Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 107 - AVS Forum | Home Theater Discussions And Reviews
 5026Likes
post #3181 of 5938 Old 02-12-2019, 04:00 AM
Liked: 0
Hi, Maybe someone can help or explain .. I have the DP-UB824 and the Samsung UE48HU7500 tv.
When i play 4k Mks video files te tv switch to 3840x2160 / 24p
When i play 4k blu-ray the Panasonic MENU is in 3840x2160 on the TV but when i start
the Blu-ray the TV switch to 1920x1080 / 24p ??
AHv _Ts is offline
post #3182 of 5938 Old 02-12-2019, 05:26 AM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 688
Originally Posted by Shaneyb2 View Post
It’s black panther Ultra HD Blu- Ray. From what I’ve read it should be good as it’s shot at 3.4k resolution for the most part anyway. I don’t have overs to compare at the moment but I am looking at getting other ones that are recommended for best picture.
It sounds like you need to adjust your HDR settings and try again. Below is a link to settings for your particular set, with HDR settings near the bottom. Make sure you follow their directions to enable “enhanced” for your HDMI input.
If you already have done all these things, then I’m at a loss. While I haven’t watched Black Panther yet, every review I’ve read states it is an improvement over thr blu-Ray.
https://www.rtings.com/tv/reviews/sony/x900f/settings
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is online now
post #3183 of 5938 Old 02-12-2019, 06:27 AM
teiresias's Avatar
Quoted: 52 Post(s)
Liked: 24
Originally Posted by trptguy View Post
I had a Sony x700 hooked up to my LG E7, took the plunge and bought the Panny 820.
After getting the Panny hooked up and the display output setting set to OLED and optimizer on, I watched Batman vs Superman which I was very familiar with on my Sony player.
The Panasonic is better, it's just a better picture overall. Buy once, cry once.
Do you leave the E7 tone mapping on? I'm a bit confused about whether the LG's tone mapping should be enabled with this player or not, and on an C8/E8 whether Dynamic Tone Mapping should be on or not.
teiresias is offline
post #3184 of 5938 Old 02-12-2019, 08:09 AM
Liked: 0
Nevermind, wrong HDMI port
AHv _Ts is offline
post #3185 of 5938 Old 02-12-2019, 10:12 AM
trptguy's Avatar
Quoted: 39 Post(s)
Liked: 24
I did, but my understanding from a post I read by Bob P is that the way LG implemented tone mapping on the "7" and "8" is not exactly the same. On the 7, the Panny tone mapping was considered complementary, on the 8 panels someone here had mentioned that LG mimicked what Panny had done with tone mapping and so it was kinda more of the same, so not as beneficial.
In that instance, I'd definitely use the eyeball test. Turn tone mapping on and off on both devices using the same scene from a movie mastered at 4000 to 10,000 and see what your eyes tell you.
trptguy is offline
post #3186 of 5938 Old 02-12-2019, 12:55 PM
Liked: 0
I have adjusted the settings on the set as per there recommendations and have cheeked that I have the enhanced HDMI on and connected via HDMI 3.
Unfortunately it hasn't really made any difference. What are the recommended settings fo the ub820? the dolby vision logo appears in the corner of the screen when you start watching the 4k film. would then dv logo appear if the short HDMI cable that connects the player to the receiver was unsuitable. what i have noticed is when 24p out put is set to automatic it plays black panther at 4k 24hz but when its set to off it will play at 4k 60hz is this normal and should I keep it off.
Shaneyb2 is offline
post #3187 of 5938 Old 02-12-2019, 03:08 PM
bobknavs's Avatar
Quoted: 2331 Post(s)
Liked: 1662
(snip)
Depends. The disk produces 24 Hz video. You want to avoid the famous 3:2 pulldown needed to convert 24Hz to 60. If your display device has a native 120 Hz refresh rate (NOT a "motion rate"), feed it 24 Hz, and there will be no pulldown.
If it's a native 60Hz device, I don't know whether the 820 or the display would do a better job of the 60 Hz conversion.
I wouldn't bet my life on these recommendations, but I think that they are correct.
bobknavs is online now
post #3188 of 5938 Old 02-12-2019, 07:37 PM
ttn333's Avatar
Quoted: 190 Post(s)
Liked: 119
Originally Posted by rrebello View Post
Does anyone else have this problem with the Amazon App? I get a great UHD picture (SDR/BT2020 conversion) but the picture will stutter after about 5 - 10 minutes. It clear sometimes. Mostly, I stop and restart the show. The picture is great again for 5 - 10 minutes. I do not have the problem on Netflix. I uploaded the firmware and it is the same issue. Tonight, I am going to remove the app and re-install to see if it fixes. If not, I am going to re-set the machine to factory settings, do the update, and then load the apps. Any other suggestions?
