Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 5717Likes
post #3511 of 7789 Old 03-19-2019, 06:12 PM
Quoted: 170 Post(s)
Liked: 50
Reposting this from the Q90 thread:
I ordered my 75 inch Samsung Q90 yesterday.
I’m in the process of ordering my Samsung Dolby Atmos speaker and a 4K player.
I’m planning on buying the Panosonic UB9000, but I just read this on TechRadar’s review.
“It’s worth noting that all of these video enhancements are also available on the cheaper Panasonic DP-UB820, so if you’re on a limited budget you don’t need to buy the UB9000 to get the benefit of features like the HDR Optimiser. “
Since the Samsung Q90 comes with an improved upscaling ability, could I go with the cheaper version of the 4K player?
Th601 likes this.
EdFlo is offline
post #3512 of 7789 Old 03-19-2019, 07:16 PM
Tom Riddle's Avatar
Quoted: 1066 Post(s)
Liked: 1273
The 820 is a great player and I’m sure you wouldn’t be disappointed. The main difference in the 9000 and 820, when it comes to the optimizer, is two lower level luminance settings for us projector owners. Your Q90 would be set at the high luminance, so the optimizer would be the same for you on both players.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7705 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #3513 of 7789 Old 03-19-2019, 07:24 PM
Quoted: 170 Post(s)
Liked: 50
Thanks, you may have just saved me $500 lol...
Tom Riddle likes this.
EdFlo is offline
post #3514 of 7789 Old 03-19-2019, 07:51 PM
Quoted: 6182 Post(s)
Liked: 2590
Originally Posted by matpal View Post
However, he set the HDR Color Gamut Output to SDR.BT2020, which would seem to me that it would prohibit The Panasonic from decoding or passing any kind of HDR/Tone mapping to the projector.
When you set the Panasonic’s output is to “SDR”, you’re not prohibiting it from “decoding HDR” - it’s the exact opposite, i.e., you’re asking it to do all the work so that the projector doesn’t need to do any.
Jive Turkey and monkaquinas like this.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #3515 of 7789 Old 03-20-2019, 06:18 AM
Quoted: 67 Post(s)
Liked: 4
Thank you for the very detailed response.
A couple of questions, if you please :
You have the Dynamic Range of the projector set to "off"?
Also, with the color gamut on the panasonic set to SDR, how are tou able to access the HDR optimizer? If I try that, a window pops up and says "this function is valid only during HDR video playback". Then if I set it to HDR2020, I can then access that menu.
Lastly, does this make any sense at all
"Fortunately, the Panasonic UHD Blu-ray player you bought is a perfect match for the deficiencies of the Optoma's handling of HDR. It allows you to take the incoming HDR data and remap it to SDR data so that it can display as HDR on an SDR-configured display"
How does SDR become HDR with all HDR settings turned off?
My HDR Optimizer setting is set to on, so it is doing tone mapping for SDR BT.2020. True, you can not access the HDR Optimizer menu though, so that is why you would set the Dynamic Range Conversion Adj setting.
SDR becomes HDR with the enabling of bt2020 color space plus the tone mapping with the HDR optimizer enabled, at least that is how I understand it.
As far as HDR deficiencies with the Optoma, that is somewhat debatable. I have great success with watching HDR content on the UHD60 using my Nvidia Shield. However, the SDR setting with bt2020 and HDR Optimizer on for the 820 results in an even better picture.
I see. So you're saying that even though you can't access the HDR optimizer menu, it should still be active and working, yes? I guess just have to set the parameters with it on HDR2020 first?
And you do have your dynamic range set to off with the Optoma?
Thanks again
matpal is offline
post #3516 of 7789 Old 03-20-2019, 08:27 AM
Quoted: 64 Post(s)
Liked: 29
Thinking about getting this player to pair with my new Q90R. I have an Xbox One X which I’ve been using as a 4k player. Will there be a noticeable different between this player and the X1X?
superman11 is offline
post #3517 of 7789 Old 03-20-2019, 09:07 AM
claw's Avatar
Quoted: 2869 Post(s)
Liked: 2742
Thanks again
If you can't access the HDR Optimizer using the Options button while playing a UHD HDR disc in SDR/BT2020 output mode, then switch the UB820 to HDR output mode, play a HDR disc, and use the Options button to bring up the Optimizer menu and turn it ON.
Once it is turned ON, change the UB820 back to SDR/BT2020 output mode. Then when playing any HDR disc, pressing the Options button will bring up the Optimizer menu where you can adjust the "Dynamic Range Conversion Adj." slider control to either increase brightness but with less contrast, or decrease brightness to get more contrast.
