Official Panasonic DP-UB820/824 Owner's Thread (No Price Talk) - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 5027Likes
post #2851 of 5941 Old 01-18-2019, 06:11 PM
Clark Burk's Avatar
Quoted: 711 Post(s)
Liked: 661
Originally Posted by StevenC56 View Post
So-Is the second projector setting locked out on the 820 then?
Yes, only one projector setting on the 820 which is the 500nit setting I think. The 9000 adds another lower nit setting around 300 or so.
There are options but 3rd party firmware discussions are not allowed on AVS forum so end of discussion.
Clark Burk is offline
post #2852 of 5941 Old 01-18-2019, 06:38 PM
Bytehoven's Avatar
Quoted: 1370 Post(s)
Liked: 1085
Originally Posted by Tom Riddle View Post
I played around a little more with my setting and did find that the Optimizer On provided the best picture. I was using Fantastic Beasts when I first played with it, which has a 4000 nit level, so when I turned it on, there was an immediate difference. Near the end there is a wand fight and with it off, it's just a blur of color, but with it on, you could see the individual colors and the actual wand rays. I left the dynamic slider at 0 and used @Bytehoven 's HDR gamma settings. I'm sure I'm in the minority on this thread, but I left it at HDR2020 - I just couldn't find settings I liked at SDR2020. I also have mine running at High Lamp.
I'm sure a calibration is in order. I need some more hours though, as I haven't hit 100 yet.
Tom, which hdr st2084 setting did you use?
Bytehoven is offline
post #2853 of 5941 Old 01-18-2019, 07:33 PM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 690
Picture Tone: 9
Darkness: 3
Brightness: -7
Bytehoven likes this.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #2854 of 5941 Old 01-18-2019, 08:07 PM
Tom Riddle's Avatar
Quoted: 781 Post(s)
Liked: 690
Watched American Made tonight with the new settings and it looked great! Not the HDR showcase you would demo to your friends, but it was a fun watch and some great audio. I’m glad I found some settings that are appeasing to my eye.
post #2855 of 5941 Old 01-19-2019, 08:02 AM
TorinoCobra's Avatar
Originally Posted by jb442386 View Post
Just picked up my 820 today & simply have a quick question. Does this player have the CEC function. Much Thanks in advance!
Apparently. I get mine Tuesday and can confirm then.
see post 56798954
TorinoCobra is offline
post #2856 of 5941 Old 01-19-2019, 09:13 AM
enricoclaudio's Avatar
Quoted: 3823 Post(s)
Liked: 4697
You are NOT the minority. I do have mine set at HDR/BT2020 as it looks much better (to my eyes) than SDR/BT2020. I was watching last night "The House with a Clock in its walls" and switched between SDR/BT2020 and HDR/BT2020 several times during the movie and all I can say is that HDR/BT2020 looked 10 times better than SDR/BT2020. At least in my 92" Stewart ST100 with a Sony 295ES. That movie is a HDR torture test from beginning to end.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #2857 of 5941 Old 01-19-2019, 12:00 PM
kwk2293's Avatar
Quoted: 88 Post(s)
Liked: 38
Any one using this player with simple control it find the player but commands don't work does it have to be controlled with ir
kwk2293 is offline
post #2858 of 5941 Old 01-19-2019, 12:30 PM
kevyh's Avatar
Quoted: 41 Post(s)
Originally Posted by stummala View Post
Yep happened to me last night with Netflix. Stops at 24% even though I have an ethernet cable directly attached to the player. It's the player software. Anyhow, just exit Netflix by hitting the Netflix home button (or back button to exit the movie you are trying to stream), and immediately select it again. The stream will zip right on through to 100%. Happens after I play a BD disc as well.
I'm sure they'll fix it with a patch in the future.
I don't think that's an 820 specific issue. The Netflix app on my Vizio TV hangs at 24% sometimes. I exit Netflix, restart it and it's good to go.
kevyh is offline
post #2859 of 5941 Old 01-19-2019, 03:25 PM
Quoted: 707 Post(s)
Liked: 1626
Get 600Mbps, and see if that'll help.
Panson is offline
post #2860 of 5941 Old 01-19-2019, 09:39 PM
Darrin's Avatar
Quoted: 14 Post(s)
Strange problem with the Youtube app. For some reason, any movies in my library that show up as "purchased" only display in standard definition! When I play the same movies through my Nvidia Shield, they are in fact 4K.
