OFFICIAL LG UBK90/80 4K UHD Blu-Ray Player Owners Thread (No Price Talk) - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 129Likes
post #241 of 755 Old 09-08-2018, 11:36 AM
Cal1981's Avatar
Quoted: 679 Post(s)
Liked: 1076
As you can tell from my above post, I did jump off on a UBK90 yesterday. My early testing has confirmed what I saw at my friend's place the other day. This is a very good disc player with, at least, a usable YouTube app. The Netflix app does suck due to the forced DV output but then again, my Oppo has no apps, not exactly a hardship. The clincher was the UBK90's ability to play MKVs with various video/audio encodings. If anything goes sideways with the Oppo and it needs to sent out for repair, the UBK90, with its excellent 4K and up-scaled image quality and its MKV abilities, is a very good, modestly priced back-up unit.
Cal1981 is offline
post #242 of 755 Old 09-08-2018, 07:43 PM
RoadLizard's Avatar
Quoted: 1441 Post(s)
Liked: 1430
Originally Posted by Cal1981 View Post
To add to this, I have a Sony X800 (bought last year before DV became more prevalent), an Oppo-203 and as of yesterday an LG UBK90. I've done numerous A-B comparisons between the up-scaling ability of the Sony and the Oppo, each with my LG C7 OLED. Truthfully, I couldn't really tell the difference from my couch 8-9 feet away so I let both players do the job. A quick Blu-ray A-B check between the UBK90 set at 1080P and the C7, again showed little if any difference so I'll just leave it on Auto. The results might be different with an LG 2018 "8" OLED series with the new A9 processor or a Sony OLED with its Extreme X1 processor but with the C7 all of my UHD players were good enough.
Yeah - I dont think the upscaling capabilities of the various players out there is that different. I too didnt see much difference with a few different players. Thats a good thing - it means they are getting better at this even with middle tier players. Used to be you had to spring for the high end stuff to get decent scaling. Not anymore!
LG OLED65E6P, Samsung PN64H5000
LG UBK-90, Samsung UBD-8500K
Polk RTi Towers, STi surrounds
Polk Subwoofer
Sony DH550 AVR
RoadLizard is offline
post #243 of 755 Old 09-10-2018, 04:34 PM
waltinaz's Avatar
Quoted: 158 Post(s)
Liked: 137
Hi all...I just ordered one of these today to go with my new 77C8 OLED. Just want a good player that does Dolby Vision, and don’t care about streaming because I use the C8’s onboard apps.
Looking forward to learning more about the UBK90, and anyone’s experience that also has a C8...
Thanks in advance!
________
LG OLED 77C8PUA...stunning!
LG UBK90 Ultra Player
Denon AVR-X2300W
waltinaz is offline
post #244 of 755 Old 09-11-2018, 05:22 AM
RoadLizard's Avatar
Liked: 1430
Thanks in advance!
Great choice. Its a solid player and handles DV well. Works great with my E6 so I expect it will be a good match for your C8.
Cal1981 and waltinaz like this.
Polk Subwoofer
Sony DH550 AVR
post #245 of 755 Old 09-11-2018, 12:58 PM
waltinaz's Avatar
Quoted: 158 Post(s)
Liked: 137
Thanks, man!
RoadLizard likes this.
________
Denon AVR-X2300W
waltinaz is offline
post #246 of 755 Old 09-12-2018, 10:56 PM
dasanii19's Avatar
Quoted: 144 Post(s)
Liked: 31
My new ubk90 player is freezing and flickering. Is this a common issue?
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
post #247 of 755 Old 09-13-2018, 09:06 AM
Cal1981's Avatar
Quoted: 679 Post(s)
Liked: 1076
One not so good issue that I've discovered on my UBK90:
When playing an MKV with embedded sub-titles, the '90 appears to turn them on by default. You have to turn them off manually. I recall that some Samsung disc players did this as well.
Cal1981 is offline
post #248 of 755 Old 09-13-2018, 09:15 AM
pmeintel's Avatar
Quoted: 149 Post(s)
Liked: 83
Is the disc freezing or the image? Lots of times the "flickering" had been caused by inadequate HDMI cables but hopefully someone more knowledgeable then I can answer.
"These go to eleven." - Great words from Nigel Tufnel.
pmeintel is offline
post #249 of 755 Old 09-13-2018, 10:26 AM
PlasmaHiDef's Avatar
Quoted: 341 Post(s)
Liked: 121
I was thinking the same thing. Usually, the flicker is caused from using HDMI cables that are not certified. That is what I have gathered from seeing people post about this issue. It should have the orange certified premium sticker on the package.
