Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 5782Likes
post #7561 of 7967 Old 05-15-2020, 09:01 PM
platinum_trunks's Avatar
Quoted: 83 Post(s)
Liked: 48
Perhaps a silly question, but would a standard Blu-ray played over a ub820 look better than say a lossless Blu-ray mkv run through a nvidia shield? What might have better upscaling?
platinum_trunks is offline
post #7562 of 7967 Old 05-16-2020, 04:19 AM
mrtickleuk's Avatar
Quoted: 6222 Post(s)
Liked: 9045
Interesting question. Resolution-wise it depends whether you want the TV to do the upscaling from 1080p to UHD, or whether you set the player to upscale to UHD. The normal advice (when this is discussed with AVRs) is to always let the TV upscale, since the TV's upscalers are more modern. However this player has the same processing chipset as in Panasonic's (2018?) TVs. Therefore I think that even if you fix the resolution to still be 1080p, I think the player would do a better job at the expansion of the chroma subsampling stage from 4:2:0 to 4:2:2, and that's one of the reasons it's so expensive, that chipset.
jeep05, funb0bfun and M2609 like this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #7563 of 7967 Old 05-16-2020, 09:57 AM
tigerhonaker's Avatar
Quoted: 1069 Post(s)
Liked: 1321
Post
Originally Posted by ti-triodes View Post
I’d like to add this to Clark’s post.
The N2QAYA000130 and 131 are both listed as a UB900 replacements. The 130 has manual skip and rewind buttons that the 131 lacks. On the 131, they are CC and DLNA buttons which are less useful for me, but YMMV.
They are both really cheap, while a real UB9000 remote usually costs a lot more. If you're looking for a UB9000 remote, check the pictures carefully. A real 9000 remote will have a HDR button. It is located in place of the sound effect button on the other remotes.
Below is the Panasonic UB9000 before it was opened to be installed.
Below is the Remote that comes in the Box of the Panasonic UB9000.
Note* You use to be able to purchase the same type of remote on-line from different sources.
I did that when I had the Panasonic UB820 that didn't have the Back-Lit remote.
Below is the Remote I purchased for use with the UB820 on-line.
Below is the invoice and as you can see it was actually for the Panasonic UB900.
This was back in 11/14/2018.
There you have the Full-Story on it guys ^^^
Terry
tonydeluce likes this.
tigerhonaker is online now
post #7564 of 7967 Old 05-16-2020, 11:02 AM
claw's Avatar
Quoted: 2935 Post(s)
Liked: 2821
i ordered a UB9000 remote from an online shop in Spain.
The only difference between mine and the one you pictured is that mine has -10 sec and +60 sec manual skip buttons instead of the CC and Mirroring buttons. The skip buttons are nice to have.
mrtickleuk likes this.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #7565 of 7967 Old 05-16-2020, 06:52 PM
DLCPhoto's Avatar
Quoted: 1842 Post(s)
Liked: 944
Has anybody here watched IP Man 4 on 4k Blu-ray Disc, with their 820?
I ask, because I just bought it, and it pixellates starting on the Menu screen, and continues if I try to actually watch the movie. I thoroughly cleaned it, with no effect. And actually, the first time I put it in, a message came up with it couldn't read the disc at all (I forget the exact wording). I cleaned it, and it at least got past that screen, but the pixellation was problematic.
I returned the Disc to Amazon, and got a replacement today, but have the same problem - almost immediate pixellation. I then played it without difficulty on my Sony X800 Player in a different room.
I seem to run into this with a very small number of discs which this player struggles with, while the Sony doesn't.
Let me know - thanks.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is offline
post #7566 of 7967 Old 05-16-2020, 08:26 PM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
I watched this disc didn't have any problem. My display is only 1080p though.
PoorSignal is offline
post #7567 of 7967 Old 05-16-2020, 09:38 PM
NxNW's Avatar
Quoted: 157 Post(s)
Liked: 149
Last night I watched the Midway UHD disc, also on a 1080p display. It played fine, but of course Dolby Vision was not being used, so I still can't tell you if firmware 1.64 fixes the Midway DV problem reported by others with the (still-current) 1.60 firmware.
NxNW is offline
post #7568 of 7967 Old 05-17-2020, 05:58 AM
DLCPhoto's Avatar
Liked: 944
Thanks for the reply. But you did play the UHD Disc, or was it the HD bluray?
DLCPhoto is offline
post #7569 of 7967 Old 05-17-2020, 07:40 AM
kwb737's Avatar
Quoted: 24 Post(s)
When I play the Midway UHD disc, the only way I've found for it to play without any freezes is if I have DV turned off on my UB820.
