Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 205 - AVS Forum | Home Theater Discussions And Reviews
 5296Likes
post #6121 of 6754 Old 11-11-2019, 07:44 AM
joshua goard's Avatar
Quoted: 1438 Post(s)
Liked: 699
Originally Posted by SubElement View Post
Oh yes, I agree completely. But they seem to be implying that if it isn't outputting in RGB it isn't correct. I just wanted to try and understand what is going on between these two revisions of DV.
I am uncertain but I've never had to even look. I just assumed it was outputting correctly because it looked awesome...I am not even sure what "low latency" DV is...I know there are different "Profiles"...some for disc and some for streaming I believe.
Sony 75xZ9D connected to Panasonic UB820 and Nakamichi Shockwafe 7.1 Pro Atmos
Sony 55x900e
Sony 55xA1E
Sony 75x940e (Returned :-( bad motion blur)
Sony 75x900e, Sony 75x940d, Sony 55x930d, 55x810c, Sony 55x850c (All retired)
joshua goard is offline
post #6122 of 6754 Old 11-11-2019, 08:42 AM
claw's Avatar
Quoted: 2544 Post(s)
Liked: 2384
Can someone help me with this Dolby Vision and "low-latency" Dolby Vision thing? I am so incredibly confused...
In discussing if DV should be output in BT.2020 with someone on another forum they mentioned this:
So what is the UB820 doing here? Should it be RGB? Or YPbCr?
With most Dolby Vision TVs, the player sends a 4K24 RGB 8-bit signal to the TV. All the Dolby Vision good stuff is wrapped inside of the RGB container. The TV then decodes the signal and processes the Dolby Vision input.
But Sony TVs don't have the ability to decode and process that full Dolby Vision signal. So Sony worked with Dolby to implement what they call Low Latency Dolby Vision or LLDV. In this case the player does most of the work. It decodes the Dolby Vision content, processes it, and outputs a 4K24 4:2:2 BT2020 12-bit Dolby Vision signal to the Sony TV.
With Sony TVs, 4K24 4:2:2 BT2020 12-bit Dolby Vision is correct.
With other brands of Dolby Vision TVs, 4K24 RGB 8-bit Dolby Vision is correct.
Note there are some TVs such as LG OLEDs that can accept and process either signal.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #6123 of 6754 Old 11-11-2019, 08:57 AM
SubElement's Avatar
Quoted: 43 Post(s)
Okay thank you, would you mind helping me out here because maybe I'm reading these incorrectly. This is what initially started the discussion. This is the HDMI info panel on my LG C9 with:
nVidia Shield Pro outputting Netflix Dolby Vision. Seemingly RGB 8bit in 709
https://imgur.com/a/ufy53Qs
UB820 playing The Matrix in Dolby Vision. Seemingly RGB 8bit in 2020.
https://imgur.com/a/KRnzGz7
Which is "correct"? Should the nVidia Shield Pro be in 2020? Am I misunderstanding how all this should work?
SubElement is offline
post #6124 of 6754 Old 11-11-2019, 11:53 AM
cgott42's Avatar
Quoted: 229 Post(s)
Originally Posted by Pip View Post
Unfortunately, the 820 can only convert HDR to SDR from Amazon prime. Due to a flaw with the Netflix app, it cannot do this conversion for Netflix. The best it can do for projectors with Netflix is to apply the HDR optimizer. This is usually a very subtle improvement.
Also unfortunately, the Amazon prime app on the 820, is so problematic that it’s almost useless. The Amazon prime app is fraught with problems on many devices – not just the 820.
Pip
The 820 has stunning PQ for UHD , and HDR makes a huge difference - however (fortunately) there's a ton of the 4K content via streaming.
So what do people with such projectors that need the HDR conversion (e.g some JVC) do for streaming to get the full (or close enough to it) HDR improvement?
cgott42 is offline
post #6125 of 6754 Old 11-11-2019, 12:12 PM
Bytehoven's Avatar
Quoted: 1606 Post(s)
Liked: 1260
I recently purchased the Apple ATV4K 64 and I have the Roku Ultra and Netflix on the UB820.
Of those three, my new favorite is the Apple ATV4k because it is working with the HDFury Dolby Vision LLDV EDID hack. You can read more about it at the link in my sig.
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - Vertex2 - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #6126 of 6754 Old 11-11-2019, 01:11 PM
Quoted: 5390 Post(s)
Liked: 2135
The first post in that thread does not seem to mention the ATV4K?
