Official OPPO UDP-205 UHD Blu-ray Player Owner's Thread - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 4174Likes
post #1411 of 7168 Old 06-09-2017, 04:38 AM
hal250's Avatar
Quoted: 339 Post(s)
Liked: 192
^ Other kewl upgrades (at least nice to have) would be a web browser and larger front panel window in order that settings changes, etc. can be made without the need for an external monitor hooked up via hdmi.
Golden Ear Triton Reference (pair), Musical Fidelity M6si, Schiit Yggdrasil-B, Oppo UDP-205, Emotiva ERC-3, LG OLED65C9PUA, Salamander Synergy Triple Unit SL20, Audeze LCD-X
hal250 is offline
post #1412 of 7168 Old 06-09-2017, 04:45 AM
hal250's Avatar
Quoted: 339 Post(s)
Liked: 192
Originally Posted by dmusoke View Post
Secrets Magazine just did the final audio tests on the Oppo UHD-205 and they found them to be excellent as they tested the limits of their test instruments. But it was also mentioned that the older BDP-105 measured the same as the 205, which I found encouraging. Since these players have already display ultra-low distortion levels, I can't see how future Oppo players (UHD-305 and UHD-405?) can improve their audio any further.
As I read the review, I note "All in all, distortion measured in the OPPO UDP-205 was inaudible. It was slightly better than the BDP-105, but the differences not significant."
hal250 is offline
post #1413 of 7168 Old 06-09-2017, 04:54 AM
T-smith's Avatar
Quoted: 399 Post(s)
Liked: 366
You can use the app to change settings
Upgraditus is a real disease
T-smith is online now
post #1414 of 7168 Old 06-09-2017, 04:59 AM
alebonau's Avatar
Quoted: 2027 Post(s)
Liked: 1403
question...
does anyone know if something changed in the hdmi handshaking with the new official firmware ?
prior ... I could boot my marantz av8802A, oppo and the jvc x7000 and i would the menu screen
now I am instead getting a blank screen... rebooting the marantz does nothing. i have to reboot the oppo before will get a menu up
i notice if instead i make sure the jvc has completely booted and then switch on the marantz and oppo then I will get a menu up.
prior to this official firmware I never seemed to have to bother with all this. have never had to reboot the oppo 205 ?
also the pana 900 doesnt exhibit this kind of hanky panky
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #1415 of 7168 Old 06-09-2017, 05:59 AM
hal250's Avatar
Quoted: 339 Post(s)
Liked: 192
I realize that. However, I do not have a "smart" phone, I have a "dumb" one
And, I already asked Oppo if they have an "app" that can run on a windows 10 OS. They do not. They should. Therefore, I'd like to add that to my previous "nice to have" post.
hal250 is offline
post #1416 of 7168 Old 06-09-2017, 07:36 AM
T-smith's Avatar
Quoted: 399 Post(s)
Liked: 366
I think you know you are in the minority though and the support model by companies is typically to support the masses.
App can also be used on an iPad which might be worth the investment if you are making changes that often.
post #1417 of 7168 Old 06-09-2017, 07:36 AM
Liked: 0
Another review that emphasizes the audio can be found at Hometheaterreview.com (sorry but I'm not allowed to add the link).
akebergv is offline
post #1418 of 7168 Old 06-09-2017, 08:03 AM
hal250's Avatar
Quoted: 339 Post(s)
Liked: 192
Yes, I do realize I am in the minority and companies such as Oppo want to support the masses. So I completely agree with you.
Nevertheless, this is why I state that a worthwhile (IMO) upgrade would be to include a larger "preview" screen on the player itself to avoid the necessity of having to use an app or monitor. Wishful thinking perhaps.
The aforementioned said, in my case there are many instances where I use the Oppo for music playback only. In those instances I prefer to have my Samsung off entirely (albeit it is in standby mode) to not incur any additional electrical cost and to prolong the life expectancy of the unit in general.
So, I have found a way to circumvent having to use any monitor by better understanding the remote control key pad entry sequence; which of course can be re-keyed having nothing to do with a monitor or app of any kind.
