Panasonic UHD Blu-ray Players at CES 2018 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 526Likes
post #31 of 369 Old 01-09-2018, 08:07 PM
Super Moderator
teachsac's Avatar
Quoted: 1282 Post(s)
Liked: 2113
Originally Posted by blafarm View Post
^ Thanks. And, yes, that was the nature of my question -- precisely what HDR formats do the apps in the DP-UB820 support?
But possibly the bigger question is -- will the DP-UB820 only 'pass-through' DV and HDR10+ metadata to a monitor connected via the HDMI port?
Expressed in a different way, if a monitor does not support HDR10+, but it does support DV, will the DP-UB820 somehow intelligently 'convert' that metadata to take advantage of the display's dynamic capabilities?
Or conversely, if you are streaming an HDR10+ movie on Amazon Prime using the DP-UB820, and your monitor only supports DV and HDR10 -- will you be stuck watching HDR10?
The Netflix and Amazon apps on my Sony Z9D monitors DO take advantage of the display's capabilities -- but as you pointed out, that's because they are resident in the monitor.
I realize we'll just have to wait -- I was just hoping someone had asked that question at CES.
No one can answer what the apps on this player will support until Panasonic has more info or it is in user's hands. Streaming doesn't work the way UHD discs do. Discs are required to have a base HDR10 if they support Dolby Vision. No discs at this point have come out with HDR10+. With a disc, you get HDR10 if your display doesn't support DV. So look at Vudu for example. For a while they only supported Dolby Vision. If your source component and/or display didn't support Dolby Vision, there was no HDR. You simply got the base UHD. NF and Amazon only provided DV for a while also. There was no base HDR10 if your display didn't support DV. And this was only available through the displays apps ubtil recently when google and apple came out with their DV devices. You are actually better off getting a separate device for streaming or using the displays internal apps than using the apps from a player. For more info on how streaming services are delivering, best to look at the HDR forum area or the streaming providers forum. This area is for the player hardware.
CaptinCrunch and mry110 like this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #32 of 369 Old 01-10-2018, 02:01 AM
thehun's Avatar
Quoted: 1177 Post(s)
Liked: 1200
Originally Posted by teachsac View Post
Panasonic has never supported SACD and only supported DVD-A on their very first Blu-ray player (Bd10). I do not see them supporting either.
S~
The article mention DSD support for it's USB input presumably but no mention of MCH on any audio formats on that same input. Clarification would be great on that.
De sagittis Hungarorum libera nos, Domine!
Attention, don't read my posts if you're a snowflake or easily offended.
The Hun
thehun is offline
post #33 of 369 Old 01-10-2018, 10:00 AM
Mashie Saldana's Avatar
Quoted: 1240 Post(s)
Liked: 1079
Any idea if the 2017 kit from Panasonic will get the HDR10+ treatment via firmware?
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is online now
post #34 of 369 Old 01-10-2018, 10:06 AM
NorthJersey's Avatar
Quoted: 574 Post(s)
Liked: 246
since hdr10+ and DV are competing specs, it's a logical assumption that if your TV doesn't support the feature, whether it's HDR10+ or DV, the UHD will play as HDR10 (if it supports that)
just like now, playing a Dolby Vision-enabled title, for example Fate of the Furious, will play in HDR10 on a UHD player / UHD TV combo that doesn't support Dolby Vision
NorthJersey is offline
post #35 of 369 Old 01-10-2018, 01:42 PM
evac311's Avatar
Will the hdr tone mapping on this player function like dynamic metadata (hdr10+, Dolby Vision?) Or is that just acting to prevent peak brightness clipping?
I have a Sony display that will be getting Dolby Vision but no word on hdr10+ and I'm wondering if this player will give me the benefits of hdr10+ without a compatible display.
Sent from my SM-N950U using Tapatalk
Nima and ShermanOlsen like this.
evac311 is offline
post #36 of 369 Old 01-14-2018, 12:48 AM
IMWhizzle's Avatar
Quoted: 987 Post(s)
Liked: 329
I am curious what the price will be. I think that this player will beat the Oppo in an instance, if they choose for the same base as the ub900.
