Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 5114Likes
post #3541 of 6212 Old 03-21-2019, 08:22 PM
smitty's Avatar
Quoted: 763 Post(s)
Liked: 1019
Originally Posted by claw View Post
I believe metadata reporting is unique to the UB9000.
That would explain it. I tried pressing it twice slowly, pressing it twice quickly, pressing it and holding it, and tried these on two separate occasions. It was in Vincent Teogh's video that I saw him do this, but he was using the UB9000.
smitty is offline
post #3542 of 6212 Old 03-21-2019, 08:41 PM
MOberhardt's Avatar
Quoted: 980 Post(s)
Liked: 683
MOberhardt is online now
post #3543 of 6212 Old 03-22-2019, 02:09 AM
chhanthony's Avatar
Quoted: 199 Post(s)
Liked: 112
Hi all,
As an UB900 owner, is it a good idea to buy UB820 for the HDR optimizer function?
Anthony Chan
AV Blog: http://www.avnewbie.com
System: 5.3.4
Panasonic DMP-UB900EBK, Egreat A5, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, Benq HT1075, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #3544 of 6212 Old 03-22-2019, 02:25 AM
lizrussspike's Avatar
Quoted: 1268 Post(s)
Liked: 1910
@chhanthony , If you own a projector, then yes. I have an Oppo 203, but just recently purchased the 820 to go with my JVC RS420, and am very impressed with the 820.
chhanthony likes this.
lizrussspike is offline
post #3545 of 6212 Old 03-22-2019, 06:37 AM
Quoted: 67 Post(s)
Liked: 4
Originally Posted by matpal View Post
So I should be able to access the dynamic range slider while watching Amazon (HDR) prime while in SDR2020?
Sorry for all the questions... I am slowly making my through all 120 pages of this thread.
No, the HDR Optimizer settings are only available in SDR/BT2020 output mode when playing a UHD disc that contains HDR.
The Optimizer settings are only available for Netflix and Amazon when the player is in HDR output mode and playing an HDR title.
I did some testing with the Dynamic Range Conversion Adj. slider and it appears to me that the setting value configured during HDR output mode is completely ignored when playing Amazon HDR content in SDR/BT2020 output mode. This was disappointing. My guess, and this is only a guess, is that in SDR/BT2020 output mode a default tone map is used to map Amazon HDR to SDR/BT2020 and the Optimizer may not be utilized.
Can you tell by the meta data that it is even doing tone mapping at all? This was my concern that the unit was not tone mapping any of it's streaming apps.
Do we know for sure if it tone maps the internal Netflix and YouTube app for HDR/UHD content?
I was doing A/B switching between streaming content with Roku and then the Panasonic apps... Exact same content and there was no appreciable difference when I would think the stuff streamed from th panasonic should look noticeably better.
Dominic Chan likes this.
matpal is offline
post #3546 of 6212 Old 03-22-2019, 08:09 AM
tigerhonaker's Avatar
Quoted: 693 Post(s)
Liked: 675
Post
Originally Posted by Jim Purcell View Post
So curious discussion starter....I read a lot about settings for 4k HDR movies on our 820, but curious as to settings people with 4k projectors are using on 820 to watch Blurays? As a lot of movies haven't converted over to 4k HDR yet I'm sure a lot of us are still watching Blurays on here as well.
I watch a lot more of DVDs & Blu-rays than the Newer 4K Disc.
Here is the bottom-line on the above.
If it's really a CRAPPY DVD and or Blu-ray then guess what your going to see ???
On the other hand if the Blu-ray is actually a quality done movie it can look darn close to a 4K Disc.
Example, AVATAR is an excellent Blu-ray and looks like a 4K.
(I'm not saying the Blu-rays look exactly like a 4K, I'm saying they look GREAT)
Keep in mind I'm viewing these on a Custom Calibrated JVC RS4500 Laser projector.
BTW,
All 4K disc don't necessarily look Fantastic just like all Blu-ray DVDs don't.
Terry
Jive Turkey and Tom Riddle like this.
tigerhonaker is online now
post #3547 of 6212 Old 03-22-2019, 08:14 AM
claw's Avatar
Quoted: 2377 Post(s)
Liked: 2238
I have an HDfury device connected after my UB820. The HDfury reports the HDR metadata received.
As an example, let's say the UB820 is set to HDR output with the Optimizer turned ON and HDR Display Type is set to OLED which represents 1000 nits. The HDR Optimizer will tone map the highlights that exceed 1000 nits in the content down to inside of 1000 nits. Before outputting the result, the Optimizer then replaces the original metadata with new values. MaxDML (Maximum Display Monitor Luminance) would be modfied to 1000 nits. MaxCLL (Maximum Content Luminance Level) would be set to a value less than or equal to 1000 nits depending upon the original MaxCLL value of the content.