Is this an app issue on this player? If not, any ideas?
Unrelated: Do we think at some point they may add Vudu and/or Movies Anywhere apps?
Darrin is offline
post #2861 of 5941 Old 01-21-2019, 08:18 AM
monkaquinas's Avatar
Quoted: 84 Post(s)
Liked: 40
It does but due to some Panasonic settings, the player will power off after 15 mins causing it to power off your equipment.
gymnos likes this.
Epson5040UB - DragonFly DFM Tab 92HC High Contrast (.9 gain) 16:9 Screen - Denon AVRS740H - Klipsch Quintet V +
Klipsch KHC-6 In-Ceiling (Atmos 5.2.2) with Polk PSW110 Sub & Monoprice Premium Select 8" Sub (via iFinity Wireless Audio) - Panasonic UB820 - PS3
monkaquinas is offline
post #2862 of 5941 Old 01-21-2019, 02:27 PM
bwillcox's Avatar
Quoted: 929 Post(s)
Liked: 537
I don't use CEC, but is there some setting to turn off the automatic player turning itself off? I'm fine with turning it off myself when I'm done with it.
1) JVC DLA-NX7 & Sony 65Z9D, Yamaha CX-A5200, Outlaw Audio 7900 & 7700, UDP-203, DP-UB9000, UBP-X800M2, Roku Ultra
2) Sony 75Z9D, Yamaha RX-A3080, 2xOutlaw Audio 2200s, UDP-203, UBP-X800M2, Roku Ultra
3) Sony 75X940E, Yamaha RX-A2080, UDP-203, UBP-X800M2, Roku Ultra
bwillcox is offline
post #2863 of 5941 Old 01-21-2019, 06:24 PM
jb442386's Avatar
Quoted: 383 Post(s)
Liked: 295
PQ via Netflix on my 820 is comparable to the AP4KTV & Dolby Vision & Atmos. Really very pleased! Take Care All!
Sony55A1E|Oppo 203|Sony Z9F Soundbar|ATV4K
jb442386 is offline
post #2864 of 5941 Old 01-21-2019, 07:11 PM
Kage's Avatar
Quoted: 112 Post(s)
Did Panasonic fixed the issues with the loud fan and loud disc drive spinning noise on their latest batches on the ub820?
Kage is offline
post #2865 of 5941 Old 01-21-2019, 07:23 PM
Quoted: 43 Post(s)
Liked: 33
My 820 with Oct.2018 build date already had latest firmware and is perfectly quiet.
Tom Riddle likes this.
Werner Roth is offline
post #2866 of 5941 Old 01-22-2019, 08:20 AM
tigerhonaker's Avatar
Quoted: 631 Post(s)
Liked: 628
Post
I have not noticed any LOUD spinning or internal noises from my UB820.
I am loving it and was at one time considering going with the UB9000.
My opinion is it would just be for bragging rights with no real-world noticeable difference to actual picture quality between the two.
Let's be honest once you place either in your rack that's the last time you'll know how heavy either unit was.
As far as actual differences in Video I doubt any of us would ever be able to see any real differences.
(Audio is the added benefit of the UB9000)
I only use the Panasonic for watching Hard-Disc not for streaming.
Me picking my UB820 up from the G/M at Best Buy here locally.
And here it is being installed ...........
Terry
tigerhonaker is offline
post #2867 of 5941 Old 01-22-2019, 09:47 AM
Erod's Avatar
Quoted: 1274 Post(s)
Liked: 788
Terry
I absolutely expect this to be true. This other projector setting on the 9000 seems pointless for 95% of us.
My 820 looks fantastic. Until dynamic tone mapping arrives, it won't move.
tigerhonaker likes this.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is offline
post #2868 of 5941 Old 01-22-2019, 09:58 AM
laguna_b's Avatar
Quoted: 119 Post(s)
Liked: 54
I have a JVC 640 projector and OPPO 203. I just bought a Panny 820 to deal with Tone Mapping of material primarily from Netflix and Amazon.
I have the projector HUE set neutral which works fine for the OPPO which is also neutral. The Panny gives me a red shift that even when set to -10 is a bit red.
My plan is to have both units with the OPPO running material from the Apple 4K streaming and the Panny only for Netflix and Amazon.
