Samsung UBD-M7500 Owner's Thread (No Price Talk) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #61 of 84 Old 06-21-2018, 10:20 AM
Herve's Avatar
Quoted: 413 Post(s)
Liked: 78
Does the CANADIAN version of this player have the Amazon Prime Video app?
Herve is offline
post #62 of 84 Old 06-21-2018, 02:26 PM
Quoted: 154 Post(s)
Liked: 43
Originally Posted by tjs1210 View Post
Thanks for the post this is exactly what was happening with my VSX-933 dropping video and sound. Thought it was cables and everything else under the sun but the switch from 4.4.4 to 4.2.2 did the trick without any discernible loss of video or audio.
Yeah I actually discovered my cords didn't really support 18Gbs bandwidth and that was the issue. The player works perfectly now with 444 and 60hz. But it drops to 422 for HDR.
Sent from my SM-G965U using Tapatalk
Billy Williams is offline
post #63 of 84 Old 06-27-2018, 04:43 PM
Quoted: 154 Post(s)
Liked: 43
new firmware tonight 1111.4 I wonder what it updated. I can't find anything.
post #64 of 84 Old 07-06-2018, 05:10 PM
b0rnarian's Avatar
Quoted: 2015 Post(s)
Liked: 1179
Can someone pls confirm if this player has FandangoNow 4K app? And if they can be kind enough to do a breakdown of how this player is different from the M8500. Thnx a ton!
b0rnarian is offline
post #65 of 84 Old 07-06-2018, 08:03 PM
Quoted: 154 Post(s)
Liked: 43
I believe the only difference between the players is that the 8500 has wifi. The 7500 is wired only.
post #66 of 84 Old 07-09-2018, 02:20 PM
tehowell's Avatar
One difference is the M7500 has only one HDMI output, so the dual HDMI method (one to receiver, one to TV) is not available.
Billy Williams likes this.
Samsung UN65JS8500 65" SUHD TV (FW 1530); Yamaha RX-A750BL Receiver (FW 2.60); Arris DCX-3600M Cable STB; Nvidia Shield Android TV (SysExp 7.2.3), Sony UBP-X800 (FW M36.R.0239, Oct. 2018), Logitech Harmony 650 iR remote.
tehowell is offline
post #67 of 84 Old 07-26-2018, 10:56 AM
BuGsArEtAsTy's Avatar
Quoted: 715 Post(s)
Liked: 346
Anyone have any issues with the noise of the fan or motor for the UDH-m7500? I saw that mentioned a couple of times in online reviews, but it sounds like it may be individual units as opposed to a problem with all units.
Well, FWIW, the pictures on the Canadian site show a menu with Amazon Prime in it. But there is no official listing of the included apps that I can find.
BuGsArEtAsTy is offline
post #68 of 84 Old 08-04-2018, 08:39 PM
Liked: 0
Sound sync issue and flashing power light
Hi there. I'm a new subscriber to this forum.
I have a two-week old UMBD7500 connected to a SONY XBR65X850E TV with audio out from the TV to a SAMSUNG M360 sound bar.
I am finding that there is a noticeable audio sync issue which manifests as sound after video, not before as is usually described. Audio Sync options allow me to increase the audio delay, not reduce it. Is this common and what can be done about it?
I thought maybe a firmware update might be available, but as other posters have noted, unless you've an Internet connection Samsung has not made any updates available on their Web site.
Something I discovered today; all of a sudden the played did not respond to some remote commands, and eventually the power light started flashing red-green. I couldn't find any troubleshooting information in the manual and online support told me to do a power reset for 10 seconds. However, I chose the easy way and replaced the remote's batteries - this fixed that problem.
So, all I have to figure out now is if I can make the audio sync issue less noticeable (on a 65-inch TV). Thoughts?
Chris
Canata is offline
post #69 of 84 Old 08-05-2018, 06:09 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5813 Post(s)
Liked: 8280
^ Take a look at the portion of my Blog post discussing the “Helpful AVR” problem to see if it gives you any ideas regarding your excess audio delay:
Lip Sync, OR Why are Her Lips Still Moving After She’s Stopped Talking?
In your case the problem might be in the sound bar.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #70 of 84 Old 10-14-2018, 04:42 PM
topcat2001's Avatar
Quoted: 16 Post(s)
Anyone have this issue where the picture seems super contrast with crushed blacks? It seems to go away if I change the resolution manually in the options. Occurs for both 1080p and 4K HDR discs. I've attached pics with and without this problem. Not having this issue on my Xbox One or HD Blu Ray player.