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED B6
Apple TV 4K
PlayStation Pro
IMWhizzle is online now
post #37 of 369 Old 01-14-2018, 05:28 AM
RoadLizard's Avatar
Quoted: 1441 Post(s)
Liked: 1433
Originally Posted by sync27 View Post
^Agree. I'm not buying anything more on the promise of "future firmware upgrade".
I wouldnt either. Not doing it. A firmware update promise is nothing more than a big fat "maybe you’ll get the update if everything works out and the stars align properly". This player isn’t going to be cheap either so if for some reason it doesn’t get the update then you’re stuck with an expensive player that does NOT play Dolby Vision Discs. Lame.
Honestly, I’m getting sick of the HDR/DV/HDR10/HLG nonsense. Pick one and discard the rest. We need to get this stuff standardized once and for all. It’s a freeging joke.
LG OLED65E6P, Samsung PN64H5000
LG UBK-90, Samsung UBD-8500K
Polk RTi Towers, STi surrounds
Polk Subwoofer
Sony DH550 AVR
RoadLizard is online now
post #38 of 369 Old 01-14-2018, 09:14 AM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
As long as the UB820 does HDR10+ out the box that’s all I care about.
Lozin is offline
post #39 of 369 Old 01-14-2018, 12:34 PM
Jonas2's Avatar
Quoted: 2839 Post(s)
Liked: 1813
AMEN Brother!
dhellner29 likes this.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #40 of 369 Old 01-17-2018, 09:35 AM
UHD Addict
aaronwt's Avatar
Quoted: 9427 Post(s)
Liked: 6110
Not going to happen. Just last week the Blu-ray Disc Association added HDR10+ and SL-HDR2 as an option to the the UHD BD specs. v3.2 spec.
So now those types of HDR can be an option on disc.
Nugget likes this.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #41 of 369 Old 01-18-2018, 05:32 PM
cgott42's Avatar
Quoted: 195 Post(s)
Liked: 27
I have the DMP-UB900 and absolutely LOVE the PQ, even 1080p looks great.
Any word on how the new 820 will compare in PQ - did people see it at CES to compare? or will the 820 be below the 900 and only a possible 920 (as mentioned by someone earlier) offer better PQ?
Also to me a huge new feature is the voice control via Alexa or Google Home - any word on whether the 900 will get this feature via a firmware upgrade?
Also (slightly off topic) what are the differences between the 2016 and 2017 versions of the UB900?
thx
cgott42 is online now
post #42 of 369 Old 01-18-2018, 05:44 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
No word, but Panasonic had great image quality for years.
As far as the 900, it is the same both years, just a two-year model.
XBR65A9G / XBR65A8F / 55R615
ATV4K / Uverse / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #43 of 369 Old 01-21-2018, 03:25 PM
Mikenificent1's Avatar
Quoted: 162 Post(s)
Liked: 46
HDTVtest discusses the new players. I haven’t heard anyone mention the “high precision chroma processor” for any of these players. Right now I believe only the UB900 has it and its arguably it’s most important feature.
Update:
Hometheater forum mentions all the new models will have it.
https://www.hometheaterforum.com/pan...metadata-tech/
Mikenificent1 is offline
post #44 of 369 Old 01-21-2018, 05:44 PM
COACH2369's Avatar
Quoted: 1209 Post(s)
Liked: 1006
Originally Posted by Mikenificent1 View Post
https://youtu.be/qksV3OSgHqQ
Update:
Any idea when we will see these in the U.S.?
COACH2369 is offline
post #45 of 369 Old 01-21-2018, 06:37 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
Summer.
post #46 of 369 Old 01-22-2018, 06:29 AM
bobbino421's Avatar
Quoted: 1296 Post(s)
Liked: 817
I?m wondering if this player will play ball and update regarding the Sony TV DV issues? I?m still going to upgrade to a DV Sony Tv down the road despite what is goin on? There is too much upside to Sony TV performance despite DV. I?m hoping it does cause I?m not that impressed with the Sony DV Blu-ray player that they are coming out with, X700!
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Samsung HW-K950 Dolby Atmos sound bar
bobbino421 is offline
post #47 of 369 Old 01-22-2018, 10:59 AM
COACH2369's Avatar
Liked: 1006
Originally Posted by gadgtfreek View Post
Summer.
