Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 150 - AVS Forum | Home Theater Discussions And Reviews
 4821Likes
post #4471 of 5119 Old 05-16-2019, 01:19 PM
jt7272's Avatar
Quoted: 46 Post(s)
Liked: 42
Originally Posted by docrog View Post
A problem, however, is that my HDMI cable and JVC PJ are capable of carrying 18Gbps. Netflix performs flawlessly, but Amazon Video is subject to intermittent "stuttering" while the ATV4K & Roku Ultra play that same source material without hiccups. While this could be a function of the Panasonic's inability to match frame rates (locked at 60), I'm not sure how the 18Gbps question is relevant here.
There are two separate issues at play here:
1. Frame rate lock forces 24p -> 60p conversion. It's not clear if this is happening in the UB820 or at Panasonic's servers or all the way back at the source (assuming it gets info that the device is 60p only). This is definitely a source of judder issues, though the Amazon Prime app has seemingly multiple framerate issues that could have various root causes
2. Frame rate lock necessitates 18gbps HDMI connection. 4k60 HDR requires 18gbps. 4k24 HDR works fine at 10gbps. So UHD Blu-rays (4k24 4:2:0 encoded, converted to 4:2:2 before transmission) will work fine on 10gbps devices as designed. UHD streaming content, though, will not work on 10gbps devices even if the source is 24p. For example, The Man in the High Castle on Amazon streams at 4K with HDR10 at 24 Hz. This works fine on 10gbps devices. The UB820, though, forces it to 60Hz. This requires an 18gbps connection. The end result is that 10gbps displays will get a 1080p60 signal in an Rec2020 container (unless you have forced all output to SDR709). Not only are you not getting UHD but the 1080p signal has desaturated colors.
These are parallel issues with the same root cause. You having a full 18gbps connection negates 2 but not 1.
Epson 6040ub
Denon AVR-X3400H + Mirage OMD-5 surrounds
Home-made Hybrid PCB Electrostatic Floorstanding L+R Speakers (with built-in DSP + amps)
Home-made sub with 15" Ultimax woofer, Dayton SA1000 Amp
Sony PS4, Sony UBP-X800, Panasonic DP-UB820
jt7272 is offline
post #4472 of 5119 Old 05-16-2019, 01:46 PM
Erod's Avatar
Quoted: 1217 Post(s)
Liked: 739
Originally Posted by mattztt View Post
I've noticed this too and have started switching to other sources for SDR Netflix content so there's no unnecessary extra processing in the pipeline. You're never going to improve an SDR image by wrapping it in an HDR container but you can degrade it if it's not done right.
But it looks really good, like a perfect 1080p picture. It's not harming it, which actually makes no sense.
Amazon Prime is a disaster though with HDR material being forced to 60 Hz. You'd think that could be addressed with an update. If the disc can be played in 24p, why not Prime?
That just pushes Prime material over to my PS4, which isn't applying the tone mapping of the 820.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: Jamo 626k4 in-wall mains, Jamo 631k4 bi/dipole surrounds, DefTech DI6.5R heights
Erod is offline
post #4473 of 5119 Old 05-16-2019, 02:08 PM
mattztt's Avatar
Quoted: 356 Post(s)
Liked: 355
When you output SDR content to an SDR display you get output that is 100% accurate to the source. If you wrap SDR in an HDR container then you introduce the possibility of altering the output through poor mapping between the containers (see the Red Dead Redemption 2 fiasco) or unnecessary tone mapping which could darken the overall image or at least the brighter elements of the image to accommodate HDR highlights which would never appear in SDR content. This could be especially problematic for projectors.
Now the Panasonic UHD players being the top notch players they are may not actually suffer from these potential issues and likely do a great job of it. But if I instead stream SDR content from a device that will output it as SDR then there is no question. Additionally my projector won't unnecessarily flip to HDR mode, open the iris up, and turn on high lamp.
mattztt is offline
post #4474 of 5119 Old 05-16-2019, 02:13 PM
MOberhardt's Avatar
Quoted: 703 Post(s)
Liked: 299
I was hoping that the "stuttering" issues in Amazon Video would have been addressed in the recent internet service maintenance. Despite owning both the ATV4K & Roku Ultra, my preference would be to use the UB820/9000 app for UHD/HDR Netflix & Amazon (and YouTube HDR) because the HDR Optimizer works much better with my JVC NX7 projector than HDR from either of the other 2 UHD streaming devices.