I love the UHD picture (SDR/BT2020 conversion) on my JVC projector. It is awesome! Just want a good streaming now. Thanks
Did you find a fix for this. I'm having the similar issues. Sometimes it'll even say something about limited bandwidth, which is ridiculous because I have 100mbps down and wired. Also, no issues playing Prime app on my xbox x.
NAD T758v3, Emotiva XPA-3, XPA-5, UPA-5, JTR Triple 12 LP L/C/R, Htm-6 surrounds, Volt 6 atmos, SVS PC13 Ultra and JTR Cap 2400 ULF - Denon x2400h, Elac Debut F5, Elac Debut C5, Elac Debut A4, Klipsch r-12swi - Stereo Totem Mite
ttn333 is offline
post #3189 of 5938 Old 02-12-2019, 11:46 PM
trptguy's Avatar
Quoted: 39 Post(s)
Liked: 24
Dolby Vision is its own animal. The HDR Optimizer is not used during dolby vision playback. And yes, Black Panther is a very dark movie.
trptguy is offline
post #3190 of 5938 Old 02-13-2019, 05:37 AM
ScottieBoysName's Avatar
Quoted: 1255 Post(s)
Liked: 429
I have an 820 paired up with a new JVC RS2000.
What are some initial steps to take on the 820 when setting up this combo?
I've also noticed on movies that (and this is just a guess) have new 4k scans (The Matrix, Transformers) - there is a lot of noise in the picture, especially in the sky. When I watch Infinity War though - looks amazing. Anything I can check on that?
ScottieBoysName is online now
post #3191 of 5938 Old 02-13-2019, 06:14 AM
claw's Avatar
Quoted: 2315 Post(s)
Liked: 2170
...And yes, Black Panther is a very dark movie.
I watched it again last night. I use SDR/BT2020 mode to my JVC projector. All I needed to do to get a more pleasing picture for this title was to adjust the Dynamic Range Conversion Adj. slider one click to the right. Then reverted the setting back to where it looks best for most other titles. The Conversion Adj. slider does not need to be a set-and-forget setting.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #3192 of 5938 Old 02-13-2019, 07:28 AM
rrebello's Avatar
Quoted: 43 Post(s)
Liked: 48
The only improvement i could get was to turn off the 4k/60Hz requirement on the settings for the player. This had the app send 1080p with HDR - Bt2020. The streaming was much better but not perfect (less buffering). Overall, it was about an 80% improvement. I did not see any difference in picture quality -- both were HDR and very nice.
rrebello is offline
post #3193 of 5938 Old 02-13-2019, 10:19 AM
ttn333's Avatar
Quoted: 190 Post(s)
Liked: 119
I usually can watch something for about an hour before it starts to stutter and become unwatchable. Did a reset last night and new update. Will see today if it makes any difference. My ub900 was glitchy too. This might be my last panasonic.
ttn333 is offline
post #3194 of 5938 Old 02-13-2019, 10:47 AM
cdnscg's Avatar
Quoted: 602 Post(s)
Liked: 123
I think the UB820 has an issue with apps. Using an Ignite tv system now to watch Netflix, and no issues with receiving HDR which was a problem through my UB820.
cdnscg is offline
post #3195 of 5938 Old 02-13-2019, 11:42 AM
ttn333's Avatar
Quoted: 190 Post(s)
Liked: 119
Sadly you may be right. I really like the ability to optmize hdr for streaming. I thought that was a really cool feature and did work well for me especially with Netflix shows like The Ozark. Interestingly enough, Netflix seems to be running well. I guess I'll be using my xbox x for Prime vids and ub820 for Netflix.
ttn333 is offline
post #3196 of 5938 Old 02-14-2019, 08:38 AM
steviedr's Avatar
Originally Posted by yld2rob View Post
I am having several issues ith this player I am hoping for some help with. I don’t think I am getting HDR (see first pic). All devices are going into the reciever and output to the tv. All ultra high speed cables are being used. I do get 4k 60 hz 3840x2160 60p HDR UHD using my Apple TV (second pic) waching Jack Ryan.
Here is my setup:
All new components. Denon X6500. Samsung Q7 and this panasonic player. All have HDR10 and are enabled where they can be.
Panny settings:
Resolution Auto
4k/60p 4:4:4
24p auto
Hdmi output mode video plus audio
Dolby vision off
Hdr 10 on
Deep color auto 12bit
Hdr/bt 20:20
Hdcp auto
On the tv:
Hdr plus enabled
Any net cec
Reciever
4k signal format enabled
All firmware has been updated on all devices and I have hard reset the Panny twice.
I have the same issue in the UK after updating firmware (unit is only 3 weeks old), I have contacted Panasonic.
