Ns-wbrdvd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-16-2018, 03:51 PM - Thread Starter
Liked: 0
Ns-wbrdvd
Decided to put this back into service... First goal would be to find an original remote made for this machine. If not... does there exist a remote that will do everything the original does. Is there an actual photograph of the remote?
- Insignia has every related manual except this model... Have gone to a number of sites but cannot find the NS-WBRDVD. Hoping for a link... That Works
- Will need an HDMI cable to connect the WBRDVD to a Proscan 26LB 30QD. Is there a recommended spec/length for the cable?
JeromeBernardJames is offline
post #2 of 2 Old 10-24-2018, 12:34 PM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
There's a drawing of the remote on page 3 in the players owner's manual. According to that drawing, the remote's model number is BD003. I don't know if that's correct.
The Blu-ray player's manual is available at https://www.insigniaproducts.com/pdp...386103#support
That's from the "downloads" page on Insignia's Web page for the disc player.
In general, a HDMI cable length of about 6 ft is considered optimal. Make sure you use a High Speed cable, not a Standard Speed cable. A "Certified Premium" cable should work fine too, and shouldn't cost any more than High Speed cables do.
Selden
Selden Ball is offline
Reply Blu-ray Players