And, obviously if I use the Oppo to watch a video the desire to have a preview window on the Oppo is moot, because in those instances I do have the Samsung powered on.
hal250 is offline
post #1419 of 7168 Old 06-09-2017, 08:10 AM
beatmachine's Avatar
Quoted: 17 Post(s)
HDMI Audio Only
So , besides the UI of the AVR, where would you one confirm that "audio only" HDMI is engaged?
beatmachine is offline
post #1420 of 7168 Old 06-09-2017, 09:13 AM
linger63's Avatar
Quoted: 116 Post(s)
Liked: 72
Well, we can only measure what we know
The BDP-95 used the ESS9018 DAC chip.
The BDP-105 used the ESS9028 DAC chip.
The UHD-205 uses the ESS9038PRO DAC chip.
All above chips are state-of-the-art with vanishingly low distortion and noise specs. Even if ESS came out with a new chip 2+ years from now, (e.g ESS9048PRO ?), I think we've reached the point where noise and distortion specs will not improve much when these chips are designed into newer audiophile players. At least unmeasurable by even the latest APx555 test instruments.
If there's a future UHD-305/405/505, I hope they have newer features such as (1) Vacuum tube emulation (2) Some type of room correction software (3) MQA support(?)
NO Oppo gear has ever used the ESS9028 DAC chip.
The BDP 105(D) used the same ESS9018 DAC chip as the previous 95 model employing a different implementation method......(the 83SE used the ESS9016).
Both the new Sonica DAC and UDP 205 use the latest ESS9038PRO.
vavan likes this.
linger63 is offline
post #1421 of 7168 Old 06-09-2017, 09:22 AM
dmusoke's Avatar
Quoted: 442 Post(s)
Liked: 221
You're correct. My mistake...
linger63 likes this.
How to phase match subwoofers to the mains speakers: https://www.avsforum.com/forum/showt...0#post19542630
dmusoke is offline
post #1422 of 7168 Old 06-09-2017, 09:23 AM
dmusoke's Avatar
Quoted: 442 Post(s)
Liked: 221
Here
A few highlights...
"After listening to the UDP-205, some will describe it as being very accurate, and they'll mean it as the highest compliment. Others may lean more toward a term like "analytical" because they prefer a different kind of sound."
" The UDP-205 definitely excels at giving you exactly what it's given, warts and all..."
"... Rather, the UDP-205 is for the all-around audiophile media enthusiast and physical media lover who wants an exceptional high-resolution audio and CD player, as well as a damned fine headphone amplifier and an exceptionally capable preamp thrown in for good measure. It's also for the discerning listener who demands the utmost in accuracy and transparency."
"On the other hand, with Miles Davis's Kind of Blue (Columbia Records, specifically CS 64935 for those of you who are curious exactly which SACD release), I definitely preferred the precision and detail of the UDP-205. The enhanced air and atmosphere it lent to the recording. The way the bright percussion hung and wafted through the air."
dmusoke is offline
post #1423 of 7168 Old 06-09-2017, 09:27 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5893 Post(s)
Liked: 8430
Originally Posted by alebonau View Post
question...
Nothing has changed in the handshake itself (as far as I know), however it may be that the 205 is booting up faster in this firmware -- thus initiating the handshake sooner than it had in the past. That would explain the difference if your JVC is slow to come alive when you power it up, so that it can't respond properly to the HDMI handshake. It is very common for displays to be slow to come alive with regards to HDMI. That's why the recommended power up sequence is in the reverse order of signal flow: Display, then AVR, then source.
--Bob
alebonau likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #1424 of 7168 Old 06-09-2017, 09:33 AM
Read the FAQ!
Liked: 8430
Well if you are getting audio in the AVR from the Audio HDMI output of the OPPO then it is obviously engaged.
If you mean how do you prove the "audio-only" nature of that output, that's simple too. The Audio HDMI output of the 205 only operates one way: If connected to a live HDMI input at the other end of the cable it will send HDMI audio embedded in a Black frame of HDMI video. Always. There is never movie or other content video on the Audio HDMI output. Not even the player's menus.
This is true regardless of your player settings, and without need to engage, e.g., Pure Mode in the player.
There IS a Black frame of video (at 1080p) on that cable. That's how HDMI works. HDMI audio is never a separate signal. It is, always and only, embedded in an HDMI video signal. HDMI audio is multiplexed into the "blanking intervals" of HDMI video. In the case of the Audio HDMI output, the player does that by having the HDMI output electronics produce a static, black frame of video so that there's a place to put the audio.