The Options button on the remote, not the HDR button.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #3518 of 7789 Old 03-20-2019, 11:32 AM
m0j0's Avatar
Quoted: 1333 Post(s)
Liked: 2037
Thanks again
Yes, what @claw said.
As for the dynamic range setting, I assume you're talking about the Optoma? I think it's set to auto, but I'd have to check.
m0j0 is online now
post #3519 of 7789 Old 03-20-2019, 11:42 AM
rhale64L7's Avatar
Quoted: 1190 Post(s)
Liked: 565
You have to be using an UHD disk when trying to access that menu
Ron
65" LG B8 Oled,Emotiva RMC1L Processor, Digital Amp Co. 5 and 4 Cherry King amplifiers, Dish Net Hopper, Panasonic UB 820, Sotm SMS 200 ultra Neo and SPS 500 power supply, Rythmik E15HP SE sub, Aerial 6t mains, Aerial 5T surrounds, Aerial cc3B center, ISO Acoustics under all the Aerials 4 Goldenear HTR 7000 ceiling speakers for Atmos All in a dedicated theater with bass traps in all corners and soffits.
rhale64L7 is online now
post #3520 of 7789 Old 03-20-2019, 02:40 PM
Quoted: 62 Post(s)
Curious to know if there would be any advantage to running a separate Audio HDMI and Video HDMI cable as there are 2 outputs on the back the of 820. Currently I am running a single HDMI for both Video and Audio to a Denon 4400 in Bitstream mode and the receiver is processing it as Atmos as it should be when watching a disk. Not a big deal to run another HDMI but the less cables the better unless there is a particular reason to run them separately.
Jerry Lee is offline
post #3521 of 7789 Old 03-20-2019, 02:43 PM
bwillcox's Avatar
Quoted: 1068 Post(s)
Liked: 628
The two HDMI outputs are for folks that own AVRs that don't support 4k. In that case you run the video to the TV and the audio to the AVR. If your AVR supports 4k passthrough then you can run the video/audio output to the AVR and then the AVR output to the TV.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #3522 of 7789 Old 03-20-2019, 03:05 PM
Quoted: 62 Post(s)
Thank you for the clarification, I will leave it as it is then.
post #3523 of 7789 Old 03-20-2019, 03:28 PM
ti-triodes's Avatar
Quoted: 589 Post(s)
Liked: 1403
Originally Posted by Lesmor View Post
OPPO did the sensible thing and did not provide apps for people to then complain about
You must have missed the endless complaining in the OPPO threads because they didn’t include any apps.
Modicen and mrtickleuk like this.
ti-triodes is offline
post #3524 of 7789 Old 03-20-2019, 06:05 PM
Quoted: 67 Post(s)
Liked: 4
Thanks again
OK, so I did what you said... Turned it back to HDR2020, turned the optimizer back on from the options menu and then switched it back to SDR2020.
However, still, when I press the options button during the same HDR source material, it tells me "this function is only valid during HDR output".
I just updated to the latest firmware today.
Can you guys check and see if it's still working for you, making sure you're in SDR output?
matpal is offline
post #3525 of 7789 Old 03-20-2019, 06:25 PM
Quoted: 67 Post(s)
Liked: 4
Thanks again
Your Optoma, yes.
matpal is offline
post #3526 of 7789 Old 03-20-2019, 06:36 PM
m0j0's Avatar
Liked: 2037
It is working but no, you cannot access the menu.
m0j0 is online now
post #3527 of 7789 Old 03-20-2019, 06:36 PM
m0j0's Avatar
Liked: 2037
Your Optoma, yes.
Confirmed it’s set to auto.
m0j0 is online now
post #3528 of 7789 Old 03-21-2019, 01:53 AM
Lesmor's Avatar
Quoted: 816 Post(s)
Liked: 368
No I didn't miss them
I am sure OPPO didn't mind the complaints probably far less complaints than if they had provided apps
I dare say that they wished that they had not provided a HDMI input either
Lesmor is offline
post #3529 of 7789 Old 03-21-2019, 02:40 AM
claw's Avatar
Liked: 2742
When do you get the message? When you press the Options button? You can't turn the Optimizer ON/OFF from SDR/BT2020 but if the Optimizer is turned ON, then you can access the Dynamic Range Conversion Adjustment slider which is all you really need to do.
If you can't do this I don't know what else to suggest.