When playing content from Netflix or Amazon with the UB820 in HDR output mode with the Optimizer turned ON, my HDfury reports that the original content metadata has been changed. So it leads me to believe that the Optimizer is indeed tone mapping. Otherwise, changing the metadata values alone without tone mapping could result in the HDR TV clipping highlights when it performed its tone mapping. This is my opinion, right or wrong.
When the UB820 is set to SDR/BT2020 output, I believe that the Optimizer is not used to tone map Amazon HDR to SDR/BT2020. For one, you can't access the Opimizer settings. They can only be accessed when playing a UHD disc. In addition, I came to this conclusion because I found that no matter what value I set the Dynamic Range Conversion Adj. slider when playing a UHD disc, it appears to have no effect on the brightness of Amazon content. Setting the slider to its maximum position makes UHD disc content too bright and washed out. Setting the slider to the minimum position makes UHD disc content too dark. But subsequent viewing of Amazon video HDR content after changing the slider value while playing a UHD disc looks the same in either case. So I believe the Optimizer is not used, and a default tone map is used to map Amazon HDR to SDR/BT2020. Again, my opinion only.
The reason you may not see a difference is so much of Amazon and Netflix content is mastered at 1000 nits and sometimes contains no metadata at all in which case a default 1000 nit tone map would be used by the Optimizer.. The Optimizer will perform less tone mapping in these cases than it would if MaxDML and MaxCLL metadata values were higher. If you set HDR Display Type to OLED (1000 nits) the Optimizer would probably not perform any tone mapping for 1000 nit content or content with missing metadata values.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is online now
post #3548 of 6212 Old 03-22-2019, 08:29 AM
Quoted: 5019 Post(s)
Liked: 1932
One Netflix show that was mastered at high nits is Altered Carbon. I can easily see clipped highlights. Maybe @matpal can test that to see if the UB820 makes a difference.
And Marco Polo looks really dim in some scenes.
Dominic Chan is online now
post #3549 of 6212 Old 03-22-2019, 08:34 AM
cdnscg's Avatar
Quoted: 608 Post(s)
Liked: 123
Yes the visuals are great, too bad can't say the same for the show itself
cdnscg is online now
post #3550 of 6212 Old 03-22-2019, 08:48 AM
claw's Avatar
Liked: 2238
I don't see where he mentioned what HDR display he has. If it is a Basic Luminance TV (500 nits) then I would expect to see the Optimizer make a more obvious difference with Amazon/Netflix content than if he has a High Luminance TV (1500 nits).
it has been a while since I watched Marco Polo but I recall that the metadata data values were very high.
CJ
claw is online now
post #3551 of 6212 Old 03-22-2019, 08:52 AM
Liked: 1932
It's an Optoma UHD60.
post #3552 of 6212 Old 03-22-2019, 08:58 AM
claw's Avatar
Liked: 2238
All bets are off if it is a projector with a fixed HDR gamma curve. And besides, most projector owners will set the UB820 to SDR/BT2020 mode in which case I have now come to believe that the Optimizer is not used at all for Amazon and Netflix.
CJ
claw is online now
post #3553 of 6212 Old 03-22-2019, 09:28 AM
Liked: 1932
I was considering getting a UB820, but I watch streaming far more than discs. Would I benefit from the Optimizer at all, if I set it to output 500 nits and construct a custom curve on the projector accordingly?
post #3554 of 6212 Old 03-22-2019, 09:39 AM
cdnscg's Avatar
Quoted: 608 Post(s)
Liked: 123
As you may have read, the apps through the UB820 are not the best
post #3555 of 6212 Old 03-22-2019, 09:45 AM
Liked: 1932
The comments seem to be mixed. If I remember correctly, most of the streaming issues are with SDR2020. In any case, my JVC eshift projector doesn't read metadata and I'm trying to see if the Optimizer helps.
post #3556 of 6212 Old 03-22-2019, 10:38 AM
claw's Avatar
Liked: 2238
I am very hesitant to answer since the last time I did I got beat down for it.
But I will say that I experimented with setting the UB820 to Projector (500 nits) and whatever the middle luminance LCD setting is called (1000 nits). I thought I got better results with the LCD 1000 nit setting combined with my 1000 nit custom curve in my JVC RS500 than I did with the 500 nit Projector setting and my 1000 nit curve. I did not try to build a 500 nit custom curve.
I now watch UHD discs in SDR/BT2020 mode on my JVC RS500. I watch Netflix and Amazon using my LG OLED where the HDR Optimizer and the LG tone mapping seem to work well together.
Tom Riddle likes this.
