Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 5026Likes
post #3481 of 5940 Old 03-17-2019, 03:30 AM
Liked: 1
Originally Posted by SLYDoggie View Post
I tried the procedure you outlined in your earlier post but it had no impact on my Netflix... It still only plays in 1080P. I also tried the "Restart Netflix" under "Help" in the Netflix app and that also had no impact. I get Netflix UHD in all of my other 4K devices but not on the 820 for some reason.
I wondered whether you found a fix for this?..
Would be grateful if you or any who have cracked the problem might share.
I have an 820 connected to a NAD 758v3 and thence to an LG 55E6 OLED.
I too have only 1080p output oddly from Netflix app on the Panasonic 820 even though my LG 55E6 strangely shows both 1080p and "Dolby Vision" when pressing info to check the resolution. The NAD AVR clearly shows the input to be 1080p. Resorting to the Netflix app on PS4 Pro although that results in the loss of DV as only HDR supported. The Netflix app on the LG not a sensible option as although DV preserved it does not output 5.1 via ARC but only stereo. This apparently a known LG 2016 issue.
First world problems certainly but the lack of DV from the 820 Netflix a pity.
radiata is offline
post #3482 of 5940 Old 03-17-2019, 06:42 AM
ddigler's Avatar
Quoted: 1095 Post(s)
Liked: 484
Does anybody else’s player generate significant heat even in a standby state?
I had to remove my player to do some work on the rack. The player was inactive for hours. The metal bottom of the player was much warmer than I would anticipate from an inactive Blu-ray player? I would almost say it was hot.
Has anybody else experienced this when in a standby state?
ddigler is offline
post #3483 of 5940 Old 03-17-2019, 10:21 AM
rylsiem's Avatar
Quoted: 23 Post(s)
Liked: 2
Originally Posted by Clark Burk View Post
Just to be safe all your cables should be premium certified 4k cables in and out of your receiver. To check on whether the receiver is the problem try going direct from player to projector.
The cable is a certified 4k cable. One of the issues is that the problem is hard to replicate as it appears at a random time during a movie.
rylsiem is offline
post #3484 of 5940 Old 03-17-2019, 10:42 AM
Quoted: 13 Post(s)
I too have been surprised by how warm this player gets while one standby.
ddigler likes this.
Hallwhite is offline
post #3485 of 5940 Old 03-17-2019, 11:33 AM
bobknavs's Avatar
Quoted: 2331 Post(s)
Liked: 1662
(snip)
I just checked mine, which hasn't been used in more than 12 hours.
The base plate felt slightly warm to the touch.
The 820 is sitting on a shelf (particle board?) in an open AV rack. More than 5" clearance above it.
ddigler likes this.
bobknavs is offline
post #3486 of 5940 Old 03-17-2019, 01:55 PM
ddigler's Avatar
Liked: 484
Yes; I’m almost nervous to touch the thing after a nice long movie. Glad that it sounds like I’m not the only one…
Originally Posted by bobknavs View Post
I just checked mine, which hasn’t been used in more than 12 hours.
I have mine in the exact scenario you describe. For mine though I would describe it as a very warm, not slightly.
I’m certainly not assuming the worst just trying to determine if it’s normal or not as I was surprised. Sounds like others to a varying extent experience the same thing.
ddigler is offline
post #3487 of 5940 Old 03-17-2019, 06:32 PM
LCSeminole's Avatar
Quoted: 166 Post(s)
Liked: 144
After having played all the Avenger's movies back to back to back, the under side of my DP-UB820 is only the slightest bit warm and the sides and top are cool to the touch.
ddigler likes this.
Emotiva RMC-1/XPR-2/XPR-5, AppleTV 4K
LG OLED65C8, Oppo UDP-203, Panasonic DP-UB820
Furman PL-PRO DMC 20A, Monster Power HTS-5000
SVS Dual PB12-Plus x 2
Klipsch KLF-20, KLF-C7, RB-5II x 4
LCSeminole is offline
post #3488 of 5940 Old 03-17-2019, 06:44 PM
ddigler's Avatar
Liked: 484
Hmmmmm... thanks for touching base Seminole. I’ll have to play some BD and check it after that... it seems to function fine but not certain why so warm...
