Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 5717Likes
post #6301 of 7789 Old 12-01-2019, 11:28 AM
bobknavs's Avatar
Quoted: 2855 Post(s)
Liked: 2066
Originally Posted by Eddie E View Post
It may be a little nit picky, but I have a concern that my Panasonic UB820 may be returned unit. I purchased it from Amazon. The batteries were already in the remote controller. I have purchased dozens of electronics that use remotes over the years, and all them either had the batteries packaged separately, or there was a plastic pull strip to prevent contact. I thinking maybe mine is re-boxed. Anyone else's player came with the remote batteries already installed? Thanks.
It has been a year plus, but I'm pretty sure that the batteries were not in the 820's remote. They are AAs, and not rechargeable. I can't swear to it, but I believe that AAs are never pre-installed, because they eventually will leak.
Eddie E likes this.
bobknavs is online now
post #6302 of 7789 Old 12-01-2019, 11:39 AM
bobknavs's Avatar
Liked: 2066
Originally Posted by enzo631 View Post
Hooking up my unit tonight. Silly question for you guys.....Are the hdmi cables that comcast/xfinity give you with their 4k cable box ok to use or do I need to upgrade my cable for my 4k Player? I've got a few extra Xfinity cables I can use. The guy at BestBuy wouldn't stop selling me on buying these 4 foot Rocket Fish 4K HDR cables that were on sale for $10.
I don't know. I would hope that Comcast supplied a cable that would work with their box. (My Comcast cable box is only HD, so I can use almost any HDMI cable with it.)
The ones to get are Certified Premium. (See the attached.) They are rated to 18 Gbps, which is required for some 4k content. They can be quite cheap.
Not having certified ones does not mean that they can't work.
If you need additional cables, I suggest not getting them at Best Buy. $10 is relatively cheap for BB, but you can get certified ones (Monoprice and others) online (Amazon and elsewhere) for less. If you want higher-end cables, it probably makes no sense to buy more expensive ones than Blue Jeans (http://www.bluejeanscable.com/). Avoid Audioquest unless you're the sort of person who can always see/hear improvement for every dollar spent, or seriously into audiophile pseudoscience.
post #6303 of 7789 Old 12-01-2019, 11:55 AM
bluesky636's Avatar
Quoted: 325 Post(s)
Liked: 267
Hooking up my Panasonic player tonight. Silly question for you guys.....Are the hdmi cables that comcast/xfinity give you with their 4k cable box ok to use or for my UB820? I've got a few extra Xfinity cables laying around. The guy at BestBuy wouldn't stop selling me on buying these 4 foot Rocket Fish 4K HDR cables that were on sale for $10.
I buy all my HDMI cables from Blue Jean's Cable.
http://www.bluejeanscable.com/indexmob.htm
JonFo, jh901 and RoadLizard like this.
Bill
bluesky636 is offline
post #6304 of 7789 Old 12-01-2019, 12:15 PM
ragged's Avatar
Quoted: 68 Post(s)
Liked: 39
Been reading through here to see if I have things setup corectly. Seems I'm getting the right output signal but if someone could confirm I would really appreciate it. Picture below shows signal info from Overlord 4k disc. Thanks.
ragged is offline
post #6305 of 7789 Old 12-01-2019, 03:05 PM
enzo631's Avatar
Quoted: 130 Post(s)
Liked: 43
Can someone share their recommended video/picture settings for using this player with an LG Oled?
I just hooked it up to my 65C8 and am uncertain about some of them. Especially the whole 4:4:4 or 4:2:2 setting. I would really appreciate it. Thanks.
enzo631 is offline
post #6306 of 7789 Old 12-01-2019, 05:59 PM
lmclouth's Avatar
Quoted: 25 Post(s)
How to go to a specific time
I asked earlier but no replies. I hope someone knows.
How do you go to a specific time on a DVD/Blu-ray or MKV?
I just got the DP-UB820 and I've looked through the online PDF manual and I cannot see how to do it.
This is such a basic feature, there must be a way to do it. Otherwise, why would you need the numbers on the remote.
lmclouth is offline
post #6307 of 7789 Old 12-01-2019, 10:13 PM
MOberhardt's Avatar
Quoted: 1500 Post(s)
Liked: 1147
No idea honestly.
MOberhardt is offline
post #6308 of 7789 Old 12-02-2019, 08:13 AM
Liked: 0
Hi
A lot of pages in this thread….
Thinking of buying this player but how is the video/audio playback support through USB from external hdd?
And does it support showing subtitles in SRT format?
