Panasonic DMP-UB200 Thread (No Price Talk) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #91 of 96 Old 05-09-2018, 06:43 AM
Legairre's Avatar
Quoted: 1214 Post(s)
Liked: 664
Originally Posted by Bob Pariseau View Post
He means can you set the player to shift movie Subtitles vertically so that they are properly positioned for the Scope screen and not off the bottom of the screen.
--Bob
Thanks for the clarification.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is online now
post #92 of 96 Old 05-09-2018, 06:44 AM
Legairre's Avatar
Liked: 664
Originally Posted by tractng View Post
Can somebody confirm if this player allow options to shift subtitles ? Since I am going with a cinemascope screen (shorter screen). Currently have a Sony 40es projector.
There are two setting called V. Center and Vertical size that allow you to adjust the picture to see the subtitles. I've never used them because I have a 16:9 screen but I'll switch the projector to 2:35 tonight and try it and post back this evening.
tractng likes this.
post #93 of 96 Old 05-09-2018, 07:27 PM
Legairre's Avatar
Liked: 664
OK so I found it in the player. You have to go into "video setting" while a disc is playing and then you can move the subtitle text up and down. You can move the subtitles from the bottom to the near the middle of the screen so you can raise them 32% of screen height.
Here's a few pics from Blade Runner 2049 which is 2:35. You can raise the titles from the bottom of the screen up to 32% and even drop them off the screen if you wanted to.
ID:	2400936   Click image for larger version
ID:	2400938   Click image for larger version
tractng and Uppsalaing like this.
post #94 of 96 Old 07-02-2018, 07:15 PM
kxa16's Avatar
Quoted: 18 Post(s)
Originally Posted by kxa16 View Post
Will the UB200 bitstream full lossless tracks (TrueHD, DTS-HD MA, Atmos) over HDMI to an AVR from files on an HDD connected via the USB 3.0 input?
To answer my own question ... I've tested playback of some mkv files from a powered desktop hard drive connected to the rear USB 3.0 port. The player has the latest firmware. The files are encoded with TrueHD Atmos 7.1 and DTS-HD MA 5.1. This player will not output audio from them. The video plays fine, but no changes in the audio settings menu would allow any audio ouput from these files, lossy cores or otherwise. Again, this is over USB. The player has no problem outputting these same audio files from a disc losslessly.
kxa16 is offline
post #95 of 96 Old 07-12-2018, 06:02 PM
zeuspaul's Avatar
Quoted: 232 Post(s)
Liked: 294
The UB200 as a jpeg photo viewer. Does anyone have any experience with this? I have been looking at 4k media players/streamers and 4k blu ray players and the Panasonic 4k players are the only devices I have found that actually call out photo slideshow as an option in the manual. They also specifically call out repeat as a function I need among other options. They do indicate that the files have to meet a specific structure to work but then don't indicate what that is!! I assume they may be referring to a standard file naming sequence in a DCIM folder which is a standard camera structure but??
Also I want actual 4k resolution in a reasonable rendering time. They make no mention of that in the manual. My basic question is will the UB200 work as a jpeg 4k photo slideshow viewer when connected to a 4k TV and a USB thumb drive? Has anyone used it for a 4k slideshow?
HT: PSA MTM-210T front, MTM-210C center, PSA MTM-210T surrounds, PSA MT-110 rears, Atmos / Canton, Ascend CBM-170SE, PSA V1800 , PSA V1801, Marantz SR7009 AVR & Emotiva A-100 stereo amp, Panasonic 65ST60 Plasma, Oppo BDP 93, Sony S1700, Music video: JBL L890, L880, LC2, SVS pc13-Ultra, Yamaha RX-V385, ASUS 31.5" IPS monitor, Sony S1700, Multichannel stereo: PSA MT-110, Bose 901, PSA S1510DF, Denon X1400H, Marantz SR6005
zeuspaul is offline
post #96 of 96 Old 11-06-2018, 08:14 PM
I'm moving up to 4k from my Oppo so I can get the Atmos tracks . My question is does the Panny output Hdmi lossless and optical lossy at the same time ?
monstermike67 is offline
Reply Blu-ray Players
