Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 5103Likes
post #4741 of 6175 Old 06-13-2019, 09:32 AM
asharma's Avatar
Quoted: 1877 Post(s)
Liked: 608
Originally Posted by asharma View Post
Hi folks
Does anyone know if I can use the 820 as a Tidal streamer? Is there a way to access the Tidal app on the 820? Thanks folks...
Any input would be appreciated, thanks folks...
Video:JVC N7 Sony 85” 900F Sony 55” 900F
Audio: Paradigm Prestige 95, 55C, 15b Dual SVS SB3000
Receiver/Amp: Anthem 1120, Emotiva XPA-5 Gen 2
Source: Panasonic UB820, Triple black velvet batcave
125" 2.35 Stewart Cima Neve Tab Tensioned Electric
asharma is offline
post #4742 of 6175 Old 06-13-2019, 11:30 AM
Nick3092's Avatar
I don't see Tidal as an option for music apps. Just Pandora, Rhapsody, ShoutCast, and TuneIn.
Nick3092 is offline
post #4743 of 6175 Old 06-13-2019, 11:40 AM
asharma's Avatar
Liked: 608
Thanks, perhaps it’s on the 9000, given the upgraded DAC on that unit...otherwise fingers crossed, it may show up in a firmware update...
asharma is offline
post #4744 of 6175 Old 06-13-2019, 12:07 PM
Quoted: 251 Post(s)
How do you upconvert with the UB820?
sound2017 is offline
post #4745 of 6175 Old 06-13-2019, 12:20 PM
cdnscg's Avatar
Quoted: 605 Post(s)
Liked: 123
Unless to set it not too, it upconverts automatically.
cdnscg is offline
post #4746 of 6175 Old 06-13-2019, 12:35 PM
docrog's Avatar
Quoted: 1194 Post(s)
Liked: 426
Since the UB820 does a more than adequate job of upscaling legacy DVD & Blu-Ray source material to 4K, the only reason to output at native resolution is if you're planning to play 3D source material. If the UB820 output is fixed at 4K it's probable that only 2D will be recognized as playable, so you'd have to go back to the settings menu and change it to native resolution.
JVC NX7, Yamaha RX-A3080 (2 discrete 7.2.4 speaker layouts: Dolby Atmos & DTS:X), Panasonic UB820, Panasonic UB420, Oppo 103D, ATV4K, Roku Ultra, TiVo Bolt Vox, Vandersteen Model 3 Signatures & VCC-1 Signature, Atlantic Technology (side, rear, front height & overhead) surrounds, SVS SB-2000 (2), Clark Synthesis Tactile Bass Transducers (2), Polk PSW-12
docrog is online now
post #4747 of 6175 Old 06-13-2019, 03:16 PM
WOKNROX's Avatar
Quoted: 408 Post(s)
Liked: 339
Which model HD-Fury should @Pip be looking for to help him rid his problem of gamma D switching with HDR?
Orotund Desert Theater:14'x20'x10',100amp service, JVC RS620, 120" AT screen, Carada Masquerade Masking, OPPO-203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5 channel amplifiers, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Triad Gold, 4 Atmos 3 way Core5's, Subs-1 Rythmik FV25HP & 4 HSU VTF-MK5-HP, 2 Rows of 3 Seatcraft Excalibur Lx Seats and more.
WOKNROX is online now
post #4748 of 6175 Old 06-13-2019, 04:14 PM
DLCPhoto's Avatar
Quoted: 1667 Post(s)
Liked: 762
The least expensive option that I'm aware of is the HDFury Linker. The Vertex can also do this, along with a number of other features which can be useful, although at higher cost.
I'm using the UB-820 with a Linker, going to my RS400. No Gamma D, and Dynamic Iris works fine. I'm using a Custom Curve, and so have HDR/BT2020 output from the UB-820 for both discs and Netflix. Overall, I'm pretty pleased with it.
