Official OPPO UDP-205 UHD Blu-ray Player Owner's Thread - Page 227 - AVS Forum | Home Theater Discussions And Reviews
 4168Likes
post #6781 of 7104 Old 07-24-2019, 03:33 PM
moonhawk's Avatar
Quoted: 144 Post(s)
Liked: 77
Originally Posted by Nicoff View Post
BTW, you can buy an HDMI switcher for less than $40 that will keep you from having to swap cables. Then you can connect the Audio Out HDMI cable from the Oppo to the SP3 and connect the video out from the Oppo to your projector. I am actually doing that to have the Oppo do all the audio processing before sending to the SP3.
When there's more 4K available I'll either do that of get the SP3 upgrade. Meanwhile, my Dish doesn't need it because there's virtually no 4K content on Dish so I just need to plug the Roku into the OPPO once I figure out why it's not passing 4K. I'll report back once I do.
Thanks, everyone, for your input.
______________________
__________
Dave
moonhawk is offline
post #6782 of 7104 Old 07-27-2019, 08:35 AM
Liked: 0
Tidal on Oppo 205
Hi all,
Can someone direct me to the instructions on how to play Tidal through the 205 .
Had a look but can't seem to find them
Many thanks
clanpitt is offline
post #6783 of 7104 Old 07-27-2019, 05:07 PM
sta363's Avatar
Quoted: 20 Post(s)
From Tidal Support:
"To use TIDAL on your Oppo device, please go to the App Store on your device to download Oppo Media Control. Once you have Downloaded the Oppo Media Control application, you will then need to connect to your Oppo device on your network. Once the App is paired, you can log in to TIDAL via the app to begin streaming on your Oppo device." (https://support.tidal.com/hc/en-us/a...203131191-Oppo)
petexian likes this.
sta363 is offline
post #6784 of 7104 Old 07-27-2019, 09:41 PM
Nicoff's Avatar
Quoted: 107 Post(s)
Liked: 33
Originally Posted by sta363 View Post
From Tidal Support:
"Once the App is paired, you can log in to TIDAL via the app to begin streaming on your Oppo device."
It is not clear to me which app they are referring to. I downloaded the Oppi App and have "paired" (i.e., connected the Oppo app to the player/network). But how do I connect Tidal to the Oppo? Can Anyone explain please?
Nicoff is offline
post #6785 of 7104 Old 07-27-2019, 09:51 PM
laserjock II's Avatar
Quoted: 1343 Post(s)
Liked: 757
I don’t think there’s any streaming available on the 200 series players.
Sounds pretty darn good using the Pro-ject Stream Box S2 Ultra USB out to the 205 DAC
laserjock II is offline
post #6786 of 7104 Old 07-28-2019, 02:19 AM
Liked: 0
Yes, i tried it with the Media Control App but it doesn't seem to work
clanpitt is offline
post #6787 of 7104 Old 07-28-2019, 02:22 AM
Liked: 0
Cannot seem to stream from my phone.
Am thinking of buying a Streamer to use in my main system to listen to Tidal but don't want to spend money unneccesarily if my 205 can do it
clanpitt is offline
post #6788 of 7104 Old 07-29-2019, 01:23 PM
mt14942's Avatar
Quoted: 837 Post(s)
Liked: 237
Originally Posted by Steriac View Post
^ That’s too funny. I guess cats are known to be fairly smart and naughty animal.
Thanks for explaining the cause. You are right about my Sony TV. It is (or maybe was by now) their latest 900 series TV.
I’ve been turning the display off while listening to 2 channel listening but that’s a pain to live with and simply dumb. Don’t know why CD input with only XLR source would trigger the HDMI handshake, is beyond me. Totally defeats the purpose having multiple cabling if the software can not differentiate signal paths.
Originally Posted by Bob Pariseau View Post
OPPO has to play by the rules for HDMI handshakes, even when they are not supposed to be happening.
Complaints better sent to Sony. Other TVs don’t do this.
—Bob
I had this same problem with my Sony 940C TV even though for 2-channel audio (cd, sacd) I am using the balanced analog outputs directly to my pre/pro and I even use the 2 HDMI outs one for video to the TV and the other to my pre/pro for 4k/bluray viewing. Just didn't make sense that I would still get the audio dropouts. However the Sony Z9D doesn't have this issue using my same setup, I just put the cd disc into the oppo and just hit play with the TV off. This was certainly not the reason I changed to the Z9D as Bob mentioned there's a few work arounds for that issue and I just turned off the video via the TV remote but it's nice not having to do that anymore.