Dominic Chan is online now
post #6127 of 6754 Old 11-11-2019, 01:26 PM
Bytehoven's Avatar
Liked: 1260
Thank you dominic, I did have added a reference in the 1st and 3rd posts, in addition to where the ATV4K is mentioned later in the thread.
I will edit and consolidate the 1st three posts, to better summarize what we know so far.
post #6128 of 6754 Old 11-12-2019, 06:43 AM
BBruin66's Avatar
Quoted: 74 Post(s)
Liked: 36
I know it's being hopeful, but...
Anyone think we'll get Disney+ on this thing?
BBruin66 is offline
post #6129 of 6754 Old 11-12-2019, 08:42 AM
claw's Avatar
Liked: 2384
Originally Posted by bo55554r View Post
is that a joke ? Where is HDR here ? is this a device problem ? Or so it is shown on Netflix ?
this no HDR color system
two years Sony could not broadcast Dolby Vision and they had many problems.
now you're saying that the best broadcast quality is on Sony TV ?
how can other manufacturers guarantee Dolby Vision ? they only have 8 BITs
and the system of colors not Dolby Vision or HDR ?
It is well known (but apparently not by all) that Dolby Vision is sent to TVs wrapped inside a 4K RGB 8-bit container. Do some homework.
Sony was unable to add Dolby Vision support to their existing line of TVs; whether it was because they were unable to implement support into their "extreme" processor or for other reasons. So they worked with Dolby and the result was "Low Latency Dolby Vision" (LLDV). LLDV puts most of the work onto the player instead of the TV. LLDV is sent to TVs as a 4K 4:2:2 12-bit signal.
LLDV at 4K 4:2:2 12-bit does not make it better than Dolby Vision at 4K RGB 8-bit. The Dolby Vision inside the RGB 8-bit container is still 12-bit.
mrtickleuk likes this.
CJ
claw is offline
post #6130 of 6754 Old 11-12-2019, 10:20 AM
snave8's Avatar
Quoted: 43 Post(s)
Forgive me if this has been addressed before but........Just got the 820 last night, and I'm experiencing some weird issues. Already did a factory reset, as well as installed the latest firmware, but neither corrected the problems.
(1) When I watch Netflix, even the log-In screen, my JVC RS-520 is going into HDR mode, and stays there unless I go into the projector menu and select another picture setting. It does not do this with Amazon unless the signal is actually HDR.
(2) I get Atmos with Netflix, but not Amazon.
(3) When in Netflix, and watching material that's just 2 channel audio, the 820 is sending a DD+ 5.1 signal to my Marantz SR 7011 receiver, but all I'm getting is two channel Front L and R audio (because that's all it is). This is a problem because it won't allow the receiver to apply any processing to the signal to turn 2 channel into multi channel audio.
My Samsung 9500 that I have been using does none of the above, however with the 9500 I can get Atmos with Amazon, but not Netflix.
Before I return the unit, I was wondering if anyone else has experienced this, and if so, is there is a fix?
Mark
snave8 is offline
post #6131 of 6754 Old 11-12-2019, 12:35 PM
claw's Avatar
Liked: 2384
(1) Do you have Advanced Settings...SDR/HDR Conv. (Network Service) turned ON? If so it will convert Netflix menus from SDR to HDR. Turn it OFF if you don't want the menus output in HDR.
(2) There is very little content in Amazon that has an Atmos track.
(3) Do you have Audio set to Bitstream? You want Bitstream audio sent to your AVR.
– Dolby Audio: “Bitstream”
– DTS/DTS-HD: “Bitstream”
– BD-Video Secondary Audio: “Off”
CJ
claw is offline
post #6132 of 6754 Old 11-12-2019, 03:29 PM
snave8's Avatar
Quoted: 43 Post(s)
(1) Changed the SDR/HDR Conv to off, that fixed the always on HDR issue with Netflix
(3) Yes to all. Had them set that way.
So I tried 15 different Netflix titles, all clearly labeled HDR. Out of the 15, only two kicked my projector into HDR mode. Tried the same thing with my Samsung 4K player......All 15 kicked the HDR on
I then Tried a bunch of Amazon HDR content, both the Pannisonic 820 and the Samsung sent an HDR signal to the projector.
I then tried 10 Netflix shows/movies that showed as being Atmos. Out of the 10, the player only sent one to the Marantz as Atmos, the others all played as DD+
Anything that's two channel audio content on Netflix is being sent to the receiver as DD+, even though it's only two channel stereo, therby preventing the receiver from doing any surround processing.
Unless someone has a suggestion, I'm going to assume I've got a defective unit.