I did some casual, not rigorous, observations comparing this with SDR/BT2020, but with limited testing, I didn't see a big difference. I've just stuck with HDR and it's working well for me.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is offline
post #4749 of 6175 Old 06-13-2019, 04:49 PM
WOKNROX's Avatar
Quoted: 408 Post(s)
Liked: 339
Ok good to know.
I've been following this thread for a while and noticed there was a ton of great info and help but, which HDFury he needed was to one piece of information that was left unclear.
Hope it helped/s him figure out his issues.
post #4750 of 6175 Old 06-13-2019, 09:19 PM
Quoted: 251 Post(s)
I heard the only advantage the Panny 820 would offer over my Sony X800 is if my BenQ LK970 is capable of displaying SDR BT2020. I am going to try to check if the BenQ has this.
docrog: Would the 820 be worth buying even if my BenQ LK970 is not capable of displaying SDR BT2020 if the 820 can upscale DVD and Blu Ray better than my Sony X800?
post #4751 of 6175 Old 06-13-2019, 10:53 PM
docrog's Avatar
Liked: 426
Unfortunately, I'm not able to comment on whether the UB820 is superior to your Sony (or the BenQ) in terms of upscaling legacy source material to 4K. Sorry!
post #4752 of 6175 Old 06-13-2019, 11:54 PM
Quoted: 251 Post(s)
My bad...
post #4753 of 6175 Old 06-14-2019, 10:15 AM
gravi's Avatar
Quoted: 403 Post(s)
Liked: 205
I have a basic question, apologize if it has been answered before. I am using the UB820 in conjunction with the new JVC, and utilizing the "double tone-mapping" (Optimizer on, JVC auto tone map), the results are really good. My question is regarding UHD discs that do not report metadata (Marvel movies, for example). In these cases, how does the Panasonic tone map to 500 nits? Or does it not tone map at all? What is the preferred way to adjust - using the Panasonic controls or JVC controls?
Th601 likes this.
gravi is offline
post #4754 of 6175 Old 06-14-2019, 11:31 AM
Quoted: 5006 Post(s)
Liked: 1926
The UB820 assumes 1000 nits when the title does nor report metadata.
WOLVERNOLE and woodhead2 like this.
Dominic Chan is offline
post #4755 of 6175 Old 06-14-2019, 07:00 PM
DLCPhoto's Avatar
Liked: 762
Turn off Front Panel Display during Netflix viewing?
Since I use my UB-820 with a Projector, I want the room as dark as possible. I have used the "High Clarity Sound" settings to turn off this display when watching Discs, and it works just fine.
I have found, however, that this doesn't work when playing Netflix, such that a bright "NET" is shown on the Front Panel Display.
Has anybody figured out a way to have this turned off as well?
DLCPhoto is offline
post #4756 of 6175 Old 06-14-2019, 07:06 PM
lizrussspike's Avatar
Quoted: 1265 Post(s)
Liked: 1894
I cheated on my solution @DLCPhoto , in my cabinet, I have black velvet that I fold over the top, and the n drop down when watching a movie, to get that dark room theater feeling.
lizrussspike is offline
post #4757 of 6175 Old 06-14-2019, 07:32 PM
EddieVanHalen's Avatar
Quoted: 20 Post(s)
In this universe ANYTHING can upscale better than the Sony X-800 which by default applies some kind of Digital Noise Reduction (maybe to mask aliasing issues when upscaling) that makes the picture lack in detail.
I have both a Sony X-800 and a Panasonic DP-UB420 that shares the same video processing of the 820 and its 4K upscaling trounces the one done by the Sony X-800.
When I only had the Sony X-800 I had its video output set to "Original Resolution" so my Samsung TV did the upscaling when playing BD's and DVD's, now with the Panasonic 420 I let it upscale both BD's and DVD's as it does a great job.
WOLVERNOLE likes this.