That works for me.... Gives me some time to see how the OPPO 203 plays out and since I am completely happy with my UB900, I am not in a hurry to change it out.
post #48 of 369 Old 01-22-2018, 12:16 PM
Quoted: 574 Post(s)
Liked: 246
you should post this in the TV thread, I doubt any UHD player is going to help much, especially without good cables (18gbps hdmi cables)
post #49 of 369 Old 01-31-2018, 09:05 AM
baseball0618's Avatar
Quoted: 436 Post(s)
Liked: 253
Update:
This is precisely why the Panny's PQ is better than the Oppo.
ReSultZ likes this.
JVC RS4500 projector/LG 65B7P/LG 55B7P/ Pannasonic UB820/Oppo 203/Oppo 103D/Apple tv 4K
St 130 138" scope screen
Marantz 7704 /Integra DTA 70.1
7.2.2 Atmos (3) B&W CWM 7.3 fronts (4) B&W CCM 7.4 surrounds
(2) B&W CCM 682 Atmos (2) JL Audio E112 subs
baseball0618 is offline
post #50 of 369 Old 02-07-2018, 06:40 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
It has the newer version of the HCX, which is created in conjunction with Panasonic Hollywood Labs, just like their older and highly accurate Uniphier SoC was. Panny has always done a great job with chroma in their in-house chips.
https://www.panasonic.com/uk/consume...p-ub820eb.html
Check out "4K High Precision Chroma Processing" at the bottom and "HCX".
Seems it might up for preorder in July now. I've got the UB200 with the current HCX, and it is a good little player that was cheap. Will hold me over till the 820 comes.
Blu-Boy in BKK likes this.
post #51 of 369 Old 02-13-2018, 07:41 AM
bobbino421's Avatar
Liked: 817
They just announced another one.
https://www.whathifi.com/news/panaso...-two-soundbars
aaronwt likes this.
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #52 of 369 Old 02-13-2018, 07:44 AM
bobbino421's Avatar
Liked: 817
The UB 9000 looks like it will have it all and will be the Flagship ship player over the 820 and this one also has THX certification according the picture.
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #53 of 369 Old 02-13-2018, 07:48 AM
bobbino421's Avatar
Liked: 817
A look inside
https://mobile.twitter.com/christhal...521665/photo/1
aaronwt likes this.
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #54 of 369 Old 02-13-2018, 08:31 AM
bobbino421's Avatar
Liked: 817
https://www.pocket-lint.com/tv/news/...y-vision-alexa
aaronwt likes this.
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #55 of 369 Old 02-13-2018, 08:46 AM
Quoted: 198 Post(s)
Liked: 85
Looks pretty great. Would the streaming quality on this be better than say an apple TV?
AVS Commenter is offline
post #56 of 369 Old 02-13-2018, 08:47 AM
Quoted: 574 Post(s)
Liked: 246
so the 9000 is the high-end market player; while the 820 will probably be sold in stores?
both with DV and HDR10+ playback
the 9000 & 820 appear to have 7.1 outs, with the 9000 having better internal components and high-end looks
doesnt the 820 come with the same HCX processor for 4k chroma processing?
so the 9000 will probably be $1000 and the 820 around $400-$500, I assume
post #57 of 369 Old 02-13-2018, 08:59 AM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
I’ll still get the 820
Lozin is offline
post #58 of 369 Old 02-14-2018, 03:52 AM
Spizz's Avatar
Quoted: 511 Post(s)
Liked: 356
Very nice. The 9000 deserves its own separate thread.
Spizz is offline
post #59 of 369 Old 02-14-2018, 06:26 AM
bobbino421's Avatar
Liked: 817
I just started one seeing that no one has yet.
I am pretty excited about this one! Looks like a power house. I own the 900 and love it!
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
post #60 of 369 Old 02-15-2018, 09:09 AM
Quoted: 574 Post(s)
Liked: 246
so by reviewing this link, is the only difference between the 420 & 820 that the 820 has 7.1 audio outs? if that's the case I might go for the 420
https://www.flatpanelshd.com/news.ph...&id=1518518354
nevermind, the 420 supports hdr10+ but not DV
so it looks like I'll be going with the 820 when it comes out this spring/summer
Reply Blu-ray Players
ces 2018 , Panasonic
