OFFICIAL Sony UBP-X700 Owners Thread (No Price Talk) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1941Likes
post #91 of 3391 Old 01-31-2018, 10:57 AM - Thread Starter
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6055
Do you cut the player on last, after everything else is up and running?
XBR65A9G / XBR65A8F / 55R615
DP-UB420 / ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is online now
post #92 of 3391 Old 01-31-2018, 11:07 AM
enricoclaudio's Avatar
Quoted: 3836 Post(s)
Liked: 4706
All the components turn ON basically at the same time. I have a Harmony Elite remote and have a scene for Watching Movies with the X700. This issue is present only when the player have been off for several hours. If I turn the system OFF then wait 10 mins or so, turn the system ON then the VUDU app just works properly without the HDCP 2.2 warning.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #93 of 3391 Old 01-31-2018, 11:14 AM - Thread Starter
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6055
Odd.
I got in a habit with HDMI 2.0 handshakes, I have my Harmony cut on my display and AVR, and then once they are up I cut the player on my self.
post #94 of 3391 Old 01-31-2018, 11:28 AM
jsmiddleton4's Avatar
Quoted: 1038 Post(s)
Liked: 373
X700 streams 4K....
Well that would be a reason to update from the X800 then.
jsmiddleton4 is offline
post #95 of 3391 Old 01-31-2018, 11:35 AM
neod192's Avatar
Quoted: 108 Post(s)
Originally Posted by jsmiddleton4 View Post
X700 streams 4K....
You're referring to VUDU, right ? Than yes Also, what TV do you have? I have a Sony Android TV and there's a VUDU 4k app that can be sideloaded and it works on mine. The only downside is that the audio track is stereo, no DD, DD+ or Atmos. If you have a Sony TV and you don't mind stereo audio, that might be a cheaper option than a $250 player.
neod192 is offline
post #96 of 3391 Old 01-31-2018, 11:37 AM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
X700 streams 4K....
https://www.avsforum.com/forum/149-bl...l#post55574766
Leon McKee
LR: XBR-65X930E | ATV4K-64GB 5th Gen | UBP-X700 | URC MX-890 | SoundTouch 300 | Luminoodle Bias Lighting
MBR: KDL-65W850A | ATV4K-64GB 5th Gen | URC MX-890 | Luminoodle Bias Lighting
4K HDR/DV Chains: ATV4K/UBP-X700>3ft Monoprice Certified Premium Cables>65X930E
Computing, Truck & Communication Devices: Proud Apple Customer Since 1979
leonmckee is online now
post #97 of 3391 Old 01-31-2018, 11:38 AM
Liked: 4706
Just checked on Amazon Prime app and it does stream in UHD 4K and HDR.
aaronwt likes this.
post #98 of 3391 Old 01-31-2018, 02:50 PM
Quoted: 14 Post(s)
Liked: 1
Just purchased this player at Best Buy this afternoon. I’m getting HDR with my 4k discs, but cannot get HDR when streaming YouTube, Netflix, or amazon. Any ideas or suggestions? I’m streaming over WiFi.
HMK71 is offline
post #99 of 3391 Old 01-31-2018, 03:55 PM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
Leon McKee
post #100 of 3391 Old 01-31-2018, 03:55 PM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
Did you update the firmware?
How's your wifi connection? Maybe check with YouTube "Stats for nerds".
Here's what you should see:
Try the video in the thumbnails below...
Leon McKee
ID:	2354530   Click image for larger version
post #101 of 3391 Old 01-31-2018, 03:58 PM
Liked: 373
If its streaming in 4K but only stereo than that would not be a reason to upgrade form an x800.
post #102 of 3391 Old 01-31-2018, 04:04 PM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
What app are you talking about? Stereo?
Leon McKee
post #103 of 3391 Old 01-31-2018, 04:27 PM
neod192's Avatar
Quoted: 108 Post(s)
Leon McKee
He was replying to my post here. The sideloaded VUDU 4k app on Android TVs.
neod192 is offline
post #104 of 3391 Old 01-31-2018, 04:46 PM
Quoted: 14 Post(s)
Liked: 1
Leon McKee
The firmware is updated, switched to a wired connection, tried the video you recommended, and HDR still didn’t trigger for that particular video. However, I tried a few other HDR videos, and those finally did work. Still no HDR Netflix or Amazon. My internet speed isn’t near as good as yours either, that may be why? I’m hovering in the 13,000 to 17,000 kbps range. Just doesn’t make sense to me why it would work with some HDR videos and not others.