EddieVanHalen is offline
post #4758 of 6175 Old 06-14-2019, 07:37 PM
Quoted: 20 Post(s)
Unhappy
In the past when I had a device with a too bright display that couldn't be turned off I used to put my box of Camel in front of the display, it worked great. I don't do that now as quit smoking 9 years ago. I miss those days .
post #4759 of 6175 Old 06-14-2019, 07:43 PM
DLCPhoto's Avatar
Liked: 762
Yeah, it may come down to a low-tech approach. I've used strips of black velvet or even electrical tape to block lights that couldn't otherwise be turned off. It seems like the Front Panel Display *should* be able to be turned off for Netflix, as it is with Disc, but it may have been overlooked by Panasonic.
DLCPhoto is offline
post #4760 of 6175 Old 06-14-2019, 07:48 PM
Quoted: 251 Post(s)
Is it better to stream netflix thru the UB820 or thru my Xfinity cable box? Will the picture be better thru the UB820?
post #4761 of 6175 Old 06-14-2019, 08:07 PM
DLCPhoto's Avatar
Liked: 762
I can't speak to the Xfinity box, but I am quite pleased with Netflix, whether SDR or HDR, with my UB820, to my JVC RS400 Projector. Very solid performance, with virtually no stuttering ever. And with HDR, you do get the benefit of Tone-Mapping, Optimizer, etc. (though I think your BenQ doesn't do HDR, so this would be less important for you).
One little glitch that I and others have noted, though: it seems the Audio-Video Delay/Sync is different for Disc output vs Netflix output, with the UB820. I have to set my AVR Delay differently depending on which I'm watching. With my Harmony Hub and Remote, I recently programmed in a sequence of commands to change the AVR when watching Netflix, and changing it back when I'm done, which works well as a work-around. But I'd prefer it wasn't there to begin with.
DLCPhoto is offline
post #4762 of 6175 Old 06-14-2019, 08:37 PM
Quoted: 251 Post(s)
Cool my Xfinity box that has Netflix does a great job with no stuttering at all. Just wondering if the video might be better from a BD player?
post #4763 of 6175 Old 06-15-2019, 05:24 AM
hifi59's Avatar
Quoted: 50 Post(s)
Liked: 65
According to my traveling calibrator, whom I consider the best in the business, pick Panasonic for best tools and PQ and Sony for best sound. Sony also tracks scratched discs slightly better. He owns both the Panny 820 and Sony X800 for these reasons in his home theater room.
If you're talkin, you ain't learnin.
hifi59 is offline
post #4764 of 6175 Old 06-15-2019, 06:30 AM
Crow351's Avatar
Curious if this is also the case with the X800M2. As the X800 was released two years prior and without DV support, it may have less robust processing capabilities. Possible that BD upscaling has improved and closed the gap some?
Crow351 is offline
post #4765 of 6175 Old 06-15-2019, 08:05 AM
Liked: 0
Hi. I'm experiencing some sync issues with my ene unit which I bought a few days ago.
I believe this only happened in the last day or so but maybe it was there from the beginning and I just didn't notice. Audio is slightly out of sync with video on every 4K Blu-ray I try, Netflix too. I have to set delay at 90ms to fix it but I'd prefer not to do this and just get some kind of fix.
Had anyone else experienced this?
ColtMrFire is offline
post #4766 of 6175 Old 06-15-2019, 06:44 PM
Quoted: 28 Post(s)
Liked: 5
Hi guys
We are about to pull the trigger on the Panny 820, but read on different places the Panny has trouble reading BD-R, there´s a moment when audio just disappears, you need to pause the video, play again and audio comes back, however it will happen again some time later.
Any experiences about this?
Eva2016 is offline
post #4767 of 6175 Old 06-15-2019, 08:58 PM
Quoted: 20 Post(s)
You're 100% right IMO. I got the Sicario 2 steelbook from Zavvi when it was released and the UHD BD came with a small side scratch. At that time I only had the Sony X-800 and the disc played with no issues,but when I got the Panasonic 420 two months ago at a certain point of the movie it froze, picture broke into macroblocking, sound had digital glitches and at one point it skipped around 3 minutes forward. I tried the disc again on the Sony X-800 and it played fine.