Sony A9G
Oppo UDP-205 4k Universal Player
Classe SSP-800 Pre/Pro
Parasound Halo 5 Channel Amp
mt14942 is offline
post #6789 of 7104 Old 07-29-2019, 04:11 PM
chrisdack's Avatar
Quoted: 241 Post(s)
Liked: 81
Hi all,
Many thanks
BubblePnP or mConnect on Android. The latter somehow gets MQA over onto the Oppo native decode and unfold. Neither does "Tidal suggestions" that well so I create a playlist of their suggestions
chrisdack is offline
post #6790 of 7104 Old 07-29-2019, 05:56 PM
Jon
Jon's Avatar
Quoted: 26 Post(s)
Tidal / Oppo
Hi all,
Many thanks
Use mconnectHD for ios / android (built in Tidal and Oppo support) or.....
Use usb driver (download from Oppo) on a Pc or Mac utilizing Tidal app / program.
Both methods work equally well with the 205. Search earlier in this thread for more details.
John
Jon is offline
post #6791 of 7104 Old 07-29-2019, 10:16 PM
Nicoff's Avatar
Quoted: 107 Post(s)
Liked: 33
FWIW I tried the HDMI switcher and decided to return it. The problem I found is that when using different sources, there was lip syncing issues. That means that I would have had to make adjustments whenever I switched from one source to another. I decided that it was not worth the effort. YMMV.
Nicoff is offline
post #6792 of 7104 Old 07-30-2019, 01:56 AM
Liked: 0
John
Thanks , i will try them both
clanpitt is offline
post #6793 of 7104 Old 08-02-2019, 07:45 PM
clpetersen's Avatar
Quoted: 216 Post(s)
Liked: 69
Hey Nicoff - we use the OPPO 205 as the pre/pro in our media setup. use a Kinovo HDMI switch, though not rated for 4K, it seems to work well even for 4K. 3 sources: Roku Ultra for streaming, Oppo 205 for physical media, and an xfinity (Comcast) box for everything else. No current lip synching issues, but previously I did had some - it was content dependent, not source dependent. In other words, say on the Roku, if I noticed a lip synching issue, switching content on the Roku (Netflix to Amazon for example) showed no lip synching issues. FYI.
clpetersen is offline
post #6794 of 7104 Old 08-02-2019, 11:17 PM
Liked: 0
Lagging when using 205 as preamp for PC
I am running the 205 as the preamp for my computer. I have the HDMI out from my NVIDIA gfx card going to the HDMI IN of the OPPO. Originally, I had planned to use the HDMI out back into my monitor, but there was a severe lag, and the resolutions didn't match up. So, I hooked up another HDMI to my gfx card to go directly to the monitor and there is no delay, but I still have the other HDMI to the OPPO for surround sound.
I thought I was in the clear with this setup, but there is still a severe lag in the audio signal. It's got to be about half a second between when I do something on the PC, and when the speakers react. The outputs of the OPPO are going directly into power amps, so it really seems like its something in or between the PC and OPPO. I tried setting the delay to -100ms, but that does not fix it.
Any suggestions? I never got a delay over the USB connection, but that does not support surround sound... I also suspect it might be Windows 10 doing something weird, but I thought I would ask here as well. TIA
Ckafoweeth is offline
post #6795 of 7104 Old 08-11-2019, 12:50 PM
cglenn's Avatar
Quoted: 44 Post(s)
Problems playing wav and flac files via USB input (both transport and timing related)
Background: I recently purchased a Zoom H4N. I'm using RCA audio L/R out from my Denon 3312 (recording Internet Radio and FM radio), passing thru a passive pre-amp to reduce signal strength (no difference with the pre-amp out of the loop), and inputting into the H4N via XLR. This unit records in 2.15gig chunks to a standard 32gig SDSC card, starting a new file each time, with no loss at the new file start.
I am saving at 96/24 as a wav file. I import the wav file into Audacity and save as 24 bit (level 8) flac. But similar things happen with both the original wav and the saved flac files. In the Oppo, using front USB input and an online playlist, I search for tracks I want listen to and skip ones I don't.
Transport: The FF and Rew buttons work only on the last file in the folder. If there are three files, the first two ignore these buttons. When I renamed the files to display in a different order, again, only the last file will accepts FF and Rew. This seems like a bug! The GoTo button is even more problematic.
