Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 204 - AVS Forum | Home Theater Discussions And Reviews
 5296Likes
post #6091 of 6755 Old 11-07-2019, 05:20 PM
tngiloy's Avatar
Quoted: 510 Post(s)
Liked: 333
Originally Posted by cgott42 View Post
where is the ir sensor on the UB820 located?
See attachment. If you are wanting to place a remote flasher on the 820, it is kind of hard because it is behind the flip-down faceplate. There really isn't a way to place it directly over the sensor, behind the faceplate, and have the faceplate close completely.
If you place the remote sensor on the faceplate I'm not sure it would work with the faceplate open- which it is when the tray is open.
FWIW it seems to be responsive to remote commands and not terribly picky about needing to aim directly at the 820 in my use.
Bytehoven likes this.
"When all else fails, read the manual."
tngiloy is offline
post #6092 of 6755 Old 11-07-2019, 07:37 PM
edfowler's Avatar
Quoted: 347 Post(s)
Liked: 182
The Panasonic UB420 has the same sensor configuration as the 820. I dangle the IR blaster a couple of inches in front of the sensor on my 420 and it works just fine.
tngiloy likes this.
Chad B calibrated JVC RS600, 112" wide 2.35 DaLite 2.8 High Power Screen (395 calibrated nits baby!!), 7.5.4 Yamaha RX-A3050, Yamaha RX-Z9, Aerial Acoustics Model 6, Model 5, CC3, Def Tech UIWBP/A, 4-15" Infinite Baffle Sub + 15" Velodyne Sub Near-field, OPPO 203, Panasonic UC420, Geek Pulse DAC, Nvidia Shield. Lots of iFi and Furman power filters which made my computer audio listenable.
edfowler is online now
post #6093 of 6755 Old 11-07-2019, 07:38 PM
AncientAlien's Avatar
Quoted: 188 Post(s)
Liked: 36
If my TV only does 4:4:4 on PC Mode do I need to put the "4K/60p Output" Setting on something other than 4:4:4? Or does it matter?
AncientAlien is offline
post #6094 of 6755 Old 11-07-2019, 09:33 PM
cgott42's Avatar
Quoted: 229 Post(s)
Originally Posted by Dominic Chan View Post
See p.9 of the manual:
thanks that worked, I taped the IR blaster on that spot - works great. The lid doesn't close fully but only a very small gap.
Anyway - would there be anything wrong if I left it without closing, or even fully open for that matter?
cgott42 is offline
post #6095 of 6755 Old 11-07-2019, 09:45 PM
cgott42's Avatar
Quoted: 229 Post(s)
Can you use the remote (for UB820) to control the volume on the Denon AV Receiver? Or the volume that the UB820 sends to the AV receiver? (I have a harmony Elite remote , but I only have this Panny and the AV receiver - and I prefer the button layout on the panny remote to that of the Harmony
thx
cgott42 is offline
post #6096 of 6755 Old 11-07-2019, 09:57 PM
Quoted: 5391 Post(s)
Liked: 2135
thx
Yes, see p.8 of the owners manual.
Dominic Chan is online now
post #6097 of 6755 Old 11-08-2019, 03:13 AM
Quoted: 45 Post(s)
DTS not is supported, only DD, problem with DTS can be easily resolved just turn off bitstream but after this avr got multichannel sound this mean you don't get dts:X metadata.
bl4ck is offline
post #6098 of 6755 Old 11-08-2019, 05:18 AM
cgott42's Avatar
Quoted: 229 Post(s)
thx
the manual only has codes for TV. no code listed for Denon AVR
cgott42 is offline
post #6099 of 6755 Old 11-08-2019, 06:54 AM
Liked: 2135
The CEC Control feature (Viera Link etc) allows using the TV’s remote to adjust the volume of the receiver. If, in addition to that, you also program the UB820 remote to emulate the TV volume control, that may do you you want, but I haven’t tried it.
post #6100 of 6755 Old 11-08-2019, 07:02 AM
cgott42's Avatar
Quoted: 229 Post(s)
I don't have a TV - I use a projector
cgott42 is offline
post #6101 of 6755 Old 11-08-2019, 07:11 AM
Liked: 2135
There is no difference between TV and projector in this context, as long as the remote code works.
EDIT: most projectors do not have a volume control, so that may not work.
post #6102 of 6755 Old 11-08-2019, 08:28 AM
joshua goard's Avatar
Quoted: 1438 Post(s)
Liked: 699
Originally Posted by bo55554r View Post
i have frimware 1.6
wireless lan 1.2
NO trueHD and NO DTS-HD NO Atmos output from USB
no DD and no dts output from USB
amazon broadcast in experiment ( Not paid )- only PCM 48 HZ 2 CH
anyone know where to hear on network, DD or DTS quality to check?