Its a handshake issue, some UHD discs are fine, but most are not, eg, loaded A Star is Born, HDR banner pops up (LG E7), at the disc menu I choose play movie, then the HDR drops and its a washed out SDR image. I need to powercycle the Av Receiver or tv to sort it out. Power cycling player will just repeat the process.
Arrival was an odd one, choose play movie and the first production company remains in HDR, then the Paramount stars start to fly in and it drops HDR (LG only allow choice of SDR modes), again, quick AV receiver power cycle and the HDR flag comes back on.
It wasn't doing this before the 820 player firmware update, I have also tried the player reset options provided by Panasonic support and no joy, unfortunately can't roll the firmware back...
Both TV/receiver last had their firmware updated months ago.
Will chase Panny again tomorrow...
A few on UK AVForums have experienced similar issues with some having 3D issues...
steviedr is offline
post #3197 of 5938 Old 02-15-2019, 05:45 AM
Tweakophyte's Avatar
Quoted: 94 Post(s)
Liked: 49
I have an issue potentially associated with the 820, connected through a Denon 6300H to an epson 5040.
When I am playing around with settings I swap between the Disc or NetFlix playing, to the home screen to go to settings. This causes a handshake with the projector, which is normal.
Sometimes when I hit the button to go to the home screen on the player (so I can change settings), it looses the signal and my PJ shows "no signal". Hitting the play or Netflix button gets me back to my movie with no issues. I've tried changing inputs on the projector, which should grab another handshake and that does not cure it. I have a Ruprio HDMI cable and when playing content the full bandwidth I am sending makes it to the projector with no issues (so I am ruling out the cable).
Anyone have a similar issue?
Panny UB820, Denon X6300H in 6.1.4 mode, Epson 5040UB, SVS PCUltra paired with a MiniDSP HD and BEQ (of course!)
Working on making things blacker...
Tweakophyte is offline
post #3198 of 5938 Old 02-15-2019, 05:49 AM
jmeitz's Avatar
Quoted: 66 Post(s)
Liked: 34
Same with my Yamaha 3070
Yamaha Aventage 3070 * Emotiva xpa5
Polk LSIM 707, 706, 703, 702, Rci85 and 65
Stereo Integrity HT18 (2) * Inuke 6000dsp
Panasonic UB820 * JVC NX5 * Silver Ticket 120” thin bezel
jmeitz is offline
post #3199 of 5938 Old 02-15-2019, 05:51 AM
Quoted: 309 Post(s)
Liked: 92
I’m looking for opinions regarding leaving discs in the player. I generally tend to leave them in over night and then swap out another one to play the next evening. I of course know not to move the player with discs in it but otherwise looking for what others do. I recall reading awhile back for CD players it helps keep the dust out if you keep a disc in so wanted to know if others applied this as the best way to go for Blu Ray players as well. Also, looking to see if cinema or standard is used more by owners of this player with SDR blu rays? Thanks so much in advance to anyone who responds!
MeganElisabeth is offline
post #3200 of 5938 Old 02-15-2019, 06:37 AM
healthnut's Avatar
Quoted: 964 Post(s)
Liked: 957
I routinely leave discs in (and always have) with no issues.
healthnut is offline
post #3201 of 5938 Old 02-15-2019, 07:30 AM
Quoted: 309 Post(s)
Liked: 92
Thank you very much! I’ve been doing this as well and feel better knowing someone else has too.
post #3202 of 5938 Old 02-15-2019, 03:42 PM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 688
I do the same - leave the disc in until I change for another one. It’s rarely empty.
post #3203 of 5938 Old 02-16-2019, 03:02 PM
Liked: 1
Question No sound out (ONLY when using Netflix app)
Originally Posted by csilverstein View Post
I’ve been having trouble getting Netflix to work on my 820.
When I start Netflix, I’ll see my lg OLED switch to Dolby Vision, but the screen goes blank. The app still responds, but I don’t get any picture from the player, only sound.
If I turn off Dolby Vision on the player, then I can access Netflix, and a picture is shown.
There shouldn’t be a problem with Dolby Vision, though, because Dolby Vision discs play fine. Only Netflix on the player has a problem.
Anyone else experiencing something like this, and any ideas what other troubleshooting to try?
Funnily enough, given the reply to your question suggesting lack of picture may be due to possibly having a 2016 LG OLED E6 - I have the opposite problem with a 2016 LG OLED but I think the TV immaterial.
Using the UB820 I no longer have sound when using Netflix app (connected to a NAD 758 and thence to the LG).
Playing a Bluray works faultlessly as indeed does the Youtube app.
Set up only a couple of days old and initially had erratic ARC/CEC issues between the NAD and the LG but found a workaround by disabling the standby mode on the NAD. HDMI ARC sound now stable and UB820 Netflix continued to work until this morning before strangely producing, now, picture only.