Mark
snave8 is offline
post #6133 of 6754 Old 11-12-2019, 03:50 PM
claw's Avatar
Liked: 2384
All Netflix audio is DD+ as far as I know. My Denon allows me to apply Dolby Surround mixing to it.
CJ
claw is offline
post #6134 of 6754 Old 11-12-2019, 04:01 PM
Geronimo.USMC's Avatar
Quoted: 366 Post(s)
Liked: 249
ATMOS is supported in NETFLIX with 820.
monkaquinas likes this.
- AUDIO: (7.2.4 Atmos) Pioneer Elite VSX-LX503 | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP + L22
- VIDEO: SONY OLED 65A9G | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is offline
post #6135 of 6754 Old 11-12-2019, 05:08 PM
Quoted: 95 Post(s)
Liked: 44
Still DD+ but with Atmos metadata.
Everything works fine here.
Geronimo.USMC likes this.
Nordvarg is offline
post #6136 of 6754 Old 11-12-2019, 08:12 PM
Viking 29's Avatar
Quoted: 390 Post(s)
Liked: 308
So guys has anyone went from an xbox one x as a player to this Panasonic? I want a great disc player and I seem to be getting stuttering on the latest update from Xbox. I'm not that worried about apps as I have a roku and lg c8 oled. The ability to play discs back in Dolby Vision is intriguing too. I'm really sick of the little issues with the Xbox and am ready to use it for gaming only I think. Which it is pretty great at. Thanks for any insight in advance!
Viking 29 is online now
post #6137 of 6754 Old 11-12-2019, 09:56 PM
Liked: 699
Yup. Xbox One S to Sony X800, to Sony X700, to Panasonic. I'll say this, the Xbox is PURE TRASH for disc playback and especially streaming. Everything is dim and looks like crap. HDR is broken and it doesn't even look like HDR.
When I play a movie on Vudu on my Xbox and then play the same movie on my Sony z9d built in app the Xbox looks like it doesn't even know what HDR is...The Panasonic would be like comparing a Farrari to a piece of $#!T...Lol, that is a little extreme, but yeah, the Panasonic blows the Xbox away. It's night and day.
Sony 55x900e
Sony 55xA1E
post #6138 of 6754 Old 11-12-2019, 10:49 PM
Pip
Pip's Avatar
Quoted: 371 Post(s)
Liked: 178
.....Anything that's two channel audio content on Netflix is being sent to the receiver as DD+, even though it's only two channel stereo, therby preventing the receiver from doing any surround processing.
My Denon also allows Dolby or DTS Surround mixing applied to two channel Netflix, so I'd assume you're Marantz does as well (Denon and Marantz are sibling units.) To do this, change from "Auto Surround" to "Movie Mode" (Denon terminology).
So I tried 15 different Netflix titles, all clearly labeled HDR. Out of the 15, only two kicked my projector into HDR mode. Tried the same thing with my Samsung 4K player......All 15 kicked the HDR on....
The 820 Netflix app has known issues with HDR (well documented in this thread). Although your issue seems rare, it could be a one off or a temporary problem. Are these 13/15 issues consistent? Each title always does the same? To diagnose issues specific to your unit, it would be helpful to list some specific HDR titles which do not activate HDR on your projector, and the two titles that do. That way someone can compare their 820 to yours.
Unfortunately, the 820 Amazon app also has known issues, ie. stuttering, although this occurs on many other streaming devices also. Prime Video problems are widespread and hardly limited to Panasonic.
Lastly, as has been well discussed in this thread, the 820 is a fantastic player for discs, but as a streaming device, it is both limited and clunky.
Pip
Pip is offline
post #6139 of 6754 Old 11-13-2019, 07:44 AM
snave8's Avatar
Quoted: 43 Post(s)
Pip
The only HDR/Atmos title that plays both consistently is the movie "Dolomite Is My Name", everything else is hit or miss and inconsistent.
As far as everything on Netflix being DD+, there are many titles that are only two channel audio. With my Samsung 9500 player, they all show as two channel stereo on my Marantz info menu, thereby allow the receiver to turn them into multi channel, but with the 820 they show as 5.1, and the receiver can only add processing to the 5,1 signal, such as turn it into 7.1. It cannot create multi channel sound out of a signal it recognizes as already being multi channel, such as DD+
I know there's another thread for the UB9000, but anyone know if the same "limited and clunky" issues are common with that unit as well? I know there very similar devices.
Mark
snave8 is offline
post #6140 of 6754 Old 11-13-2019, 04:38 PM
bluesky636's Avatar
Quoted: 121 Post(s)
Liked: 76
I tried a search without much luck.