CJ
claw is offline
post #3530 of 7789 Old 03-21-2019, 06:14 AM
Quoted: 67 Post(s)
Liked: 4
Yes, when I press the options button. I've gone back and verified at least 5 times the the HDR optimizer is set to on. And each time I go back to SDR2020, I can bring up the options menu, yes, but accessing the dynamic range slider does this (see attached).
If it is not too much trouble, can you please humor me and ensure that you're set on SDR2020, and then try to select the HDR optimum adjustment, which you must do to get to the dynamic range slider? If you can still access it, what firmware are you on? Thanks very much.
matpal is offline
post #3531 of 7789 Old 03-21-2019, 07:10 AM
claw's Avatar
Liked: 2742
The attached picture won't display for me. I only use SDR/BT2020 mode.
Here is a link to a post in the JVC thread where I provided the same instructions and the original poster succeeded.
https://www.avsforum.com/forum/24-di...l#post57768782
You are playing a UHD disc? Not trying while playing Netflix or Amazon? Netflix won't even send SDR/BT2020. Amazon will but I don't think you can access the Optimizer to make settings adjustments.
CJ
claw is offline
post #3532 of 7789 Old 03-21-2019, 12:08 PM
cemo62's Avatar
Quoted: 187 Post(s)
Liked: 49
Is there any update playing mkvs with hd audio?
cemo62 is offline
post #3533 of 7789 Old 03-21-2019, 12:24 PM
Quoted: 67 Post(s)
Liked: 4
Ah, so I guess that's it... I was trying all of the internal apps. So the 820 will not do the tone mapping for any of its own apps?
I did try Amazon Prime, Netflix and YouTube for stuff that should have been HDR.
I was about to take a hammer to this thing!
matpal is offline
post #3534 of 7789 Old 03-21-2019, 02:03 PM
claw's Avatar
Liked: 2742
The HDR Optimizer works with both Netflix and Amazon if you are in HDR output mode. You can tell if you have a way to display the metadata that the UB820 outputs. It has changed the metadata to match the HDR Display Type configured.
It will output SDR/BT2020 for Amazon. Netflix App has what I believe to be a bug and outputs SDR/REC709. But it is difficult to tell what the Optimizer might be doing or not doing for Amazon. One thing I meant to try, but haven't got around to, is adjusting the Dynamic Range Conversion Adj. slider to its maximum position while playing a UHD disc. Then play an Amazon HDR title. Repeat with the slider set to the minimum position. If the Optimizer is working with Amazon there should be an obvious difference in brightness level between the two slider positions.
CJ
claw is offline
post #3535 of 7789 Old 03-21-2019, 03:00 PM
Quoted: 67 Post(s)
Liked: 4
So I should be able to access the dynamic range slider while watching Amazon (HDR) prime while in SDR2020?
Sorry for all the questions... I am slowly making my through all 120 pages of this thread.
matpal is offline
post #3536 of 7789 Old 03-21-2019, 03:08 PM
Quoted: 22 Post(s)
Liked: 2
So curious discussion starter....I read a lot about settings for 4k HDR movies on our 820, but curious as to settings people with 4k projectors are using on 820 to watch Blurays? As a lot of movies haven't converted over to 4k HDR yet I'm sure a lot of us are still watching Blurays on here as well.
Jim Purcell is offline
post #3537 of 7789 Old 03-21-2019, 03:17 PM
MOberhardt's Avatar
Quoted: 1500 Post(s)
Liked: 1147
I don't think I use any non standard setting for blu-ray, and I do watch a lot on my projector.
I do love it for the subtitle shift and luminance though. Best Feature Ever. I just wish it remembered settings between discs.
MOberhardt is offline
post #3538 of 7789 Old 03-21-2019, 05:06 PM
smitty's Avatar
Quoted: 764 Post(s)
Liked: 1020
Does anybody else have trouble getting the metadata information on the 820 when playing a 4k HDR disc? My understanding is that you have to hit the Playback Info button twice in succession. But when I do that, I only get the more limited information that you get if you hit the button once (such as the audio format and whether it is outputting SDR or HDR). Hitting the Playback Info button twice does not seem to give me the screen that I've seen in some videos that show, among other things, the metadata values.
smitty is offline
post #3539 of 7789 Old 03-21-2019, 05:20 PM
rrebello's Avatar
Quoted: 51 Post(s)
Liked: 49
Go back and re-press the button and hold it down. You can’t give a quick touch.
rrebello is offline
post #3540 of 7789 Old 03-21-2019, 05:50 PM
claw's Avatar
Liked: 2742
I believe metadata reporting is unique to the UB9000.
MOberhardt likes this.
CJ
claw is offline
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