ddigler is offline
post #3489 of 5940 Old 03-17-2019, 09:05 PM
docrog's Avatar
Quoted: 1156 Post(s)
Liked: 406
Considering all of the heat issues that several of you are describing, has anyone ever had a failure of the laser pick-up to be able to read any disc (CD, DVD, BR, UHD)???? If so, how did you eventually get the player operative?
docrog is online now
post #3490 of 5940 Old 03-18-2019, 10:43 AM
ddigler's Avatar
Liked: 484
Hey Doc. Unfortunately I cannot help you with this. My player works perfectly (knock on wood) - I was just concerned about how hot it gets during standby...
ddigler is offline
post #3491 of 5940 Old 03-18-2019, 05:29 PM
fr8flyr's Avatar
Quoted: 33 Post(s)
Liked: 53
I am in the process of upgrading my H/T and I have just replaced my old processor with an Integra DRC-R1.1 and I am upgrading my 7.1 setup to a 7.1.4. My question is that I have an older JVC projector, that is not 4k, if I add this player will it down res to 1080P, so that I can still get the UHD audio formats, Atmos, DTS X and such to work, or will the player not output to a non 4k projector?
Earl
fr8flyr is offline
post #3492 of 5940 Old 03-18-2019, 05:41 PM
Super Moderator
teachsac's Avatar
Quoted: 1273 Post(s)
Liked: 2091
Backwards compatibility is mandatory. All players can output to a non UHD display. The Panasonic players do it a little better than most.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3493 of 5940 Old 03-18-2019, 06:14 PM
fr8flyr's Avatar
Quoted: 33 Post(s)
Liked: 53
Thanks for the quick response, that means I will be able enjoy the new sound formats without waiting to upgrade my projector.
Earl
fr8flyr is offline
post #3494 of 5940 Old 03-19-2019, 05:29 AM
JonFo's Avatar
Quoted: 194 Post(s)
Liked: 241
That, and if you look up the various mentions of HDR to SDR/709 tone mapping, you also benefit from the wider dynamic range on HDR discs. Just set up a memory in the JVC with all the right settings (like Gamma 2.4, iris settings, etc.) for use with the UB820 + UHD/HDR content.
So far, I'm enjoying the Faux-K from the UB820 (outputting 1080P) going to my JVC 4810 (input 1080p, e-shift to 4K). The big win is the pseudo-HDR. One has to get used to the overall lower APL (average picture level), but a few minutes into the movie, it's all good.
Jonathan
JonFo is offline
post #3495 of 5940 Old 03-19-2019, 06:39 AM
Quoted: 48 Post(s)
Liked: 25
Originally Posted by oledmod View Post
has anyone compared a 2018 oled (i am using the lg c8) vis-à-vis using the pana ub820 for playback of video files (4k sdr/hdr or high-quality 1080p) and/or streaming (amazon)?
this would be my main purpose, but so far, differences seem subtle at best, but i just used a few times...
any advice?
oledmod is offline
post #3496 of 5940 Old 03-19-2019, 08:47 AM
Lesmor's Avatar
Quoted: 765 Post(s)
Liked: 335
any advice?
Yes
don't do it
the 820 is a disc spinner not a media player
as a media player it sucks
OPPO did the sensible thing and did not provide apps for people to then complain about
vollans likes this.
Lesmor is offline
post #3497 of 5940 Old 03-19-2019, 09:08 AM
Quoted: 4876 Post(s)
Liked: 1840
Originally Posted by Lesmor View Post
Yes
don't do it
Can you please elaborate on this? Others have reported good results, at least with latest firmware, for tone-mapping Netflix and Prime Video HDR contents.
Dominic Chan is online now
post #3498 of 5940 Old 03-19-2019, 10:36 AM
cdnscg's Avatar
Quoted: 602 Post(s)
Liked: 123
I guess it may depend on your display, I have to unplug the 820 after playing a discs in order for Netflix rot load, plus the Amazon Prime app starts to stutter after watching 15min of UHD programming.
cdnscg is online now
post #3499 of 5940 Old 03-19-2019, 10:46 AM
Liked: 1840
I did read about Prime stuttering, but believe it’s only in one of the two output modes (SDR2020 or Optimzed HDR, I forgot which one). Which setting do you use?
post #3500 of 5940 Old 03-19-2019, 10:58 AM
Lesmor's Avatar
Quoted: 765 Post(s)
Liked: 335
well you asked for any advice so I gave mine
I can't speak for anyone else
My Amazon Firestick 4K is far superior to using the Panasonic App
the Panasonic wont play mkv rips
the 820 or 9000 is no substitute for a proper media player
MOberhardt likes this.