Apparently the 820 has a function where to conserve power, the player will shut off after it has been paused for about 20 minutes. Is there any way to turn this "feature" off?
Bill
bluesky636 is offline
post #6141 of 6754 Old 11-13-2019, 04:59 PM
mrtickleuk's Avatar
Quoted: 5362 Post(s)
Liked: 7749
I've read the whole thread recently (hard work!) and I remember this. Lots of people posted saying they hate it, but it's baked in with no configurable option sorry.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #6142 of 6754 Old 11-13-2019, 05:08 PM
bluesky636's Avatar
Quoted: 121 Post(s)
Liked: 76
Darn. Guess I'll have to make my bathroom breaks shorter and less often.
If I stop the player instead of pause it, does it restart at the same place? Guess I'll have to try that tonight.
Bill
post #6143 of 6754 Old 11-13-2019, 05:17 PM
mrtickleuk's Avatar
Liked: 7749
Dunno, I haven't even got one But "resume play" is a "feature of some discs" as far as I know. The BD-Live ones. They can choose whether to give you that feature and/or bookmarks etc when they author the discs. There's zero excuse for not doing it, but some do not. Therefore it would be better if it had been a player feature and not a disc feature, so that the evil studios who don't author discs nicely and use the feature can't take it away from us. This problem was well known when 4K Blu-Ray was being created, so it's a shame they didn't fix it (eg by making it mandatory).
_______________
post #6144 of 6754 Old 11-13-2019, 05:17 PM
Liked: 2135
It has the Resume option, but that may disappear in seconds, depending on the movie. On projectors that have a long resync delay, you may not see that option.
post #6145 of 6754 Old 11-13-2019, 06:11 PM
bluesky636's Avatar
Quoted: 121 Post(s)
Liked: 76
Owners manual says Resume does not work for BD-Video.
Bill
post #6146 of 6754 Old 11-14-2019, 08:32 PM
Razor*'s Avatar
Quoted: 35 Post(s)
I'm actually in the market for a 4K player as I'm using my Xbox One X right now. Of course it's not as good as a stand alone player but it does the job. Tops on my list is the Panny UB820. It was between that and the Sony X800m2. Will see what Black Friday brings.
Sony 65" A8F 4k OLED
Sony 4K XBR49X850B, Panasonic TC-P65VT50
Cambridge Audio Azur 640R & 740C
Paradigm Studio 60's, 20's, CC-590 & Seismic 12
Xbox One X Project Scorpio, Xbox One S LE GoW, PS4 w VR
Razor* is offline
post #6147 of 6754 Old 11-15-2019, 04:48 AM
Tom10422's Avatar
Angry Tray won't eject
My disc tray won't eject. I tried the sequence in the user manual without luck. Is there a manual eject (with a paper-clip, etc)? I did not see one. Figures, I think I've had the player over a year.
Tom10422 is offline
post #6148 of 6754 Old 11-15-2019, 05:45 AM
tngiloy's Avatar
Quoted: 510 Post(s)
Liked: 333
I also had the 820 and X800m2 as my final choices. I went with the UB820 and have been very happy.
The main thing that tilted the choice to the UB820 was Sony's unbelievable decision to not make Dolby Vision switching automatic. If you were to play a DV enabled disc you needed to go into setup to switch DV on. If the next movie you watched was HDR10 the X800m2 would force DV unless you went back into setup and turned off DV.
Unless Sony has fixed this glitch with a firmware update since I was shopping a while back, you should check this out.
"When all else fails, read the manual."
tngiloy is offline
post #6149 of 6754 Old 11-15-2019, 06:53 AM
Yankees24's Avatar
Quoted: 268 Post(s)
Liked: 100
I was in the same situation, I went with the Panny, in addition to the sony and DV switching issue, the Panny has a better processor.
Think before you speak....
Yankees24 is offline
post #6150 of 6754 Old 11-15-2019, 08:30 AM
Liked: 699
In my opinion, you aren't even getting HDR with the Xbox...Microsoft's implementation of it is really bad compared to any stand alone player I've used. When I watch a 4k disc on the panny or even using the streaming apps on my z9d there is no comparison. The Xbox looks pathetic comparatively...Obviously you need a good tv to really take advantage of HDR and the Sony z9d is arguably still the best HDR tv with the least compromises so you can tell there's a massive difference when the HDR sucks...
I'm not here trying to tout how awesome my tv is, just saying that I have a good frame of reference for what HDR should look like and the Xbox does not deliver...
Sony 55x900e
Sony 55xA1E
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