Any help appriciated
Mr Mister is offline
post #6309 of 7789 Old 12-02-2019, 10:12 AM
tbird8450's Avatar
Quoted: 95 Post(s)
Liked: 70
Originally Posted by Bytehoven View Post
I tested Netflix on my ub820 and the output mirrored whatever you had it set for, HDR2020, SDR2020 or SDR709. The ub820 will output DV when connected to a DV capable display, but only if DV is turned ON in the ub820 video settings menu. The ub820 can be forced to output DV with a DV title when spoofed with a Sony or LG EDID, but not with SDR or HDR content, only DV content.
It is worth noting, if you're XBOX is one of the newer S/X models, it can be forced to output DV. I believe one of the EDIDs is the LG C8. You're XBOX might be doing what it has been designed to do with the C8 DV content, but is also mistakenly doing it with SDR content, which would look affected. This should not happen with the ub820 based on my testing.
I took delivery of a UB820 and tested this, and so far its behavior is mirroring the Xbox, which is what I was concerned about. I've perused the settings and tried turning off everything that seemed like it could affect it, but so far, no luck.
Here is what I'm seeing with Netflix specifically...
With Dolby Vision turned ON in the UB820 settings:
ALL of Netflix forces my LG C8 into its DV preset. Obviously for DV content, this is fabulous, but for SDR content, this is not at all desirable.
With Dolby Vision turned OFF in the UB820 settings:
Netflix displays SDR content properly, however, DV content reverts to being displayed in HDR.
How can I resolve this so that I don't need to toggle DV on / off each time I'm changing content?
tbird8450 is offline
post #6310 of 7789 Old 12-02-2019, 11:22 AM
tbird8450's Avatar
Quoted: 95 Post(s)
Liked: 70
Apologies for the back-to-back posts, but I’m looking for some general recommendations on settings for both disc playback and streaming. My goal is to maintain audio and video fidelity as much as possible. How much do I want to mess with the HDR Optimizer (or do I at all?)
Gear:
Professionally calibrated LG C8
Denon x3300w AVR
5.2 speaker configuration (no Atmos)
Thank you.
post #6311 of 7789 Old 12-02-2019, 01:56 PM
Quoted: 311 Post(s)
Liked: 250
Just finished watching Captain America 1-3 4K UHD DolbyAtmos in 5.1.4; on my ub820 over uhd60 optoma. The contrast & colors via SDR bt2020 WCG 10bit looked fantastic!! I have never seen Capt's uniform look so blue; and black widow's red hair; some truly spectacular stuff. Civil War having the most special effects; looked and sounded amazing! My eyes were amazed.
Thanks Panasonic UB820 for finally unlocking my 4K UHD movie discs; they look fantastic!
m0j0 and MOberhardt like this.
am2model3 is offline
post #6312 of 7789 Old 12-02-2019, 02:06 PM
Quoted: 6182 Post(s)
Liked: 2590
Gear:
Denon x3300w AVR
Thank you.
If the C8 is calibrated I would just set the Display Type to OLED and not change the Optimizer default settings.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #6313 of 7789 Old 12-02-2019, 05:58 PM
tbird8450's Avatar
Quoted: 95 Post(s)
Liked: 70
By default the Optimizer is off. Does that mean I should keep it off, or turn it on and not adjust any specific settings? Or is that just the same as "off"?
post #6314 of 7789 Old 12-02-2019, 06:01 PM
Eddie E's Avatar
Quoted: 46 Post(s)
Liked: 24
I returned it to Amazon and picked up one from Best Buy. The price was the same. New one is working great.
Eddie E is offline
post #6315 of 7789 Old 12-02-2019, 06:42 PM
355F1's Avatar
Quoted: 351 Post(s)
Liked: 138
Just bought one of these yesterday.
Been 10 years since I have bought a new dvd player.
Why are there two HDMI outs? (One says Audio the other is A/V)? I thought audio and video were both run on one HDMI cable?
I will be hooking this up to a Marantz Av7705 pre/pro to a 2019 model 85" Sony or Samsung LED.
😎It's just life, dude. We are all gonna die sometime--Might as well try and have a kickass time while we're still here.😜
355F1 is offline
post #6316 of 7789 Old 12-02-2019, 07:09 PM
Yankees24's Avatar
Quoted: 268 Post(s)
Liked: 100
The 2nd hdmi is audio only, in case you want to run it to your audio receiver.
Think before you speak....
Yankees24 is offline
post #6317 of 7789 Old 12-02-2019, 07:46 PM
355F1's Avatar
Quoted: 351 Post(s)
Liked: 138
In what situation would you do this?
Like if you wanted to run separate HDMIs to separate the Audio to the pre-pro and the Video straight to the TV?
What is the purpose of this?
