Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 92 - AVS Forum | Home Theater Discussions And Reviews
 4821Likes
post #2731 of 5119 Old 01-07-2019, 04:31 PM
enricoclaudio's Avatar
Quoted: 3651 Post(s)
Liked: 4380
Is there any way to disable the Off Timer Function on this player? After about 15 mins it goes on standby with black screen then if I press play it goes back up. Kinda annoying. My Oppo 203 used to play a screen saver instead.
gymnos likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #2732 of 5119 Old 01-08-2019, 05:04 AM
avtoronto's Avatar
Quoted: 137 Post(s)
Liked: 56
Short answer: no. We are hoping this is addressed along with having the player run a screensaver in a future firmware release, but no word on that from Panasonic.
tigerhonaker and gymnos like this.
Elunevision 4K 112" Audioweave motorized screen, Epson Pro Cinema 4040 projector, Emotiva XPA-5 amplifier, Denon AVR X4400h receiver, XTZ M6 LCR, XTZ S2 surround, XTZ 1X12 subwoofer, RSL C34E Atmos speakers, Apple TV 4K, Panasonic DP-UB820
avtoronto is offline
post #2733 of 5119 Old 01-08-2019, 06:35 AM
Quoted: 288 Post(s)
Liked: 84
I have tried two different Dolby Vision discs and they both only will show as HDR10... any ideas I can try? I have DV enabled as well as 12 bit but when displaying playback info it’s only displaying 10 bit. Says I’m on the most current firmware at 1.47. My TV (C8) displays DV on Netflix and has the most current firmware.. My AVR (S720W) has the firmware update containing Dolby Vision as well.
MeganElisabeth is offline
post #2734 of 5119 Old 01-08-2019, 09:34 AM
monkaquinas's Avatar
Quoted: 79 Post(s)
Liked: 40
Originally Posted by exm View Post
Hi, I have an Epson 6040 (5040) and just got the UB820.
Correct me if I'm wrong for the only settings to change in the UB820:
- Set Color Mode to Ycbr 4:2:2
- Leave Deep COlor Output to Auto (12bit Priority)
- Set HDR TV Type to Basic Luminance
Do I need to set to
HDR/Color Output to SDR/BT.2020 (Auto)
Or
HDR/Color Output to HDR/BT.2020 (Auto)
If I set it to SDR I don't get to use the HDR Settings options. Will the HDR optimizer still work?
I also have Resolution to Auto, 4k60p Off, 24p output Auto, DV Off, HDR10+ On
Anything else I need to change, or anything set incorrectly? Thanks!
Use HDR/Color Output to SDR/BT.2020 (Auto). You have the display set to Projector, so the Tone Mapping is enabled. You can't use the HDR Optimizer slider but you can still adjust the Luminescence Bright Curve and Dark Curve using the Options button once a UHD disc is playing. I like that with SDR output you can perform a SDR calibration if needed, which is easier than an HDR calibration.
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.2.2) with Polk PSW110 Sub & Monoprice Premium Select 8" Sub (via iFinity Wireless Audio) - Panasonic UB820 - PS3
monkaquinas is offline
post #2735 of 5119 Old 01-08-2019, 10:08 AM
Quoted: 2324 Post(s)
Liked: 1130
So now that LG, Sony, Samsung 2019 TVs will have HDMI 2.1 - what does this mean for the UB820...
WOLVERNOLE and Bahn Yuki like this.
Shopping List:
TV: Samsung Q90R, or LG C9, or Sony ...
Blu-ray: Panasonic UB820, or Sony X800M, or Pioneer Elite LX500
Soundbar: Samsung Q90R, or Sennheiser Ambeo, or...
AVR and Speakers: Marantz 8012, or... and GE Triton Reference, or...
New24K is offline
post #2736 of 5119 Old 01-08-2019, 10:58 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5931
Nothing.
XBR65A9G / XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #2737 of 5119 Old 01-08-2019, 11:08 AM
Liked: 1130
Originally Posted by gadgtfreek View Post
Nothing.
OK, well, maybe nothing for the UB820...
But Panasonic will probably come out with an HDMI 2.1 "UB850" in short order...?