Seriously if you are interested in streaming, buy an Apple TV. Something that will allow frame rate matching. Stuttering can also be from the abomination that is 60 hz conversion of 24hz material. And nearly every Netflix app on everything other than an Apple TV and maybe one or two other devices will force 60hz.
MOberhardt is offline
post #4475 of 5119 Old 05-16-2019, 02:22 PM
docrog's Avatar
Quoted: 1059 Post(s)
Liked: 361
I'm confused by recent posts. My comment regarding my preference for the UB820 over the Roku Ultra was specifically for streaming HDR content. Are you implying that content which is in SDR is being forced to HDR on UB820 output and therefore being "wrapped" in an incorrect envelope? AFAIK, with regards to my UB820 settings (I do NOT force SDR-BT2020 output), SDR remains SDR and only "native" HDR content will trip the JVC flag. No?
docrog is offline
post #4476 of 5119 Old 05-16-2019, 02:30 PM
claw's Avatar
Quoted: 2215 Post(s)
Liked: 2070
But how much of that tone mapping is really applied to a network stream?
I have a JVC projector, too, and I do notice that SDR2020 is applied to literally every movie on Netflix through the ub820, regardless if its HDR or not.
You probably have SDR/HDR Network Conversion turned ON. This has the UB820 convert all SDR from Netflix and Amazon to HDR. Then if you are in SDR/BT2020 mode it might then tone map the converted HDR to SDR BT2020. In other words, SDR/REC709 -> HDR/BT2020 -> SDR/BT2020. This is one of several reasons I have SDR/HDR Network Conversion turned OFF.
Clark Burk, namirkhan and jh901 like this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Vertex/Linker/Integral
claw is offline
post #4477 of 5119 Old 05-16-2019, 02:41 PM
docrog's Avatar
Liked: 361
As I'd previously written in the post which you quoted, I DO own the ATV4K. I have absolutely no Netflix issues when using the UB820 app, allowing me to make use of the Optimizer for HDR content.
smitty likes this.
docrog is offline
post #4478 of 5119 Old 05-16-2019, 10:15 PM
audioguy3107's Avatar
Do any of the JVC projector users/experts know whether the 820 and it's UHD features are compatible with the slightly older 4K eshift projectors? I have a DLA-RS48 (X55) but cannot seem to find any feedback about compatibility this far back. JVC's website doesn't list these models in their support page when it comes to downloading the BT.2020 color gamut/file........the info screen while playing a 4K disc indicates that the player is displaying a 1080p signal rather than 4K. Was hoping to get by with the Panasonic UB820 and my 48 until it's time to upgrade to one of their new 4K models.
audioguy3107 is offline
post #4479 of 5119 Old 05-17-2019, 04:52 AM
jt7272's Avatar
Quoted: 46 Post(s)
Liked: 42
This model is listed as having HDMI 1.4. It should be able to receive a 4k24 SDR signal. So you can try to set the output to SDR709 and it should work at 4k for Uhd blu-ray.
Epson 6040ub
jt7272 is offline
post #4480 of 5119 Old 05-17-2019, 05:08 AM
Quoted: 4493 Post(s)
Liked: 1681
To play 4K contents on the older eshift projectors you need an HDCP 2.2 to 1.4 converter such as this one
https://www.monoprice.com/product?c_...105&p_id=15242
EDIT: This works with the e-shift3 models such as the X500, but the e-shift2 models such as X55 do not accept 4K inputs.
The jvc calibration software required to load the BT.2020 software works with X95 and X75, but not X55:
https://www3.jvckenwood.com/english/...3_en_v1_03.pdf
Dominic Chan is offline
post #4481 of 5119 Old 05-17-2019, 06:47 AM
claw's Avatar
Liked: 2070
Does not accept 4K input. From the user manual:
Digital Video Signal 480i, 480p, 576i, 576p, 720p/50 Hz, 720p/60 Hz, 1080i/50 Hz, 1080i/60 Hz,
1080p/24 Hz, 1080p/50 Hz, 1080p/60 Hz
CJ
claw is offline
post #4482 of 5119 Old 05-17-2019, 06:49 AM
jt7272's Avatar
Quoted: 46 Post(s)
Liked: 42
Yikes. That is unfortunate. So that JVC has HDMI 1.4a (capable of 4k24 SDR) and 4k e-shift panels but it does not actually support 4k? Mind = blown
Epson 6040ub
jt7272 is offline
post #4483 of 5119 Old 05-17-2019, 09:38 AM
jh901's Avatar
Quoted: 724 Post(s)
Liked: 275
Why is that mind-blowing? The new JVC RS3000 can't accept an 8K signal, but it has 8K e-shift. There's no standard to accept a signal for a format that doesn't exist is there?