CJ
claw is online now
post #3557 of 6212 Old 03-22-2019, 11:11 AM
Quoted: 20 Post(s)
Liked: 2
BTW,
Terry
Terry, which copy of Avatar just out of curiosity? Original or the extended. I've been debating getting the extended vs waiting for Cameron to pull head out of butt and give us a 4k HDR cut
Jim Purcell is offline
post #3558 of 6212 Old 03-22-2019, 12:24 PM
Quoted: 693 Post(s)
Liked: 675
Post
I really-really luv watching and listening to AVATAR.
It's one of my All-time-Favorites !!!
I just watched it and viewed the option of Extended 16-minutes version.
Terry
Al Kuenster likes this.
post #3559 of 6212 Old 03-22-2019, 02:12 PM
Al Kuenster's Avatar
Before doing Avatar in 4K I would like to see The Abyss & True Lies, bring 'em on!
william06 and Tom Riddle like this.
Al Kuenster is offline
post #3560 of 6212 Old 03-22-2019, 02:46 PM
Quoted: 20 Post(s)
Liked: 2
The Abyss for sure!!!
post #3561 of 6212 Old 03-22-2019, 03:14 PM
monkaquinas's Avatar
Quoted: 84 Post(s)
Liked: 40
It's coming...
http://thedigitalbits.com/columns/my...ts/030519-1200
Al Kuenster, yoguy1 and per1971 like this.
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.2.2) with Polk PSW110 Sub & Monoprice Premium Select 8" Sub (via iFinity Wireless Audio) - Panasonic UB820 - PS3
monkaquinas is offline
post #3562 of 6212 Old 03-22-2019, 03:54 PM
ScottieBoysName's Avatar
Quoted: 1329 Post(s)
Liked: 488
Agreed!
ScottieBoysName is online now
post #3563 of 6212 Old 03-22-2019, 05:15 PM
Quoted: 67 Post(s)
Liked: 4
You are a gentleman and a scholar; thank you.
matpal is offline
post #3564 of 6212 Old 03-22-2019, 07:43 PM
Quoted: 64 Post(s)
Liked: 62
Anyone using the player with both hdmi outs( one to tv and one to reciever)? I am still not having any luck getting sound from my reciever. There has got to be some setting that is keeping the sound off from the hdmi audio out. It plays fine when the reciever’s hdmi out is disconnected from the tv but wont play when it is connected. It is a yahmaha reciever and had no problem outputting audio only the oppo 203. Also, the display flashes that the high clarity sound is on. Is that normal or something that should be turned off?
coxjamb is offline
post #3565 of 6212 Old 03-22-2019, 07:56 PM
m0j0's Avatar
Quoted: 670 Post(s)
Liked: 689
Try this:
Set the following items in the setup menu
  • Set “HDMI(VIDEO) Output Mode” to “Auto ( Video Only / Video+Audio )”.
  • Set “HDMI(AUDIO) Output Mode” to “Audio Only”.
m0j0 is online now
post #3566 of 6212 Old 03-22-2019, 08:18 PM
Liked: 488
I’m using both. No issues here. I don’t even remember having to set anything up to get it to work. Might have though.
post #3567 of 6212 Old 03-22-2019, 09:14 PM
Ruppgu's Avatar
Quoted: 501 Post(s)
Liked: 556
Picked this up today. With my b7a i tried a/b testing of the first fantastic beasts movie. It wasn’t as drastic as the pictures earlier in this thread (my b7a with it off still shows details on the wand blasts) BUT it does look a lot more detailed with it on with both still shots and in real time. Definitely worth the money to get the best hdr possible. Will be interesting to see if it’s helpful with the new 2019 oleds as well.
TV: Sony A9G 77" Oled & LG B7A 65" Oled
AVR: Denon AVRX4300H
F/L: Emotiva Airmotiv T2, Center: Emotiva Airmotiv C2, Surround: Emotiva Airmotiv B1 x4, Atmos: Elac A4 x4, Subwoofer: PSA V1811, Actuator: Crowson x2
4k Player: Panasonic UB 820
Ruppgu is offline
post #3568 of 6212 Old 03-22-2019, 09:17 PM
Quoted: 64 Post(s)
Liked: 62
Thanks guys. i have the settings adjusted as suggested but no dice. It is something to do with both the player and reciever connected to the tv at same time. I didn’t have to do anything with oppo either.
coxjamb is offline
post #3569 of 6212 Old 03-22-2019, 09:20 PM
Quoted: 64 Post(s)
Liked: 62
Is your reciever connected to your tv as well as your player?
coxjamb is offline
post #3570 of 6212 Old 03-22-2019, 10:03 PM
Liked: 488
Yup. What receiver do you have?
Panny 820 - HDMI video direct to projector.
Panny 820 - HDMI audio direct to Marantz 7704
Nintendo Switch - HDMI to Marantz 7704
PS4 - HDMI to Marantz 7704
Marantz 7704 - HDMI direct to projector.
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
