Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 231 - AVS Forum | Home Theater Discussions And Reviews
 5382Likes
post #6901 of 7013 Old 02-12-2020, 11:38 AM
siciliano611's Avatar
Quoted: 162 Post(s)
Liked: 41
I just bought the UB820 player to go with my Sony z9d and had a question. I put the luminance setting at SUPER HIGH as this tv can go 1800 nits peak brightness but when I play a HDR10 Blu-ray like Lucy and I go to playback info... under hdr10 metadata it shows both the Blu-ray and my fav max at 1000, wouldn’t the super high put it at 1500? Regardless my tv can do even higher than that. Someone help explain this to me, thanks!
siciliano611 is online now
post #6902 of 7013 Old 02-12-2020, 11:50 AM
Quoted: 5579 Post(s)
Liked: 2250
The UB820 is just reporting the metadata of the disc. In the case of Lucy it's 1000 nits max, which is within your TV's capability so the UB does not need to do any tone mapping.
Note that tone mapping will not boost the luminance of the movie, even if your TV is capable of handling more.
https://docs.google.com/spreadsheets...#gid=184653968
Dominic Chan is online now
post #6903 of 7013 Old 02-12-2020, 02:11 PM
Vriess's Avatar
On some reviewers channels they noted some problems with image quality in Dolby Vision(blown out?). Has there been any updates to address this issue?
I have been very happy with the quality of this player, I don't have a 4k HDR tv yet but the player really seems to make Blu Rays look excellent. Sound even seems better than my old PS3 too although I'm not sure how much is wishful thinking.
Vriess is offline
post #6904 of 7013 Old 02-12-2020, 02:49 PM
ISF Level III Certified
Evan201's Avatar
Quoted: 297 Post(s)
Liked: 215
Super high is the correct setting for your display. This will help map down to 1500 nits at the source for movies that exceed 1000 nits. Since your tv can display 1500 nits comfortably, that would be the better option than having the player map all the way down to 1000.
ISF Level III Certified Display Calibrator - Los Angeles
Advanced Visual Systems & Calibration
[email protected]
Evan201 is offline
post #6905 of 7013 Old 02-12-2020, 04:16 PM
claw's Avatar
Quoted: 2637 Post(s)
Liked: 2494
The UB820 HDR Optimizer will do its stuff when you play a title like Mad Max Fury Road where the brightest pixels reach beyond 4000 nits. The Optimizer will tone map the bright content down to 1500 nits in your case.
Look at the bright explosions when they drive into the dust storm. You should see more detail.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #6906 of 7013 Old 02-13-2020, 10:52 AM
Quoted: 70 Post(s)
Originally Posted by bluesky636 View Post
You can try doing a reset or not. I don't care.
Sorry, didn't mean to offend you somehow. All I'm saying is it seems everyone has to keep resetting these units for one reason or another, there has got to be a better way. I learned the other day from a dealer that won't push the Panasonic anymore, even the $1200 model is junk apparently. They display their projectors with a $250 sony that they said was better and doesn't fail all the time like Panasonic. Sort of regretting buying it, but although I don't have any basis for comparison it does appear the PQ is pretty darn good. Shame reliability and function performance is so poor.
Panasonic DP-UB820, Yamaha RX-V1075, Epson 5040UB. Elunevision Reference 4K 125" screen.
marcosphoto is offline
post #6907 of 7013 Old 02-13-2020, 11:15 AM
tigerhonaker's Avatar
Quoted: 855 Post(s)
Liked: 894
Post
For what it's worth I have now the Panasonic UB9000 and before that the UB820 for a year.
Neither ever gave me any negative issues !!!
I also had a Sony player and it worked nicely.
I also had a high-end Integra and it worked as expected with no issues.
Buy what one prefers and enjoy that item ................
Terry
tigerhonaker is online now
post #6908 of 7013 Old 02-13-2020, 11:20 AM
bluesky636's Avatar
Quoted: 237 Post(s)
Liked: 173
Terry
Not had any issues with mine either. I also read the owner's manual on how to set it up and operate it.
tigerhonaker and Superman2 like this.
bluesky636 is online now
post #6909 of 7013 Old 02-13-2020, 05:18 PM
xrtdr's Avatar
Quoted: 32 Post(s)
Hi everyone,
I just ordered a JVC faux 4k projector and I'm looking at the Panny UB820 to go with it.