HT: Panasonic DP-UB820 | JVC RS600 | 106" x 45" Stewart ST 100 | Cary Audio Cinema 12 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut F5/B6; Focal CMS Sub
STEREO: [Shunyata Denali] Playback Designs MPS-5 (fully upgraded) | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 ES | Focal Diablo Utopia III DEN: 60" Panasonic VT60
jh901 is offline
post #4484 of 5119 Old 05-17-2019, 10:04 AM
jt7272's Avatar
Quoted: 46 Post(s)
Liked: 42
But there IS a standard to accept 4k24/4k30 with HDMI 1.4 and there were devices that used it. The same cannot be said for 8k at the moment.
EDIT:
Sorry for getting so far off-topic. Also sorry that the JVC won't do any 4k.
Epson 6040ub
jt7272 is offline
post #4485 of 5119 Old 05-17-2019, 10:19 AM
Thanks guys, that’s kind of what I thought, I wasn’t sure if the eshift specs on mine were the same as on some of the later models.
post #4486 of 5119 Old 05-17-2019, 02:23 PM
Quoted: 37 Post(s)
Playing an mkv file through my UB820: I get an error message that the Audio Format is not supported.
This has a standard 5.1 track (not a hires one DTSHD-MA or DolbyTrueHD).
Do you know what the issue might be?
TV: LG 55C8 / Blu-Ray Player: Panasonic UB820 / AVR: Denon X6200W
Speakers: ELAC Debut 2xF6, 1xC5, 2xB6, 1xS12EQ
escu is offline
post #4487 of 5119 Old 05-17-2019, 03:08 PM
Fox
Fox's Avatar
Can anyone confirm there's reasonable control4 drivers available for this? I'm planning on picking one up soonish.
Fox is offline
post #4488 of 5119 Old 05-19-2019, 07:48 AM
irishluck73's Avatar
Quoted: 277 Post(s)
Liked: 186
I think that the biggest problem with Amazon prime is that they don't stream in 24p. IDK how a player at this price point, designed for this type of user, does not have 24p support for all streaming. It is beyond stupid.
Alas, I still have a Sony X800 which streams Netflix and Amazon Prime flawlessly. Unfortunately it is just about useless as a disc player (constant lockups). So, yes, I have the X800 solely for streaming as the UB820 is straight trash for it...
Our Sony X800 puts out an outstanding picture streaming, the up conversion looks great. Is the UB820 not up to the task?
Curious cause I'm looking to upgrade our player and we do a lot of Netflix streaming.
NEVERMIND. Read further and answered my own question.
irishluck73 is offline
post #4489 of 5119 Old 05-19-2019, 08:00 AM
Slingshot's Avatar
Quoted: 59 Post(s)
Liked: 41
deepsneaker appears to be located in Germany. The UB9000 remote is available from many online shops in Europe. I was never able to locate one from a US based shop. Maybe because there are only two US based retailers that sell the UB820 and UB9000 player.
The remote part number is N2QAYA000172.
I found a remote control retail shop in Spain that would ship to the US. It cost me $79 USD including shipping to US. It arrived 18 days after I placed my order.
https://mandisremotes.com/en/Panason...e-control.html
You can find the UB900 remote in the US on eBay and elsewhere. Its part number is N2QAYA000131. The main difference is that the UB900 remote does not have the HDR button that the UB9000 remote has.
Even the actual UB820 remote is difficult to find in the US. It is such a pain to use that I bought a UB9000 remote to use instead. The UB820 remote model number is N2QAYB001206. It appears you can get one from here for $16.95:
https://panasonic.encompass.com/item.../N2QAYB001206/
*** The next poster that asks me why I didn't get a Harmony instead goes directly to my Ignore list. ***
I just purchased one from Spain for $2 more than you paid probably as the Euro fluctuates every day. Thanks for the info.