Shopping List:
New24K is offline
post #2738 of 5119 Old 01-08-2019, 12:12 PM
SLYDoggie's Avatar
Quoted: 250 Post(s)
Liked: 166
Originally Posted by kevyh View Post
What does one do if the projector does not have a BT2020 profile? My Sony VPL-HW40ES has REC709 and 2 generic names profiles (description says TV and Movie).
Does the 40ES have "DCI" as an option? I own the Sony 1100ES and it doesn't have BT2020 but does have DCI (which is a subset of BT2020). The 820 won't recognize DCI as a BT2020 compliant device so, as another forum member states, you will need to get something like the HDFury Integral 2 to "fool" the 820 into thinking you have a BT2020 capable device. You can then use the DCI setting on your projector when receiving BT2020 output... That is what I have done, however, I don't now that I would say that it has been worth the effort. I have calibrated my projector for both REC709 and BT2020 (using my DCI setting) and I still prefer the REC709 option. I think the main reason for this is that the DCI setting on my projector cuts down on the light output for some reason.
If your projector doesn't have DCI, then never mind
Regards, Steve
Projector/Receiver - Sony VPL-VW1100ES 4K PJ & Sony STR-ZA5000ES 4K Atmos AVR
Media Devices - Panasonic DP-UB820 4K BR, Sony UBP-X800 4K BR, ATV 4K, and Roku 4K
Screen - 145" Dragonfly, 1.2 Gain, 16:9, Matte White Fixed Screen
Theater Remote/Cables - Universal MX-990 RF Remote, Monoprice Certified 18Gb HDMI Cables
SLYDoggie is offline
post #2739 of 5119 Old 01-08-2019, 12:57 PM
bobknavs's Avatar
Quoted: 2128 Post(s)
Liked: 1506
Are you anticipating any content that would require HDMI 2.1 on a BD player? (4k 120FPS, 8k.) HDMI 2.1 sounds cool, but I'm not sure when it will become relevant. (Leaving off eARC, which is available on hardware that supports none of the other HDMI 2.1 features.)
Ted99 likes this.
bobknavs is offline
post #2740 of 5119 Old 01-08-2019, 02:44 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5931
Im not sure players and AVR's will get HDMI 2.1 chips this year, and I'd be really hesitant on the displays claiming it first year. They like to pull tricks with specs to be first.
Geronimo.USMC likes this.
XBR65A9G / XBR65A8F
post #2741 of 5119 Old 01-09-2019, 04:52 AM
BreakPoint's Avatar
Quoted: 160 Post(s)
Liked: 134
I have an 820 on order, arriving today. Swapping out my Sony x700. One question I have is can one use the HDMI optimizer settings on Netflix streaming stuff, both SDR and HDR? Or is it disc only?
Sony XBR-65A8F
Denon X1400, ATV 4K, HTPC
Roku Premiere+, Panasonic UB820, Sony x700
BreakPoint is offline
post #2742 of 5119 Old 01-09-2019, 04:55 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5931
HDR Opt works on HDR Amazon and Netflix.
BreakPoint and MOberhardt like this.
XBR65A9G / XBR65A8F
post #2743 of 5119 Old 01-09-2019, 05:30 AM
hemo cave's Avatar
Quoted: 25 Post(s)
Liked: 8
Red face Panasonic UB820 is Amazing
I had this since they came out and was blown away, I was sad i didnt get an Oppo 203 but having the UB820 which i feel is better then the 203 makes me happy especially for using with a Projector. Only downside is the MKV files not working.
Also i saw a video on youtube where someone compared the UB9000 with the UB820 and you could hardly tell a difference.
So happy and this is the Oppo killer.
monkaquinas likes this.
hemo cave is offline
post #2744 of 5119 Old 01-09-2019, 06:06 AM
SL600's Avatar
Quoted: 231 Post(s)
Liked: 125
MKV files work fine here.
LG OLED65C8PUA, F/W: 05.20.00
SL600 is offline
post #2745 of 5119 Old 01-09-2019, 06:13 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5931
Doesnt play with lossless audio.