LG OLED55B8PUA
LG OLED65C7P
LG UBK90
ATV 4K
Samsung HW-N950
PlasmaHiDef is offline
post #250 of 755 Old 09-13-2018, 10:47 AM
Cal1981's Avatar
Quoted: 679 Post(s)
Liked: 1076
I just e-mailed LG Support about the Netflix app being locked in to displaying everything as Dolby Vision and how bad that makes anything in SDR or below look. I asked about a possible fix for this via firmware update but I'm not holding my breath.
Cal1981 is offline
post #251 of 755 Old 09-14-2018, 09:20 AM
Cal1981's Avatar
Quoted: 679 Post(s)
Liked: 1076
I got a reply from LG support with a bunch of reset steps which, of course, completely missed the point. At the very end of the message there was an indication that the Netflix/DV issue was being referred to the software engineers. For laughs and giggles, I got on LG's live chat this morning and explained that this problem was baked into the UBK90's firmware and that only a firmware update could, if it's even possible, fix it. The rep said that the engineers are aware of the issue and are investigating the possibility of a future firmware fix. Again, I'm not holding my breath.
Cal1981 is offline
post #252 of 755 Old 09-15-2018, 10:21 AM
Otto Pylot's Avatar
Quoted: 3462 Post(s)
Liked: 2510
I'm thinking on purchasing the UBK90 because I think it would be a nice complement to the 65C8, which has been purchased but not yet delivered. My concern is ARC/CEC. I do not use ARC/CEC but prefer to use a Harmony to control my HTS and an optical cable for the SmartApps (if and when I use them). I know you can disable ARC/CEC on the C8 but I understand that you can not disable it on the UBK90. With ARC/CEC disabled on the 65C8, will there or would there be any issues using the Harmony to control the UBK90, 65C8, and of course the receiver, which will be the hub of my HTS?
Otto Pylot is offline
post #253 of 755 Old 09-15-2018, 03:15 PM
pwishart's Avatar
Quoted: 475 Post(s)
Liked: 468
If CEC is a problem just get a Lindy HDMI CEC Less Adapter, Female to Male (41232) from Amazon to put inline with the Player to disable CEC.
pwishart is offline
post #254 of 755 Old 09-15-2018, 03:45 PM
Otto Pylot's Avatar
Liked: 2510
Thanks. I'll have to look into that.
post #255 of 755 Old 09-15-2018, 03:48 PM
Quoted: 2453 Post(s)
Liked: 1174
Any pro reviews of this...?
Shopping List:
TV: LG C9/C10, or Samsung Q90R, or Sony ...
Blu-ray: Panasonic UB820, or Pioneer Elite LX500, or Sony X800M
AVR/Pre-pro: Marantz 8805/7705 or 8012, or Yamaha 5200 or 3080
Speakers: GE Triton One.R, or ML ElectroMotion ESL X
New24K is offline
post #256 of 755 Old 09-16-2018, 05:18 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
There shouldn't be any issue if you disabled CEC on the TV. It takes both sides of a HDMI link to make CEC work.
Sent from my ZTE A2017U using Tapatalk
Foxbat121 is offline
post #257 of 755 Old 09-16-2018, 09:19 AM
Otto Pylot's Avatar
Liked: 2510
"Shouldn't be" are the operative words because I keep hearing conflicting reports. Thanks. Why LG didn't program the option to disable/enable ARC/CEC is beyond me.
post #258 of 755 Old 09-16-2018, 11:41 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
There are times that one need to enable CEC for ARC but not for switching inputs and power on/off. CEC contains three functional groups:
1. HDMI input switch and auto power on/off.
2. Remote command relay from TV to connected devices
3. ARC for audio
If you want ARC, you have to enable CEC. But based on my experience with my LG OLED, there is no way to disable HDMI input switch once you enabled CEC (SimpleLink).
I found that Harmony works fine with CEC turned on if you know what you are doing when configuring the remote most of the time.
With SimpleLink turned off, none of the above will work regardless the other end device settings.
Spock1234 likes this.
post #259 of 755 Old 09-16-2018, 12:11 PM
Otto Pylot's Avatar
Liked: 2510
3. ARC for audio
Yeah, I'm fully aware of how ARC/CEC works. Fortunately, some of the newer devices have actually separated the two so one has individual control instead of all or none. That's not what I'm concerned about. I have contacted LG support so we'll see what they have to say. It makes sense to me if ARC/CEC is disabled on all of your sink devices (receiver and tv) then there shouldn't be any issue controlling the UBK90 with another remote even if it attempts to send an "On" command to a connected device. I have my other system setup so that the receiver is the first device that is turned on, and then either the tv, blu-ray player, or ATV4 depending on what I want to do (Watch TV, Watch a Movie, Watch ATV4). I don't want to have a device turn off just because I've decided to switch from tv to the blu-ray player and it sends an "On" command which turns the tv or receiver off.