I eventually got a new disc two or three weeks ago from Zavvi when they had a 2 UHD BD's for 32 Euros includding shipping, I like both the movie and the picture quality of the Panasonic and I didn't have Gladiator so it was a good chance to get it on UHD BD and a replacement disc for my Sicario 2 Steelbook.
hifi59 likes this.
post #4768 of 6175 Old 06-16-2019, 12:43 AM
bolmsted's Avatar
Quoted: 12 Post(s)
I'm trying to get my DP-UB820 working with my Denon AVR-4310CI and my Samsung KS8000 TV. I have the video going to the TV no problem, but when I try to hear the audio through the HDMI out to the AVR I get nothing.
I have checked and I have Auto for the HDMI video and Audio Only for the HDMI audio. I confirmed the port is fine for the AVR as I swapped another device into that port and get audio as part of my troubleshooting.
I understood the point of the additional HDMI port was for this exact situation.
Any ideas what is going on?
I have the latest firmware and an odd annoyance is that the sub menus exit you without doing anything and you can't change things easily or you think you did it and can't. I think this is a bug with this firmware. (I think it is 1.55 IIRC, so perhaps I can downgrade?)
Maybe I have to call Panasonic Canada on Monday.
I only noticed this when I unplugged the optical cable from the TV going to the AVR on my "TV" input set to optical 1 on the AVR and then no audio on HDMI1.
Not really getting much help from this document.
http://eng-ca.faq.panasonic.com/app/...ail/a_id/43497
http://eng-ca.faq.panasonic.com/app/...7937/related/1
Help would be gladly appreciated. Bought box around mid-May so my 30 days be close but perhaps they will do something considering I've only played with the player briefly to check out video but this is weird.
bolmsted is offline
post #4769 of 6175 Old 06-16-2019, 06:18 AM
bolmsted's Avatar
Quoted: 12 Post(s)
Originally Posted by ratskrad View Post
I picked up a UB820 yesterday to replace my UB900 so as to be able to use the Dolby Vision instead of HDR10 for movies. I have encountered a couple of issues with one being DV does no pass through my receiver (Yamaha RX-A3070 latest firmware that supports DV pass through and only six weeks old bought new and I have posted in the Yamaha thread as to this issue) and the other being I can hook up the UB820 directly to my TV and get DV to work but the Audio out sends no sound to my receiver. I have the Audio out set to Audio out only and the Video is set to Auto. Latest firmware on the UB820 as well. I have reset both the factory defaults and set them up again but no go as to both of these issues. Sound wise I run Straight on my receiver with Bitstream out on the UB820 and it works great sound wise when running a single cable but it only comes across as HDR10 for playback. Well kinda stumped here and I am most of the time pretty good with getting things to work as they are supposed to. Using Monoprice certified HDMI cables, guess I could go out and spend $200 on some AudioQuest HDMI cables but not sure that will make a difference as hooked up directly to TV I get DV to work as well as the good sound when running into the receiver running only one cable. I have also read pages and pages as well as doing many a search on both threads as to a fix but was not able to really find one as I find the search feature on this site leaves much to be desired.
Did you get a resolution to this? I seem to experience the same thing
DP-UB820 -----------> Denon AVR-4310 (can play Dolby TruHD/Master DTSHD) (audio)
+------------------> Samsung KS8000 (video)
I confirmed that HDMI port on my Denon AVR4310 is working properly by hooking up my Oppo BDP103 to the port that I was hooking up the audio for the Panasonic DP-UB820
I reset factory defaults as I had played with them before. I had my TV inputting audio via optical into the receiver and that's how I was getting sound (5.1 Dolby I guess) before but I can't get the sound from the player directly to the receiver. What's going on here? Something so simple
bolmsted is offline
post #4770 of 6175 Old 06-16-2019, 06:38 AM
woodhead2's Avatar
Quoted: 89 Post(s)
Just got mine this weekend, and I have the same problem. Audio is just a hair off.
woodhead2 is offline
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