Timing: When I use GoTo, very strange things happen. Occasionally, for skipping over the first 5 or so minutes, it works as advertised. But after that, here is one Really Bad Example. BTW, this 2.15 gig at 96/24 records 62 minutes. I GoTo +45 minutes and press enter. The time display and the progress bar both display what I entered, that is 45min, 3/4 of the bar visible, but what really happens is the track is resumed where I pressed GoTo. So I'm still playing at the point where I pressed GoTo, but display shows 45min. I have 3 of these files on the thumb drive, and when the 45minutes plays for 17 more minutes, the display shows I'm on the second track, with time advancing, but in reality, I'm only about 30 minutes into the first track. If I press stop and start over, the same happens, as when I remove and re-insert the USB drive.
The owners manual only discusses GoTo with video disks; in the media area, it's not mentioned
Another failure mode which I have seen in these wav files only (which is why I converted to flac just for listening), is a near-the-beginning-of-the-track GoTo will work, but after roughly 5 minutes, if I GoTo, all I get is static. Every GoTo after this, until I press Stop, results in static, *except* if I GoTo the 5 minute or less mark.
Thus, I am not able to search for specific locations on the file. The only thought I had, and I would think the Oppo would have no problem with this, is that the hi-res-ness of the file is too much for the Oppo. There were few within-this-area search hits and none on this topic, so I don't think it is a Known Issue.
Thoughts/reflections?
Last edited by cglenn; 08-11-2019 at 02:12 PM. Reason: Changes to Transport paragraph
cglenn is offline
post #6796 of 7104 Old 08-12-2019, 08:59 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5869 Post(s)
Liked: 8403
^ Turn off Gapless playback in Settings. That should fix your FF / REW problem. Most playback controls will not function when Gapless. The difference with the last track in the folder is that there is no following track so Gapless is not engaged.
This may also cure your GoTo problem.
—Bob
ti-triodes likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #6797 of 7104 Old 08-13-2019, 03:43 PM
cglenn's Avatar
Quoted: 44 Post(s)
Thanks Bob!
cglenn is offline
post #6798 of 7104 Old 08-16-2019, 10:09 PM
Liked: 0
Originally Posted by angryfoot View Post
1) OLD: The OPPO lists each track on an album in ALPHABETICAL order. The only way I have found to get the tracks in the correct order is to use iTunes "Song Info" to RENAME each track with a number (e.g. 01 Magical Mystery Tour, 02 The Fool on the Hill, 03 Flying, 04 Blue Jay Way etc.) Then the OPPO sees and sorts by numerical value. Renaming each track is time consuming to say the least. Is there a simpler way than renaming each track to get the OPPO to play the track in the order they are listed on the album after they have been been imported into iTunes? (iTunes displays them
Joined the forum so that I could reply to this. I have the same problem and it's super annoying! What's really weird is that my tracks are prefixed with the track number; I use the following filename template: <track #> - <track name>.<extension>
The Oppo 205 seems to ignore the "<track #> - " part and sort on <track name>.<extension>
I emailed Oppo support about it awhile ago, and here's what they said:
If you are using DLNA streaming, what is the DLNA server that you are using to share the files over the network? It is possible that your DLNA server is removing the track number from the filename. The player uses the filename for sorting, not the metadata, because many files will not support metadata information.
Any ideas? I'm using the latest firmware.
Adrian Bickerstaffe is offline
post #6799 of 7104 Old 08-17-2019, 05:27 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4742 Post(s)
Liked: 4619
Welcome to AVSForum.
Are you using DLNA, as OPPO asked? If so order is determined by the server, not the player.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6800 of 7104 Old 08-19-2019, 12:48 AM
THXTEX1's Avatar
Quoted: 42 Post(s)
Liked: 25
When using the USB DAC feature or when playing back MQA bass management is not working. These 2 only works as a 2.0 setup.
I use power amplifiers directly connected to the Oppo with ‘Small’ speakers and subs.
I was thinking of disabling subwoofer and set the left + right speakers to ‘Large’ in Oppo setup – then connect the stereo outputs to the subwoofer. The subwoofer has ‘Output’ connectors. These would then go back to my power amplifier, which then drives the main speakers.
I have not done it yet because I do not have all the cables needed in the correct length.
Crossoverfilter will be in the subwoofer and not the one in the player.