Is Netflix working? Honestly, this isn't the best streaming player and definitely not a good choice for USB file playback either. You're much better off uploading your library to Plex and streaming them that way. That's how I play my rips. Just make sure the computer with the server on it is plugged in to ethernet and not Wifi...I get Atmos and DTS:X over plex with my 4k rips. The Sony x700 was much better for USB videos but again, no TrueHD with MKV, but it did play M2TS files with TrueHD just fine.
Sony 75xZ9D connected to Panasonic UB820 and Nakamichi Shockwafe 7.1 Pro Atmos
Sony 55x900e
Sony 55xA1E
Sony 75x940e (Returned :-( bad motion blur)
Sony 75x900e, Sony 75x940d, Sony 55x930d, 55x810c, Sony 55x850c (All retired)
joshua goard is offline
post #6103 of 6755 Old 11-08-2019, 09:24 AM
cgott42's Avatar
Quoted: 229 Post(s)
Also, I don't see a code for Denon listed
cgott42 is offline
post #6104 of 6755 Old 11-08-2019, 09:27 AM
cgott42's Avatar
Quoted: 229 Post(s)
Doesn't the UB820 process the streaming videos also to improve the video quality. Plus for those with some slightly older JVC projectors - doesn't it convert the HDR to SDR? i.e. woudn't it provide better PQ (and HDR PQ) that other (e.g. Roku or Shield) streamers?
cgott42 is offline
post #6105 of 6755 Old 11-08-2019, 11:52 AM
Liked: 699
no DTS via USB
no DTS-HD via USB
no dts:X via USB
I literally just played a 4k rip of Planet Earth 2 with is DTS 5.1 from an external hard drive yesterday. Ripped it myself using makemkv. Rear USB from a usb 3.0 external hard drive formatted to ExFat.
Sony 55x900e
Sony 55xA1E
post #6106 of 6755 Old 11-08-2019, 05:09 PM
Liked: 699
thank you for your help !
1. formatted to ExFat the USB 3 connector
2. i downloaded sound files from this site for review in 820
https://thedigitaltheater.com/
it works wonderfully on PC and Blue Ray OPPO
in Blue Ray Panasonic nothing works in sound via USB
NO DTS 5.1 / NO DD 5.1 / NO DTS-HD /no TrueHD
the only thing that works in 820 is the 2 channel Dolby Digital soundtrack
or
2 channels DTS
So I know the file has DD 5.1 but it also contains the 2.1 audio, it may have used the 2.1 stream. But my point is this blu ray player sucks for USB files. Better off using the plex app on your tv or xbox or something like that...
Sony 55x900e
Sony 55xA1E
post #6107 of 6755 Old 11-08-2019, 08:25 PM
Quoted: 188 Post(s)
Liked: 36
I recently asked about 4:4:4 a few posts ago. Wanted to clarify and add to it.
My Samsung Q6FN only does 4:4:4 when renaming an Input to PC. Not currently doing that nor plan to but I do have the (4K/60P Output) on the 820 set at 4K/60P(4:4:4). Is this the correct setting if I'm never going to be getting 4:4:4 on the TV?
Also,
The Q6FN is a 10 Bit TV. I currently have the (Deep Color Output) setting on the 820 at Auto(12 Bit Priority). Is this the correct setting or is there a 10 Bit setting I need to switch to?
Sorry for the noob questions but im new to 4K and a bit confused with all the settings.
Thanks in advance.
post #6108 of 6755 Old 11-08-2019, 11:55 PM
Quoted: 45 Post(s)
Because it is no longer produced.
bl4ck is offline
post #6109 of 6755 Old 11-09-2019, 12:06 AM
Kage's Avatar
Quoted: 124 Post(s)
I was watching Wonder Woman (2017) and within 2 hours in the movie there was a slight layer change freeze, the ub820 timer froze up, and the remote stop sending commands to the unit, but the movie kept on playing. The same thing happened as well in The Man of Steel. Is this a common issue with the earlier 4K movies from Warner Bros with the ub820?
Kage is offline
post #6110 of 6755 Old 11-09-2019, 08:26 AM
Liked: 699
if not TrueHD So all the movies in this format without the sound?
the Blue Ray doesn't know how to convert another sound.
and if there is none TrueHD no Atmos So why need 4K Via USB ?
