Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 193 - AVS Forum | Home Theater Discussions And Reviews
 5038Likes
post #5761 of 5994 Old 09-14-2019, 06:37 AM
Quoted: 4884 Post(s)
Liked: 1847
Originally Posted by evanft View Post
Yes, but this corresponds to 350 nits wine using the SDR output selection. Per Kris Deering, lowering th value raises this number, so to tone map to 575 you’d have to lower the slider by about 11 in my case.
Where did you see “each level is about 20 nits” stated? It doesn’t sound right to me.
Dominic Chan is online now
post #5762 of 5994 Old 09-14-2019, 06:38 AM
evanft's Avatar
Quoted: 75 Post(s)
Liked: 35
It’s a ballpark based on the fact that +12 corresponds to 100. So each level is about 20, assuming it’s linear and true in both directions, of course.
JVC RS-520, Elite Screens 100" AcousticPro UHD electric
Klipsch RP-8000F, RP-450C, 2xRP-240S, 2xRP-402S, 2xSVS PB-1000
Onkyo TX-NR585/HDFury Linker/MiniDSP 2x4 HD
Panasonic UB820/PC/PS3/PS4 Pro/Switch/WiiU/Xbox One X
Logitech Harmony Hub
evanft is offline
post #5763 of 5994 Old 09-14-2019, 06:46 AM
Liked: 1847
Theses settings are definitely not linear; they are more like logarithmic.
post #5764 of 5994 Old 09-14-2019, 06:58 AM
evanft's Avatar
Quoted: 75 Post(s)
Liked: 35
Not surprised based on my experience just now with the lowered range setting. Do we have a way to test what each level corresponds to?
evanft is offline
post #5765 of 5994 Old 09-14-2019, 08:26 AM
Liked: 1847
My projector has 108 nits peak and these are the measured results of the "diffused white" level (50% input) at 3 settings of the Dynamic Range Conversion Adj. The listed multiplier are based on 94.4 nits.
+6: 36 nits, 2.6X
0: 26 nits, 3.6x
-6: 15.8, 6.0x
EDITED to correct previous error. Also see follow-up post.
post #5766 of 5994 Old 09-14-2019, 09:13 AM
evanft's Avatar
Quoted: 75 Post(s)
Liked: 35
+6: 19.6 nits, 4.8X
0: 26 nits, 3.6x
-6: 38.3, 2.5x
Oh this are brilliant. So the 50% measurement is getting dimmer as the slider moves to the right? How do you use this info to pick the 5x multiplier?
evanft is offline
post #5767 of 5994 Old 09-14-2019, 09:44 AM
claw's Avatar
Quoted: 2318 Post(s)
Liked: 2173
This is a response from Kris Deering posted elsewhere....
With 120 nits you are looking at a multiplier of around 500-600. The default is 350 for the slider, so you want to turn it DOWN. Again, middle is 350 and all the way up is 100, so each change in the slider is approximately 20 nits. So go down to roughly 500 (7-8 clicks) and that should be a good starting point.
Remember, tone mapping is always a trade off. When using the slider the brighter the image you make (lower multiplier) the less overall dynamic range you have. The darker the image you select (higher multiplier) the more overall dynamic range you'll have. I think a range between 4 and 6x works best with most material, which is why I recommend people start around 5x. But some people want a brighter image and some people like more contrast, so tailor to your taste. There really isn't a "wrong" selection.
With 120 nits from the projector he suggested starting at 7-8 clicks to the left as a starting point.
Then adjust to taste. Lower for more contrast. Higher for more brightness.
I wish I could get 115 nits. I don't and leave the the slider at its default 350 nit position and then raise it one or two clicks when watching darker movies. I lower it by one or two clicks when watching very bright movies.
atabea likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is online now
post #5768 of 5994 Old 09-14-2019, 06:26 PM
Liked: 1847
Sorry, the previous results were somehow mixed up. Here are the new measurements which make more sense:
Slider/nits/multiplier
12 44.4 2.1
9 41.8 2.3
6 37.5 2.5
3 32.8 2.9
0 26.8 3.5
-3 20.9 4.5
-6 16.4 5.8
-9 11.8 8.0
-12 8.7 10.9
post #5769 of 5994 Old 09-14-2019, 11:11 PM
Rieper's Avatar
Quoted: 283 Post(s)
Liked: 119
Can anyone tell me the difference between the the Panasonic DP-UB820 & DP-UB420 besides Dolby Vision support? I can't imagine having DV support is the main reason for the $250 price difference. The housing, and the remote look identical. So what am I missing??
Also, has the DP-UB420 come out yet? I cant find it anywhere on Amazon, and Best Buy has a product page for it, but listed as "Coming Soon".
Any help appreciated. Thanks!