--Bob
post #1425 of 7168 Old 06-09-2017, 09:38 AM
dmusoke's Avatar
Quoted: 442 Post(s)
Liked: 221
So ... for those of us who liked the streaming apps like Vudu, Amazon Prime etc...what is the next available option? Does a 4K Roku box fit the bill or do I need something else?
dmusoke is offline
post #1426 of 7168 Old 06-09-2017, 09:41 AM
ironsurvivor's Avatar
Quoted: 243 Post(s)
Liked: 100
I would go for the Nvidia shield. Hands down the best streamer
Sent from my SAMSUNG-SM-G935A using Tapatalk
dmusoke likes this.
Marantz AV7702MKii, 2x Marantz MM7055, Oppo UDP-205
Sony 65 A1E
Bowers and Wilkins CM10 S2, CM Center 2 S2, CM1 S2
SVS Prime Elevation
SVS SB16 Ultra
ironsurvivor is offline
post #1427 of 7168 Old 06-09-2017, 09:47 AM
linger63's Avatar
Quoted: 116 Post(s)
Liked: 72
No biggie..
IMHO they're all great machines!!!!
BIG OPPO "fanboy" here..............LOL
linger63 is offline
post #1428 of 7168 Old 06-09-2017, 09:48 AM
eganz1's Avatar
Quoted: 119 Post(s)
Liked: 109
Although many people find the audio quality already good enough, there are many remaining areas that could be improved.
For example, the analog output stages could be improved, Power supply noise reduced, high frequency internal noise reduced.
The electrolytic output coupling capacitors could also be removed.
Internal bypass capacitors to analog stages could be improved, as well as for the main sabre chip.
LPS could be implemented for the main chips, and clocking could be improved.
These concepts continue to be explored in the DIY forum thread on this topic.
Of course, others have hoped that room correction or atmos or DTS-X decoding would be included.
E
my solution to these limitations is an anthem AVM 60.
Theater: Sony A1E OLED 4K Ultra HD, Oppo-205, Anthem AVM60, 7.1.4 B & W CM 7 LR,CDM-cse, CM 1, CM 1 S2, Silverline minuet , SVS SB13 Ultra, Rotel RMB 1555, Parasound A23, Naim NAP 100, EEcolor lut box. Calman, MobileForge, I1D3 & I1pro 2.
Stereo: Aurender N100H, Auralic Vega DAC, Focal Chorus 836 W, BAT VK-3ix, Pass XA 30.5, PPP.
eganz1 is offline
post #1429 of 7168 Old 06-09-2017, 12:19 PM
hal250's Avatar
Quoted: 339 Post(s)
Liked: 192
Originally Posted by Bob Pariseau View Post
... If connected to a live HDMI input at the other end of the cable it will send HDMI audio embedded in a Black frame of HDMI video. Always. ...
Except in cases of Audio Output > HDMI Audio Format > Off.
True?
hal250 is offline
post #1430 of 7168 Old 06-09-2017, 12:37 PM
Bill Mac's Avatar
Quoted: 2282 Post(s)
Liked: 3544
Happy to report that with the latest firmware I'm no longer getting the audio pause with SACDs when set to DSD . Another fine job of Oppo paying close attention to the owners of their players. The 205 is far from perfect but it's working quiet well for me!
A quick video related question. This might be commonly known but will the 205 play PAL / R2 DVDs?
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound STP-SE (preamp), SX-500s, ST-500, ST-250, Oppo UDP-205, UDP-203, BDP-105, BDP-103, BDP-93, BDP-83, Panasonic TC-P60GT50, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #1431 of 7168 Old 06-09-2017, 12:38 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4762 Post(s)
Liked: 4679
Bill
Not out of the box, but there is a free software patch -- SuperDisc -- that will make it region free for DVDs. Not for Blu-ray.
See the FAQ for details.
-Bill
Bill Mac likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #1432 of 7168 Old 06-09-2017, 12:40 PM
Bill Mac's Avatar
Liked: 3544
-Bill
Bill,
Thanks for that information !
post #1433 of 7168 Old 06-09-2017, 01:01 PM
hal250's Avatar
Quoted: 339 Post(s)
Liked: 192
-Bill
the superdisk hyperlink points to http://www.multi-region.net/oppo_bdp-83 and that throws an internal server error
hal250 is offline
post #1434 of 7168 Old 06-09-2017, 01:17 PM
dmusoke's Avatar
Quoted: 442 Post(s)
Liked: 221
E
1. Test data shows no power supply noise injected into the analog circuits. if there was any, it was well below the background noise of the player.