ID:	2468530   Click image for larger version
topcat2001 is offline
post #71 of 84 Old 11-03-2018, 08:18 AM
Liked: 0
I haven't seen this brought in previous posts, does the 7500 have the ability to play HDR10+,? I have a Samsung nu8000 tv and dolby vision will never be an option for me so I want to make sure I get a player with HDR10+.
scip3392 is offline
post #72 of 84 Old 11-03-2018, 01:09 PM
Horace Clark's Avatar
Quoted: 45 Post(s)
Liked: 42
I would say yes but can’t say for sure as their is no content yet in hdr10+. Samsung hasn’t released any Uhd Blu-ray players since 2017 so the m series is the newest. I love this player just keep in mind that it does not have WiFi.
Horace Clark is offline
post #73 of 84 Old 11-03-2018, 03:29 PM
Liked: 0
what would you say the downside of not having wifi on a blu-ray player is?
scip3392 is offline
post #74 of 84 Old 11-04-2018, 05:46 AM
Quoted: 45 Post(s)
Liked: 42
There’s no downside. It’s a matter of convenience. Can you connect an Ethernet cable or not is the only issue. Now if you’re asking about not being connected to the internet than yes there is a downside. That would be not getting the software updates that enable the player to output hdr10+.
scip3392 likes this.
post #75 of 84 Old 11-07-2018, 08:36 AM
DamianostheGreek's Avatar
Could you post a screenshot while playing an 1080p mkv with external srt subtitles?
Thank you in advance
DamianostheGreek is offline
post #76 of 84 Old 11-30-2018, 09:38 PM
Liked: 1
Universal replacement remote
Can anyone suggest a replacement remote for the device? I seem to have mislaid mine in such a way that buying a replacement seems the only way to find it again.
Danke!
Edit: This one worked: https://www.amazon.com/gp/product/B01GCUKWUY/
xmagusx is offline
post #77 of 84 Old 12-25-2018, 11:06 AM
shark1987's Avatar
So I got one for my in-laws but they don't have Ethernet where the player is located. And the Samsung website only has USB update files for the 9500 from what I see right now, not 7500/8500. Does anyone know if those are compatible (the same) or where I could get the update files for the 7500.
It's currently on 1105. But I just wanted to get it updated for them in case their were any critical fixes.
shark1987 is offline
post #78 of 84 Old 12-27-2018, 01:17 PM
Liked: 3
On screen display timeout
Hello. Sorry if this has been covered. I can't seem to find it. I am new to the 7500 and I'm wondering if there is any way to change to on screen display timeout. Specifically, I'm talking about the giant white bar of information that appears when you pause a disc. Once you hit play again, it hangs around for way too long. Any suggestions? Thanks.
HurricaneDitka is offline
post #79 of 84 Old 12-29-2018, 09:03 AM
tehowell's Avatar
FYI - the current firmware for the UBD-M7500 is 1111. I don't know about across player compatibility.
tehowell is offline
post #80 of 84 Old 02-08-2019, 10:24 AM
Philip Hamm's Avatar
Does the "smart" part of this blu-ray player have MLB.TV? Can you confirm this player can not do 3D?
Philip Hamm
Philip Hamm is offline
post #81 of 84 Old 02-08-2019, 12:39 PM
tehowell's Avatar
Not sure about MLB.TV, but UBD-M7500 does not support 3D Blu-ray.
tehowell is offline
post #82 of 84 Old 03-17-2019, 12:10 PM
Liked: 0
Hello. I've a M7500 and M9500. (The former has been adjusted so it's BD and DVD region free, hence the two machines.) However, the remote control units are identical; identical enough to operate both machines at the same time, which is really, REALLY annoying. Samsung's support line advice was to try putting the two machine a long way apart! Not exactly what I was hoping for. Anyone got any suggestions as to how to resolve this problem, short of sticking tape all over one of the machines to block the signal or unplugging it when not in use? Considering how expensive they are, it's disappointing that Samsung doesn't seem to offer any sort of channel adjustment for the remotes. Thanks.
SpikyCactus is offline
post #83 of 84 Old 06-25-2019, 08:19 AM
jack54's Avatar
Quoted: 136 Post(s)
Liked: 39
I just got a new 75" Class NU7100 Smart 4K UHD TV and Samsung HW-F550 2.1-Channel 310 Watt Soundbar and ordered this new Samsung UBD-M7500 4K Ultra HD Blu-ray DVD Player. Anxious to try it all out... will let you all know how it goes once I set everything up.
jack54 is offline
post #84 of 84 Old 09-01-2019, 03:16 AM
Liked: 0
Is there a way to or an app that can download external subtitles when playing videos from my network HDD? Like VLC for example?
Steven Weyne is offline
Reply Blu-ray Players
