might perform a bit better without the HF garbage on the line outputs. When I put a scope on other well-designed audio components, or my own designs, I don't see stuff like this.
Today, I did a bit more investigating, disconnecting the Oppo from all other components, trying different cables, all the input modes. The oscillations appears only on the headphone jack and the left channel stereo RCA connector. The stereo right channel and multi-channel outputs are clean. This makes me think that there is a defect. A marginally unstable op-amp? A flaw in a ground connection or shield that is letting in noise from the switching power supply or digital circuits?
I'll contact Oppo service, and see what they say.
linger63 likes this.
Sony XBR-65A1E, Panasonic TC-P58VT25, Apple TV 4K, Oppo UDP-205, Counterpoint SA-3000, Linn Sondek LP12, Ekos, Aragon 4004 Mk II, Acoustat 3, beer
couchfungus is offline
post #6666 of 6799 Old 05-26-2019, 06:04 PM
Bill Mac's Avatar
Quoted: 2206 Post(s)
Liked: 3342
If you are unable to determine if the "artifacts" effect overall SQ then I'd say it's a non issue. It seems that the issue you found is most likely inaudible. Listening to music with the XLR analog outputs of my 205 sounds excellent to me. Not concerned in the least.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Marantz SA-10, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #6667 of 6799 Old 05-27-2019, 09:14 AM
mdanderson's Avatar
Quoted: 114 Post(s)
Liked: 112
Anyone have a suggestion for Region free bluray players to go along with my Oppo 205? I am seeing more and more region 2 bluray movies that I would like to have. I know people have their Oppos modified to play all regions, but I am a bit unsure about trusting a company to do that. By the way I love my Oppo 205-best player I have ever had. Thanks.
Paradigm Studio 20v5-fronts
Paradigm Studio CC-490v5-center
Paradigm Studio 10v5- side surrounds,Monitor surround 3v7-bck surr
Oppo UDP-205/LG 65C6 OLED
Outlaw 976 prepro/ Emotiva BasX A-700amp/PSA 15S sub
mdanderson is offline
post #6668 of 6799 Old 05-27-2019, 10:03 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5795 Post(s)
Liked: 8267
You can install it yourself. The Region Free 3rd party hardware mods for Blu-Ray work fine and have been problem-free for years. If you are nervous about doing the internal install version (inside the player lid) you can get the version that plugs into a USB socket in the player back panel. Works the same but you tie up one socket for it.
See Bill’s FAQ— linked at the top of the first post of the 203 owners thread.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #6669 of 6799 Old 05-27-2019, 12:45 PM
mdanderson's Avatar
Quoted: 114 Post(s)
Liked: 112
—Bob
Thanks so much Bob for the info. It looks like the external kit just plugs into a USB port and the other end into the RS232 port. Correct me if I am mistaken. Thanks.
post #6670 of 6799 Old 05-27-2019, 02:42 PM
David Aiken's Avatar
Quoted: 816 Post(s)
Liked: 1467
I can't correct you. That's what I'm doing with my external kit and it works perfectly.
mdanderson likes this.
David Aiken is online now
post #6671 of 6799 Old 05-27-2019, 04:58 PM
mdanderson's Avatar
Quoted: 114 Post(s)
Liked: 112
Thanks David. I appreciate the help.
post #6672 of 6799 Old 05-28-2019, 04:52 PM
Liked: 6
Australian Firmware UDP-205
I see that other countries have a firmware upgrade as of Feb 2019
The Australian firmware is fresh as of June 2018 and says it is the latest update.
The Australian Oppo Digital website is now essentially defunct with no links to any upgrades.
Would there be any issues applying the US firmware ?
oppo_robbo is offline
post #6673 of 6799 Old 05-28-2019, 04:58 PM - Thread Starter
kucharsk's Avatar
Quoted: 1750 Post(s)
Liked: 1035
—Bob
Can you change regions as much as you want?
For example, some DVD-ROM drives allowed you to change regions, but only a certain number of times, and then the region was set to whatever you had last set it to forever without warning.
kucharsk is online now
post #6674 of 6799 Old 05-28-2019, 06:57 PM
Read the FAQ!
Liked: 8267
^ There’s no such limit with these 3rd party Region Free hardware mods.
—Bob
post #6675 of 6799 Old 05-28-2019, 07:04 PM
Read the FAQ!
Liked: 8267
You have to install the AU release of the firmware. The US release won’t install in your AU version player.
The AU firmware can be found on the Interdyn (OPPO distributor for AU) website here:
http://support.interdyn.com.au/suppo...icial-firmware
—Bob
post #6676 of 6799 Old 05-28-2019, 08:32 PM
Liked: 6
—Bob
Awesome thanks for that.
The network update server must not have been updated then.
Appreciate your fast response.
post #6677 of 6799 Old 05-29-2019, 11:37 AM
Jim Parys's Avatar
Quoted: 90 Post(s)
Liked: 49
—Bob
can you provide a link to one of these products?
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is offline
post #6678 of 6799 Old 05-29-2019, 01:17 PM
Read the FAQ!
