Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 245 - AVS Forum | Home Theater Discussions And Reviews
 5788Likes
post #7321 of 7973 Old 04-09-2020, 10:55 PM
Brettmckinney's Avatar
Quoted: 116 Post(s)
Liked: 80
Originally Posted by avtoronto View Post
I definitely obtain better results using the HDR2020 setting, with for example better colour space conversion. The Epson’s HDR1 setting is set-up to tone map 1000 nits.
I haven't got the S&M disc to check but I've been using SDR2020 on my Epson projector with the panny and the color using digital cinema mode looks really good. With lifting the DR converter I can get the image to pop a lot more. Would be keen to see your HDR settings based on the test patterns!
Brettmckinney is online now
post #7322 of 7973 Old 04-10-2020, 05:06 AM
Quoted: 227 Post(s)
Liked: 27
UB820 vs. UB824
What's the difference in the UB820 and UB824, just a regional/distribution difference?
No other player tops HDR optimization right now?
Nothing new coming up that you guys know?
Will use this player with an Epson 6050UB.
Vitus4K is offline
post #7323 of 7973 Old 04-10-2020, 09:51 AM
avtoronto's Avatar
Quoted: 212 Post(s)
Liked: 87
I’m using an Epson 4040 so my settings are not going to directly correspond to a 5040’s. Suffice to say, what I settled on is not much different than the default settings. There are many patterns intended for calibrators available on the disc but in the absence of equipment and better expertise, for the average end user; there are only a few things to evaluate; brightness, colour space, sharpness, etc. Minimal changes to colour and tint and typically no change to contrast are recommended.
All this being said, I still have other HDR settings Adapted from others’ that I’ve kept and use from time-to-time, including a slightly modified Harpervision.
The S&M disc is good with the 820, but it’s frustrating to have so many unusable patterns on it. I could obviously pay for a calibration but I expect to change my projector within a couple of years.
Elunevision 4K 112" Audioweave motorized screen, Epson Pro Cinema 4040 projector, Emotiva XPA-5 amplifier, Denon AVR X4400h receiver, XTZ M6 LCR, XTZ S5 surround, XTZ 1X12 and Definitive Technology Powerfield subwoofers, RSL C34E Atmos speakers, Apple TV 4K, Panasonic DP-UB820
avtoronto is offline
post #7324 of 7973 Old 04-10-2020, 10:19 AM
mrtickleuk's Avatar
Quoted: 6248 Post(s)
Liked: 9080
Please see >>THIS POST<<. HTH
Edit: the NL website has been updated since - so I've updated that post too
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #7325 of 7973 Old 04-10-2020, 12:08 PM
Quoted: 227 Post(s)
Liked: 27
Wow, what an utter mess!
Thank you very much!
The 824 is $100 more expensive here in Sweden.
Makes the 820 a no-brainer.
mrtickleuk likes this.
Vitus4K is offline
post #7326 of 7973 Old 04-10-2020, 01:56 PM
Quoted: 314 Post(s)
Liked: 255
Glad I could help! the ub820 HDR optimizer and tonemapping option really helps to solve the HDR 4K UHD viewing display issues.
It was by Kris Deering on sound and vision, reviewed the ub820.
https://www.soundandvision.com/conte...-player-review
am2model3 is offline
post #7327 of 7973 Old 04-10-2020, 03:23 PM
Clark Burk's Avatar
Quoted: 761 Post(s)
Liked: 697
Just be mindful of region restrictions. Won't matter much for UHD blu-rays but will for regular blu-rays and DVD's. The 820 and 824 have different region coding.