First question: Anyone else experience the red shift especially on Amazon (not tried other sources)
Second Question: Why does the HDR button not work telling me that it only works with HDR content? If it is converting to SDR that might be why but I think at one point it might have worked.
Is there any general guide to setting up the 820. I didn't want to read through 93 pages
KevinH and sparky7 like this.
Past: CRTs NEC/Runco, Barco 1208, 1209 Current: JVC RS-640, Stewart Cima Neve 123" Screen 92" Da-Lite
laguna_b is offline
post #2869 of 5941 Old 01-22-2019, 10:06 AM
KevinH's Avatar
Quoted: 255 Post(s)
Liked: 103
Ditto. I have a JVC X550R(RS400) and I have the 820 set for SDR.2020. I don't know about any of the other HDMI settings and have left everything else at default for the time being until I know if I should change anything.
JVC X550R /Panny UB820/GIK treatments
Elunevision 140" 2.35
Marantz AV8802a/Wyred4Sound 7-channel amp
Outlaw 5000/ 4 JBL 328Cs for Atmos/ 7.2.4 Atmos
JTR 3TX LCRs/Single8 HT-LP surrounds(4)/Dual Pierce/Speakerpower 21" subs
KevinH is offline
post #2870 of 5941 Old 01-22-2019, 10:22 AM
Clark Burk's Avatar
Quoted: 711 Post(s)
Liked: 661
Try playing a UHD Blu-ray. Your HDR options should appear. You should now have the HDR Optimizer and the other options.
post #2871 of 5941 Old 01-22-2019, 10:28 AM
bdmckinl's Avatar
Quoted: 74 Post(s)
Liked: 25
Using a Panny 820 connected to a Sony 295 via a Denon X6500H. SDR.2020
Amazon delivered First Man 4K today which I'm eager to watch tonight with some buddies. I noticed that this disc has Dolby Vision, but I know my projector doesn't support it. Quick question then: does it matter whether or not I have Dolby Vision selected on the 820? I guess what I'm asking is if it's better for a Dolby Vision disc to be processed as such by the Panny and then displayed within the capabilities of the projector, or is it better to just send a non-Dolby Vision signal from the 820 to begin with, or does it not matter?
Thank you!
4K/3D Projector: Sony VPL-VW295es | Screen: 120" 16x9 framed 'Screen Goo’ (Digital Grey) | 4K Player: Panasonic DP-UB820-K | Streaming: Apple TV 4K (64 GB) | Gaming: PS4 (500 GB), PS3 Slim (320 GB) | Receiver: Denon AVR-X6500H | Speakers (5.1.4): Axiom VP150 (centre), Axiom M60 x2 (towers), Axiom EP350 (LFE), Axiom QS8 quadpolar x2 (surrounds), Axiom M3 In-Ceiling x4 (atmos) | Remote: Harmony Elite
bdmckinl is offline
post #2872 of 5941 Old 01-22-2019, 10:30 AM
laguna_b's Avatar
Quoted: 119 Post(s)
Liked: 54
I should point out that I have the following settings set:
HDMI - resolution set to auto, 4K/60 444
HDR color gamut output HDR bt2020 auto
HDR tv type set low for projector
laguna_b is offline
post #2873 of 5941 Old 01-22-2019, 10:32 AM
laguna_b's Avatar
Quoted: 119 Post(s)
Liked: 54
I will try this tonight but implicit in your comment is that I won't be able to use Tone Mapping for streaming which is actually the main reason for getting the panny. Is that the case?
laguna_b is offline
post #2874 of 5941 Old 01-22-2019, 10:46 AM
Erod's Avatar
Liked: 788
Is there any general guide to setting up the 820. I didn't want to read through 93 pages [IMG class=inlineimg]/forum/images/smilies/frown.gif[/IMG]
Set the 820 to SDR bt2020, and change your projector to the same. (It's the same thing without the metadata.)