post #260 of 755 Old 09-16-2018, 01:27 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
I have yet to see any device take or receive on/off CEC commands when CEC is off. So, I suspect your worry is unfounded. The fact that you keep saying ARC/CEC together leads me to above post. ARC is just small part of CEC protocol and devices like player doesn't support it at all.
post #261 of 755 Old 09-16-2018, 01:35 PM
Otto Pylot's Avatar
Liked: 2510
I mention ARC/CEC out of habit because both are usually on the same chipset and problems with CEC (of which there are many) sometimes affect ARC, which we are not talking about. I think you are correct that if CEC is disabled on the sink devices, the CEC commands sent by the UBK90 are ignored. The concern arises from what LG may or may not have done in how the On/Off commands are related to the CEC commands, and if the UBK90 needs to receive an ACK for the On/Off and other functions.
post #262 of 755 Old 09-16-2018, 02:52 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
There is zero evidence that it will do that. In fact, in my own test, the CEC link when enabled does not work very well across different brands. The player only works correctly with LG OLED. Doesn't work at all with my Sharp TVs and two of my different Samsung TVs. Only partially work with a 3rd different model of Samsung TV.
post #263 of 755 Old 09-16-2018, 04:52 PM
Otto Pylot's Avatar
Liked: 2510
Yep. And you just identified the main issue with CEC, which is its lack of standardization so that it rarely works across various mfrs. CEC can even have issues within the same mfr which is very frustrating. That's why I gave up on ARC/CEC years ago and went with an optical cable instead of ARC for the SmartApps/OTA television and a Harmony remote in lieu of CEC. Thanks.
post #264 of 755 Old 09-16-2018, 05:00 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
Have to say my Sharp TV does work flawlessly with my Yamaha soundbar via ARC. That's the only time I really need the ARC/CEC.
post #265 of 755 Old 09-16-2018, 05:11 PM
Liked: 1174
So can the UBK90 be used with an older flagship AVR that doesn't have HDMI inputs?
Use the UBK90's HDMI output to the new TV's input for picture...
And use the UBK90's optical out to the AVR for the sound...
Shopping List:
New24K is offline
post #266 of 755 Old 09-16-2018, 05:51 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
It should work just fine but you will be limuted to old lossy Dobly Digital or DTS 5.1 audio. The player even has DTS re-encode mode for optical out.
post #267 of 755 Old 09-17-2018, 10:51 AM
Cal1981's Avatar
Quoted: 679 Post(s)
Liked: 1076
That will work well. Of course older AVRs don't have Dolby Surround Upmix or DTS Neural X capabilities to expand 5.1 audio to 5.1.2, 7.1 etc but may have Dolby Prologic II or IIX which will expand 5.1 to 7.1. With a baseline 5.1 or a 7.1 speaker setup you still get very good surround sound.
Cal1981 is offline
post #268 of 755 Old 09-18-2018, 07:13 PM
DistractedforLife's Avatar
Quoted: 35 Post(s)
Are Technicolor Hdr discs playable on this player? I know my tv can. I just bought Oblivion which uses Technicolor and was wondering if i will actually get Technicolor...
DistractedforLife is offline
post #269 of 755 Old 09-25-2018, 03:28 PM
mooch49's Avatar
Quoted: 58 Post(s)
Liked: 25
Does anyone know if this player plays DV on a Sony x900f?
Sent from my Pixel 2 using Tapatalk
mooch49 is offline
post #270 of 755 Old 09-27-2018, 08:51 AM
mbernstein's Avatar
Quoted: 94 Post(s)
Liked: 27
I'm about to pull the plug on the UBK90 and from what I've read here, there seems to be no advantage in a more expensive player such as the Oppo-like Cambridge Audio CXUHD (to my understanding other mainstream players have no clear advantage over the UBK): PQ in both Blu-rays and UHD are pretty much the same, right?
In terms of Multi-Region for Blu-rays is there any hope on the UBK90 (or the Cambridge)? I don't care about DVDs nor about streaming apps.
Appreciate any input. Thanks.
Samsung UN78HU9000GXZD / Marantz SR8012 / B&W 705 S2 + HTM71 S2 Front + B&W DB4S sub + Polk Audio Monitor 30 Back
LG OLED 65C8PSA / Marantz SR6013 / B&W CM1 S2 + CM Center S2 Front + Jamo J10 sub + NHT SuperZeros 2.1 Back
LG OLED 55EA9850 / Yamaha Soundbar YSP 2700
mbernstein is offline
Reply Blu-ray Players
disable on screen display , lg ubk 90 , on screen pop ups