Clark
Clark Burk is offline
post #7328 of 7973 Old 04-11-2020, 06:31 AM
mavang's Avatar
Quoted: 30 Post(s)
Liked: 9
Hi there i was wondering if someone could assist me trying to stream Netflix with atmos through my Panasonic player I can’t get it to work I own a Yamaha 3060 strange because I had a UB900 and that streamed 4K atmos no problem
I feel like I have gone backwards in the audio dept sadly any advice would be greatly appreciated
jeep05 likes this.
mavang is online now
post #7329 of 7973 Old 04-11-2020, 07:34 AM
william06's Avatar
Quoted: 937 Post(s)
Liked: 521
I might be wrong but when I first got my ub9000 I had the same issue. Go Into settings and make sure you have Dolby Vision on I believe that is what solved the issue for me. It was over a year ago.
Lg oled65G7P
Panasonic UB9000 . pioneer lx500 uhd blu ray players
atv4k 2nd gen cube, roku ultra 2019
Toshiba Xa2 HD-DVD
Samsung HW-Q90R ZA soundbar
william06 is online now
post #7330 of 7973 Old 04-11-2020, 08:26 AM
Quoted: 227 Post(s)
Liked: 27
Originally Posted by Erod View Post
Yes, essentially.
When you send SDR2020, you're sending the same information except without the HDR metadata that tells the projector it's HDR. So you're still getting all the information, but your projector won't go into a mode that was an issue for some projector gamma curve functions.
With SDR2020, the 820 can TONE MAP the image so that you're still benefiting from the improvement for bright and dark detail like HDR is supposed to do, and you're getting the 2020 color file along with it. That's what the "HDR" thing is for us as consumers.
There is a very noticeable improvement in depth, color, and highlights as a result. Even though your projector can only project around 350 nits, not enough for true HDR, you still get the benefits. Then you can push the slider up a few notches to get it brighter if you want (I've settle on 2.)
The PQ is stunning. Not sure of your projector, but set it up for BT2020 color profile, D6500 color temp, and a 2.4 gamma. Then set the 820 to SDR2020, turn the optimizer on, adjust the dynamic range slider to your liking, and see what you think.
Does this require an HDFury device paired with an Epson 6050UB?
Would the Epson handle the SDR2020 signal correctly, being able to put the P3 filter in place, without adding any HDR curves?
I assume that you might need an HDFury device for this to work properly, hence my question.
Thank you.
Vitus4K is offline
post #7331 of 7973 Old 04-11-2020, 08:42 AM
Quoted: 227 Post(s)
Liked: 27
Does the DP-UB820 handle .MKV-files encoded with .FLAC audio via Home Network?
Vitus4K is offline
post #7332 of 7973 Old 04-11-2020, 10:25 AM
claw's Avatar
Quoted: 2937 Post(s)
Liked: 2823
Yes, essentially.
Thank you.
Removing HDR metadata with an HDfury device is not the same has having the UB820 tone map in SDR/BT2020 output mode.
Removing HDR metadata still requires that the display device apply an HDR gamma and tone map. If you put your display into a non-HDR mode with a Gamma 2.4, the colors would be way off.
Sending SDR/BT2020 output requires a Gamma 2.4 (some use 2.2). If you put your display into its HDR mode, the colors would be way off.
And no, you don't need an HDfury device for SDR/BT2020 output instead of HDR with the UB820. Just choose the SDR/BT2020 option in the UB820. The earlier generation UB900 required an HDfury device since it did not include such an option.
I don't have an Epson so I can't answer whether it would automatically engage its P3 filter and a 2.4 gamma.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #7333 of 7973 Old 04-11-2020, 10:31 AM
mrtickleuk's Avatar
Liked: 9080
Yes and no, that's not quite right, sorry because there's more than one "820" . I'm in the UK and if I buy a DP-UB820 from them Panasonic UK, I would get a DP-UB820EB, which is the UK model with a UK plug, it would be Region 2 for DVD and Region B for Blu-ray. But it's still very much an 820! . The PDF manual says "Model number suffix “EB” denotes UK model."
There's also a DP-UB820EG model but the PDF manual for that doesn't give any clues other than a big "EG" in a box on the cover! Same situation with the PDF manual for the DP-UB824EG model.