Erod is offline
post #2875 of 5941 Old 01-22-2019, 10:53 AM
Quoted: 99 Post(s)
OK, youse guz. I was all set to getting the 9000 until I started reading this forum. I knew I would be getting one of the Panasonic players, just not which one. My wife's a little ticked because this is the 4th 4k player I will be buying. I have a Samsung K8500 in the den, a Samsung M8500 and Sony X700 in the theater and I just wasn't happy with what I was seeing. I saw that one member was asking for some help because he didn't want to read the manual and I quite understand. I would like some input, if this is the correct forum, as to the 820 fitting in my theater. I have a Optoma UHD60 projector, a Yamaha Aventage RX-
A8070 AVR and the RX-A3010 for my external amplifier, and a 7.2.4 setting currently. The sound is fantastic, but I want another player. Can anyone tell me why I should get the 820 instead of the 9000 or the Sony 1000ES?
jdhelaman is offline
post #2876 of 5941 Old 01-22-2019, 10:56 AM
Clark Burk's Avatar
Quoted: 711 Post(s)
Liked: 661
Not positive as I don’t use the 820 for streaming but if you set it up for SDR2020 I believe Netflix will not send a 4k stream. If you set up for HDR2020 you should be good to go but then you will be sending the HDR flag to your projector.
post #2877 of 5941 Old 01-22-2019, 11:09 AM
I just hooked my 820 into my system (LG C7, Onkyo TX-RZ810 w/ATMOS speakers enabled), and already have an issue with NetFlix.
When I select a know Dolby Vision and ATMOS movie ("Bright") in the NetFlix app on my LG TV, it displays as both DV and ATMOS as long as the receiver is powered off or HDMI cable disconnected. If I start the movie, and then power on the receiver, The Onkyo will process and play ATMOS audio. Even if I select a different movie ("Roma") without disconnecting/shutting off the receiver, the new movie will also play Dolby ATMOS. I've come to accept this quirk of the LG/Onkyo handshake issue, as long as I get ATMOS audio.
((EDIT: Firmware update on ONKYO receiver seems to have corrected the NetFlix app. It now displays both Dolby Vision and ATMOS in the menu selection, and receiver switches to ATMOS correctly. The firmware was already updated to the latest version according to the software checker on the other two devices.))
However, I CANNOT get ATMOS to work from the 820 NetFlix app, with any combination of connections. Dolby Vision is fine.
I have tried connecting the HDMI VIDEO OUT to the LG HDMI 1, and HDMI AUDIO out to the ONKYO. I have tried disconnecting the HDMI AUDIO, and using only the LG Audio pass-through. I've tried connecting the VIDEO out directly to the receiver, and then passing the video to the LG TV.
I've changed various HDMI and AUDIO setting in the 820, and nothing seems to work. I currently have Bitstream selected for both Dolby Audio and DTS/DTS-hd, with BD-Video Secondary Audio turned OFF.
It this another shortcoming of the NetFlix app on the 820? Or, is this some combination of settings in the 820?
Anybody have an Onkyo RZ-series receiver connected to an 820 that does pass ATMOS from NetFlix? (I have no ATMOS disks yet to test with.)
It's not a deal breaker. I can continue to use the LG app. I was just hoping everything would work out of the box.
As an aside I have this question - Why is "ROMA" streaming in Dolby Vision? 12-bit black and white?
Gregg
post #2878 of 5941 Old 01-22-2019, 11:17 AM
laguna_b's Avatar
Quoted: 119 Post(s)
Liked: 54
I guess I can try it both ways but the PJ has an HDR setting which is expecting HDR flag. I guess part of my confusion here is that if this is the case then what is the function of Tone Mapping? Am I mapping into SDR but using HDR setting on the PJ to properly display it or going back to just an SDR which would defeat the whole purpose of HDR in either the content or the PJ?
laguna_b is offline
post #2879 of 5941 Old 01-22-2019, 01:03 PM
jbrinegar's Avatar
Quoted: 355 Post(s)
Liked: 275
You can try it both ways and see which you prefer. IMO SDR2020 with optimizer on looks better to my eye. In this mode the panasonic will do all the tone mapping according to the metadata on the disc, which makes it more set and forget (IMO). You just have to make sure your pj is configured properly (gamma 2.4/d65/bt2020)
JVC RS2000
Anthem mrx1120//Lumagen Radiance Pro
Klipsch Ref series 7.2.4 setup
Oppo 203 //Xbox one X // Apple 4k TV
Stewart Filmscreen 135" Cima Neve
jbrinegar is offline
post #2880 of 5941 Old 01-22-2019, 01:09 PM
KevinH's Avatar
Quoted: 255 Post(s)
Liked: 103
How do you ensure the optimizer is on? I have the Panny set to SDR.2020 and the JVC is set up right.....but I haven't seen the optimizer or anything in the Panny HDMI settings by that name?
KevinH is offline
Reply Blu-ray Players