HMK71 is offline
post #105 of 3391 Old 01-31-2018, 05:11 PM
Liked: 373
"The sideloaded VUDU 4k app on Android TVs."
No, I have asked about the x700 and if it streams 4K. I don't care about Android TV's.
The x800 does not.
I've not asked a single question about any TV Android or otherwise.
post #106 of 3391 Old 01-31-2018, 05:16 PM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
My guess would be the speed of your connection to be honest
Leon McKee
post #107 of 3391 Old 01-31-2018, 05:20 PM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
The x800 does not.
The OP can answer most, if not all, of your questions about audio. However, I'm not aware of any of the apps being limited to stereo. The X700 is actually robust with features and when it's updated with Dolby Vision I suspect we'll get even better app features.
Leon McKee
post #108 of 3391 Old 01-31-2018, 05:39 PM
Quoted: 14 Post(s)
Liked: 1
Leon McKee
Kind of what I was thinking, but I can stream both Amazon and Netflix in HDR and DV on the built in apps. I have the Sony 940E. Just trying to figure out if I need to exchange this player. I’ll keep playing around with it. Thanks for the help!
HMK71 is offline
post #109 of 3391 Old 01-31-2018, 06:15 PM
Quoted: 14 Post(s)
Liked: 1
So I’m noticing that many videos that claim to be an hdr video on you tube, don’t all play in hdr (through this player). Matter of fact, it seems only videos on The HDR Channel, are the only ones that work for me. Can anyone else check this and let me know if they are experiencing the same?
HMK71 is offline
post #110 of 3391 Old 01-31-2018, 06:20 PM
Liked: 4706
Youtube is not a trusted source for HDR, UHD or Atmos videos. Some videos claim been HDR and they are not. Trusted sources are Amazon Prime Video, Netflix and VUDU.
post #111 of 3391 Old 02-01-2018, 07:39 AM
leonmckee's Avatar
Quoted: 505 Post(s)
Liked: 582
Please reference the post I made here:
Only profile version two of the YouTube codec will play HDR.
Leon McKee
post #112 of 3391 Old 02-01-2018, 09:24 AM
toonontherun's Avatar
Quoted: 92 Post(s)
Liked: 41
3motion_tv
The HDR Channel
FUTURE etc
have hdr on youtube
leonmckee likes this.
toonontherun is offline
post #113 of 3391 Old 02-01-2018, 10:44 AM
Quoted: 83 Post(s)
Liked: 7
I have the European version and it doesn't have the Amazon video app (which is advertised on the box), I don't see any way to download it either. The player is up to date so I have no idea what to do.
Markitron is offline
post #114 of 3391 Old 02-01-2018, 12:37 PM
Quoted: 24 Post(s)
I bought the sony x700 yesterday, watched some of the blue planet 2 just fine, but had some problems with dunkirk ultrahd 4k blu-ray some freezeups and slowdowns, watched then the whole disc on my xbox one x and it worked just fine, then I tried it again on the x700 and it played the problemscenes without any problems. I expect this to improve with fw updates...
Anfinn Berland is offline
post #115 of 3391 Old 02-02-2018, 08:05 AM
d10brp's Avatar
Quoted: 17 Post(s)
Mine is a UK version and Amazon works fine, installed out of the box
Sent from my Pixel XL using Tapatalk
d10brp is offline
post #116 of 3391 Old 02-02-2018, 10:00 AM
wowzors's Avatar
Quoted: 93 Post(s)
Liked: 29
A little disappointed that HDR isnt in for VUDU (yet?). I hope they can find a way to implement it and DV for VUDU, most of my collection is on VUDU.
wowzors is offline
post #117 of 3391 Old 02-02-2018, 10:58 AM
Quoted: 24 Post(s)
Mine is the version sold in Norway, it's missing the app for norwegian national tv, but I have the nrk app on my zd9
post #118 of 3391 Old 02-02-2018, 12:15 PM
Quoted: 14 Post(s)
Liked: 1
I now seem to be able to stream everything on Netflix in hdr that is tagged as such, except for Stranger Things. Can’t figure out why yet.
HMK71 is offline
post #119 of 3391 Old 02-03-2018, 08:46 AM - Thread Starter
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6055
Season One is NOT HDR.
unretarded likes this.
post #120 of 3391 Old 02-04-2018, 04:59 AM
rene2kx's Avatar
Quoted: 956 Post(s)
Liked: 374
why is this player still saying not yet released on amazon? when does amazon have it?
rene2kx is offline
Reply Blu-ray Players
bluray , hdmi , soundbar