Liked: 8267
^ See Bill's FAQ section here:
http://watershade.net/wmcclain/UDP-2...-modifications
--Bob
post #6679 of 6799 Old 05-29-2019, 06:48 PM
Jim Parys's Avatar
Quoted: 90 Post(s)
Liked: 49
--Bob
Bob,
That link seems to be for a disk based sw that only works for DVD. Anything for the USB for blu rays?
post #6680 of 6799 Old 05-29-2019, 06:55 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1890 Post(s)
Liked: 2283
Originally Posted by Jim Parys View Post
Bob,
Scroll down a bit and look at the hardware mod links...
gsr is offline
post #6681 of 6799 Old 05-30-2019, 09:19 PM
Bill Cruce's Avatar
Liked: 27
Region Free Mods
—Bob
Both mods require opening the player box and inserting something. Nothing about using the USB socket. I have ordered the one from JSB and will see how that works.
Bill Cruce
Widescreen Review
Bill Cruce is offline
post #6682 of 6799 Old 05-30-2019, 09:31 PM - Thread Starter
kucharsk's Avatar
Liked: 1035
Perhaps both listed mods, but there is an external version that connects to the RS-232 port and has a cable that plugs into a USB port to supply power.
In fact, many vendors sell a board that can be connected either way by connecting different cables.
I recommend the external one for the 205, simply because to install the internal one means significant disassembly and moving around of the two audio boards; on the 203 you pop the cover and it plugs right in, as it doesn't have the audio boards that cover the connector on the 205.
post #6683 of 6799 Old 05-30-2019, 09:52 PM
Bill Cruce's Avatar
Liked: 27
Multi Region External Mod
What is the link to the external mods? I did not find it in the FAQ
Bill Cruce
Widescreen Review
post #6684 of 6799 Old 05-31-2019, 03:05 AM
ht guy's Avatar
Quoted: 197 Post(s)
Liked: 165
Try this.
Internal or external.
ht guy is offline
post #6685 of 6799 Old 05-31-2019, 12:38 PM
Bill Cruce's Avatar
Liked: 27
Originally Posted by ht guy View Post
Try this.
Bill Cruce
Widescreen Review
post #6686 of 6799 Old 05-31-2019, 01:01 PM
Bill Cruce's Avatar
Liked: 27
I poked around on the JVB site and found a mod that plugs into the RS-232 port
http://www.jvbdigital.nl/jvb.asp?cur...tle&title=1285
Bill Cruce
Widescreen Review
post #6687 of 6799 Old 06-01-2019, 09:37 AM
Quoted: 109 Post(s)
Liked: 77
I have a 203 and a 205 that I bought with the hardware region free mod (from JVB, if it matters).
Does anyone know if it's safe to update the firmware, or will the modification present a conflict?
I hate to even attempt it since just about everything else is working fine- but the one complaint I do have is how discs with Dolby Vision are locked out of the Oppo's image processing controls. I don't even know if the Dolby Vision issues that were addressed in the second to the last FW update would cover this, I just noticed that that update seemed to concern DV primarily.
My only real issue is on the one WB title I have (Superman TM), the reds are way oversaturated, and almost fluorescing. Even the reds tones in people's cheeks are too pronounced and come off looking like clown make up.
My display is a JVC 4910 pj. I don't think an upgrade is in my future anytime soon.
Paulidan XM is offline
post #6688 of 6799 Old 06-01-2019, 09:43 AM
Soccerdude's Avatar
Quoted: 349 Post(s)
Liked: 112
My Oppo 203 won't allow Dolby Atmos audio disc to play with my LG/Meridian Sound Bar . I can't figure it out
LG OLED C8 65 2018 , LG SL 10YG SoundBar. HT: JVC RS2000, Studio Tek 130 1.3 Gain Sscreen, Apple TV4k, Def Tech 9080/9060 Dolby Atmos Speakers, Denon X6500H , Oppo203 and a nagging wife.
Soccerdude is offline
post #6689 of 6799 Old 06-01-2019, 04:13 PM - Thread Starter
kucharsk's Avatar
Liked: 1035
Installation instructions for the external mod.
I just got mine and I am watching a region B disc at the moment with no difficulties.
Name:	Screen Shot 2019-06-01 at 5.12.19 PM.png
post #6690 of 6799 Old 06-05-2019, 12:34 PM
Shane.Strawn's Avatar
Apologies for what is probably a dumb question, I am investing in some ZMF Aeolus headphones and obviously want to get the best out of them with my 205, can anyone advise what is the best method of connection to get the best sound i can. I am also using an Arcam AV-860 if this makes any difference.
TIA
Panasonic TX-65EZ1002B(ISF Calibrated),Oppo UDP-205,Arcam AV860,
Amps: Nord One UP NC500DM 3CH powering XTZ M8's L/C/R, Lexicon LX-7 powering XTZ S5's, Rears XTZ M6's,Sub's: Dual PSA S1811's ,AV Cabinet: BDI OLA in chocolate Walnut.
Shane.Strawn is offline
Reply Blu-ray Players