355F1 is offline
post #6318 of 7789 Old 12-02-2019, 09:37 PM
Natrix1973's Avatar
Quoted: 84 Post(s)
Liked: 60
It's for older receivers that don't support 4k/HDR/DV, that way you can still run audio through the receiver and 4k video options by running the video straight to your TV
tngiloy, am2model3 and 355F1 like this.
Natrix1973 is offline
post #6319 of 7789 Old 12-03-2019, 04:27 AM
Yankees24's Avatar
Quoted: 268 Post(s)
Liked: 100
A couple of reasons as others have mentioned,
In my case I like running a direct connection to my tv and not through my receiver (even though it’ has 4K pass through), and then a direct audio connection to my receiver.
post #6320 of 7789 Old 12-03-2019, 06:12 AM
m0j0's Avatar
Quoted: 1333 Post(s)
Liked: 2037
The 820 was meant for the UHD60. Getting proper tone mapping really allows you to see what your projector is capable of.
am2model3 likes this.
m0j0 is online now
post #6321 of 7789 Old 12-03-2019, 06:14 AM
m0j0's Avatar
Liked: 2037
How are you using it? With a projector? Passing HDR or doing SDR with bt2020? If SDR bt2020, you definitely want to turn the optimizer on.
m0j0 is online now
post #6322 of 7789 Old 12-03-2019, 07:51 AM
tbird8450's Avatar
Quoted: 95 Post(s)
Liked: 70
It's an OLED (calibrated LG C8), so I've left it off. I'm just looking to verify that I wouldn't have any reason to use it given my setup.
post #6323 of 7789 Old 12-03-2019, 10:18 AM
355F1's Avatar
Quoted: 351 Post(s)
Liked: 138
Thanks, peeps!
So its just like the old-school days of running s-video/component video cables straight to the tv to bypass the receiver for those who wanted the best possible picture.
evoll88 likes this.
355F1 is offline
post #6324 of 7789 Old 12-03-2019, 10:24 AM
evoll88's Avatar
Quoted: 108 Post(s)
Liked: 58
I run mine the same way so i don't have anything messing with picture quality. I only use the optimizer on 4000 nit or higher movies on my C8 oled. On 1000 nit movies i see no difference with the optimizer on but def do with higher nit movies.
evoll88 is offline
post #6325 of 7789 Old 12-03-2019, 11:30 AM
claw's Avatar
Quoted: 2869 Post(s)
Liked: 2742
I made a discovery yesterday that seems to explain why I never got Atmos from Amazon Prime Video when others say they do.
I experimented sending a Dolby Vision LLDV signal to my non-DV JVC projector and noticed my AVR reporting Atmos for Jack Ryan. I went back to sending HDR10 and my AVR reported DD+ with no Atmos. So it seems to me that Amazon, at least in some cases, has Atmos for Dolby Vision but not for HDR10.
mrtickleuk likes this.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #6326 of 7789 Old 12-05-2019, 06:55 PM
Quoted: 134 Post(s)
Liked: 7
Got my first projector and this player this fall. Netflix and prime seem to work well on it. Is there a way to stream Disney+ on it?
Porknz is offline
post #6327 of 7789 Old 12-05-2019, 07:04 PM
Quoted: 134 Post(s)
Liked: 7
Also ordered a few more echos, including one for the room with the projector and this player. What can Alexa do with this player?
Porknz is offline
post #6328 of 7789 Old 12-06-2019, 12:21 AM
Quoted: 51 Post(s)
Good joke
No Alexa and no Disney+.
bl4ck is offline
post #6329 of 7789 Old 12-06-2019, 07:55 AM
jh901's Avatar
Quoted: 829 Post(s)
Liked: 346
Dual HDMI is essential as some of us have audio only processor/preamps. I don't ever want video "passed through" any device aside from a hi-end video processor. Finally, my 820 sits with my front projector in the back of the theater and the audio electronics are in the front.
______________________
Separately, is there any hope that Panny will add streaming apps such as ESPN+, Disney+, and Youtube TV?
355F1 likes this.
HT: Panasonic DP-UB820 | JVC RS600 | 106" x 45" Stewart ST 100 | Cary Audio Cinema 12 | NAD M27 | Elac Uni-Fi UF5, UC5, Debut F5/B6; Focal CMS Sub
STEREO: [Shunyata Denali] Playback Designs MPS-5 (fully upgraded) | Cary Audio SLP-05 tube line level | Cary Audio SA-200.2 ES | Focal Diablo Utopia III DEN: 60" Panasonic VT60
jh901 is offline
post #6330 of 7789 Old 12-06-2019, 10:17 AM
mrtickleuk's Avatar
Quoted: 6104 Post(s)
Liked: 8853
There is hope, but it's only forlorn and unrealistic fantasy hope!
jorgebetancourt likes this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