If you buy a DP-UB820 in USA you'll get an American model with American plug, it would be Region 1 for DVD and Region A for Blu-Ray.
So if @Vitus4K did want to get an 820, then be super-careful it's an 820EB. But no benefit for him. I would be suspicious the extra cost is for importing an American model which, as you say, would be the wrong region coding. Or it could be pure profiteering, and he'd get a UK 820 identical in every way to his cheaper Euro 824!
Summary:
  • DP-UB820 USA model = Region 1 DVD / Region A Blu-Ray
  • DP-UB820EB UK model = Region 2 DVD / Region B Blu-Ray
  • DP-UB820EG Euro model = Region 2 DVD / Region B Blu-Ray
  • DP-UB824EG Euro model = Region 2 DVD / Region B Blu-Ray
HTH!
_______________
post #7334 of 7973 Old 04-11-2020, 10:36 AM
claw's Avatar
Liked: 2823
That's not quite right, sorry. I'm in the UK and if I buy a DP-UB820 from them Panasonic UK, I would get a DP-UB820EB, which is the UK model with a UK plug, it would be Region 2 for DVD and Region B for Blu-ray. But it's still very much an 820! . The PDF manual says "Model number suffix “EB” denotes UK model."
Summary:
HTH!
I believe the USA model is actually the Canadian model sold in the USA.
CJ
claw is offline
post #7335 of 7973 Old 04-11-2020, 10:38 AM
mrtickleuk's Avatar
Liked: 9080
Ta. Complicated. Makes me nervous when there is no suffix at all!
_______________
post #7336 of 7973 Old 04-11-2020, 11:49 AM
Clark Burk's Avatar
Quoted: 761 Post(s)
Liked: 697
Summary:
HTH!
Thanks for the clarification.
post #7337 of 7973 Old 04-11-2020, 12:23 PM
avtoronto's Avatar
Quoted: 212 Post(s)
Liked: 87
Earlier in the thread, some found getting Atmos depended on which receiver you had. Denon/Marantz were found to be supporting Atmos but not Yamaha. Unsure if this has subsequently been addressed. Unless the list has been updated, officially the 820 did not show as supporting Atmos with Netflix.
post #7338 of 7973 Old 04-11-2020, 01:52 PM
Quoted: 227 Post(s)
Liked: 27
What's a DP-UB820EGK then?
Importing a US-model seems pointless as it's most likely made for 120VAC.
The UK model has a different power plug than the Euro models, so it's useless for me as I live in the Euro region.
The EG seems like the way to go, but I wonder what the added 'K' might be at the end?
Vitus4K is offline
post #7339 of 7973 Old 04-11-2020, 02:04 PM
Quoted: 227 Post(s)
Liked: 27
Does anyone know if the UB820 maps to DCI-P3 or sends a pure REC.2020 signal with SDR BT.2020 selected?
Vitus4K is offline
post #7340 of 7973 Old 04-11-2020, 02:28 PM
Quoted: 227 Post(s)
Liked: 27
The N2QAYA000172 works fine with my US UB820.
This gives me hope that the UB9000 remote will work for my UB820 too, do you think the odds are on my side?
I live in Europe.
Vitus4K is offline
post #7341 of 7973 Old 04-11-2020, 03:22 PM
mavang's Avatar
Quoted: 30 Post(s)
Liked: 9
Thanks sounds dumb on Panasonics part an older model supports atmos through Netflix but the new better model does not and it supports it when the player plays discs
But I guess they will blame Yamaha I thanks but disappointing as the units picture is awesome
post #7342 of 7973 Old 04-11-2020, 05:20 PM
blake's Avatar
Quoted: 1036 Post(s)
Liked: 155
So what mode should the display device be on if it’s receiving tone map SDR/2020
blake is offline
post #7343 of 7973 Old 04-11-2020, 05:28 PM
Quoted: 227 Post(s)
Liked: 27
I'm just guessing here, but I assume that you don't need any 'particular mode' set.