Interestingly this problem briefly reared up during the set up to the puzzlement of SSAV (store which sold and installed all gear) but disappeared on switching to a different source (live TV I believe) and then back to the Panasonic and Netflix.
As for the HDMI cables, entire system installed by Sevenoaks and worked to begin with (and the price of the cable suggests it certainly up to the task).
Speakers Radius 270 fron and 90 rear with a REL T70 sub but I do not believe the issue there.
The NAD now shows "PCM Stereo" on the display panel when Netflix app used on the Panasonic but of course no sound going through.
Any suggestions gratefully received...
redtommy76 likes this.
radiata is offline
post #3204 of 5938 Old 02-16-2019, 03:30 PM
Quoted: 94 Post(s)
Liked: 49
I was playing around with the Denon Remote App and saw that "Auto Lip Sync" was turned on. I definitely don't remember turning that on and I don't think that is the default. Do these players (or the PJ) signal the receiver to turn that feature on?
Thx
post #3205 of 5938 Old 02-16-2019, 04:27 PM
Liked: 429
I have a JVC RS2000 projector. I’m having a bit of trouble seemingly seeing a “noisy” picture.
It’s strange, I only really notice on faces and in the background/sky. Darker areas it doesn’t show up.
It also doesn’t show up in animation. It’s odd.
Take Ready Player One for instance. The race scene near the beginning, anything in the “Oasis” world looks great. When the IOI guys are getting into their “cars”’in the real world, it’s static or something. Really grainy.
I’m using the HDR/2020 setting on my 820 and the HDR10 setting on my JVC.
What could be causing this noise? Why do you use SDR/2020 for HDR content?
post #3206 of 5938 Old 02-16-2019, 06:06 PM
Liked: 429
Your use of the term auto tone mapping is confusing me. The term means different things to different people. Panasonic does not use that term. The UB820 has the HDR Optimizer. Better to just call it the Optimizer.
In SDR/BT2020 mode you set your display to a 2.4 gamma whether you have the Optimizer turned ON or OFF. In HDR mode you set your display to an HDR gamma whether you have the Optimizer turned ON or OFF since it sends HDR signal in both cases.
I have mentioned this before but here goes again.
In HDR output mode, the HDR Optimizer uses the HDR Display Type setting nit value as a tone mapping target. If you choose 500 nit Projector as Display Type, the Optimizer will tone map all bright content above 500 nits so that it falls under 500 nits. It will modify the HDR metadata that the display sees. If the original metadata was MaxDML=4000 and MaxCLL=800, it will modify them to MaxDML=500 and MaxCLL=500. If the metadata was 1000/300, it would modify the metadata to 500/300. The Optimizer is making it easier for your projector to complete the tone mapping of the HDR content. It doesn't have to be concerned with anything above 500 nit because there no longer is any.
In SDR/BT2020 output mode, the HDR Optimizer does not use the HDR Display Type setting. It uses the HDR metadata values to assist in performing a complete tone mapping of the HDR content to a 2.4 Gamma but preserving the BT2020 wide color gamut. The projector in this case does not do any HDR tone mapping since it has already been completed by the UB820.
I can't help you with the settings to use in your brand of projector as I have a JVC. The setting procedures for HDR/BT2020 vs SDR/BT2020 differ just like they do in different brands of HDR TVs.
This is all great information. Can you help with my post above at all? I’m using HDR2020 right now. You’re saying I should be using SDR2020?
What JVC projector do you have?
post #3207 of 5938 Old 02-16-2019, 06:41 PM
BigCoolJesus's Avatar
Quoted: 2180 Post(s)
Liked: 1727
Hey all,
Thinking of getting the Panny 820 to replace my Sony x800 so I can have DV capability. However, I have a Sony x940e TV, which requires DV to be handled by the player. Does the Panny 820 work with the Sony x940e for Dolby Vision?
General question:
How is the DV quality? Is there still elevated black levels that plagued movies back when DV capability first rolled out in 2017?
BigCoolJesus is online now
post #3208 of 5938 Old 02-16-2019, 07:49 PM
claw's Avatar
Liked: 2170
I use SDR/BT2020 because I have a JVC RS500 and the result is better than any custom curve I have built so far. Kris Deering also recommended SDR/BT2020 for projectors. That recommendation may or may not change when he tests the new JVC lineup and auto tone mapping.
I have no idea what might be the cause of the noise you are experiencing.
CJ
claw is offline
post #3209 of 5938 Old 02-16-2019, 08:04 PM
Liked: 429
Gotcha. With SDR/2020, what do you setup for gamma in the projector?
Wish I could pinpoint the source of the noise.
post #3210 of 5938 Old 02-16-2019, 09:34 PM
claw's Avatar
Liked: 2170
2.4
CJ
claw is offline
Reply Blu-ray Players