XBR65A9G / XBR65A8F
post #2746 of 5119 Old 01-09-2019, 08:56 AM
Gardo's Avatar
Quoted: 12 Post(s)
@gadgtfreek is right, and in my experience, the HDR Optimizer makes a noticeable positive difference on streaming PQ. That said, my experience, confirmed by others here, is that the Netflix app introduces some uncorrectable a/v sync errors. For me, they're consistent, and sometimes annoying. The APrime app also has a bug in that UHD content has a small, intermittent stutter that for me is right on the bubble between annoying and tolerable, depending.
I'm hoping that future firmware updates will address these issues, as I do prefer playback through the 820 over the built-in LG C8 app. The C8 app looks fine, but the 820 is appreciably better.
Gardo is offline
post #2747 of 5119 Old 01-09-2019, 09:11 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5931
Yeah, I just use a Roku for Netflix and Amazon, especially since it outputs 24hz as well.
XBR65A9G / XBR65A8F
post #2748 of 5119 Old 01-09-2019, 09:29 AM
rc-zombies's Avatar
Quoted: 164 Post(s)
Liked: 98
Bar Area Peeps...if you're looking to get this awesome machine... a few of BB stores have them in stock.
rc-zombies is offline
post #2749 of 5119 Old 01-09-2019, 10:45 AM
bobknavs's Avatar
Liked: 1506
A good player for barflies?
(Yeah, I know it's a typo. Or a Freudian slip.)
MOberhardt likes this.
bobknavs is offline
post #2750 of 5119 Old 01-09-2019, 11:22 AM
Daryl L's Avatar
Quoted: 654 Post(s)
Liked: 448
I have the A9F and when I got home this Saturday after being away all last week my Panny UB820 Was waiting for me from value electronics. From what I understand the Sony is supposed to have very good (simulated) HDR tone mapping. It has also been stated that the Panasonic has very good HDR tone mapping.
So I’m confused as to whether to leave the Panasonic‘s HDR optimizer enabled or disabled. Any ideas or suggestions. Any information appreciated.
Sony XBR-55A9F OLED
Samsung SMT-H3272 HDC DVR Cable Box / Panasonic DP-UB820 4K BD Player
Roku Premium+ 4k / AppleTV 4K 4th Gen
Denon AVR-X4500H AV Receiver / Klipsch 5.1.2 Speakers
Daryl L is offline
post #2751 of 5119 Old 01-09-2019, 11:33 AM
Quoted: 79 Post(s)
Liked: 40
Stranger Things UHD Discs
I received for Christmas the Target VHS style UHD box set of Stranger Things. I had watched on NF in 1080p on my projector when it came out. I threw this in on Sunday and was impressed by the brightness that was missing when I streamed this. I did a check and was a little baffled that it was indeed 4k but Rec 709. I checked all my settings and even threw in my John Wick 4k disc and everything was fine. Has anyone seen a 4k disc encoded with Rec 709 before? I didn't notice any real issues with the image and my settings for 4k, I did try my 4k1080 settings and the image was too dark.
Just wondering why NF would encode 4K at rec 709.
post #2752 of 5119 Old 01-09-2019, 12:22 PM
jbrinegar's Avatar
Quoted: 341 Post(s)
Liked: 253
Stranger things is one of the few non HDR 4k discs
JVC RS2000
Anthem mrx1120//Lumagen Radiance Pro
Klipsch Ref series 7.2.4 setup
Panasonic UB820 //Xbox one X //PS4 Pro // Apple 4k TV
Stewart Filmscreen 135" Cima Neve
jbrinegar is offline
post #2753 of 5119 Old 01-09-2019, 02:23 PM
bobknavs's Avatar
Liked: 1506
Hotel Artemis is the one 4k non-HDR disk that I own. I was surprised by it. (Also something of a ripoff. To me, the HDR aspect is more significant than 4k.)
jbrinegar likes this.
bobknavs is offline
post #2754 of 5119 Old 01-09-2019, 03:21 PM
healthnut's Avatar
Quoted: 922 Post(s)
Liked: 908
At this point, 2.1 is more about marketing than anything else. It’ll be years before there’s content that can take advantage of it. We’re still dealing with half-baked 4k HDR implementation. The early implementations of 2.1 will also likely be compromised until the chipsets are ready, to say nothing of the new HDMI cables that’ll be required (as far as I know, they don’t even exist yet). 12 bit color (which should be arriving before long) will be a much more meaningful advance in PQ
healthnut is offline
post #2755 of 5119 Old 01-09-2019, 03:30 PM
vollans's Avatar
Quoted: 209 Post(s)
Liked: 150
More often than not it's been the fact that the UHD has an Atmos or DTS:X soundtrack that has swung the purchase for me over the blu ray.