Receiver: Pioneer Atmos VSX-LX102, 5.1.2 Setup
Source: Panasonic DB-UB820 4K Player
Display: Sony XBR-85X900F LCD 4K
Speakers: Klipsch Lt & Rt Front RP-280FA Atmos, Center RP-45OCA, Lt & Rt Surrounds RP-250S, Subwoofer R-112SW
kwb737 is offline
post #7570 of 7967 Old 05-17-2020, 08:11 AM
cemo62's Avatar
Quoted: 188 Post(s)
Liked: 50
Is it still problematic with mkv files /true hd audio?
cemo62 is online now
post #7571 of 7967 Old 05-17-2020, 09:10 AM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
It’s the UHD disc I got it first day release from
Target.
Try turning off Dolby vision and audio delay settings to see if it changes. Or unplug it for a while. Just a guess.
post #7572 of 7967 Old 05-17-2020, 09:15 AM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
I got a remote from eBay it seems to be a counterfeit or OEM remote for ub900. It doesn’t have the HDR or the go back 10 seconds. But there is a light button that lights up. It weights more doesn’t have the Netflix button in a poor location. way better than the stock un820 remote. I got it for less than $20.
post #7573 of 7967 Old 05-17-2020, 10:09 AM
DLCPhoto's Avatar
Liked: 944
Target.
Thanks for confirming it was the UHD disc that you were playing.
I'm connected to a JVC Projector, so Dolby Vision is already off.
The fix, at least temporary, is your last comment, about unplugging it.
I ran into this issue with a different disc about a month ago. Unplugging and replugging it in after 5 minutes or so, didn't have any effect. So I just unplugged it overnight, and the next morning it was able to play that problematic disc without issue. With IP Man, I unplugged it for about 10 minutes, but no effect. So I unplugged it last night, and tried again just now, and it plays the disc fine.
So there's something 'funky' going on here, which only a prolonged unplugging seems to solve. What the minimum time is I can't say, but overnight seems to do it.
I'm hoping, though not optimistic, that the new upcoming firmware might fix this. When this will become available in the U.S., I have no idea. In the meanwhile, I guess I'll just have to unplug it periodically. I may have to look into an outlet plug that can be controlled by Control4, to automatically cut the power to it on a regular basis if the firmware doesn't come soon, or doesn't fix it when it does.
DLCPhoto is offline
post #7574 of 7967 Old 05-17-2020, 10:31 AM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
Oh good that you can watch the disc now but overall concerning.
I have all my stuff plugged into my power conditioner and a master switch shuts the power to everything when I am done for the day (because everything draws about 60W just standing by). So essentially I have unplugged everything between viewings.
DLCPhoto and am2model3 like this.
post #7575 of 7967 Old 05-17-2020, 01:52 PM
MOberhardt's Avatar
Quoted: 1595 Post(s)
Liked: 1237
There was no hHDR button on the 900 remote, just the 9000 and 820 etc. Sounds like you have the US 900 remote. Skip is the euro ones I think.
MOberhardt is offline
post #7576 of 7967 Old 05-17-2020, 03:09 PM
claw's Avatar
Liked: 2821
I believe the only remote that has both an HDR button and -10 and +60 second skip buttons is the European UB9000 remote.
The European UB900 remote has the -10/+60 second skip buttons but no HDR button.
The US UB9000 remote has an HDR button but no -10/+60 second skip buttons.
CJ
claw is offline
post #7577 of 7967 Old 05-17-2020, 04:43 PM
mrtickleuk's Avatar
Liked: 9045
What do you mean "still problematic"?
Lossless audio was and is not supported from mkv files. This is not a bug, it is a design decision. It's never going to change in any firmware update. It was not problematic before, that implies it worked sometimes but had problems
_______________
post #7578 of 7967 Old 05-17-2020, 08:12 PM
tonydeluce's Avatar
Quoted: 103 Post(s)
Liked: 120
Terry
Thank you, the pic of the actual UB-9000 remote was very helpful in identifying the real thing. Many sites selling alternatives and yes it was very expensive - just over $100 from Panasonic but as I plan on keeping the UB-820 for a while as I do not see anything else on the horizon that would likely make me want to upgrade. Thanks again.
tigerhonaker and mrtickleuk like this.
Sony XBR-65A8G 65 inch Bravia OLED 4K TV
Panasonic DP-UB820 UltraHD Premium Blu-ray Player * 2019 Nvidia Shield TV * Roku Ultra
LG SL10YG 7.1.2 Channel Soundbar + Rear Speaker kit w/Meridian Technology & Dolby Atmos / DTS:X
tonydeluce is offline
post #7579 of 7967 Old 05-18-2020, 06:16 PM
Kai Winters's Avatar
Quoted: 231 Post(s)
Liked: 315
Well I decided to pull the trigger and bought one today at BB
Setup was super easy, though I say that after watching several youtube videos on unboxing, setup, reviews, etc. so I had an edge. Still it was very easy to set up.
I've not had a chance to read the owner's manual yet though I have dl'd it and will likely tonight or tomorrow but I do have a question. If I stop the movie I'm watching and shut down the player then start it up again will it pick up where I left off or give me that option?
I watched the BD version of The Mummy 2 and honestly I saw quite an improvement in video quality compared to my LG UBK90. Better detail and clarity by quite a factor...woohoo !