Lesmor is offline
post #3501 of 5940 Old 03-19-2019, 10:58 AM
monkaquinas's Avatar
Quoted: 84 Post(s)
Liked: 40
I think @claw had a great post on his findings of the diff settings and it's affect on streaming a couple of months ago. I know that the Prime app is buggy and the Netflix app is almost problem free, except for not supporting 24p for us non-60hz projector users.
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.2.2) with Polk PSW110 Sub & Monoprice Premium Select 8" Sub (via iFinity Wireless Audio) - Panasonic UB820 - PS3
monkaquinas is offline
post #3502 of 5940 Old 03-19-2019, 11:05 AM
cdnscg's Avatar
Quoted: 602 Post(s)
Liked: 123
I use SDR2020 with a Sony 4K(non HDR) pj
post #3503 of 5940 Old 03-19-2019, 03:31 PM
Quoted: 67 Post(s)
Liked: 4
Hey guys, I really need some help here. I'm a novice in the AV world, and just had my projector (Optoma UHD 60) calibrated which is hooked up to my Panasonic Ub820.
It was a well respected technician, not some guy from Geek Squad, but I'm afraid things were not done correctly.
He claims that the HDR mapping on the Optoma was poor, so we opted to let the panasonic do it. Fine. However, he set the HDR Color Gamut Output to SDR.BT2020, which would seem to me that it would prohibit he Panasonic from decoding or passing any kind of HDR/Tone mapping to the projector.
Indeed, when you try to access the HDR menu with this setting, you are told that HDR content must be being displayed to access the HDR optimizer. Makes sense to me.
When asked about this, here was the response:
Fortunately, the Panasonic UHD Blu-ray player you bought is a perfect match for the deficiencies of the Optoma's handling of HDR. It allows you to take the incoming HDR data and remap it to SDR data so that it can display as HDR on an SDR-configured display.
I'm sorry but that makes no sense at all. How can you display an HDR signal when HDR is turned off all the way around, both on the Panasonic and on the Optoma?
matpal is offline
post #3504 of 5940 Old 03-19-2019, 03:41 PM
MOberhardt's Avatar
Quoted: 908 Post(s)
Liked: 567
Yeah seriously, anyone really interested in a media player should never look at some all in one throw in solution to it, on a TV or a disc player. If you are an serious about quality, get something stable and built for it. And something that support native frame rates, like an appletv, and doesn't for 24p content to 60hz like nearly everything else.
That is one other thing I like about the pio 500 - no other trinkets.
MOberhardt is offline
post #3505 of 5940 Old 03-19-2019, 04:44 PM
m0j0's Avatar
Quoted: 580 Post(s)
Liked: 555
I have both the UHD60 and the Panasonic 820 and agree that you should configure it for SDR BT2020. I recommend that you don't let yourself get hung up on the HDR vs SDR thing. Tone mapping is a good thing and you want to take advantage of it on the 820 for the best picture.
Here's the settings I use and it looks great:
"Display Mode: Cinema
Wall Color: Off
Brightness: 0
Contrast: -2
Sharpness: 8
Color: 19
Tint: -2
Gamma: 2.4
Ultra Detail: 3 (unless film grain is present, then I will drop down to 1 or 2)
Dynamic Black: On
Brilliant Color: 2
Color Temp: D65
Color Gamut: Cinema
CMS: Defaults
Color Space: Auto
RGB Gain/Bias Settings:
Red Gain: -4
Green Gain: -1
Blue Gain: 12
Red Bias: 0
Green Bias: -1
Blue Bias: 2
820 Settings:
HDMI settings:
Resolution: Auto
4K60p Output: 4K/60p(4:4:4)
24p Output: Auto
HDMI Advanced settings:
Color Mode: Auto
Deep Color Output: Auto (10bit Priority)
HDR/Color Gamut Output: SDR/BT.2020 (Auto)
SDR/HDR Conv: Off
HLG/PQ Conversion: Auto
HDR TV Type: Basic Luminance
Player Options while playing movie:
Luma: +1
Edge: +4
HDR Optimizer: on
Dynamic Range Conversion Adj: +6
Noise Reduction: Optional - If it's an older movie with a lot of distracting film grain, I might set all three noise filters between a value of 1 to 3, until I'm comfortable with the picture
Setting the Gamma to 2.4, turning down the brilliant color setting to 2 on the UHD60 and then compensating by setting the Dynamic Range Conversion Adj to +6 really helped get the best picture while also eliminating shimmering that I sometimes see on the UHD60 when I set the brilliant color setting above 3. "
m0j0 is online now
post #3506 of 5940 Old 03-19-2019, 05:00 PM
fr8flyr's Avatar
Quoted: 33 Post(s)
Liked: 53
Well I got off the fence and went with the Panny 820, so you can add me to the owners list. I picked one up from Bestbuy today and will try and play with it some tomorrow.