But what do you think of this? I’m not in the big need of USB DAC and MQA is more like a ‘nice to have’.
What do you think? Will I loose more in sound quality by changing to this setup than gaining with the ability to play back MQA?
Regards
Thomas
UE55F9005 - SEK-3500U/ZG
OPPO UDP-205EU
ROTEL RB980 + RB985 poweramps
3 Miller & Kreisel MP150 + 2 S150T speakers + 2 V12 subs
THXTEX1 is offline
post #6801 of 7104 Old 08-20-2019, 02:17 PM
Nuro's Avatar
For the first time since I have owned my OPPO205 I turned on DTS Neo Cinema and I also tried DTS Neo Music. Now I can’t turn NEO off. I go to settings and choose OFF. But then I play a stereo CD and three channels are active (fr,fl, sr). When I play Cable TV via HDMI, the same three channels are active. I have reset the Oppo to factory settings, but the problem remains and DTS is stuck on.
Any suggestions?
Nuro is offline
post #6802 of 7104 Old 08-21-2019, 03:15 AM
Liked: 0
-Bill
Thanks for pointing me in the direction of DNLA. I was using Windows' in-built media streaming functionality, which seems to be the cultrit.
Things started to work as expected when I disabled the Windows media streaming option and installed Serviio instead. I didn't realise that the server dictates the order.
Thanks again,
A.
post #6803 of 7104 Old 08-21-2019, 10:55 AM
Kamikaze13's Avatar
Quoted: 109 Post(s)
Liked: 51
Worth it? Used UDP-205 or mainstream player?
Just looking for input if it's worth picking up a used mint condition 205 for $750 CAD or go with the offerings from a mainstream player?
I have a dedicated theater, full light control and running a JVC DLA-RS57U projector with 122" screen, 7.2.4 speaker setup and used for 99% movie watching.
VIDEO: JVC DLA-RS57U Projector / 130″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
post #6804 of 7104 Old 08-21-2019, 12:43 PM
Quoted: 768 Post(s)
Liked: 309
[QUOTE=Kamikaze13;58453276]Just looking for input if it's worth picking up a used mint condition 205 for $750 CAD?
If you can buy a mint 205 for $750 CAD I'd snap it up now.
dbphd is online now
post #6805 of 7104 Old 08-21-2019, 12:56 PM
Read the FAQ!
Liked: 8403
Any suggestions?
Confirm that DTS Neo:6 Mode is set to OFF.
Set Standby Mode to ENERGY EFFICIENT, and turn the player off. While still off, unplug the player and press and hold the power button on the front panel for a few seconds to discharge any residual power. Plug back in, power up, and test again. If the problem persists, get in touch with OPPO Tech Support. You can use the Email Us link on the OPPO Digital Support page for the 205.
--Bob
post #6806 of 7104 Old 08-21-2019, 01:55 PM
Nuro's Avatar
Thanks Bob. I tried this, but no change: I still have FR, FL and SR active on redbook CDs. I also swapped out my old 5 channel amp for a new one in case the issue was the amplifier, but results are the same.
I contacted OPPO CS with this issue. CS says it is weird. I agree and hope they have a solution.
My lesson learned; never use DTS Neo.
Nuro is offline
post #6807 of 7104 Old 08-21-2019, 02:00 PM
Kamikaze13's Avatar
Quoted: 109 Post(s)
Liked: 51
[quote=dbphd;58453780]
Looks like a scam
post #6808 of 7104 Old 08-21-2019, 03:44 PM
Nuro's Avatar
For Bob Pariseau
Second time is the charm! I repeated the procedure and my 205 is back to normal! The speakers all act as they should.
Thank you Bob.
Nuro
Bob Pariseau likes this.
Nuro is offline
post #6809 of 7104 Old 08-21-2019, 08:26 PM
Read the FAQ!
Liked: 8403
For Bob Pariseau
Thank you Bob.
Nuro
Keep an ear out in case the problem returns. Also check whether any settings in Setup seem to have changed on their own — e.g., speaker distance settings mysteriously changing back to defaults after you’ve set them to correct values. If so, get back in touch with OPPO, as your hardware may have a fault in its settings memory.
—Bob
post #6810 of 7104 Old 08-22-2019, 09:05 PM
Nicoff's Avatar
Quoted: 107 Post(s)
Liked: 33
Would you buy it for me please? I will wire you the money. Does that tell you something?
Nicoff is offline
Reply Blu-ray Players