Can't wait to watch a Dolby Vision movie to really see how it plays, but my wife and I started the trilogy last night and will watch #3 tomorrow night.
I'm glad I decided to buy it !
M2609 likes this.
TV: Sony XBR 65X950G, AVR: Marantz SR5014, Speakers: front/Paradigm Prestige 15B bookshelf, center/Paradigm Prestige 45C, surround/Paradigm Atom, sub/SVS SB3000, DVD: Panasonic DP-UB820P-K Disk Player, Media Player: Zidoo Z9S & Roku Streaming Stick +, Remote: Logitech Harmony Ultimate Home
Kai Winters is online now
post #7580 of 7967 Old 05-18-2020, 06:27 PM
DLCPhoto's Avatar
Liked: 944
Surprisingly, it seems this depends on the Disc, and not the player. You can do some searching in this thread for discussion on this point to provide the specifics, but this seems to be the bottom line.
Kai Winters likes this.
DLCPhoto is offline
post #7581 of 7967 Old 05-19-2020, 07:07 AM
Quoted: 164 Post(s)
Liked: 30
I had a lot of questions with related issues when I first bought the 820. First off, there is no screensaver even though there is a non-related function in the menu that is worded screensaver. While I have since confirmed there is in fact no screensaver feature like an Oppo, some BR media has them somehow. I've noticed a bunch of 20th Century Fox films come with an active screensaver.
With regards to the start-where-left-off, the other member is correct. It depends on the disk and it's prohibitions. Some do, some start from the beggining and force you to go through every warning and preview, and some start from the beginning but you can skip right to the menu. I believe the biggest culprits of this annoyance is BD-J (Bluray Disk Java) which is a large pain-in-the-&@^ than it's worth. I think it allows for special menus but allows them extra control overall. Here's an interesting article I just found:
https://www.businesswire.com/news/ho...on-Remove-BD-J
Unless the player is hacked, it is at the mercy of the disk you put inside of it. Since we cannot talk about this subject, I am not completely sure if options I had considered are legit.
Kai Winters and mrtickleuk like this.
Panasonic DP-UB820, Yamaha RX-V1075, Epson 5040UB. Elunevision Reference 4K 125" screen.
marcosphoto is offline
post #7582 of 7967 Old 05-19-2020, 10:23 AM
cbatc's Avatar
Quoted: 137 Post(s)
Liked: 60
I recently upgraded from the UP970. 1080P bluays have never looked better. I watched Hobbs and Shaw 4k, but preferred HDR10 with enhancer over Dolby Vision. I'm just happy I have the option of choosing now.
perzon57 and Kai Winters like this.
cbatc is offline
post #7583 of 7967 Old 05-19-2020, 02:40 PM
MOberhardt's Avatar
Liked: 1237
I can't tell you how much I despise BDJ. There is nothing you need on a disc you can't do without it.
post #7584 of 7967 Old 05-19-2020, 03:32 PM
mrtickleuk's Avatar
Liked: 9045
Yes. And there's plenty of things you need that you can't do WITH it! Such as take photos of a paused screen with no stupid massive chapter icons (custom designed per disc, so they are desperate that you see them as much as possible) overlaid for one thing.
_______________
post #7585 of 7967 Old 05-19-2020, 04:53 PM
NxNW's Avatar
Quoted: 157 Post(s)
Liked: 149
I noticed the press release, at least as far as I could understand the Engrish, stated that the first 4K disc with BD-J was.. Midway.
NxNW is offline
post #7586 of 7967 Old 05-19-2020, 05:18 PM
MOberhardt's Avatar
Liked: 1237
Hmm - so not Knives Out? That was the other one that was causing issues with Panasonic.
post #7587 of 7967 Old 05-20-2020, 08:27 AM
Quoted: 314 Post(s)
Liked: 255
thanks! I Will try unplugging my ub820 whenever i get a bad glitchy video disc.
am2model3 is offline
post #7588 of 7967 Old 05-21-2020, 08:14 AM
Super Moderator
teachsac's Avatar
Quoted: 1436 Post(s)
Liked: 2513
Posts edited/deleted for price talk.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #7589 of 7967 Old 05-21-2020, 09:01 AM
Lorderl's Avatar
Quoted: 118 Post(s)
Liked: 57
Anyone know when Panasonic schedules releases for newer models as this models thread is nearly 2 years old? TIA
Display: Samsung LN55B650
AVR: Denon 2809ci
Players: OPPO BDP-83 || Streaming: Amazon Fire TV || Kindle Fire HD8
Speakers: Paradigm Studio 20v3 || CC-570v3 || ADP-470v3
Sub: JTR Captivator 2400ULF-10hz
Lorderl is offline
post #7590 of 7967 Old 05-21-2020, 09:43 AM
Super Moderator
teachsac's Avatar
Liked: 2513
They are not releasing a new player this year. There are no new features.
teachsac is offline
Reply Blu-ray Players
4k blu-ray player , blu-ray player , blu-ray settings , panasonic ub820