Earl
fr8flyr is offline
post #3507 of 5940 Old 03-19-2019, 05:13 PM
Quoted: 67 Post(s)
Liked: 4
Wall Color: Off
Brightness: 0
Contrast: -2
Sharpness: 8
Color: 19
Tint: -2
Gamma: 2.4
Dynamic Black: On
Brilliant Color: 2
Color Temp: D65
Color Gamut: Cinema
CMS: Defaults
Color Space: Auto
Red Gain: -4
Green Gain: -1
Blue Gain: 12
Red Bias: 0
Green Bias: -1
Blue Bias: 2
820 Settings:
HDMI settings:
Resolution: Auto
24p Output: Auto
Color Mode: Auto
SDR/HDR Conv: Off
Luma: +1
Edge: +4
HDR Optimizer: on
Thank you for the very detailed response.
A couple of questions, if you please :
You have the Dynamic Range of the projector set to "off"?
Also, with the color gamut on the panasonic set to SDR, how are tou able to access the HDR optimizer? If I try that, a window pops up and says "this function is valid only during HDR video playback". Then if I set it to HDR2020, I can then access that menu.
Lastly, does this make any sense at all
"Fortunately, the Panasonic UHD Blu-ray player you bought is a perfect match for the deficiencies of the Optoma's handling of HDR. It allows you to take the incoming HDR data and remap it to SDR data so that it can display as HDR on an SDR-configured display"
How does SDR become HDR with all HDR settings turned off?
matpal is offline
post #3508 of 5940 Old 03-19-2019, 06:10 PM
m0j0's Avatar
Quoted: 580 Post(s)
Liked: 555
My HDR Optimizer setting is set to on, so it is doing tone mapping for SDR BT.2020. True, you can not access the HDR Optimizer menu though, so that is why you would set the Dynamic Range Conversion Adj setting.
SDR becomes HDR with the enabling of bt2020 color space plus the tone mapping with the HDR optimizer enabled, at least that is how I understand it.
As far as HDR deficiencies with the Optoma, that is somewhat debatable. I have great success with watching HDR content on the UHD60 using my Nvidia Shield. However, the SDR setting with bt2020 and HDR Optimizer on for the 820 results in an even better picture.
m0j0 is online now
post #3509 of 5940 Old 03-19-2019, 06:12 PM
Quoted: 166 Post(s)
Liked: 50
Reposting this from the Q90 thread:
I ordered my 75 inch Samsung Q90 yesterday.
I’m in the process of ordering my Samsung Dolby Atmos speaker and a 4K player.
I’m planning on buying the Panosonic UB9000, but I just read this on TechRadar’s review.
“It’s worth noting that all of these video enhancements are also available on the cheaper Panasonic DP-UB820, so if you’re on a limited budget you don’t need to buy the UB9000 to get the benefit of features like the HDR Optimiser. “
Since the Samsung Q90 comes with an improved upscaling ability, could I go with the cheaper version of the 4K player?
Th601 likes this.
EdFlo is offline
post #3510 of 5940 Old 03-19-2019, 07:16 PM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 689
The 820 is a great player and I’m sure you wouldn’t be disappointed. The main difference in the 9000 and 820, when it comes to the optimizer, is two lower level luminance settings for us projector owners. Your Q90 would be set at the high luminance, so the optimizer would be the same for you on both players.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is online now
Reply Blu-ray Players