Rieper is offline
post #5770 of 5994 Old 09-15-2019, 03:29 AM
DLCPhoto's Avatar
Quoted: 1593 Post(s)
Liked: 714
Discrete IR Codes for the HDR Dynamic Range Slider??
One of the advantages of this player is the Dynamic Range Slider used when playing HDR content. As we all know, especially with Projectors, this needs to be tweaked for different content to achieve optimal results, because of inaccurate or absent metadata, etc.
Accessing this adjustment requires several button pushes, with stuff all over the screen, so it's very intrusive if you're watching when you have people over.
Does anybody know, have access to, or a link that contains a discrete IR code for that specific function, such that when you use it, the slider appears at the bottom of the screen, where it can be adjusted, and then removed?
I've automated the keystrokes with Control4, but it still has to call up the other screens to get there. I wanting to program in the proper IR code, if there is one, to go directly to engage that slider.
Anyone?
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #5771 of 5994 Old 09-15-2019, 04:27 AM
docrog's Avatar
Quoted: 1157 Post(s)
Liked: 407
The DP-UB420 is not available for sale in the US and I haven't seen any press releases to suggest that when/if it will be. It has been available in Canada much of this year. Much smaller than the DP-UB820 but technically identical, other than lack of DV and no 7.1 analogue audio outputs; same remote but no front panel readout.
JVC NX7, Yamaha RX-A3080 (2 discrete 7.2.4 speaker layouts: Dolby Atmos & DTS:X), Panasonic UB820, Panasonic UB420, Oppo 103D, ATV4K, Roku Ultra, TiVo Bolt Vox, Vandersteen Model 3 Signatures & VCC-1 Signature, Atlantic Technology (side, rear, front height & overhead) surrounds, SVS SB-2000 (2), Clark Synthesis Tactile Bass Transducers (2), Polk PSW-12
docrog is offline
post #5772 of 5994 Old 09-15-2019, 07:04 AM
xenofin's Avatar
Quoted: 16 Post(s)
Just managed successfully program my 820 player as DVD region free using a very old One For All URC-8206 "Kameleon 6" remote and codes I found by googling around the net. I have not yet found satisfactory Bluray hardware mod.
7.1.4 Dolby Atmos system: Denon AVR-X4500H, Sony DA2400ES, 2xMonitor Audio Silver RS6, 2xRS1, 2xRadius 90, Radius 225, 4xDali Alteco C-1, BK XLS200, JVC N5BE with Ruipro 10m fibre HDMI cable, Grandview Fixed 4K Edge 100" (1.0), Panasonic DP-UB824, Sony BDP-S790, Topfield FHD DVR, Sony FHD 46" TV, Denon DP-450USB, Logitech Harmony Hub + Samsung S4 TAB, Hi-Shock RF Pro Black Diamond + XPand X-105-RF 3D glasses
xenofin is offline
post #5773 of 5994 Old 09-15-2019, 07:27 AM
Quoted: 226 Post(s)
Liked: 113
What’s a DVD?
Spizz, gomo657, MOberhardt and 1 others like this.
Johnson-from-Arizona is offline
post #5774 of 5994 Old 09-15-2019, 07:34 AM
Pip
Pip's Avatar
Quoted: 335 Post(s)
Liked: 149
Good work! Care to share any leads?
Pip
Pip is online now
post #5775 of 5994 Old 09-15-2019, 10:58 AM
evanft's Avatar
Quoted: 75 Post(s)
Liked: 35
12 44.4 2.1
9 41.8 2.3
6 37.5 2.5
3 32.8 2.9
0 26.8 3.5
-3 20.9 4.5
-6 16.4 5.8
-9 11.8 8.0
-12 8.7 10.9
So what should that multiplier be in an ideal scenario?
evanft is offline
post #5776 of 5994 Old 09-15-2019, 12:05 PM
xenofin's Avatar
Quoted: 16 Post(s)
Pip
I actually found those codes from avforums.com site. Depending on the IR remote type, programming these codes to buttons changes a bit so check the manual.
I used my remote's Magic Button + Key magic function. First you program these codes, 5 digits, behind OFA buttons; I used number buttons 1,2...,0.
Here are the codes:
00191, 00120, 00065, 00180, 00143, 00155, 00122, 00117, 00129, 00123.
After this you just select Dvd device in OFA and press buttons in programmed order. Player will shut down and restart after which you send code 5198 during start up phase.
And player is Dvd region free. I tested it with R3 dvd. My player's default was R2.
xenofin is offline
post #5777 of 5994 Old 09-15-2019, 02:48 PM
Liked: 0
Here are the codes:
If you try this on a US device, all you get is a "cannot play" message for non-NTSC DVDs.
In addition to that, it doesn't make sense to discuss specific topics on this board if moderators censor information...