What are the pros and cons of this unit as opposed to the 9000 which is MSRP $999? Or the UB420 which seems too cheap to be any good.
Does this unit have an itunes app or do I still need an appleTV?
Would I still want a Roku or can it do everything a Roku can?
Thanks! I am not much of a techie as you can tell. I know the answers are probably somewhere in this thread but it's 230 pages!!
xrtdr is offline
post #6910 of 7013 Old 02-13-2020, 05:30 PM
claw's Avatar
Liked: 2494
Originally Posted by xrtdr View Post
Hi everyone,
Neither Panasonic player has any Apple TV+ App or Vudu or most anything else other than Netflix, Amazon, and YouTube. But hey, you get 4K HDR from YouTube. And all output from the streaming Apps is 4K60, no native 4K24 output.
With a JVC e-Shift projector, most will recommend sending SDR BT2020 using the UB820/UB9000 HDR Optimizer.
CJ
claw is offline
post #6911 of 7013 Old 02-13-2020, 05:35 PM
xrtdr's Avatar
Quoted: 32 Post(s)
Thanks, Claw!
xrtdr is offline
post #6912 of 7013 Old 02-13-2020, 07:16 PM
DLCPhoto's Avatar
Quoted: 1775 Post(s)
Liked: 860
Hi everyone,
You can also go with the cheaper UB420, which provides the same needed functionality as its more expensive siblings, as I'm sure claw is well aware. Just posting to perhaps save you some money!
Superman2 likes this.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #6913 of 7013 Old 02-13-2020, 07:34 PM
xrtdr's Avatar
Quoted: 32 Post(s)
Ok, so what does the extra $$ pay for over the cheaper model?
xrtdr is offline
post #6914 of 7013 Old 02-13-2020, 07:42 PM
DLCPhoto's Avatar
Liked: 860
You can check features online, but by memory, the main difference is that the UB420 doesn't have Dolby Vision, which wouldn't be used with a Projector anyway.
post #6915 of 7013 Old 02-13-2020, 07:47 PM
xrtdr's Avatar
Quoted: 32 Post(s)
Ok thanks. You're right, I should just look directly.
xrtdr is offline
post #6916 of 7013 Old 02-13-2020, 09:49 PM
Pip
Pip's Avatar
Quoted: 380 Post(s)
Liked: 187
The 820 adds Dolby Vision which no projector has. The 9000 adds customized optimizer settings for the newer JVC projectors (which you don't have) plus a different chassis with supposedly better "build quality" whatever that means. It certainly weighs more.
With your projector, all three will provide the same image quality and features.
Pip
mrtickleuk likes this.
Pip is offline
post #6917 of 7013 Old 02-14-2020, 08:14 AM
Quoted: 70 Post(s)
Terry
So sufficed to say you've had a lot of BR player experience, this is my first. (I had an oppo DVD prior to this). Which players did you like most/least and why? IYO.
post #6918 of 7013 Old 02-14-2020, 08:40 AM
bluesky636's Avatar
Quoted: 237 Post(s)
Liked: 173
Ya know, this is the thread to discuss the Panasonic 820/824 UHD player. If you want help in choosing a new player, you should post your questions here:
https://www.avsforum.com/forum/149-blu-ray-players/2482833-official-help-me-choose-uhd-player-thread.html
post #6919 of 7013 Old 02-14-2020, 09:13 AM
Quoted: 855 Post(s)
Liked: 894
Post
A simple but honest reply to your question ^^^.
I liked all of them that I have owned.
The real reason I went with the Panasonic UB9000 and exchanged the UB820 for it at Best Buy is.
I am not all that sure how many High-End players will continue to be offered.
So since I could exchange the UB820 (Worked Perfect) for the (Much-Much Higher-End) UB9000 and was only out the difference in cost.
I figured do it now and if manufacturers in the future do stop with the High-End units I'm already set.
Keep in mind that I have the JVC RS4500 Laser Projector which benefits from the UB9000 for increasing Video Performance.