Just calibrate your direct-view display to a 2.4 gamma, and the incoming SDR BT.2020 signal will be displayed properly.
SDR2020 is not a 'tone map', it's just a signal, the tone map takes place in the unit converting the HDR signal to SDR.
It basically just removes the HDR metadata present in the HDR signal and/or source, but preserves the wider color gamut BT.2020 / REC.2020.
Anyone please correct me if I'm wrong.
Edit: Not all players keeps the wider color gamut BT.2020 / REC.2020 when converting HDR to SDR, but the DP-UB820 does so when selecting SDR/BT.2020 mode.
NxNW and mrtickleuk like this.
Vitus4K is offline
post #7344 of 7973 Old 04-12-2020, 03:12 AM
tngiloy's Avatar
Quoted: 560 Post(s)
Liked: 361
I live in Europe.
I use a universal remote and the same codes work on the UB9000 and UB820 and the UB420. You're fine.
Some of the buttons slightly differ from the Euro and US remotes, but they all work.
MOberhardt likes this.
"When all else fails, read the manual."
tngiloy is online now
post #7345 of 7973 Old 04-12-2020, 03:34 AM
rjruby's Avatar
Quoted: 46 Post(s)
Liked: 43
Just a guess but a "K' in the model number usually indicates the items color is black.
rjruby is offline
post #7346 of 7973 Old 04-12-2020, 04:18 AM
MOberhardt's Avatar
Quoted: 1606 Post(s)
Liked: 1247
Thank goodness. When I moved from the old 900 to the 9000 I didn't need to reprogram the Harmony
MOberhardt is offline
post #7347 of 7973 Old 04-12-2020, 05:15 AM
Quoted: 227 Post(s)
Liked: 27
Right along, nice to know!
Seems plausible, thank you.
Vitus4K is offline
post #7348 of 7973 Old 04-12-2020, 07:16 AM
Quoted: 145 Post(s)
Apparently from what I have read in other posts sdr tone mapping is still HDR and outputs at 350nits but you do still use the gamma 2.4.
Check out post #7305
johnnyboy632 is offline
post #7349 of 7973 Old 04-12-2020, 08:06 AM
NxNW's Avatar
Quoted: 158 Post(s)
Liked: 150
Originally Posted by Dominic Chan View Post
In spite of the name, SDR/BT.2020 is still HDR so the TV/projector should be set for the same peak nits as HDR, not 100 nits which is for SDR.
To quote Bill Clinton, it depends what "is" is.
SDR2020 produces a signal in an SDR format. The resulting image will "look right" on a display that can go brighter than 100 nits and has a large color gamut. So in that sense the viewing experience "is" HDR. But the signal "is" SDR.
NxNW is online now
post #7350 of 7973 Old 04-12-2020, 08:29 AM
Quoted: 6285 Post(s)
Liked: 2644
Let me explain what I meant by my statement:
Option 1: Set the UB820 to output HDR; set the TV to HDR (which would use ST.2084 EOTF and BT.2020)
Option 2: Set the UB820 to output SDR/BT.2020; set the TV to the same settings as Option 1 other than changing the EOTF from ST.2084 to Gamma 2.4. Keep the same peak luminance as well as colour space (BT.2020).
Option 3: Set the UB820 to output SDR; set the TV to SDR mode (100 nits peak, BT.709)
In terms of the end result (what the user sees on the screen, not what the signal "looks like" to the TV), Option 2 should look substantially the same as Option 1 (which is unquestionably HDR), whereas Option 3 is unquestionably SDR. (I'm focusing on the Dynamic Range as in SDR/HDR, aside from the colour gamut).
Actually you’re better off using BT.709 if your display does not have a BT.2020 mode, even if it has a “wider gamut”. BT.2020 uses completely different colour coordinates and the colours will all be wrong if the display expects BT.709 or DCI-P3.
NxNW likes this.
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