BerndH is offline
post #5778 of 5994 Old 09-15-2019, 03:42 PM
docrog's Avatar
Liked: 407
I seem to have found another difference between the 820 & 420. Despite my 420 having the current firmware (1.60), it does not show the nits IN & OUT (HDR10 Metadata) as the 9000 & up to date 820 are capable of achieving. This deficiency is basically irrelevant to me, since the relevant data is able to be displayed on my projector's information menu screen.
Rieper likes this.
docrog is offline
post #5779 of 5994 Old 09-16-2019, 12:50 AM
docrog's Avatar
Liked: 407
Thanks for the relevant info. May I ask how you acquired the 420? Did u import it from Canada or bought off eBay?
I acquired the UB420 as a birthday present from a close friend who lives in Toronto.
docrog is offline
post #5780 of 5994 Old 09-16-2019, 07:16 AM
docrog's Avatar
Liked: 407
Hmm, well I'm in New York city. Might have to make a weekend car trip to Montreal for some poutine and check out the local BB's in the area. Thanks again.
In case you were being serious about driving up to Canada, the Canadian Best Buy website indicates that the UB420 is only available online without any shipping option to the US.
docrog is offline
post #5781 of 5994 Old 09-16-2019, 09:36 AM
Rieper's Avatar
Quoted: 283 Post(s)
Liked: 119
I was being sincere, I love the city of Montreal. Visited at least a dozen times over the years.
And thanks for the heads up! Will call ahead and see if I can order online for instore pickup.
Rieper is offline
post #5782 of 5994 Old 09-16-2019, 02:40 PM
docrog's Avatar
Liked: 407
I lived there from 1973-1976, during the great political upheaval leading up to the Olympics in Montreal. I haven't been back since and, truly, have no interest in returning. I'm glad that you find it to your liking.........
Rieper likes this.
docrog is offline
post #5783 of 5994 Old 09-16-2019, 05:39 PM
docrog's Avatar
Liked: 407
Does any owner of the UB820/9000 make use of the "System Gamma" adjustment? If so, under what circumstances? Thanks!
Bytehoven and monkaquinas like this.
docrog is offline
post #5784 of 5994 Old 09-19-2019, 09:57 PM
SoonerDoc's Avatar
Quoted: 69 Post(s)
Liked: 25
Is this thread still alive?
SoonerDoc is offline
post #5785 of 5994 Old 09-20-2019, 01:52 PM
Liked: 9
Until there’s a new update...
C8UB820 is offline
post #5786 of 5994 Old 09-21-2019, 01:08 AM
danbez's Avatar
Quoted: 65 Post(s)
Liked: 24
@claw - when watching Netflix (HDR), how you define the settings below (assuming a JVC proj)
- HDR TV Type: always set to Basic Luniance LCD and Projector?
- Under HDR Optimizer, what do you have for the range adjustment?
- do you change anything else - such as Tone Curve White and Black?
I have ~105 nits on HDR mode (RS 500, Arve curve).
I just want to get some baseline numbers to start playing tomorrow.
danbez is online now
post #5787 of 5994 Old 09-21-2019, 09:29 AM
claw's Avatar
Liked: 2173
I don't use a fixed setting for either the Dynamic Range Adj. slider (HDR) or the Dynamic Range Conversion Adj. slider (SDR/BT2020). I adjust them based on the content. I leave the sliders at default for most content, raise the sliders a couple of clicks for darker content, and lower a click for extremely bright content. There is no right or wrong setting value. Up to you whether you prefer more brightness or more shadow detail contrast.
I don't adjust any other settings other than HDR TV Type set to Projector.
CJ
claw is online now
post #5788 of 5994 Old 09-21-2019, 11:01 AM
danbez's Avatar
Quoted: 65 Post(s)
Liked: 24
Thanks Claw!
post #5789 of 5994 Old 09-21-2019, 11:03 AM
bobbino421's Avatar
Quoted: 1244 Post(s)
Liked: 785
Hi guys this is not a specific 820 question but being that the 820 does have special video features that other players don’t, does anyone with an AVR run their 820 directly to their TV and then run the audio out to their receiver? What are the pros and cons to doing this? I was wondering if the video signal would be better and somehow improved directly connected to tv?
My AVR is a Denon X4500H which can pass any signal. But I’m wondering if the tone mapping is affected when passing through the AVR when connected through the receiver also?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Samsung HW-K950 Dolby Atmos sound bar
bobbino421 is offline
post #5790 of 5994 Old 09-21-2019, 11:49 AM
Bytehoven's Avatar
Quoted: 1377 Post(s)
Liked: 1087
For convenience, routing thru the AVR is my preference. I have the Denon 4300, and the pass thru options eliminate any impact on the video signal, such as affects on tone mapping you reference.
If the AVR did not offer complete pass thru, direct connections would solve the problem, but for a limited number of devices.
JVC DLA-X990 (RS640) - 128" 2.35 1.3 Gain Screen - Panasonic UB820 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