Bytehoven likes this.
New Home Cinema: Sony VPL-VW760, Anthem MRX 1120, Q Acoustics 30x0 series speakers fronts, SVS Prime Elevation surround speakers, Proficient C791 Atmos, SVS PB2000 sub, Panasonic DMP-UB820, Apple TV, Pioneer CLD-D5V laserdisc, FetchTV, eeColor 3D LUT & Radiance XD-3D and ScreenTechnics CinemaSnap Hi Contrast 130" screen
vollans is offline
post #2756 of 5119 Old 01-09-2019, 10:40 PM
MOberhardt's Avatar
Quoted: 703 Post(s)
Liked: 299
When you say non HDR, do you mean it is BT2020 but no HDR metadata? Or it is 4k rec709?
MOberhardt is offline
post #2757 of 5119 Old 01-09-2019, 11:01 PM
ac388's Avatar
Quoted: 188 Post(s)
Liked: 49
UB820 on Epson 5040
Hi Claw,
Wonder if you can point me to the article that Mr. Chris Deering mentioned about the settings between these 2 units. Many thanks !!!!!!!
Originally Posted by claw View Post
- If you read this thread from the beginning you would know that the UB820 does not support any HD audio when playing video media from USB or disk storage.
- SDR/BT2020 mode does not drop bit depth to 8-bit. It retains the BT.2020 wide color gamut that is contained in the original content and will output either 10-bit or 12-bit. SDR/REC709 mode may output 8-bit. You may still get REC709 if your projector does not support BT.2020 and you select SDR/BT2020 output mode.
- SDR/BT2020 mode is recommended for projectors. Because of their limited brightness capabilities they use very aggressive tone mapping to map the bright highlights that exceed the projector capabilities to display. In UB820 HDR output mode, the HDR Optimizer performs aggressive tone mapping to map the bright highlights above 500 nits (HDR TV Type Projector). Chris Deering posted that applying two aggressive tone maps; HDR Optimizer tone mapping plus Projector tone mapping is not good practice. He recommends SDR/BT2020 mode for all projectors, not just JVC, letting the HDR Optimizer perform all of the tone mapping.
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #2758 of 5119 Old 01-10-2019, 04:06 AM
kevyh's Avatar
Quoted: 41 Post(s)
Originally Posted by CBdicX View Post
Nobody please
No.
Google Netflix Atmos support and you will see what devices do.
Windows 10
Xbox (later version)
Apple TV 4K
And a couple TV's.
kevyh is offline
post #2759 of 5119 Old 01-10-2019, 04:19 AM
kevyh's Avatar
Quoted: 41 Post(s)
Originally Posted by liverpool_for_life View Post
I've been recommended this player in light of an impending 4k projector upgrade. Our daily watching is mostly streaming Netflix/Prime from an Apple TV(4th gen).
Is the streaming quality of Netflix/Prime out of the 820 comparable to that of the standalone streaming boxes? Thanks!
I'm using the 820 on a 1080p projector. I have noticed that Netflix displays a bit of a quirk with movement - on a BBC Planet Earth show for example...an animal walking across the screen does not move smoothly. Very slight stutter but noticeable. I haven't found the right combination of settings to fix that yet.
The Prime Video app works well but for me it has an overall darker picture compared to PS4 and Apple TV4K. I like the sound from the 820 better than the ATV though.
kevyh is offline
post #2760 of 5119 Old 01-10-2019, 04:31 AM
WOKNROX's Avatar
Quoted: 308 Post(s)
Liked: 211
Originally Posted by ac388 View Post
Hi Claw,
Here you go...
https://www.google.com/url?sa=t&sour...=1547123331104
WOKNROX is offline
Reply Blu-ray Players