Terry
xrtdr likes this.
post #6920 of 7013 Old 02-14-2020, 06:00 PM
xrtdr's Avatar
Quoted: 32 Post(s)
All those 4K streaming apps look like invitations to cut the cable cord. Any reason not to do that? Can you add apps like HBOgo or Spectrum?
xrtdr is offline
post #6921 of 7013 Old 02-14-2020, 06:13 PM
skylarlove1999's Avatar
Quoted: 1508 Post(s)
Liked: 1234
Panasonic is not a very good streaming player. You cannot add other apps.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #6922 of 7013 Old 02-15-2020, 03:04 PM
alettiere's Avatar
Quoted: 638 Post(s)
Liked: 384
So I bought Once Upon a Time in Hollywood and the 4K disc will not play. It attempts to read it and just goes back to the main menu.
BD disc works fine. Just not 4K.
Has anyone else had this happen? Just curious before I go through the process of exchanging it.
alettiere is offline
post #6923 of 7013 Old 02-15-2020, 03:14 PM
sparksd's Avatar
4K disc plays fine on my 820.
sparksd is offline
post #6924 of 7013 Old 02-15-2020, 03:46 PM
willieconway's Avatar
Quoted: 353 Post(s)
Liked: 348
Try cleaning the disc, even if you don't see anything on it.
sparksd likes this.
willieconway is online now
post #6925 of 7013 Old 02-15-2020, 03:48 PM
alettiere's Avatar
Quoted: 638 Post(s)
Liked: 384
Tried that (twice). No luck.
I’m guessing it’s just faulty. Only time I’ve not had a disc play in my 820.
post #6926 of 7013 Old 02-15-2020, 03:58 PM
Quoted: 353 Post(s)
Liked: 348
I only got mine a couple of weeks ago but it already happened with two discs. In both cases a good wipe fixed it. Sorry you have to go the exchange route.
post #6927 of 7013 Old 02-15-2020, 05:07 PM
Quoted: 61 Post(s)
I loaded the Spears & Munsil UHD Benchmark (at least a dozen or more plays since purchase) to check some adjustments and got a message "This Disc is Not Playable" and my jaw dropped. First time I ever saw that for any disc since I bought the player last June. Visual inspection showed a number of fingerprints, all mine, I'm sure, likely from attempting to store the disc back on its hub in the dark. Gave it a good cleaning to make it shiny new looking. Reloaded. Played without a hitch.
Panasonic DP-UB820, Marantz AV7704, Epson 5050UB, Stewart Firehawk 16x9 82"; Parasound Amplifiers: HCA 1000A, HCA 1206; Paradigm Speakers: Premier 800F (R/L), ADP-370 (SS), Premier 600C, Monitor v.4 (RB, LB), PW2100 v.2, Hsu sub VTF-2 Mk5; Power Condition: Adcom ACE 315 & 515, Tripplite HT7300PC & HTRL15UPS; Other Sources: Pioneer CLD-D606 & DVL-919, JVC HR-S9600U; Cable: Redmere Elite HDMI, Monster Mi.2S, Kimber Kable.
fredworld is offline
post #6928 of 7013 Old 02-16-2020, 10:58 PM
Thebarnman's Avatar
Quoted: 181 Post(s)
Liked: 77
I've never had a problem with my 820. However, I wonder if the newest 4K discs have to have the latest in software update for the player? I know with my older Blu-ray player, the newest of the new Blu-rays would not play on them (or play properly) unless the player had the latest update. Though I'm not sure if all that is the same when it comes to playing 4K discs.
Movies must be OAR, sports and movies must also have 5.1 audio, No EE or NO SALE!
Thebarnman is offline
post #6929 of 7013 Old 02-16-2020, 11:20 PM
bluesky636's Avatar
Quoted: 237 Post(s)
Liked: 173
V1.60 is the latest firmware version.
post #6930 of 7013 Old 02-17-2020, 03:00 PM
hsindogg's Avatar
Quoted: 39 Post(s)
Originally Posted by filip629 View Post
I do want to thank everyone that did take their time to try and help me. Even though I was unsuccessful in getting the 820 to work, I truly appreciate everyone's advice and recommendations.
Did you try setting the HDMI signal to "Enhanced" on your Denon?
hsindogg is online now
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