2. Improve the clocking? The ESS dacs have excellent jitter tolerance while hardly producing any jitter.
3. Better bypassing of the ESS dac? Again, if it was inadequate, power supply noise and/or other forms of noise junk (spikes?) would have been shown up in the test plots. None ever did. Noise is
electrical in nature and not invisible.
4. As for the output cap, the one used in the 105 was of very high quality (i.e. very low distortion cap with a very low voltage coefficient). I'm assuming the same type of cap or better is used in the
205. Besides the output cap is needed to block DC into the inputs of preamps and amplifiers, which is a good thing.
5. Curious, how is the AVM60 the solution to the limitations you mentioned above?
dmusoke is offline
post #1435 of 7168 Old 06-09-2017, 01:28 PM
wmcclain's Avatar
Liked: 4679
It's working from here.
-Bill
post #1436 of 7168 Old 06-09-2017, 01:35 PM
birdboy01's Avatar
Quoted: 20 Post(s)
--Bob
thank you Bob
birdboy01 is offline
post #1437 of 7168 Old 06-09-2017, 02:02 PM
Bigmoviefan's Avatar
Quoted: 646 Post(s)
Liked: 468
Has anyone using the Oppo 205 also owned the Oppo 203 and found that Blu ray and 4K Blu-ray movies and concert Blu-rays actually sound better on the Oppo 205 over 203! I know Oppo 205 has a better supply and I read less jitter than 203, I wonder if you have a High end surround system you could hear a difference in the 205 over 203 with lossless movies and concerts (I know two channel analog audio will be better) ?
Bigmoviefan is offline
post #1438 of 7168 Old 06-09-2017, 02:11 PM
eganz1's Avatar
Quoted: 119 Post(s)
Liked: 109
As I said, many people find the sound from this unit sufficiently good or excellent already, and there's no point arguing whether you could hear the difference or not. I certainly find the overall 205 package very appealing and purchased it myself.
Test data are of course very important but often do not distinguish between great sounding and excellent audio equipment.
For pure two channel use, and a high-resolution system, with modern high resolution recordings, I find that a dedicated DAC such as a Auralic Vega DAC sounds much better than the universal OPPO. This is due to many factors that are better in the dedicated DAC, including better clocking, reclocking, power supplies, RF noise avoidance, jitter avoidance, bypassing, better analog output circuitry etc.
One problem with having a video player etc. in the box is that you get a lot of high frequency and RF noise introduced.
3. The SABRE DAC is using high-frequency current pulses to assemble the final output voltage or current. Therefore, it does benefit from increased local bypassing as I have demonstrated myself on a 105. The 205 actually uses four times higher current...
upthread, someone else discussed the benefits of improved bypassing on the analog parts of the 205 analog stereo board.
4. You're wrong if you think it is desirable to send your musical signals through a polarized electrolytic capacitor. This electrolytic cap is generally not needed and can simply be bypassed or omitted. This will remove some of the remaining grain on female voice especially. I have also demonstrated this previously on a 105.
5. I thought it would be apparent that the AVM has room correction, DTS-X, and Dolby atmos decoding...
for two channel use such as SACD, DSD , or 96/24 etc I believe that the OPPO is probably higher resolution, but it would benefit from some modifications.
E
At the end of the day, I encourage you to enjoy your equipment and listen to the music.
Since you specifically asked how one could improve the unit, I made you a list of some potential improvements that could be considered.
dmusoke and vavan like this.
eganz1 is offline
post #1439 of 7168 Old 06-09-2017, 02:39 PM
ti-triodes's Avatar
Quoted: 570 Post(s)
Liked: 1353
I compared both via HDMI and found no difference that I could hear. Stereo through the SE analogs was a different story. The 205 was clearly better with a wider soundstage and more focused imaging. But the 203 is no slouch, even through the analogs it will satisfy the vast majority of people who use it that way. OTOH, the balanced outs of the 205 are absolutely spectacular. IMO, it's where the 205 really shines.
Bigmoviefan likes this.
ti-triodes is online now
post #1440 of 7168 Old 06-09-2017, 02:51 PM
Quoted: 646 Post(s)
Liked: 468
Thank you for the reply! A person told me I would hear a difference with movies cause of better power supply and jitter control. But maybe it is so slight as it is not really discernible. Appreciate you sharing your experience!
Reply Blu-ray Players