DTS:X in Sony x700 work Via USB ?
in 820 Panasonic No other format conversion !
in 820 Panasonic - Panasonic guarantees conversion of PCM 48KHZ to 192 KHZ
but in receiver testing you can get only 48KHZ ( no 96 khz no 192KHZ )
i don't understand how Panasonic puts out a product so poorly, and promises elements
that do not work without updates and there is no support for Panasonic
Getting atmos over USB on the Sony x700 only works with M2TS files not mkv. So you can get atmos over USB, you just have to rip your 4k movies to M2TS rather than mkv.
Sony 55x900e
Sony 55xA1E
post #6111 of 6755 Old 11-09-2019, 11:43 AM
bobknavs's Avatar
Quoted: 2506 Post(s)
Liked: 1783
Not for me.
monkaquinas likes this.
bobknavs is offline
post #6112 of 6755 Old 11-09-2019, 12:01 PM
Pip
Pip's Avatar
Quoted: 371 Post(s)
Liked: 178
Unfortunately, the 820 can only convert HDR to SDR from Amazon prime. Due to a flaw with the Netflix app, it cannot do this conversion for Netflix. The best it can do for projectors with Netflix is to apply the HDR optimizer. This is usually a very subtle improvement.
Also unfortunately, the Amazon prime app on the 820, is so problematic that it’s almost useless. The Amazon prime app is fraught with problems on many devices – not just the 820.
Pip
Pip is offline
post #6113 of 6755 Old 11-09-2019, 12:21 PM
Liked: 2135
To use it in the way I described (assuming it works) you would select the brand of the TV/projector, not the brand of the receiver.
post #6114 of 6755 Old 11-10-2019, 06:29 AM
mrtickleuk's Avatar
Quoted: 5362 Post(s)
Liked: 7751
it makes no sense why close a Blue Ray OPPO division it's worth 50-100 million dollar .
People will always look for Quality processor, image quality improvement, Blue Ray, USB connection, streaming
These are all questions for 18 MONTHS ago, not today, and not this thread
tngiloy and MechaGodzilla like this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #6115 of 6755 Old 11-10-2019, 07:19 AM
Liked: 699
and now a generation of HDMI 2.1 starting up will bring a new rash to close the company?
like oppo ?
OPPO has received publicity and fame thanks to its Blue Ray device
no sense, something we are not told.
cambridge Audio CXUHD 4K Instead of developing the same device, closed the production line?
after OPPO left her in the ring alone ?
no logic
And Oppo didn't have streaming either in their 203...I think we should be done with your rants. I think we all know you're disappointed with the player. I think it's time to either accept it's limitations or return it and move on.
65Goat, gomo657, tngiloy and 1 others like this.
Sony 55x900e
Sony 55xA1E
post #6116 of 6755 Old 11-10-2019, 08:04 AM
gomo657's Avatar
Quoted: 841 Post(s)
Liked: 843
I’m really trying to understand why we’re entertaining the rants of someone that can’t spell blu-ray correctly. It’s obvious they don’t understand what players and previous players are/were capable of.
mrtickleuk likes this.
"well you know what doctor I'm going to go home take two aspirins and call you a b****"
gomo657 is offline
post #6117 of 6755 Old 11-10-2019, 09:00 PM
SubElement's Avatar
Quoted: 43 Post(s)
Can someone help me with this Dolby Vision and "low-latency" Dolby Vision thing? I am so incredibly confused...
In discussing if DV should be output in BT.2020 with someone on another forum they mentioned this:
If your bluray player outputs the "real" DV, which is an RGB signal containing the actual data stream, your TV will probably *not* say bt2020 along with DV. Also your receiver should be able to tell you what video signal is incoming and outgoing. RGB 24 bit incoming should be reported if the real DV is being sent. if low latency DV is being sent it'll say ycbcr 422 12bit.
So what is the UB820 doing here? Should it be RGB? Or YPbCr?
SubElement is offline
post #6118 of 6755 Old 11-10-2019, 09:43 PM
Liked: 699
You can set color space to auto and the player will figure it out. You don't need to get into the weeds.
Sony 55x900e
Sony 55xA1E
post #6119 of 6755 Old 11-10-2019, 09:46 PM
SubElement's Avatar
Quoted: 43 Post(s)
Oh yes, I agree completely. But they seem to be implying that if it isn't outputting in RGB it isn't correct. I just wanted to try and understand what is going on between these two revisions of DV.
post #6120 of 6755 Old 11-11-2019, 06:26 AM
tngiloy's Avatar
Quoted: 510 Post(s)
Liked: 333
i returned the product!
the product is not salable to customers!
there is no end to his flaws!
The UB820 has worked flawlessly for me from day one.
But I was looking for a very good video disc player, which it is.
Maybe you'll do a little more investigating and find a component that actually does what you want it to do next time.
Good luck and goodbye.
tngiloy is offline
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