Slingshot is offline
post #4490 of 5119 Old 05-19-2019, 10:35 AM
asharma's Avatar
Quoted: 1634 Post(s)
Liked: 498
I ordered and received a UB9000 remote (not UB900) from a shop in Spain. With shipping charges to US and no VAT charged (VAT charges removed when shipping address/payment method provided and a commercial invoice is not requested), it came to just under $80 when converted to USD. Arrived 18 days after order placed.
Mandis Shop - Original Remote Control Panasonic UB9000 N2QAYA000172
Photo of UB820 remote vs the UB9000 remote I received:
Thanks Claw...just ordered this. $110 CDN and no tracking Here’s hoping!
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual JL Audio D110
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820
Triple black velvet bat cave
asharma is offline
post #4491 of 5119 Old 05-19-2019, 07:59 PM
bigzee3's Avatar
Quoted: 171 Post(s)
Liked: 122
HDR Picture Modes
Hi guys,
Anyone use these at all and more importantly what does it do to the image if changing from one to another . I think they are Standard, natural, light and bright.
bigzee3 is offline
post #4492 of 5119 Old 05-20-2019, 07:33 AM
tigerhonaker's Avatar
Quoted: 538 Post(s)
Liked: 559
Post
Originally Posted by bigzee3 View Post
Hi guys,
I had my RS4500 Custom Calibrated by Chad B. so I use his settings.
Terry
JVC RS4500 Laser Projector:
My "New" Home Theater Up-Dates with Pictures, March 6th, 2019 .
https://www.avsforum.com/forum/15-ge...st-2018-a.html
tigerhonaker is offline
post #4493 of 5119 Old 05-20-2019, 08:04 AM
avtoronto's Avatar
Quoted: 137 Post(s)
Liked: 56
Terry
The question pertains to the differences in the 820's HDR settings. Did your calibrator reference these?
Elunevision 4K 112" Audioweave motorized screen, Epson Pro Cinema 4040 projector, Emotiva XPA-5 amplifier, Denon AVR X4400h receiver, XTZ M6 LCR, XTZ S2 surround, XTZ 1X12 subwoofer, RSL C34E Atmos speakers, Apple TV 4K, Panasonic DP-UB820
avtoronto is offline
post #4494 of 5119 Old 05-20-2019, 09:01 AM
Quoted: 538 Post(s)
Liked: 559
Post
I was not in the H/T when he did the Audio as well as the Video.
I do know both were set-up to work with one another.
And I recall Chad setting both the RS4500 as well as the UB820 to work together for all HDR content.
I'm referring to the Auto-Tone-Mapping feature of the UB820 Panasonic to work with the JVC RS4500 Laser projector.
Terry
Jive Turkey likes this.
post #4495 of 5119 Old 05-20-2019, 02:24 PM
docrog's Avatar
Liked: 361
Terry
Which AVR are you using?
docrog is offline
post #4496 of 5119 Old 05-20-2019, 02:45 PM
Quoted: 538 Post(s)
Liked: 559
Post
Marantz AV8805 ...............
Terry
post #4497 of 5119 Old 05-20-2019, 03:01 PM
todaxy's Avatar
Quoted: 23 Post(s)
I just hooked up my UB820 and there is an audio feature that "speaks" every command that you give the player. e.g. "Tray open", etc. The odd thing is that it barks out these commands at a rate that seems like 50% faster than normal. How do I turn this feature off? I've looked through the various menus to no avail. Help please.
todaxy is offline
post #4498 of 5119 Old 05-20-2019, 03:18 PM
DLCPhoto's Avatar
Quoted: 1560 Post(s)
Liked: 693
There is a "Voice Guidance Setting" in the Audio section of the main Settings menu. Disable it there, and you'll be good to go!
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is offline
post #4499 of 5119 Old 05-20-2019, 03:19 PM
ti-triodes's Avatar
Quoted: 515 Post(s)
Liked: 1103
If you guys can live without the HDR button, Amazon has the N2QAYA000085. IIRC, it’s the remote for the DMP-BDT700 BD player. I picked one up for $20 a few months ago.
It seems to be stocked on an irregular basis so it’s worth checking every so often. It’s the best price I’ve found for one these premium Panny remotes.
MOberhardt likes this.
ti-triodes is offline
post #4500 of 5119 Old 05-20-2019, 03:50 PM
todaxy's Avatar
Quoted: 23 Post(s)
I must have missed that! Thanks, I'll check it out.
todaxy is offline
Reply Blu-ray Players
